convertire mpc in mp3 (meglio ancora in wav)... come??
Re: convertire mpc in mp3 (meglio ancora in wav)... come??
ho capito quel che intendi
io metto gli include nel pacchetto, così anche chi non ha i sorgenti può compilarsi musepack
con la versione del sito mi compila tutto, ma poi mi installa solamente mpcenc
Però puoi prendere i tool a mano
con la versione svn da qualche errore, sempre ancora un progetto in lavorazione la versione SV8
rimetto la vecchia
danix
Nome Cognome: Danilo M.
Slackware: 64 current
Kernel: 6.12.13 x86_64
Desktop: i3
Messaggio da danix »
Building ...
-- The C compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check if the system is big endian
-- Searching 16 bit integer
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of unsigned short
-- Check size of unsigned short - done
-- Using unsigned short
-- Check if the system is big endian - little endian
-- Configuring done
-- Generating done
-- Build files have been written to: /tmp/build/tmp-musepack/musepack_src_r435/build
Scanning dependencies of target mpcdec_static
[  2%] Building C object libmpcdec/CMakeFiles/mpcdec_static.dir/huffman.o
[  5%] Building C object libmpcdec/CMakeFiles/mpcdec_static.dir/mpc_decoder.o
[  7%] Building C object libmpcdec/CMakeFiles/mpcdec_static.dir/mpc_reader.o
[ 10%] Building C object libmpcdec/CMakeFiles/mpcdec_static.dir/streaminfo.o
[ 12%] Building C object libmpcdec/CMakeFiles/mpcdec_static.dir/mpc_bits_reader.o
[ 15%] Building C object libmpcdec/CMakeFiles/mpcdec_static.dir/mpc_demux.o
[ 17%] Building C object libmpcdec/CMakeFiles/mpcdec_static.dir/requant.o
[ 20%] Building C object libmpcdec/CMakeFiles/mpcdec_static.dir/synth_filter.o
[ 22%] Building C object libmpcdec/CMakeFiles/mpcdec_static.dir/__/common/crc32.o
Linking C static library libmpcdec_static.a
[ 22%] Built target mpcdec_static
Scanning dependencies of target mpcpsy_static
[ 25%] Building C object libmpcpsy/CMakeFiles/mpcpsy_static.dir/ans.o
/tmp/build/tmp-musepack/musepack_src_r435/libmpcpsy/ans.c: In function 'NS_Analyse':
/tmp/build/tmp-musepack/musepack_src_r435/libmpcpsy/ans.c:292: warning: passing argument 10 of 'FindOptimalANS' from incompatible pointer type
/tmp/build/tmp-musepack/musepack_src_r435/libmpcpsy/ans.c:297: warning: passing argument 10 of 'FindOptimalANS' from incompatible pointer type
[ 27%] Building C object libmpcpsy/CMakeFiles/mpcpsy_static.dir/cvd.o
[ 30%] Building C object libmpcpsy/CMakeFiles/mpcpsy_static.dir/fft4g.o
[ 32%] Building C object libmpcpsy/CMakeFiles/mpcpsy_static.dir/fft_routines.o
[ 35%] Building C object libmpcpsy/CMakeFiles/mpcpsy_static.dir/profile.o
[ 37%] Building C object libmpcpsy/CMakeFiles/mpcpsy_static.dir/psy.o
/tmp/build/tmp-musepack/musepack_src_r435/libmpcpsy/psy.c: In function 'Psychoakustisches_Modell':
/tmp/build/tmp-musepack/musepack_src_r435/libmpcpsy/psy.c:1031: warning: passing argument 2 of 'CalcShortThreshold' from incompatible pointer type
/tmp/build/tmp-musepack/musepack_src_r435/libmpcpsy/psy.c:1039: warning: passing argument 2 of 'CalcShortThreshold' from incompatible pointer type
/tmp/build/tmp-musepack/musepack_src_r435/libmpcpsy/psy.c:1164: warning: passing argument 2 of 'CalcShortThreshold' from incompatible pointer type
/tmp/build/tmp-musepack/musepack_src_r435/libmpcpsy/psy.c:1172: warning: passing argument 2 of 'CalcShortThreshold' from incompatible pointer type
[ 40%] Building C object libmpcpsy/CMakeFiles/mpcpsy_static.dir/psy_tab.o
[ 42%] Building C object libmpcpsy/CMakeFiles/mpcpsy_static.dir/__/common/fastmath.o
/tmp/build/tmp-musepack/musepack_src_r435/common/fastmath.c: In function 'Init_FastMath':
/tmp/build/tmp-musepack/musepack_src_r435/common/fastmath.c:36: warning: incompatible implicit declaration of built-in function 'atan'
/tmp/build/tmp-musepack/musepack_src_r435/common/fastmath.c:47: warning: incompatible implicit declaration of built-in function 'cos'
