winbond usb2wlan [RISOLTO (grazie)]
- Luci0
- Slackware: 12.2 14.0
- Desktop: KDE 3.5.10 Xfce
I' ve tested ndiswrapper some months ago ... I don't remember the version ... 1.46? ... Ndiswrapper succed in installing the driver ... but don't works... Now the version is 1.49 , you can do another test ... !
I' ve sold the USB Wifi adapter and I can' t help you ...
Good luck ... Ciao
P.S. You can read some info from the INSTALL textfile into the ndiswrappper tree ...
Good luck ... Ciao
Once the driver has been unpacked, locate .inf and .sys files. If
necessary, move these files so both .inf and .sys are in the same
directory. Some drivers also come with firmware files, such as
fwrad16.bin etc. These files also should be in the same
directory. Then install the Windows driver with
ndiswrapper -i driver.inf
lcostantino
- Slackware: 11
Re: winbond usb2wlan [RISOLTO (grazie)]
Hi, we had a lot of problems trying to make this card work with kernel 2.6.22 using original driver.
We made a little port ( beta ... ), that have basic features.
Right now, driver is not exporting /proc/wireless so most of the UI tools won't work as expected ( they get interfaces from /proc/wireless ). But works fine on console or other's ui tools that adquire interfaces from some other file.
WPA was tested only with 1 algorithm, but, need to be tested too, may crash depending the algoritm.
I hope someone can test it, and patch features not working right now.
( We ported this to make it work on koshinja laptops ), but at the moment i dont have the equipment anymore..
http://repositorio.pixartargentina.com. ... _rxart.tgz
siribarren
Hi!
I've got a Kohjinsha SAF100 with this WIFI HW.
I'm currently using Ubuntu Gutsy Gibbon with 2.6.24-5-generic kernel.
I've download the release "rxart" published by lconstanstino (Thanks!) but i've got the following errors during make all. (Sorry, the errors are in spanish)
Any ideas?
I've using the Ubuntu 7.04 Feisty Fawn and this driver compile correctly with the built in kernel but with the new kernels never has run.
Thanks and sorry by my poor english!
Simon Iribarren
simon@simon-laptop:~/hal_142_o_rxart/linux$ make
make -C /lib/modules/2.6.24-5-generic/build M=/home/simon/hal_142_o_rxart/linux modules
make[1]: se ingresa al directorio `/usr/src/linux-headers-2.6.24-5-generic'
make[2]: *** No hay ninguna regla para construir el objetivo `/home/simon/hal_142_o_rxart/linux/dispatch.o', necesario para `/home/simon/hal_142_o_rxart/linux/w35und.o'. Alto.
make[1]: *** [_module_/home/simon/hal_142_o_rxart/linux] Error 2
make[1]: se sale del directorio `/usr/src/linux-headers-2.6.24-5-generic'
make: *** [all] Error 2
Simon Iribarren
lcostantino
- Slackware: 11
================== EDIT =============simon@simon-laptop:~/hal_142_o_rxart/linux$ make
further than below explanation, dispatch.o must be removed from Makefile.!
Hi simon, i just tested it at home on 2.6.24 ( on slackware , stock kernel from kernel.org , lot of include warnings on this kernel :P ) and compiled ok with 2 mods ( kernel removed some functions, other are deprectaed now... )
At first, on wblinux.c
replace eth_copy_and_sum( skb, BufAddr, BufSize, 0 )
for skb_copy_from_linear_data(skb, BufAddr, BufSize )
On linux/wbusb.c , comment the line SET_MODULE_OWNER(netdev)
I used kernel source ( not headers ), it must have wireless options enabled ( module or builtin, dont matter ), then a make to generate x86/makefiles , when basic files are generated, compile the driver ). Also remember to have Module.symvers in your kernel dir, or you will get warning about symbols from usb unresolved.
I didnt test if its working or not on this kernel, i dont have the wireless card, i am at home.
