[PIU' CHE RISOLTO :) ] iptables - creazione rc.firewall
Re: iptables - creazione rc.firewall
mi dici ifconfig che output ti da?
danix
Nome Cognome: Danilo M.
Slackware: 64 current
Kernel: 6.12.13 x86_64
Desktop: i3
Messaggio da danix »
# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:50:8d:54:8d:c9
          inet addr:192.168.1.4  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::250:8dff:fe54:8dc9/64 Scope:Link
          UP BROADCAST NOTRAILERS RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:8569 errors:0 dropped:0 overruns:0 frame:0
          TX packets:9547 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:4400831 (4.1 MiB)  TX bytes:1025156 (1001.1 KiB)
          Interrupt:20 Base address:0xa000
eth1      Link encap:Ethernet  HWaddr 00:10:a7:17:d9:bb
          inet addr:192.168.7.1  Bcast:192.168.7.255  Mask:255.255.255.0
          inet6 addr: fe80::210:a7ff:fe17:d9bb/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:9218 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8095 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:975098 (952.2 KiB)  TX bytes:4425385 (4.2 MiB)
          Interrupt:21 Base address:0xa400
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:3446 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3446 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:432962 (422.8 KiB)  TX bytes:432962 (422.8 KiB)
ppp0      Link encap:Point-to-Point Protocol
          inet addr:79.13.118.224  P-t-P:192.168.100.1  Mask:255.255.255.255
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1492  Metric:1
          RX packets:96 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:3
          RX bytes:6490 (6.3 KiB)  TX bytes:37 (37.0 B)
danix
ma eth0 a cosa ti serve?
Io continuo a pensare che nella tua configurazione (oddio, a questo punto inizio a credere di non averci capito niente) non serve a niente, e devi agire su ppp0
danix
Desktop: i3
anche io ci ho capito poco, comunque eth0 è l'interfaccia che dialoga con il modem... dici che non mi serve a niente??
danix
danix ha scritto:anche io ci ho capito poco, comunque eth0 è l'interfaccia che dialoga con il modem... dici che non mi serve a niente??
fisicamente è eth0, ma in realtà è ppp0
ma senti qualcuno più esperto.
Io quando uso pppoe non configuro nemmeno l'interfaccia che si allaccia al modem
danix
Desktop: i3
ma quindi nel firewall devo fare riferimento a eth0 come porta d'uscita o a ppp0?? Non ci sto capendo più nulla... :(
danix
danix
Desktop: i3
rieccomi...
Per cominciare ho rimosso le regole di iptables impostate dal firewall di pppoe, ho rimosso le regole di forwarding impostate nell'rc.modules e ho scritto tutto in un rc.firewall... questo:
#!/bin/bash
SW_VERB="-v"
firewall_init() {
	sh /etc/rc.d/rc.ip_forward stop
	/usr/sbin/iptables -F $SW_VERB
	/usr/sbin/iptables -t nat -F $SW_VERB
	/usr/sbin/iptables -t mangle -F $SW_VERB
	/usr/sbin/iptables -X $SW_VERB
	/usr/sbin/iptables -t nat -X $SW_VERB
	/usr/sbin/iptables -t mangle -X $SW_VERB
firewall_policies() {
	/usr/sbin/iptables -P INPUT $1 $SW_VERB
	/usr/sbin/iptables -P OUTPUT $1 $SW_VERB
	/usr/sbin/iptables -P FORWARD $1 $SW_VERB
main_rules() {
	/usr/sbin/iptables -A INPUT -i lo -j ACCEPT $SW_VERB
