slackpkg, lilo+elilo+initrd
Messaggioda ZeroUno » dom apr 29, 2018 17:32
Sto pensando di aggiungere a slackpkg+ un plugin per far gestire - dopo l'upgrade del kernel - non solo lilo ma anche un initrd (purchè prefatto) ed elilo.
Una bozza dello script è quì: https://www.linuxquestions.org/question ... 175628620/
copia in /usr/libexec/slackpkg/functions.d/zlookkernel.sh
e dai chmod +x /usr/libexec/slackpkg/functions.d/zlookkernel.sh
riporta bug e suggerimenti.
lookkernel() {
  NEWKERNELMD5=$(md5sum /boot/vmlinuz 2>/dev/null)
  if [ "$KERNELMD5" != "$NEWKERNELMD5" ]; then
    KERNEL=$(ls -l /boot/vmlinuz|rev|cut -f1 -d-|rev)
    echo -e "\nYour kernel image was updated (found $KERNEL). You have to rebuild the bootloader.\nDo you want slackpkg to do it? (Y/n)"
    answer
    if [ "$ANSWER" != "n" ] && [ "$ANSWER" != "N" ]; then
      INITRD=/boot/initrd.gz
      if [ -e /boot/initrd-tree/command_line ];then
        INITRD=$(cat /boot/initrd-tree/command_line|sed -r -e 's/^.* -o //' -e 's/ .*$//')
        if [ -z "$INITRD" ];then
        fi
        if [ -e "$INITRD" ];then
          echo -en "Found $INITRD; do you want to rebuild it with:\n  "
          cat /boot/initrd-tree/command_line|sed -r "s/-k [0-9\.]+ /-k $KERNEL /"
          echo "Do you want continue? (Y/n)"
          answer
            cat /boot/initrd-tree/command_line|sed -r "s/-k [0-9\.]+ /-k $KERNEL /"|sh
          fi
        fi
      fi
      if [ -x /sbin/lilo ]&&[ -e /etc/lilo.conf ]; then
        echo -e "\nFound lilo. Do you want to run now: /sbin/lilo ? (Y/n)"
        answer
          if ! /sbin/lilo -t ;then
            echo "You need to fix your lilo configuration. Then press return to continue."
            read
          fi
          /sbin/lilo -v
        fi
      elif [ -e /boot/efi/EFI/Slackware/elilo.conf ];then
        echo -e "\nFound elilo. Copying files to EFI partition"
        COPYDONE=""
        for tocopy in vmlinuz vmlinuz-generic vmlinuz-huge `basename $INITRD`;do
          if [ -e /boot/$tocopy ]&&[ -e /boot/efi/EFI/Slackware/$tocopy ]&&grep -E -q "= *$tocopy *$" /boot/efi/EFI/Slackware/elilo.conf ;then
            echo "Do you want to copy $tocopy to EFI partition? (Y/n)"
            answer
              cp /boot/$tocopy /boot/efi/EFI/Slackware/$tocopy && COPYDONE="$COPYDONE $tocopy"
              touch -r /boot/$tocopy /boot/efi/EFI/Slackware/$tocopy
            fi
          fi
        done
        if [ -z "$COPYDONE" ];then
          echo -e "\nWARNING! no files to copy found. You have to fix bootloader yourself\n"
        fi
      elif [ -e /boot/grub ]&&[ -x /usr/sbin/grub-install ];then
        echo -e "\nWARNING! Grub found but not supported by slackpkg. You have to fix it yourself\n"
      else
        echo -e "\nWARNING! slackpkg can't found your bootloader configuration. You have to fix it yourself\n"
      fi
    fi
  fi
E' una bozza ovviamente, e c'è tanto da fare, ma non vuole essere un script che costruisce un initrd o modifica file di configurazione come fanno ubuntu e centos, ma solo il lancio del comando mkinitrd e - se in uso - la copia dei nuovi file nella partizione EFI.