Anyway, if you have another problem, let me now, i speak spanish too. I am very interested seeing if driver is working or not in that kernel
[Log -> Warning's removed ]
make -C /usr/src/linux M=/usr/src/hal_142_o_rxart/linux modules
make[1]: Entering directory `/usr/src/linux-2.6.24'
CC [M] /usr/src/hal_142_o_rxart/linux/wbusb.o
CC [M] /usr/src/hal_142_o_rxart/linux/wb35reg.o
CC [M] /usr/src/hal_142_o_rxart/linux/wb35rx.o
CC [M] /usr/src/hal_142_o_rxart/linux/wb35tx.o
CC [M] /usr/src/hal_142_o_rxart/linux/new_wireless.o
CC [M] /usr/src/hal_142_o_rxart/linux/../bssdbase.o
CC [M] /usr/src/hal_142_o_rxart/linux/../ds_tkip.o
CC [M] /usr/src/hal_142_o_rxart/linux/../knl.o
CC [M] /usr/src/hal_142_o_rxart/linux/../mds.o
CC [M] /usr/src/hal_142_o_rxart/linux/../mlme_assoc.o
CC [M] /usr/src/hal_142_o_rxart/linux/../mlme_auth.o
CC [M] /usr/src/hal_142_o_rxart/linux/../mlmetask.o
CC [M] /usr/src/hal_142_o_rxart/linux/../mlmetxrx.o
CC [M] /usr/src/hal_142_o_rxart/linux/../mto.o
CC [M] /usr/src/hal_142_o_rxart/linux/../phy_calibration.o
CC [M] /usr/src/hal_142_o_rxart/linux/../reg.o
CC [M] /usr/src/hal_142_o_rxart/linux/../roamtask.o
CC [M] /usr/src/hal_142_o_rxart/linux/../rxisr.o
CC [M] /usr/src/hal_142_o_rxart/linux/../scan_probe.o
CC [M] /usr/src/hal_142_o_rxart/linux/../scantask.o
CC [M] /usr/src/hal_142_o_rxart/linux/../sme_api.o
CC [M] /usr/src/hal_142_o_rxart/linux/../smetask.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wbhal.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wblinux.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wpa/eap.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wpa/4Way.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wpa/Adapter_Bridge.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wpa/STLFunction.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wpa/passphrase.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wpa/prf.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wpa/rc4.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wpa/sha1.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wpa/hmac_sha1.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wpa/hmac_md5.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wpa/md5.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wpa/aes.o
CC [M] /usr/src/hal_142_o_rxart/linux/../wpa/aes_wrap.o
LD [M] /usr/src/hal_142_o_rxart/linux/w35und.o
Building modules, stage 2.
MODPOST 1 modules
CC /usr/src/hal_142_o_rxart/linux/w35und.mod.o
LD [M] /usr/src/hal_142_o_rxart/linux/w35und.ko
make[1]: Leaving directory `/usr/src/linux-2.6.24'
this is a config example ( its missing a lot of features, was just for testing )
# Automatically generated make config: don't edit
# Linux kernel version: 2.6.24
# Thu Jan 31 04:56:01 2008
# CONFIG_64BIT is not set
CONFIG_X86_32=y
# CONFIG_X86_64 is not set
CONFIG_X86=y
CONFIG_GENERIC_TIME=y
CONFIG_GENERIC_CMOS_UPDATE=y
CONFIG_CLOCKSOURCE_WATCHDOG=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_SEMAPHORE_SLEEPERS=y
CONFIG_MMU=y
CONFIG_ZONE_DMA=y
CONFIG_QUICKLIST=y
CONFIG_GENERIC_ISA_DMA=y
CONFIG_GENERIC_IOMAP=y
CONFIG_GENERIC_BUG=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_ARCH_MAY_HAVE_PC_FDC=y
CONFIG_DMI=y
# CONFIG_RWSEM_GENERIC_SPINLOCK is not set
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
# CONFIG_ARCH_HAS_ILOG2_U32 is not set
# CONFIG_ARCH_HAS_ILOG2_U64 is not set
CONFIG_GENERIC_CALIBRATE_DELAY=y
