errore nf_conntrack nei log
Messaggioda conraid » ven nov 02, 2018 11:16
Ho un firewall come segue (sono anni che uso lo stesso, sicuramente ci sarebbe da cambiarlo anche perché ho regole per programmi che non uso più (amsn, gnomemeeting, etc...))
#!/bin/bash
modprobe nf_conntrack nf_conntrack_helper=0
modprobe nf_conntrack_ftp
modprobe nf_conntrack_irc
IPTABLES=$(which iptables)
EXT=wlan0
INT=eth0
LAN_IP="192.168.0.50"
LAN_IP_RANGE="192.168.0.0/24"
LAN_IFACE="eth0"
LO_IFACE="lo"
LO_IP="127.0.0.1"
fw_start() {
    $IPTABLES -F
    $IPTABLES -t mangle -F
    $IPTABLES -t nat -F
    $IPTABLES -X
    $IPTABLES -P INPUT DROP
    $IPTABLES -P FORWARD DROP
    $IPTABLES -P OUTPUT ACCEPT
    $IPTABLES -A INPUT -m conntrack --ctstate INVALID -j DROP
    $IPTABLES -A INPUT -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
    $IPTABLES -A INPUT -p tcp --tcp-flags SYN,ACK SYN,ACK -m conntrack --ctstate NEW -j REJECT --reject-with tcp-reset
    #$IPTABLES -A INPUT -p tcp ! --syn -m conntrack --ctstate NEW -j LOG --log-prefix "New not syn:"
    $IPTABLES -A INPUT -p tcp ! --syn -m conntrack --ctstate NEW -j DROP
    $IPTABLES -A INPUT -p ALL -i $LO_IFACE -s $LO_IP -d $LO_IP -j ACCEPT
    $IPTABLES -A INPUT -p ALL -i $LAN_IFACE -s $LAN_IP_RANGE -d $LAN_IP_RANGE -j ACCEPT
    $IPTABLES -A INPUT -p ALL -i $LO_IFACE -s $LAN_IP -d $LAN_IP_RANGE -j ACCEPT
    $IPTABLES -A INPUT -p icmp --icmp-type 8 -m length --length 128:65535 -j DROP
    $IPTABLES -A INPUT -m limit -p tcp ! -s $LAN_IP_RANGE --dport 0:1024 -j LOG --log-prefix "Bad packet not from LAN"
    $IPTABLES -A INPUT -p tcp --dport 222 -j ACCEPT
    $IPTABLES -A INPUT -p tcp --sport 53 -j ACCEPT
    $IPTABLES -A INPUT -p udp --sport 53 -j ACCEPT
    $IPTABLES -A INPUT -p tcp --dport 6891 -j ACCEPT
    $IPTABLES -A INPUT -p tcp --dport 6892 -j ACCEPT
    $IPTABLES -A INPUT -p tcp --dport 1863 -j ACCEPT
    $IPTABLES -A INPUT -p tcp --dport 1720 -j ACCEPT
    $IPTABLES -A INPUT -p tcp --dport 1503 -j ACCEPT
    $IPTABLES -A INPUT -p udp --dport 1720 -j ACCEPT
    $IPTABLES -A INPUT -p udp --dport 1503 -j ACCEPT
    #$IPTABLES -A INPUT -p tcp --dport 30000:30010 -j ACCEPT
    #$IPTABLES -A INPUT -p udp --dport 5000:5016 -j ACCEPT
    #$IPTABLES -A INPUT -p udp --dport 5020:5023 -j ACCEPT
    $IPTABLES -A INPUT -p tcp --dport 4662 -j ACCEPT
    $IPTABLES -A INPUT -p udp --dport 4672 -j ACCEPT
    $IPTABLES -A INPUT -p udp --dport 4673 -j ACCEPT
    $IPTABLES -A INPUT -p tcp --dport 4661 -j ACCEPT
    $IPTABLES -A INPUT -p udp --dport 4665 -j ACCEPT
    $IPTABLES -A INPUT -p tcp --dport 6881:6889 -j ACCEPT
    $IPTABLES -A INPUT -p tcp --dport 32836 -j ACCEPT
fw_stop() {
    $IPTABLES -F
    $IPTABLES -X
    $IPTABLES -P INPUT ACCEPT
    $IPTABLES -P FORWARD ACCEPT
fw_drop() {
    $IPTABLES -F
    $IPTABLES -X
    $IPTABLES -P OUTPUT DROP
case "$1" in
    start)
        fw_start
    stop)
        fw_stop
    restart)
        fw_stop
        sleep 1
        fw_start
    status)
        $IPTABLES -L -n -v
    drop)
        fw_drop
        echo " Firewall personale, usare con le opzioni:"
        echo " start   - Attiva il Firewall"
        echo " stop    - Disattiva il Firewall"
        echo " restart - Riavvia il Firewall"
        echo " drop    - Blocca ogni connessione"
        echo " status  - Mostra lo stato del Firewall"
        exit 1
esac
exit 0
ultimamente (sospetto dal 4.19) mi compare questo messaggio nei log
nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
Ora se non ricordo male questo messaggio compariva quando si usava il vecchio "-m state --state" al posto del "nuovo" --ctstate.
