visualizzare immagini in transito sulla rete... Come?
Cosa hai aggiornato di preciso?orso75 ha scritto:Problemino..
Ho aggiornato un po tutto, ma ancora mi da un errore
autio.o in libreria....
quando eseguio il make
non riesco a capire come sistemarlo..
nem Makefile è segnalato come DO NOT REMOVE....
Consigli?
Posta l'errore del make... cosi' su due piedi nn saprei cosa dirti!
Ciao ciao...
GiAn
Dunque,
attualmente sto provando su una fedora core 4
il problema riscontrato è quiello che ti allego di seguito.
il problema suilla slack mi sembra lo stesso...
Grazie Mille
Orso
cc -g -Wall -I/usr/include/pcap -D_BSD_SOURCE `pkg-config --cflags gtk+-2.0` -DDRIFTNET_VERSION='"0.1.6"' -o endian endian.c
./endian > endianness.h
makedepend -- -g -Wall -I/usr/include/pcap -D_BSD_SOURCE `pkg-config --cflags gtk+-2.0` -DDRIFTNET_VERSION='"0.1.6"' `cat endianness` -- audio.c mpeghdr.c gif.c img.c jpeg.c png.c driftnet.c image.c display.c playaudio.c connection.c media.c util.c http.c
cat: endianness: No such file or directory
makedepend: warning: /usr/include/gnu/stubs-32.h: non-portable whitespace encountered at line 7
makedepend: warning: audio.c (reading /usr/include/string.h, line 33): cannot find include file "stddef.h"
not in /usr/include/pcap/stddef.h
not in /usr/include/gtk-2.0/stddef.h
not in /usr/lib/gtk-2.0/include/stddef.h
not in /usr/X11R6/include/stddef.h
not in /usr/include/atk-1.0/stddef.h
not in /usr/include/pango-1.0/stddef.h
not in /usr/include/freetype2/stddef.h
not in /usr/include/freetype2/config/stddef.h
not in /usr/include/glib-2.0/stddef.h
not in /usr/lib/glib-2.0/include/stddef.h
not in /usr/local/lib/gcc-include/stddef.h
not in /usr/include/stddef.h
not in /usr/lib/gcc/i386-redhat-linux/4.0.1/include/stddef.h
makedepend: warning: audio.c (reading /usr/include/bits/types.h, line 31): cannot find include file "stddef.h"
makedepend: warning: audio.c (reading /usr/include/sys/types.h, line 147): cannot find include file "stddef.h"
makedepend: warning: audio.c (reading /usr/include/sys/socket.h, line 29): cannot find include file "stddef.h"
makedepend: warning: audio.c (reading /usr/include/bits/socket.h, line 29): cannot find include file "stddef.h"
makedepend: warning: audio.c (reading /usr/include/limits.h, line 124): cannot find include file "limits.h"
not in /usr/lib/gcc/i386-redhat-linux/4.0.1/include/limits.h
makedepend: warning: audio.c (reading /usr/include/stdio.h, line 34): cannot find include file "stddef.h"
makedepend: warning: audio.c (reading /usr/include/_G_config.h, line 14): cannot find include file "stddef.h"
makedepend: warning: audio.c (reading /usr/include/wchar.h, line 48): cannot find include file "stddef.h"
makedepend: warning: audio.c (reading /usr/include/gconv.h, line 31): cannot find include file "stddef.h"
makedepend: warning: audio.c (reading /usr/include/libio.h, line 53): cannot find include file "stdarg.h"
not in /usr/include/pcap/stdarg.h
not in /usr/include/gtk-2.0/stdarg.h
not in /usr/lib/gtk-2.0/include/stdarg.h
not in /usr/X11R6/include/stdarg.h
not in /usr/include/atk-1.0/stdarg.h
not in /usr/include/pango-1.0/stdarg.h
not in /usr/include/freetype2/stdarg.h
not in /usr/include/freetype2/config/stdarg.h
not in /usr/include/glib-2.0/stdarg.h
not in /usr/lib/glib-2.0/include/stdarg.h
not in /usr/local/lib/gcc-include/stdarg.h
not in /usr/include/stdarg.h
not in /usr/lib/gcc/i386-redhat-linux/4.0.1/include/stdarg.h
makedepend: warning: img.c (reading /usr/include/stdlib.h, line 33): cannot find include file "stddef.h"
makedepend: warning: img.c (reading /usr/include/alloca.h, line 25): cannot find include file "stddef.h"