# CONFIG_GENERIC_TIME_VSYSCALL is not set
CONFIG_ARCH_SUPPORTS_OPROFILE=y
# CONFIG_ZONE_DMA32 is not set
CONFIG_ARCH_POPULATES_NODE_MAP=y
# CONFIG_AUDIT_ARCH is not set
CONFIG_GENERIC_HARDIRQS=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_X86_BIOS_REBOOT=y
CONFIG_KTIME_SCALAR=y
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
# General setup
# CONFIG_EXPERIMENTAL is not set
CONFIG_BROKEN_ON_SMP=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_SWAP=y
# CONFIG_SYSVIPC is not set
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_TASKSTATS is not set
# CONFIG_AUDIT is not set
# CONFIG_IKCONFIG is not set
CONFIG_LOG_BUF_SHIFT=14
# CONFIG_CGROUPS is not set
CONFIG_FAIR_GROUP_SCHED=y
CONFIG_FAIR_USER_SCHED=y
# CONFIG_FAIR_CGROUP_SCHED is not set
CONFIG_SYSFS_DEPRECATED=y
# CONFIG_RELAY is not set
# CONFIG_BLK_DEV_INITRD is not set
CONFIG_SYSCTL=y
# CONFIG_EMBEDDED is not set
CONFIG_UID16=y
CONFIG_SYSCTL_SYSCALL=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_EXTRA_PASS is not set
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_ANON_INODES=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLUB_DEBUG=y
# CONFIG_SLAB is not set
CONFIG_SLUB=y
# CONFIG_SLOB is not set
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
# CONFIG_TINY_SHMEM is not set
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODVERSIONS=y
CONFIG_MODULE_SRCVERSION_ALL=y
CONFIG_KMOD=y
CONFIG_BLOCK=y
# CONFIG_LBD is not set
# CONFIG_BLK_DEV_IO_TRACE is not set
# CONFIG_LSF is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_AS=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_DEFAULT_AS is not set
# CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
# CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="cfq"
# Processor type and features
# CONFIG_TICK_ONESHOT is not set
# CONFIG_NO_HZ is not set
# CONFIG_HIGH_RES_TIMERS is not set
CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
# CONFIG_SMP is not set
CONFIG_X86_PC=y
# CONFIG_X86_ELAN is not set
# CONFIG_X86_VOYAGER is not set
# CONFIG_X86_NUMAQ is not set
# CONFIG_X86_SUMMIT is not set
# CONFIG_X86_BIGSMP is not set
# CONFIG_X86_VISWS is not set
# CONFIG_X86_GENERICARCH is not set
# CONFIG_X86_ES7000 is not set
# CONFIG_X86_VSMP is not set
CONFIG_SCHED_NO_NO_OMIT_FRAME_POINTER=y
# CONFIG_PARAVIRT_GUEST is not set
# CONFIG_M386 is not set
# CONFIG_M486 is not set
# CONFIG_M586 is not set
# CONFIG_M586TSC is not set
# CONFIG_M586MMX is not set
CONFIG_M686=y
# CONFIG_MPENTIUMII is not set
# CONFIG_MPENTIUMIII is not set
# CONFIG_MPENTIUMM is not set
# CONFIG_MPENTIUM4 is not set
# CONFIG_MK6 is not set
# CONFIG_MK7 is not set
# CONFIG_MK8 is not set
# CONFIG_MCRUSOE is not set
# CONFIG_MEFFICEON is not set
# CONFIG_MWINCHIPC6 is not set
# CONFIG_MWINCHIP2 is not set
# CONFIG_MWINCHIP3D is not set
# CONFIG_MGEODEGX1 is not set
# CONFIG_MGEODE_LX is not set
# CONFIG_MCYRIXIII is not set
# CONFIG_MVIAC3_2 is not set
# CONFIG_MVIAC7 is not set
# CONFIG_MPSC is not set
# CONFIG_MCORE2 is not set
# CONFIG_GENERIC_CPU is not set
# CONFIG_X86_GENERIC is not set
CONFIG_X86_CMPXCHG=y
CONFIG_X86_L1_CACHE_SHIFT=5
CONFIG_X86_XADD=y
CONFIG_X86_PPRO_FENCE=y
CONFIG_X86_WP_WORKS_OK=y
CONFIG_X86_INVLPG=y
CONFIG_X86_BSWAP=y
CONFIG_X86_POPAD_OK=y
CONFIG_X86_GOOD_APIC=y
CONFIG_X86_USE_PPRO_CHECKSUM=y
CONFIG_X86_TSC=y
CONFIG_X86_CMOV=y
CONFIG_X86_MINIMUM_CPU_FAMILY=4
# CONFIG_HPET_TIMER is not set
CONFIG_PREEMPT_NONE=y
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