/tmp/build/tmp-musepack/musepack_src_r435/common/fastmath.c:60: warning: incompatible implicit declaration of built-in function 'sqrt'
/tmp/build/tmp-musepack/musepack_src_r435/common/fastmath.c:63: warning: incompatible implicit declaration of built-in function 'sqrt'
Linking C static library libmpcpsy_static.a
[ 42%] Built target mpcpsy_static
Scanning dependencies of target mpcenc_static
[ 45%] Building C object libmpcenc/CMakeFiles/mpcenc_static.dir/analy_filter.o
[ 47%] Building C object libmpcenc/CMakeFiles/mpcenc_static.dir/bitstream.o
[ 50%] Building C object libmpcenc/CMakeFiles/mpcenc_static.dir/encode_sv7.o
[ 52%] Building C object libmpcenc/CMakeFiles/mpcenc_static.dir/huffsv7.o
[ 55%] Building C object libmpcenc/CMakeFiles/mpcenc_static.dir/quant.o
[ 57%] Building C object libmpcenc/CMakeFiles/mpcenc_static.dir/__/common/crc32.o
Linking C static library libmpcenc_static.a
[ 57%] Built target mpcenc_static
Scanning dependencies of target wavformat_static
[ 60%] Building C object libwavformat/CMakeFiles/wavformat_static.dir/input.o
[ 62%] Building C object libwavformat/CMakeFiles/wavformat_static.dir/output.o
Linking C static library libwavformat_static.a
[ 62%] Built target wavformat_static
Scanning dependencies of target mpcgain
[ 65%] Building C object mpcgain/CMakeFiles/mpcgain.dir/mpcgain.o
/tmp/build/tmp-musepack/musepack_src_r435/mpcgain/mpcgain.c:38:38: error: replaygain/gain_analysis.h: No such file or directory
/tmp/build/tmp-musepack/musepack_src_r435/mpcgain/mpcgain.c: In function 'analyze_get_max':
/tmp/build/tmp-musepack/musepack_src_r435/mpcgain/mpcgain.c:80: error: 'Float_t' undeclared (first use in this function)
/tmp/build/tmp-musepack/musepack_src_r435/mpcgain/mpcgain.c:80: error: (Each undeclared identifier is reported only once
/tmp/build/tmp-musepack/musepack_src_r435/mpcgain/mpcgain.c:80: error: for each function it appears in.)
/tmp/build/tmp-musepack/musepack_src_r435/mpcgain/mpcgain.c:80: error: expected ';' before 'left_samples'
/tmp/build/tmp-musepack/musepack_src_r435/mpcgain/mpcgain.c:81: error: expected ';' before 'right_samples'
/tmp/build/tmp-musepack/musepack_src_r435/mpcgain/mpcgain.c:86: error: 'left_samples' undeclared (first use in this function)
/tmp/build/tmp-musepack/musepack_src_r435/mpcgain/mpcgain.c:87: error: 'right_samples' undeclared (first use in this function)
/tmp/build/tmp-musepack/musepack_src_r435/mpcgain/mpcgain.c: In function 'main':
/tmp/build/tmp-musepack/musepack_src_r435/mpcgain/mpcgain.c:185: warning: initialization discards qualifiers from pointer target type
/tmp/build/tmp-musepack/musepack_src_r435/mpcgain/mpcgain.c:218: warning: initialization discards qualifiers from pointer target type
make[2]: *** [mpcgain/CMakeFiles/mpcgain.dir/mpcgain.o] Error 1
make[1]: *** [mpcgain/CMakeFiles/mpcgain.dir/all] Error 2
make: *** [all] Error 2
cp: impossibile fare stat di `ABOUT*': No such file or directory
cp: impossibile fare stat di `AUTHORS': No such file or directory
cp: impossibile fare stat di `BUGS': No such file or directory
cp: impossibile fare stat di `ChangeLog*': No such file or directory
cp: impossibile fare stat di `COPYING': No such file or directory
cp: impossibile fare stat di `CREDITS': No such file or directory
cp: impossibile fare stat di `FAQ': No such file or directory
cp: impossibile fare stat di `GPL*': No such file or directory
cp: impossibile fare stat di `HACKING': No such file or directory
cp: impossibile fare stat di `LICENSE': No such file or directory
cp: impossibile fare stat di `MAINTAINERS': No such file or directory
cp: impossibile fare stat di `NEWS': No such file or directory
cp: impossibile fare stat di `README*': No such file or directory
cp: impossibile fare stat di `TODO': No such file or directory
Slackware package maker, version 3.14159.