	/usr/sbin/iptables -A INPUT -i eth1 -j ACCEPT $SW_VERB
	/usr/sbin/iptables -A INPUT -i ppp0 -m state --state ESTABLISHED,RELATED -j ACCEPT $SW_VERB
	/usr/sbin/iptables -A OUTPUT -o lo -j ACCEPT $SW_VERB
	/usr/sbin/iptables -A OUTPUT -o eth1 -j ACCEPT $SW_VERB
	/usr/sbin/iptables -A OUTPUT -o ppp0 -j ACCEPT $SW_VERB
	# Log & Deny the rest of the privileged ports
	/usr/sbin/iptables -A INPUT -i ppp0 -p tcp --dport 0:1023 -j LOG $SW_VERB
	/usr/sbin/iptables -A INPUT -i ppp0 -p udp --dport 0:1023 -j LOG $SW_VERB
	/usr/sbin/iptables -A INPUT -i ppp0 -p tcp --dport 0:1023 -j DROP $SW_VERB
	/usr/sbin/iptables -A INPUT -i ppp0 -p udp --dport 0:1023 -j DROP $SW_VERB
	# Blocco i ping dall'esterno
	/usr/sbin/iptables -A INPUT -i ppp0 -p icmp --icmp-type echo-request -j DROP $SW_VERB
forwarding_rules() {
	/usr/sbin/iptables -A FORWARD -i ppp0 -o eth1 -m state --state ESTABLISHED,RELATED -j ACCEPT $SW_VERB
	/usr/sbin/iptables -A FORWARD -i eth1 -o ppp0 -j ACCEPT $SW_VERB
	# Abilito il masquerading
	/usr/sbin/iptables -t nat -A POSTROUTING -o ppp0 -j MASQUERADE $SW_VERB
custom_rules() {
	/usr/sbin/iptables -A INPUT -i eth1 -p tcp --dport 8022 -j ACCEPT $SW_VERB	# SSH sulla lan interna
	/usr/sbin/iptables -A INPUT -i ppp0 -p tcp --dport 80 -j ACCEPT $SW_VERB	# HTTPD
	/usr/sbin/iptables -A INPUT -i ppp0 -p udp --dport 27960 -j ACCEPT $SW_VERB	# URBAN TERROR
closing_rules() {
	/usr/sbin/iptables -A INPUT -j DROP $SW_VERB
	/usr/sbin/iptables -A OUTPUT -j DROP $SW_VERB
	/usr/sbin/iptables -A FORWARD -j DROP $SW_VERB
	/usr/sbin/iptables -Z $SW_VERB
	/usr/sbin/iptables -t nat -Z $SW_VERB
	/usr/sbin/iptables -t mangle -Z $SW_VERB
	sh /etc/rc.d/rc.ip_forward start
sys_config() {
	# no IP spoofing
	if [ -e /proc/sys/net/ipv4/conf/all/rp_filter ] ; then
	   for i in /proc/sys/net/ipv4/conf/*/rp_filter; do
	      echo 1 > $i
	   done
	fi
	# Disable Source Routed Packets
	for i in /proc/sys/net/ipv4/conf/*/accept_source_route; do
	   echo 0 > $i
	done
case "$1" in
	start)
		echo "Configuring firewall... "
		firewall_init
		firewall_policies DROP
		main_rules
		forwarding_rules
		custom_rules
		closing_rules
		sys_config
	stop)
		echo "Resetting firewall... "
		firewall_init
		firewall_policies ACCEPT
	status)
		if [ -r /tmp/firewall.out ];then
			rm /tmp/firewall.out
		else
			touch /tmp/firewall.out
		fi
		/usr/sbin/iptables -L -n -v --line-numbers > /tmp/firewall.out
		echo >> /tmp/firewall.out
		/usr/sbin/iptables -t nat -L -n -v --line-numbers >> /tmp/firewall.out
		less /tmp/firewall.out
		echo "Usage:  `basename $0`  start|stop|status"
		exit 1
esac
di questo che ne dite??
Se poteste dargli un'occhiata e dirmi come vi sembra sarebbe ottimo :D
danix
sardylan
Nome Cognome: Luca Cireddu
Slackware: current 64bits
Kernel: 3.16
Desktop: KDE 4.14
Distribuzione: Debian - CLFS
Messaggio da sardylan »
@danix
Se ho capito bene:
eth0 --> Router Telecom
eth1 --> Rete locale (c'è solo il portatile collegato)
Se usi la eth0 per collegarti con il modem, allora non ti serve che la configuri!!! Il traffico PPPoE viaggia a livello di link, e non di rete: http://it.wikipedia.org/wiki/PPPoE
Ne consegue quindi che le impostazioni per il firewall non agiscono sul traffico dati relativo alla connessione...