# CONFIG_X86_UP_APIC is not set
# CONFIG_X86_MCE is not set
CONFIG_VM86=y
# CONFIG_TOSHIBA is not set
# CONFIG_I8K is not set
# CONFIG_X86_REBOOTFIXUPS is not set
# CONFIG_MICROCODE is not set
# CONFIG_X86_MSR is not set
# CONFIG_X86_CPUID is not set
# CONFIG_NOHIGHMEM is not set
CONFIG_HIGHMEM4G=y
# CONFIG_HIGHMEM64G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_HIGHMEM=y
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
# CONFIG_SPARSEMEM_STATIC is not set
# CONFIG_SPARSEMEM_VMEMMAP_ENABLE is not set
CONFIG_SPLIT_PTLOCK_CPUS=4
# CONFIG_RESOURCES_64BIT is not set
CONFIG_ZONE_DMA_FLAG=1
CONFIG_BOUNCE=y
CONFIG_NR_QUICK=1
CONFIG_VIRT_TO_BUS=y
# CONFIG_HIGHPTE is not set
# CONFIG_MATH_EMULATION is not set
# CONFIG_MTRR is not set
CONFIG_SECCOMP=y
# CONFIG_HZ_100 is not set
CONFIG_HZ_250=y
# CONFIG_HZ_300 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=250
# CONFIG_KEXEC is not set
CONFIG_PHYSICAL_START=0x100000
CONFIG_PHYSICAL_ALIGN=0x100000
CONFIG_COMPAT_VDSO=y
CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG=y
# Power management options
# CONFIG_PM is not set
CONFIG_SUSPEND_UP_POSSIBLE=y
CONFIG_HIBERNATION_UP_POSSIBLE=y
# CPU Frequency scaling
# CONFIG_CPU_FREQ is not set
# CONFIG_CPU_IDLE is not set
# Bus options (PCI etc.)
# CONFIG_PCI is not set
# CONFIG_ARCH_SUPPORTS_MSI is not set
CONFIG_ISA_DMA_API=y
# CONFIG_ISA is not set
# CONFIG_MCA is not set
# CONFIG_SCx200 is not set
# CONFIG_PCCARD is not set
# Executable file formats / Emulations
CONFIG_BINFMT_ELF=y
# CONFIG_BINFMT_AOUT is not set
# CONFIG_BINFMT_MISC is not set
# Networking
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
CONFIG_PACKET_MMAP=y
CONFIG_UNIX=y
CONFIG_XFRM=y
# CONFIG_XFRM_USER is not set
# CONFIG_NET_KEY is not set
CONFIG_INET=y
# CONFIG_IP_MULTICAST is not set
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_FIB_HASH=y
# CONFIG_IP_PNP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_XFRM_TUNNEL is not set
CONFIG_INET_TUNNEL=y
CONFIG_INET_XFRM_MODE_TRANSPORT=y
CONFIG_INET_XFRM_MODE_TUNNEL=y
CONFIG_INET_XFRM_MODE_BEET=y
# CONFIG_INET_LRO is not set
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
CONFIG_IPV6=y
# CONFIG_IPV6_PRIVACY is not set
# CONFIG_IPV6_ROUTER_PREF is not set
# CONFIG_INET6_AH is not set
# CONFIG_INET6_ESP is not set
# CONFIG_INET6_IPCOMP is not set
# CONFIG_INET6_XFRM_TUNNEL is not set
# CONFIG_INET6_TUNNEL is not set
CONFIG_INET6_XFRM_MODE_TRANSPORT=y
CONFIG_INET6_XFRM_MODE_TUNNEL=y
CONFIG_INET6_XFRM_MODE_BEET=y
CONFIG_IPV6_SIT=y
# CONFIG_IPV6_TUNNEL is not set
# CONFIG_NETWORK_SECMARK is not set
# CONFIG_NETFILTER is not set
CONFIG_BRIDGE=y
CONFIG_VLAN_8021Q=y
CONFIG_DECNET=y
CONFIG_LLC=y
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_NET_SCHED is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_HAMRADIO is not set
# CONFIG_IRDA is not set
# CONFIG_BT is not set
# Wireless
CONFIG_CFG80211=y
CONFIG_NL80211=y
CONFIG_WIRELESS_EXT=y
CONFIG_IEEE80211=y
CONFIG_IEEE80211_DEBUG=y
CONFIG_IEEE80211_CRYPT_WEP=y
CONFIG_IEEE80211_CRYPT_CCMP=y
CONFIG_IEEE80211_CRYPT_TKIP=y
# CONFIG_RFKILL is not set
# Device Drivers
# Generic Driver Options
CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
# CONFIG_FW_LOADER is not set
# CONFIG_SYS_HYPERVISOR is not set
# CONFIG_CONNECTOR is not set
# CONFIG_MTD is not set
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_FD is not set
# CONFIG_BLK_DEV_COW_COMMON is not set
# CONFIG_BLK_DEV_LOOP is not set
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
