errori con ruby e current [RISOLTO]
Messaggioda conraid » ven set 28, 2018 14:52
Non riesco più a creare pacchetti con ruby
Stavo provando nokogiri, e mi da errori
ERROR:  While executing gem ... (TypeError)
    no implicit conversion of nil into String
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/package/file_source.rb:21:in `exist?'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/package/file_source.rb:21:in `present?'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/package.rb:136:in `new'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/installer.rb:102:in `at'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/commands/install_command.rb:278:in `install_gem_without_dependencies'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/commands/install_command.rb:235:in `install_gem'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/commands/install_command.rb:299:in `block in install_gems'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/commands/install_command.rb:295:in `each'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/commands/install_command.rb:295:in `install_gems'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/commands/install_command.rb:202:in `execute'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/command.rb:307:in `invoke_with_build_args'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/command_manager.rb:168:in `process_args'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/command_manager.rb:138:in `run'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/gem_runner.rb:54:in `run'
        /usr/bin/gem:21:in `<main>'
bundler dal mio repository
bundler# sh bundler.SlackBuild
ERROR:  While executing gem ... (ArgumentError)
    wrong number of arguments (given 1, expected 0)
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/core_ext/kernel_require.rb:46:in `require'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/installer.rb:161:in `initialize'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/installer.rb:103:in `new'
        /usr/lib64/ruby/site_ruby/2.5.0/rubygems/installer.rb:103:in `at'
ruby-gist da SBo
# sh ruby-gist.SlackBuild
è cambiato qualcosa? :/
me lo da sia nella mia installazione sia in chroot
Kernel: 5.4.2
Re: errori con ruby e current
Messaggioda ponce » ven set 28, 2018 18:47
ho provato solo ruby-gist e sembra funzionare...
visto che fondamentalmente nello SlackBuild viene eseguito il comando gem puo' darsi che sia quello che non funziona nella tua installazione.
Messaggioda conraid » ven set 28, 2018 20:43
ponce ha scritto:ho provato solo ruby-gist e sembra funzionare...
Ultimamente me ne capitano troppe di situazioni così :-k
Anche in chroot poi, domani provo all'installazione in qemu.
Messaggioda conraid » dom set 30, 2018 11:26
Ho risolto cancellando ogni contenuto in /usr/lib64/ruby (c'erano ancora file di 2.3.4) che rimaneva anche dopo aver disinstallato il pacchetto ruby e pacchetti che usano gem (avevo solo bundler). Reinstallando tutto ora ok. Mi sono accorto di possibili problemi perché gem -v in chroot dava 2.5.4 nell'installazione normale 2.7.7 (di default con il pacchetto è 2.7.6, diventa 2.7.7 dopo un gem system update)
Però a parte bundler, secondo me è inutile stare a creare pacchetti, infatti le dipendenze sono troppe per ogni pacchetto e, a differenza per esempio di npm, non le installa dentro la directory del gem, ma in quella di sistema. Quindi imho o si creano diversi pacchetti per ogni dipendenza (strada scelta da SBo che infatti usa "ignore-dipendencies" tra le opzioni di gem) o meglio usare gem da linea di comando e amen.
Ma intanto ho creato il pacchetto wpscan, per altri vedrò.