Ma ora cosa può essere adesso?
p.s.
se avete suggerimenti per migliorarlo ben vengano
Kernel: 4.20
Desktop: Xfce 4.12
Distribuzione: archlinux
Re: errore nf_conntrack nei log
Messaggioda rik70 » sab nov 03, 2018 11:55
In pratica stai caricando gli 'helper' per il tracking delle connessioni ftp e irc - ma ti servono? -
però l'assegnazione automatica dell'helper negli ultimi kernel di default è disabilitata - e tu lo specifichi col parametro
Devi perciò assegnarlo tu manualmente nella tabella row, tipo:
iptables -v -A OUTPUT -t raw -p tcp -j CT --helper irc
iptables -v -A OUTPUT -t raw -p tcp -j CT --helper ftp
Tieni presente che molto probabilmente è meglio specificare anche la --dport tcp - per FTP è 21, per IRC(??) - e a seconda dei casi forse devi aggiungere le medesime regole anche nella catena PREROUTING.
Alternative:
- riabilitare l'assegnazione automatica dell'helper fino a quando sarà possibile
modprobe nf_conntrack nf_conntrack_helper=1
- non caricare i relativi moduli irc e ftp.
Messaggioda conraid » sab nov 03, 2018 12:06
No che non mi servono, sicuramente erano frutto di prove di tempo fa (irc soprattutto, ftp non credo di averlo mai abilitato nei miei pc).
Grazie della spiegazione.
Kernel: 4.20
Desktop: Xfce 4.12
Messaggioda rik70 » sab nov 03, 2018 12:54
conraid ha scritto:No che non mi servono, sicuramente erano frutto di prove di tempo fa (irc soprattutto, ftp non credo di averlo mai abilitato nei miei pc).
No, le porte non è necessario specificarle.
Faccio un esempio:
- aggiungo una regola che "rifiuta" in ingresso connessioni tcp NEW sulle porte ftp e ssl:
iptables -v -A INPUT -p tcp -d 192.168.1.121 -m conntrack --ctstate NEW -m multiport --dports 21,22 -j REJECT --reject-with tcp-reset
- aggiungo la regola per l'helper ftp:
- ora un portscan su ssl e ftp che dovrebbe fare da "trigger":
nmap -p 21,22 192.168.1.121
L'output di dmesg è "pulito".
Ora "pulisco" la catena OUTPUT della tabella raw:
iptables -v -t raw -F OUTPUT
rifaccio il portscan
e stavolta dmesg restituisce:
[ 1117.815330] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
:thumbright:
Ultima modifica di rik70 il sab nov 03, 2018 14:15, modificato 1 volta in totale.
Messaggioda conraid » sab nov 03, 2018 13:58
E infatti dopo aver provato nmap eccolo
# nmap -p 21,22 192.168.0.50
Starting Nmap 7.70 ( https://nmap.org ) at 2018-11-03 13:55 CET
Nmap scan report for blankstar.home.local (192.168.0.50)
Host is up (0.00011s latency).
PORT   STATE  SERVICE
21/tcp closed ftp
22/tcp closed ssh
Nmap done: 1 IP address (1 host up) scanned in 0.15 seconds
# dmesg
[18556.475117] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
Ma mi serve in uscita? Tieni presente che in questa macchina ho solo ssh sulla 222 per la rete locale e niente altro aperto, tranne appunto qualche programma che ne ga bisogno all'occorrenza (amule, torrent, etc...). Anche il DNS che prima usavo per la rete locale ora non lo uso più, avendo solo il notebook.
Kernel: 4.20
Desktop: Xfce 4.12
Messaggioda rik70 » sab nov 03, 2018 14:19
Mah... secondo me, come dicevi anche tu, ti conviene non caricare i 2 moduli per l'helper irc e ftp visto che non te ne fai niente.
Edit:
Altrimenti questa regola che hai nel firewall
ti fa da "trigger" ogni volta che per caso ricevi un pacchetto tcp con i flag specificati su porte ftp e/o irc - immagino eh, non prenderla per buona.
Kernel: 4.20
Desktop: Xfce 4.12
Messaggioda rik70 » sab nov 03, 2018 15:14
PP.SS.
rik70 ha scritto:Altrimenti questa regola che hai nel firewall
Confermo:
iptables -v -A INPUT -p tcp --tcp-flags SYN,ACK SYN,ACK -m conntrack --ctstate NEW -j REJECT --reject-with tcp-reset
iptables -v -t raw -A OUTPUT -p tcp -j CT --helper irc # nota: il comando carica in automatico il modulo nf_conntrack_irc
Siccome non ricordo quali sono le porte di default del protocollo irc, faccio:
nmap -p 6000-7000 192.168.1.121
Vediamo:
dmesg:
Eliminiamo la regola che assegna l'helper irc:
iptables -v -t raw -D OUTPUT -p tcp -j CT --helper irc
Portscan di prima:
dmesg:
A questo punto è svelato l'arcano :thumbright:
Messaggioda conraid » sab nov 03, 2018 15:19
In prarica senza regole specifiche i moduli son di default disabilitati anche se caricati, e danno quel log?
Kernel: 4.20
Desktop: Xfce 4.12
Messaggioda rik70 » sab nov 03, 2018 15:41
conraid ha scritto:In prarica senza regole specifiche i moduli son di default disabilitati anche se caricati, e danno quel log?
Sì, immagino che sia così.
In pratica, se i moduli helper sono caricati e c'è una regola nella tabella filter che utilizza l'estensione conntrack, questa può innescare l'assegnazione automatica dell'helper,
che però fallisce, essendo disabilitata di default.
A questo punto il log del kernel restituisce quell'errore/avviso che ci dice che dobbiamo farlo noi a mano, agendo nella tabella 'raw' come abbiamo visto sopra.