CONFIG_MISC_DEVICES=y
# CONFIG_EEPROM_93CX6 is not set
# CONFIG_IDE is not set
# SCSI device support
# CONFIG_RAID_ATTRS is not set
# CONFIG_SCSI is not set
# CONFIG_SCSI_DMA is not set
# CONFIG_SCSI_NETLINK is not set
# CONFIG_ATA is not set
# CONFIG_MD is not set
# CONFIG_MACINTOSH_DRIVERS is not set
# CONFIG_NETDEVICES is not set
# CONFIG_ISDN is not set
# CONFIG_PHONE is not set
# Input device support
CONFIG_INPUT=y
# CONFIG_INPUT_FF_MEMLESS is not set
# CONFIG_INPUT_POLLDEV is not set
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
# CONFIG_INPUT_JOYDEV is not set
# CONFIG_INPUT_EVDEV is not set
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=y
CONFIG_MOUSE_PS2_ALPS=y
CONFIG_MOUSE_PS2_LOGIPS2PP=y
CONFIG_MOUSE_PS2_SYNAPTICS=y
CONFIG_MOUSE_PS2_LIFEBOOK=y
CONFIG_MOUSE_PS2_TRACKPOINT=y
# CONFIG_MOUSE_PS2_TOUCHKIT is not set
# CONFIG_MOUSE_SERIAL is not set
# CONFIG_MOUSE_VSXXXAA is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
# CONFIG_INPUT_MISC is not set
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_I8042=y
CONFIG_SERIO_SERPORT=y
# CONFIG_SERIO_CT82C710 is not set
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_RAW is not set
# CONFIG_GAMEPORT is not set
# Character devices
CONFIG_VT=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
# CONFIG_VT_HW_CONSOLE_BINDING is not set
# CONFIG_SERIAL_NONSTANDARD is not set
# Serial drivers
# CONFIG_SERIAL_8250 is not set
CONFIG_FIX_EARLYCON_MEM=y
# Non-8250 serial port support
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=y
CONFIG_HW_RANDOM_VIA=y
# CONFIG_NVRAM is not set
# CONFIG_RTC is not set
# CONFIG_GEN_RTC is not set
# CONFIG_R3964 is not set
# CONFIG_MWAVE is not set
# CONFIG_PC8736x_GPIO is not set
# CONFIG_NSC_GPIO is not set
# CONFIG_CS5535_GPIO is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_HANGCHECK_TIMER is not set
# CONFIG_I2C is not set
# SPI support
# CONFIG_SPI is not set
# CONFIG_SPI_MASTER is not set
# CONFIG_W1 is not set
# CONFIG_POWER_SUPPLY is not set
CONFIG_HWMON=y
# CONFIG_HWMON_VID is not set
# CONFIG_SENSORS_IT87 is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_W83627HF is not set
# CONFIG_SENSORS_W83627EHF is not set
# CONFIG_SENSORS_HDAPS is not set
# CONFIG_SENSORS_APPLESMC is not set
# CONFIG_HWMON_DEBUG_CHIP is not set
# CONFIG_WATCHDOG is not set
# Sonics Silicon Backplane
CONFIG_SSB_POSSIBLE=y
# CONFIG_SSB is not set
# Multifunction device drivers
# CONFIG_MFD_SM501 is not set
# Multimedia devices
# CONFIG_VIDEO_DEV is not set
# CONFIG_DVB_CORE is not set
CONFIG_DAB=y
# Graphics support
# CONFIG_VGASTATE is not set
# CONFIG_VIDEO_OUTPUT_CONTROL is not set
# CONFIG_FB is not set
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# Display device support
# CONFIG_DISPLAY_SUPPORT is not set
# Console display driver support
CONFIG_VGA_CONSOLE=y
# CONFIG_VGACON_SOFT_SCROLLBACK is not set
# CONFIG_VIDEO_SELECT is not set
CONFIG_DUMMY_CONSOLE=y
# Sound
CONFIG_SOUND=y
# Advanced Linux Sound Architecture
# CONFIG_SND is not set
# Open Sound System
# CONFIG_SOUND_PRIME is not set
CONFIG_HID_SUPPORT=y
CONFIG_HID=y
CONFIG_HID_DEBUG=y
# CONFIG_HIDRAW is not set
CONFIG_USB_SUPPORT=y
# CONFIG_USB_ARCH_HAS_HCD is not set
# CONFIG_USB_ARCH_HAS_OHCI is not set
# CONFIG_USB_ARCH_HAS_EHCI is not set
# NOTE: USB_STORAGE enables SCSI, and 'SCSI disk support'
# USB Gadget Support
# CONFIG_USB_GADGET is not set
# CONFIG_MMC is not set
# CONFIG_NEW_LEDS is not set
# CONFIG_RTC_CLASS is not set
CONFIG_VIRTUALIZATION=y