Quindi, a meno che tu non abbia la necessità di dialogare con il router alice "DAL SERVER" per accedere tramite 192.168.1.1 al pannello di amministrazione (ma visto che non hai ne monitor ne tastiera collegati, penso proprio che non ti serva ;) ), non occorre che tu configuri questa interfaccia...
Puoi quindi tranquillamente __NON ASSEGNARE__ nessun indirizzo IP (o assegnare 0.0.0.0 per eliminare eventuali configurazioni), ed tralasciarla completamente nella configurazione di NetFilter con iptables...
Concentrati solo ed esclusivamente sulla ppp0 per quanto riguarda la parte internet, e sulla eth1 per la parte della rete locale (quella collegata al portatile).
E ricorda:
Se vuoi rendere disponibili su internet i servizi del tuo server, allora devi _SEMPLICEMENTE_ aprire le porte usando la tabella -t filter (parametro solitamente omesso) e la catena -A INPUT... Perché non c'è bisogno ne di FORWARDING ne di NATTING... E questo è quello che a te iinteressa!!
Mentre devi FORWARDARE le porte usando -A FORWARD e tutto il resto se vuoi rendere disponibili servizi presenti nei PC della lan (dove te hai solo il portatile), ovvero computer per i quali "IL SERVER FA DA GATEWAY"...
Per il resto, ad una prima occhiata, a parte la regola
che risulta inutile, per il resto dovrebbe andare tutto bene..
Questa regole risulta inutile perché i pacchetti che rispettano quei parametri vengono accettati dalla precedente regola
Infatti se provi a fare rc.firewall status, vedrai che di bytes corrispondenti a quella regola non ne transitano nella catena... ;) Tutto il traffico in entrata dalla eth1 viene già accettato nelle regole delle main rules...
Spero di essere stato chiaro!! :) Se hai altri dubbi chiedi pure!
:tongue1: :tongue1: :hello2: :lol:
danix
Desktop: i3
Grazie della risposta sardylan, avevo notato che quella regola non produceva traffico, ma sarà stata un po' la mia insicurezza, un po' il fatto che era tardi e non ho indagato troppo... ;)
eppure il server non appare in internet :(
nmap -v 127.0.0.1 mi dice che la porta 80 è aperta, ma ieri in irc mi hanno detto di non riuscire a contattare il server... :(
che controlli posso fare??
danix
sardylan
Kernel: 3.16
Desktop: KDE 4.14
$ nslookup danixquellochee.dyndns.org
# ifconfig ppp0
E controlli gli indirizzi IP... Se sono uguali __DEVE FUNZIONARE__... Altrimenti prova a dare direttamente l'indirizzo IP per vedere se funziona!!!
Ah... Ricordati che httpd vuole configurato per andare su tutti gli indirizzi... Se hai nell'httpd.conf la direttiva
Listen 127.0.0.1:80
non ti funzionerà nemmeno se picchi il computer!!! :D :D :D :D
Corregila con
Listen 80
danix
Desktop: i3
httpd è in ascolto sulla 80 correttamente, nslookup mi ha risposto:
# nslookup danixland.endofinternet.org
Server:         127.0.0.1
Address:        127.0.0.1#53
Non-authoritative answer:
Address: 79.19.188.250
e ifconfig
# ifconfig ppp0
          inet addr:79.19.188.250  P-t-P:192.168.100.1  Mask:255.255.255.255
          RX packets:1042 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1155 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:587968 (574.1 KiB)  TX bytes:121075 (118.2 KiB)
dove sta l'inghippo??
danix
netstat -autpn | grep 80
danix
Desktop: i3
mmmh... questa non è una bella cosa...
# netstat -autpn |grep 80
tcp        0      0 192.168.7.1:8022        0.0.0.0:*               LISTEN      1122/sshd
tcp        0      0 192.168.7.1:8022        192.168.7.100:49666     ESTABLISHED 1788/sshd: danix [p
tcp6       0      0 :::80                   :::*                    LISTEN      1337/httpd
Ho sbagliato a configurare apache??
danix
danix ha scritto:mmmh... questa non è una bella cosa...
sì, sembra in ascolto solamente su ipv6
La direttiva Listen come ce l'hai?
danix
Desktop: i3
Listen 80
ServerName danixland.endofinternet.org:80
danix