Searching for symbolic links:
No symbolic links were found, so we won't make an installation script.
You can make your own later in ./install/doinst.sh and rebuild the
package if you like.
This next step is optional - you can set the directories in your package
to some sane permissions. If any of the directories in your package have
special permissions, then DO NOT reset them here!
Would you like to reset all directory permissions to 755 (drwxr-xr-x) and
directory ownerships to root.root ([y]es, [n]o)? n
Creating Slackware package:  /tmp/musepack-r435-x86_64-1dx.txz
usr/
usr/doc/
usr/doc/musepack-r435/
usr/doc/musepack-r435/musepack.SlackBuild
install/
install/slack-desc
Slackware package /tmp/musepack-r435-x86_64-1dx.txz created.
md5sum: musepack-r435-x86_64-1dx.tgz: No such file or directory
musepack.SlackBuild FAILED at line 175
Ho superato quello scoglio che mi bloccava da un paio di giorni, ma la compilazione finisce comunque male...
Le 2 librerie le ho incluse in questo modo:
  cmake \
    -DCUEFILE_INCLUDE_DIR:FILEPATH=/usr/lib64 \
    -DREPLAY_GAIN_INCLUDE_DIR:FILEPATH=/usr/lib64 \
Conraid, mi dici come hai fatto?? Mi sa che mi sfugge qualcosa di palese... :(
EDIT
ho visto le risposte prima di postare... hai idea di quale sia l'errore??
danix
sì, allora
io non ho dovuto mettere nessun percorso, ho messo gli include nei pacchetti.
Ti faccio un esempio
in libcuefile.SlackBuild
# Add include header for build musepack
cp -a include $PKG/usr
chmod 644 $PKG/usr/include/cuetools/*
in libreplaygain.SlackBuild
install -Dm644 include/replaygain/gain_analysis.h $PKG/usr/include/replaygain/gain_analysis.h
ho dovuto far così perché...
cuefile
There may be a make install command, but the current CMakeLists.txt doesn't properly install the lib (the include dir is not installed). Contributions welcome !
replaygain
I fear make install doesn't install the include file.
sono ancora molto indietro nello sviluppo sembra, e come ti dicevo la versione svn di ieri non compilava
Però tieni presente che
libmpc needs libcuefile for reading .cue files to import chapters information. This is the same libcuefile as in cuetools, but we made it a standalone library for our use.
Also libreplaygain is needed to build the mpcgain application.
quindi magari funziona con cuetools, non provato
danix ha scritto: Le 2 librerie le ho incluse in questo modo:
  cmake \
inoltre stai attento a queste cose, quelle variabili sono per gli headers non per le librerie, quindi al limite
    -DCUEFILE_INCLUDE_DIR:FILEPATH=/usr/include... \
    -DREPLAY_GAIN_INCLUDE_DIR:FILEPATH=/usr/include... \
i puntini perché non so se ci va il percorso completo o meno, ma se fai come ti ho detto nel messaggio di prima non ne hai bisogno
danix
Desktop: i3
alla fine anche a me ha installato solo mpcenc nel txz, ho preso da /tmp l'eseguibile di mpcdec ma mi ha creato un mp3 corrotto, quindi credo che qualcosa non sia andato per il verso giusto... :-k
Sto disperando di riuscire a masterizzare questo cd... :(
Nella vecchia versione c'è mpcdec?? Mi diresti come si chiama il pacchetto (se c'è su slackers)??
danix
no, non c'è, ci sono solamente le librerie, il pacchetto vecchio si chiama libmpc
devi provare svn fino a che non migliora