# Userspace I/O
# CONFIG_UIO is not set
# Firmware Drivers
# CONFIG_EDD is not set
# CONFIG_DELL_RBU is not set
# CONFIG_DCDBAS is not set
CONFIG_DMIID=y
# File systems
# CONFIG_EXT2_FS is not set
# CONFIG_EXT3_FS is not set
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_FS_POSIX_ACL is not set
# CONFIG_XFS_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_ROMFS_FS is not set
CONFIG_INOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_QUOTA is not set
CONFIG_DNOTIFY=y
# CONFIG_AUTOFS_FS is not set
# CONFIG_AUTOFS4_FS is not set
# CONFIG_FUSE_FS is not set
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
# CONFIG_MSDOS_FS is not set
# CONFIG_VFAT_FS is not set
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
# CONFIG_PROC_KCORE is not set
CONFIG_PROC_SYSCTL=y
CONFIG_SYSFS=y
# CONFIG_TMPFS is not set
# CONFIG_HUGETLBFS is not set
# CONFIG_HUGETLB_PAGE is not set
# Miscellaneous filesystems
# CONFIG_HFSPLUS_FS is not set
# CONFIG_CRAMFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
# CONFIG_NFS_FS is not set
# CONFIG_NFSD is not set
# CONFIG_SMB_FS is not set
# CONFIG_CIFS is not set
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
# CONFIG_NLS is not set
CONFIG_INSTRUMENTATION=y
# CONFIG_PROFILING is not set
# CONFIG_KPROBES is not set
# CONFIG_MARKERS is not set
# Kernel hacking
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
# CONFIG_PRINTK_TIME is not set
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
# CONFIG_MAGIC_SYSRQ is not set
CONFIG_UNUSED_SYMBOLS=y
# CONFIG_DEBUG_FS is not set
# CONFIG_HEADERS_CHECK is not set
# CONFIG_DEBUG_KERNEL is not set
# CONFIG_SLUB_DEBUG_ON is not set
CONFIG_DEBUG_BUGVERBOSE=y
# CONFIG_SAMPLES is not set
CONFIG_EARLY_PRINTK=y
CONFIG_DOUBLEFAULT=y
# Security options
# CONFIG_KEYS is not set
# CONFIG_SECURITY is not set
CONFIG_CRYPTO=y
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_MANAGER=y
# CONFIG_CRYPTO_HMAC is not set
# CONFIG_CRYPTO_NULL is not set
# CONFIG_CRYPTO_MD4 is not set
# CONFIG_CRYPTO_MD5 is not set
# CONFIG_CRYPTO_SHA1 is not set
# CONFIG_CRYPTO_SHA256 is not set
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_WP512 is not set
# CONFIG_CRYPTO_TGR192 is not set
CONFIG_CRYPTO_ECB=y
# CONFIG_CRYPTO_CBC is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_DES is not set
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_TWOFISH is not set
# CONFIG_CRYPTO_TWOFISH_586 is not set
# CONFIG_CRYPTO_SERPENT is not set
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_AES_586 is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
# CONFIG_CRYPTO_TEA is not set
CONFIG_CRYPTO_ARC4=y
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_ANUBIS is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_DEFLATE is not set
CONFIG_CRYPTO_MICHAEL_MIC=y
# CONFIG_CRYPTO_CRC32C is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_TEST is not set
# CONFIG_CRYPTO_AUTHENC is not set
CONFIG_CRYPTO_HW=y
# CONFIG_CRYPTO_DEV_PADLOCK is not set
# Library routines
CONFIG_BITREVERSE=y
# CONFIG_CRC_CCITT is not set
# CONFIG_CRC16 is not set
# CONFIG_CRC_ITU_T is not set
CONFIG_CRC32=y
# CONFIG_CRC7 is not set
# CONFIG_LIBCRC32C is not set
CONFIG_PLIST=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT=y
CONFIG_HAS_DMA=y
Ultima modifica di lcostantino il sab 2 feb 2008, 20:35, modificato 1 volta in totale.
