audio con rosegarden
samiel
- Slackware: 13.0
- Kernel: 2.26
- Desktop: KDE
- Distribuzione: anche Debian
yes... io ho fatto anche il tgz
che trovi qui su slacky, anzi adesso
ho fatto pure quello col supporto a jack
e devo mandarlo a Lorys.
Hai visto il mio SlackBuild?
Però Timidity per suonare ha bisogno
dei soundfont e di /etc/timidity.cfg
che devi aggiungere tu.
Se vuoi ti mando il mio timidity.cfg
M.
M.
samiel
- Slackware: 13.0
- Kernel: 2.26
- Desktop: KDE
Sì, timidity.cfg in pratica dice a timidity
dove cercare i soundfont, che però devono
essere scompattati, cioè devi avere i singoli
file *.pat, e poi ha l'elenco di questi.
Viene fuori una cosa del tipo:
M.
# I've tweaked the amps pretty well, they should sound pretty good as they are
# now. If you don't like the balance, just change it
soundfont /usr/lib/sfbank/timidity/instruments
bank 0
0 instruments/acpiano amp=125
1 instruments/britepno amp=115
2 instruments/synpiano amp=115
3 instruments/honky
4 instruments/epiano1
5 instruments/epiano2 amp=80
6 instruments/hrpschrd amp=115
7 instruments/clavinet
8 instruments/celeste amp=100
9 instruments/glocken amp=75
10 instruments/musicbox
11 instruments/vibes amp=60
12 instruments/marimba
13 instruments/xylophon
M.
bash-3.00$ timidity
TiMidity++ version 2.13.2 -- MIDI to WAVE converter and player
Copyright (C) 1999-2004 Masanao Izumo <iz@onicos.co.jp>
Copyright (C) 1995 Tuukka Toivonen <tt@cgs.fi>
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
questo è l'output se digito timidity, quindi credo che sia correttamente installato, cosa mi consigli di fare?
P.S. dimenticavo i soundfiles che ho scaricato hanno estensione .sf2 che credo che sia quella corretta.... io da rosegarden ho caricato proprio questo file con estensione sf2....
se digito locate timidity.cfg ho questo output:
bash-3.00$ locate timidity.cfg
/usr/man/man5/timidity.cfg.5.gz
/usr/local/timidity-2.11.3/man/man5/timidity.cfg.5
/home/b4sh/TiMidity++-2.13.0/doc/C/timidity.cfg.5
/home/b4sh/TiMidity++-2.13.0/doc/ja_JP.eucJP/timidity.cfg.5
/home/b4sh/TiMidity++-2.13.0/doc/timidity.cfg.5
quale tra questi file devo copiare nella directory /etc/ ?
