ATI proprietary drivers. Ecco uno SlackBuild !!!
ekxius
Slackware: 12.0
Kernel: 2.6.23.12
Desktop: KDE 3.5.9
Messaggio da ekxius »
allora spina ho provato e ti posto l'output in ogni caso perchè non ho ben capito se è andato tutto bene o no. scusami per la lunghezza:
root@slackware:/tmp# sh ati-driver-installer-8.35.5-x86.x86_64.run --buildpkg custom-package/Slackware
Created directory fglrx-install.wbzFCX
Verifying archive integrity... All good.
Uncompressing ATI Proprietary Linux Driver-8.35.5.......................................................................................
 ATI Technologies Linux Driver Installer/Packager
Generating package: custom-package/Slackware
Warning no patch for driver 8.35.5 with kernel 2.4.33.3
If you have any problem write at
        spina80@freemail.it
with subject "ATI Slackware Packager", and posted this output.
ATI module generator V 2.0
initializing...
cleaning...
patching 'highmem.h'...
probing for VMA API version...
Probing for VMAP API version
Use default vmap API
Probing for munmap API version
doing script based build for kernel 2.4.x and similar
compiling './agpgart_be.c'...
compiling './agp3.c'...
compiling './i7505-agp.c'...
compiling './nvidia-agp.c'...
compiling './firegl_public.c'...
In file included from ./drm_proc.h:41,
                 from ./firegl_public.c:357:
./drmP.h:126:1: warning: "DRM_DEBUG_CODE" redefined
./firegl_public.c:177:1: warning: this is the location of the previous definition
./firegl_public.c:475: warning: initialization from incompatible pointer type
./firegl_public.c:3336: warning: initialization from incompatible pointer type
linking of fglrx kernel module...
duplicating results into driver repository...
done.
You must change your working directory to /tmp/fglrx-install.wbzFCX/common/lib/modules/fglrx
and then call ./make_install.sh in order to install the built module.
Slackware package maker, version 2.1.
Searching for symbolic links:
No symbolic links were found, so we won't make an installation script.
You can make your own later in ./install/doinst.sh and rebuild the
package if you like.
This next step is optional - you can set the directories in your package
to some sane permissions. If any of the directories in your package have
special permissions, then DO NOT reset them here!
Would you like to reset all directory permissions to 755 (drwxr-xr-x) and
directory ownerships to root.root ([y]es, [n]o)? n
Creating tar file fglrx-module-8.35.5-i686-1.tar...
install/
install/doinst.sh
install/slack-desc
lib/
lib/modules/
lib/modules/2.4.33.3/
lib/modules/2.4.33.3/external/
lib/modules/2.4.33.3/external/fglrx.o.gz
tar-1.13: fglrx-module-8.35.5-i686-1.tar is the archive; not dumped
Gzipping fglrx-module-8.35.5-i686-1.tar...
Renaming fglrx-module-8.35.5-i686-1.tar.gz to fglrx-module-8.35.5-i686-1.tgz...
Package creation complete.
which: no X in (/usr/local/sbin:/usr/local/bin:/sbin:/usr/sbin:/bin:/usr/bin)
mv: impossibile fare stat di `/tmp/fglrx-install.wbzFCX/arch/i686/usr/*': No such file or directory
Creating tar file fglrx-8.35.5-i686-1.x690.tar...
install/
install/doinst.sh
install/slack-desc
usr/
usr/X11R6/
usr/X11R6/include/
usr/X11R6/include/X11/
usr/X11R6/include/X11/extensions/
usr/X11R6/include/X11/extensions/fglrx_gamma.h
usr/X11R6/lib/
usr/X11R6/lib/modules/
usr/X11R6/lib/modules/drivers/
usr/X11R6/lib/modules/drivers/fglrx_drv.so
usr/X11R6/lib/modules/linux/
usr/X11R6/lib/modules/linux/libfglrxdrm.so
usr/X11R6/bin/
usr/X11R6/bin/fireglcontrolpanel
usr/include/
usr/include/GL/
usr/include/GL/glxATI.h
usr/include/GL/glATI.h
usr/sbin/
usr/sbin/atigetsysteminfo.sh
usr/share/
usr/share/doc/
usr/share/doc/fglrx/
usr/share/doc/fglrx/user-manual/
usr/share/doc/fglrx/user-manual/index.html
usr/share/doc/fglrx/release-notes/
usr/share/doc/fglrx/release-notes/images/
usr/share/doc/fglrx/release-notes/images/backgrnd.gif
usr/share/doc/fglrx/release-notes/images/caution.gif
usr/share/doc/fglrx/release-notes/images/clipbrd.gif