aiutoooooo!!!
ho un problema da novellino!
mi trovo a dover installare questa stessa chiavetta su ubuntu 7.10 ma arrivato a "commentare" con //la riga 31 del file specificato non so come andare avanti??
aiutatemi vi prego! non capisco cosa vuol dire selezionare il makefile e come continuare...
grazie a tutti!
grazie a tutti!
lcostantino
- Slackware: 11
Standard Makefile its fine, when you move Makefile.26 to Makefile , dispatch.o must be removed from OBJS !!!
I attached a newer version with fixed Makefile, and the changes to compile on 2.6.24. I also removed the README files, cause forum allowed only 256kb, so you can take it from the .tgz you already have on your pc.
This one, have only 1 Makefile for 2.6.24, just:
#cd hal_142_o_rxart-2624/linux
#make
In 2.6.24 you will get lot of warnings coming from original code ( the winbond original included linux/windows code ).
So, download this attach and test. As i said , compiled fine on 2.6.24(slack) on my pc, but i was not able to test if its working or not since i dont have this card anymore. I can assure its working on 2.6.22.2, thats the enviroment where we tested it at that moment.
Good luck!
#make
Good luck!
hal_142_o_rxart_2624.tar.bz2- (254.43 KiB) Scaricato 226 volte
tnx costa!!! now, can i ask you how can i continue for the installation? it doesn't start in plug in...
lcostantino
- Slackware: 11
i sent you a pm, i will be on msn for a little while, add me if you want, or wait until i post a better guide
now my system is everytime in crack... the usb wireless is working but when i try to connect it.... CRACK!
I don't know why...
I don't know why...
lcostantino
- Slackware: 11
http://code.google.com/p/winbondport/
I will post updates there, and you can submit bugs and that things.
What do you mean by "crack"? i dont understand
Anyway, you can check this newer version on that site
with crack i means that pc go in complete stop. mouse, keypad... i've just to reset!
tnx
tnx
i get the files... how does i've to install them??
tnx a lot!
tnx a lot!
- Luci0
Re:
@nooiLuci0 ha scritto:@xxhp
ok correggo ma il succo del discorso non cambia ... tanto lavoro per nulla ... ma meritil ha detto che con collegamento un Ad-Hoc c'era riuscito e allora visto l' interesse mi sono cimentato anch'io ... e questi sono i risultati ... (per ora scarsi )
Ciao e grazie della collaborazione ...
EDIT !!
Ho provato con una Fedora Core 3 kernel 2.6.9 il modulo compila si installa e iwlist wlan0 scan funziona e le informazioni sugli accesspoint vengono visualizzate correttamente ... in compenso quando provo ad associarmi ad un access point aperto ... il PC si freeza !!!
Ottimi driver davvero .... complimenti !!! ... li ha scritti topo gigio ??
Qualche tempo fa avevo testato il driver con altri kernel ed il risultato é stato simile al tuo ... un bel freeze !! inoltre il termine crack in informatica é una patch per sproteggere un software, forse intendevi dire, crash ma credo che si sia trattato di freeze .... credo che quando parte il dispositivo USB ci sia un assorbimento di corrente anomalo che blocca l' interfaccia USB della mainbord forse mettendo un HUB USB agganciato ad un alimentatore esterno si riesce ad ottenere qualche informazione in più !!
@lcostantino
I think that the driver even if compile ... is buggy ...
nooi get a crash or a freeze (not crack .. I think so !) if you read a my post I wrote ..
THE LINUX DRIVER WINBOND WLAN USB ADAPTER 18e8:6201 DON'T WORK AT ALL ...
thank you for all the work... Ciao
so i can not do nothing? i can not use this wireless adapter on ubuntu??
