[Risolto] Radio in streaming, individuare url
sunreal
Slackware: 14.1
Re: [Risolto] Radio in streaming, individuare url
Messaggio da sunreal »
QUESTO È IL LINK --> mplayer http://www.rai.tv/dl/RaiTV/popup/player_radio.html?v=1
MPLAYER RISPONDE
MPlayer dev-SVN-r28238-4.2.4 (C) 2000-2008 MPlayer Team
CPU: AMD Athlon(tm) XP 2000+ (Family: 6, Model: 6, Stepping: 2)
CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
Compiled with runtime CPU detection.
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing http://www.rai.tv/dl/RaiTV/popup/player_radio.html?v=1.
Resolving http://www.rai.tv for AF_INET...
Connecting to server http://www.rai.tv[212.162.68.64]: 80...
Read failed.
STREAM_ASF, URL: http://www.rai.tv/dl/RaiTV/popup/player_radio.html?v=1
unknown ASF streaming type
Failed, exiting.
Cache size set to 320 KBytes
Cache fill: 3.00% (9831 bytes)
Found plugin: libvorbis.so (Ogg Vorbis Player 1.2.11).
Found plugin: libmp4.so (MP4 & MPEG2/4-AAC audio player - 1.2.x).
Found plugin: libmpg123.so (MPEG Layer 1/2/3 Player 1.2.11).
Found plugin: libwav.so (Wave Player 1.2.11).
Found plugin: libxmms-flac.so (Reference FLAC Player v1.2.1).
Found plugin: libcdaudio.so (CD Audio Player 1.2.11).
Found plugin: libtonegen.so (Tone Generator 1.2.11).
Waiting for the XMMS plugin to start playback of 'http://www.rai.tv/dl/RaiTV/popup/player_radio.html?v=1'...
Closing plugin: /usr/lib/xmms/Input/libtonegen.so.
Closing plugin: /usr/lib/xmms/Input/libcdaudio.so.
Closing plugin: /usr/lib/xmms/Input/libxmms-flac.so.
Closing plugin: /usr/lib/xmms/Input/libwav.so.
Closing plugin: /usr/lib/xmms/Input/libmpg123.so.
Closing plugin: /usr/lib/xmms/Input/libmp4.so.
Closing plugin: /usr/lib/xmms/Input/libvorbis.so.
Exiting... (End of file)
Questo era link per radio 1 (in teoria...)
PS è sicuramente un problema di link, in quanto se copio un link da streamtuner e in konsole do mplayer + link incollato qualsiasi stazione si sente.
sardylan
Nome Cognome: Luca Cireddu
Slackware: current 64bits
Kernel: 3.16
Desktop: KDE 4.14
Distribuzione: Debian - CLFS
Messaggio da sardylan »
Allora... Quello non è il link giusto!!!
Quello è il link ad una pagina HTML che contiene tutti i controlli per far andare la cosa!!!
Il link vero e proprio è questo: http://www.radio.rai.it/live/radio2.ram
Che si risolve nel vero flusso audio: rtsp://live.media.rai.it/broadcast/radiodue.rm
Questo è quello che mi dice VLC... Con MPlayer invece non risolve la cosa!!! E mi da esattamente il tuo stesso errore!!
Alla fine ho notato che il tutto è un flusso "Real Audio"
Il mio VLC mi da questi messaggi di errore:
[00000311] live555 demuxer: real codec detected, using real-RTSP instead
[00000311] live555 demuxer error: Nothing to play for rtsp://live.media.rai.it/broadcast/radiodue.rm
che probabilmente è dovuto al fatto che uso qualche vecchia versione del codec live555 (tieni conto che uso un VLC compilato da me, con tutti i codecs statici, alla AlienBob ;) )
Non so cosa occorre su Linux per utilizzare gli streams in Real Audio... Prova ad informarti se hai tutte le librerie necessarie!! Eventualmente facci sapere!!
sunreal
Slackware: 14.1
Avevo detto all'inizio che nel frattmpo sono passato a slack 12.2, così memore del fatto che con la 12 riuscivo ad ascoltare radio due, ho avviato slack 12 e ......................... MAGIA!!!!! Funziona! Quindi non è il problema di link che è rimasto lo stesso:
ma evidentemente a qualche configurazione di non so che.... Prima mi ero concentrato sull' eventuale incompatibilità tra linux e real media, ora vorrei cercare di capire quali pacchetti possono creare questo problema. Vedremo...
sardylan
Kernel: 3.16
Desktop: KDE 4.14
sunreal ha scritto: [...] Funziona! Quindi non è il problema di link che è rimasto lo stesso:
rtsp://live.media.rai.it/broadcast/radiodue.rm [...]
Ed infatti VLC mi trovava il giusto link... Quindi questo è risolto!!
sunreal ha scritto: [...] ma evidentemente a qualche configurazione di non so che.... Prima mi ero concentrato sull' eventuale incompatibilità tra linux e real media, ora vorrei cercare di capire quali pacchetti possono creare questo problema. Vedremo...
Esattamente... Sto provando a ricompilare live555 all'ultima versione!! Ti faccio sapere..
Edit:: Niente da fare!! Non va... Anche perché ho notato che live555 contiene solamente librerie statiche .a, perciò bisognerebbe ricompilare mplayer con le nuove librerie se si vuole fare una prova con le nuove live555...
sunreal
Slackware: 14.1
A me quello che fa inc....re è che uno si aspetta che col passare del tempo e dei rilasci le cose migliorino, invece...... Comunque per ora anche cercando in rete non ho trovato nulla di utile. La ricerca continua, e poi dicono che in italia i ricercatori non ci sono più :lol: :lol:
sardylan
Kernel: 3.16
Desktop: KDE 4.14
sunreal ha scritto: [...] La ricerca continua, e poi dicono che in italia i ricercatori non ci sono più :lol: :lol:
Ma looooool!!!!!!!!!!! :)
Comunque proverò a ricompilare mplayer... Non c'è alternativa per ora...
sunreal
Slackware: 14.1
Stavo pensando.... però se fosse un problema con mplayer altri software potrebbero "aprire" lo streaming, mentre invece non si riesce con nessuno. Anche gli altri tipo xmms, streamtuner, vlc (che non ho provato io ma tu) non funzionano perchè anche loro si appoggiano a mplayer?
PS OH MINC... ho installato kaffeine e lo lanciato da konsole sulla konsole mi appare questa scritta:
kaffeine: ERROR: PlaylistImport: ram: Download via rtsp protocol not supported.
PECCATO!!!!!!
MA...... SI SENTE!!!!!!!!!!!!!!!!!!!!!!
DOVE SARÀ LA DIFFERENZA TRA MPLAYER E KAFFEINE?????? SARÀ LA KAFFEINA?