makedepend: warning: png.c (reading /usr/include/unistd.h, line 195): cannot find include file "stddef.h"
makedepend: warning: driftnet.c (reading /usr/include/dirent.h, line 235): cannot find include file "stddef.h"
makedepend: warning: display.c (reading /usr/include/glib-2.0/glib/gmacros.h, line 36): cannot find include file "stddef.h"
makedepend: warning: display.c (reading /usr/lib/glib-2.0/include/glibconfig.h, line 12): cannot find include file "float.h"
not in /usr/include/pcap/float.h
not in /usr/include/gtk-2.0/float.h
not in /usr/lib/gtk-2.0/include/float.h
not in /usr/X11R6/include/float.h
not in /usr/include/atk-1.0/float.h
not in /usr/include/pango-1.0/float.h
not in /usr/include/freetype2/float.h
not in /usr/include/freetype2/config/float.h
not in /usr/include/glib-2.0/float.h
not in /usr/lib/glib-2.0/include/float.h
not in /usr/local/lib/gcc-include/float.h
not in /usr/include/float.h
not in /usr/lib/gcc/i386-redhat-linux/4.0.1/include/float.h
makedepend: warning: display.c (reading /usr/include/glib-2.0/glib/gconvert.h, line 30): cannot find include file "stddef.h"
makedepend: warning: display.c (reading /usr/include/glib-2.0/glib/gutils.h, line 31): cannot find include file "stdarg.h"
makedepend: warning: display.c (reading /usr/include/glib-2.0/glib/gmarkup.h, line 24): cannot find include file "stdarg.h"
makedepend: warning: display.c (reading /usr/include/glib-2.0/glib/gmessages.h, line 30): cannot find include file "stdarg.h"
makedepend: warning: display.c (reading /usr/include/glib-2.0/glib/gstrfuncs.h, line 30): cannot find include file "stdarg.h"
makedepend: warning: display.c (reading /usr/include/gtk-2.0/gtk/gtktreestore.h, line 25): cannot find include file "stdarg.h"
makedepend: warning: display.c (reading /usr/X11R6/include/X11/Xlib.h, line 77): cannot find include file "stddef.h"
touch depend
rm -f Makefile.bak
make: *** No rule to make target `/usr/lib/gcc-lib/i386-redhat-linux/2.96/include/stddef.h', needed by `audio.o'. Stop.
Grazie Mille
Orso
touch depend
rm -f Makefile.bak
Hai provato a dare il make da root?orso75 ha scritto:Dunque,
Grazie Mille
Orso
Mi dava un problema simile anche a me se lo compilavo da utente...
Ciao ciao...
GiAn
Ultima cosa che mi viene in mente... Controlla se il tuo Makefile contiene una sfilza di righe sotto un "DO NOT DELETE".orso75 ha scritto:Si, il logo è con il majke lanciato da root...
Se e' cosi' prova ad usare un Makefile senza quelle righe compilando da root.
Di piu' nn so... mi spiace...
Ciao ciao...
GiAn
Due cose:orso75 ha scritto:Allora ho eliminato le linee sotto a DO NOT REMOVE
ed ora sembra rpendere tutto quello che naviag ail mio PC.
Mi viene il dubbio che l'apparato che uso non sia un hub ma uno switch
secondo te è possibile prendere le immagini passanti attraverso un apparato di questo tipo?
1) Non ho mai avuto a che fare direttamente con hub e switch ma e' ovvio che se e' uno switch e "sniffi" l'interfaccia del PC A non leggerai alcun dato diretto al PC B.
2) Io ci sto lavorando su per la tesi (il problema al momento e' che perde un sacco di pacchetti in reti molto veloci => sto riprogrammando la parte di acquisizione/studio/ricercaimmagini in multithread ma la soluzione e' ancora lontana) e ho trovato una marea di BUG... anche se indichi la directory temporanea con -d al suo interno non troverai tutte le foto che driftnet trova ma solo alcune. Se vuoi, appena ho tempo, ti spedisco una versione riveduta e corretta da me... (nn garantisco nulla sul corretto funzionamento!
Ciao ciao...
GiAn