usr/share/doc/fglrx/release-notes/images/linux_10.gif
usr/share/doc/fglrx/release-notes/images/linux_82.gif
usr/share/doc/fglrx/release-notes/images/linux_83.gif
usr/share/doc/fglrx/release-notes/images/linux_84.gif
usr/share/doc/fglrx/release-notes/images/linux_85.gif
usr/share/doc/fglrx/release-notes/images/linux_86.gif
usr/share/doc/fglrx/release-notes/images/linux_87.gif
usr/share/doc/fglrx/release-notes/images/linux_88.gif
usr/share/doc/fglrx/release-notes/images/linux_89.gif
usr/share/doc/fglrx/release-notes/images/linux_8a.gif
usr/share/doc/fglrx/release-notes/images/noboarder.gif
usr/share/doc/fglrx/release-notes/index.html
usr/share/doc/fglrx/driverfaq.html
usr/share/doc/fglrx/index.html
usr/share/doc/fglrx/linuxfaq.html
usr/share/doc/fglrx/tips-linux.html
usr/share/doc/fglrx/issues.html
usr/share/doc/fglrx/ATI_LICENSE.TXT
usr/share/doc/fglrx/configure.html
usr/share/doc/fglrx/installer.html
usr/share/doc/fglrx/articles/
usr/share/doc/fglrx/articles/1gbhang.html
usr/share/doc/fglrx/articles/4461.html
usr/share/doc/fglrx/articles/4462.html
usr/share/doc/fglrx/articles/4463.html
usr/share/doc/fglrx/articles/4464.html
usr/share/doc/fglrx/articles/4469.html
usr/share/doc/fglrx/articles/4470.html
usr/share/doc/fglrx/articles/4475.html
usr/share/doc/fglrx/articles/4478.html
usr/share/doc/fglrx/articles/4479.html
usr/share/doc/fglrx/articles/4480.html
usr/share/doc/fglrx/articles/4481.html
usr/share/doc/fglrx/articles/4482.html
usr/share/doc/fglrx/articles/4483.html
usr/share/doc/fglrx/articles/4484.html
usr/share/doc/fglrx/articles/4485.html
usr/share/doc/fglrx/articles/corruptstereo.html
usr/share/doc/fglrx/articles/corruptvtswitch.html
usr/share/doc/fglrx/articles/devshm.html
usr/share/doc/fglrx/articles/dga3dhang.html
usr/share/doc/fglrx/articles/doom3corrupt.html
usr/share/doc/fglrx/articles/dualheadvideo.html
usr/share/doc/fglrx/articles/laptopsuspend.html
usr/share/doc/fglrx/articles/missingdrmheaders.html
usr/share/doc/fglrx/articles/mousecursorhang.html
usr/share/doc/fglrx/articles/no3d-aiw8500dv.html
usr/share/doc/fglrx/articles/no3d-kt400.html
usr/share/doc/fglrx/articles/nomembercount.html
usr/share/doc/fglrx/articles/pcie3dmemoryleak.html
usr/share/doc/fglrx/articles/r420blankdisplay.html
usr/share/doc/fglrx/articles/rv280dviblankdisplay.html
usr/share/doc/fglrx/articles/rv350springdale.html
usr/share/doc/fglrx/articles/secondheadcorruption.html
usr/share/doc/fglrx/articles/xf86_enodev.html
usr/share/doc/fglrx/articles/xrestartpcie.html
usr/share/doc/fglrx/articles/xvsatshift.html
usr/share/doc/fglrx/examples/
usr/share/doc/fglrx/examples/etc/
usr/share/doc/fglrx/examples/etc/acpi/
usr/share/doc/fglrx/examples/etc/acpi/ati-powermode.sh
usr/share/doc/fglrx/examples/etc/acpi/events/
usr/share/doc/fglrx/examples/etc/acpi/events/a-ac-aticonfig
usr/share/doc/fglrx/examples/etc/acpi/events/a-lid-aticonfig
usr/share/doc/fglrx/examples/etc/init.d/
usr/share/doc/fglrx/examples/etc/init.d/atieventsd.sh
usr/share/doc/fglrx/LICENSE.expat
usr/share/doc/fglrx/LICENSE.xmlconfig
usr/share/doc/fglrx/LICENSE.GPL
usr/share/doc/fglrx/LICENSE.QPL
usr/share/man/
usr/share/man/man8/
usr/share/man/man8/atieventsd.8.gz
usr/share/gnome/
usr/share/gnome/apps/
usr/share/gnome/apps/amdcccle.desktop
usr/share/icons/
usr/share/icons/ccc_small.xpm
usr/share/icons/ccc_large.xpm
usr/share/ati/
usr/share/ati/amdcccle/
usr/share/ati/amdcccle/amdcccle_ar_EG.qm
usr/share/ati/amdcccle/amdcccle_cs.qm
usr/share/ati/amdcccle/amdcccle_da_DK.qm
usr/share/ati/amdcccle/amdcccle_de.qm
usr/share/ati/amdcccle/amdcccle_el_GR.qm
usr/share/ati/amdcccle/amdcccle_es_ES.qm
usr/share/ati/amdcccle/amdcccle_fi_FI.qm
usr/share/ati/amdcccle/amdcccle_fr_FR.qm
usr/share/ati/amdcccle/amdcccle_he.qm
usr/share/ati/amdcccle/amdcccle_hu_HU.qm
usr/share/ati/amdcccle/amdcccle_it_IT.qm
usr/share/ati/amdcccle/amdcccle_ja.qm
usr/share/ati/amdcccle/amdcccle_ko_KR.qm
usr/share/ati/amdcccle/amdcccle_nl_NL.qm
usr/share/ati/amdcccle/amdcccle_no.qm
usr/share/ati/amdcccle/amdcccle_pl.qm
usr/share/ati/amdcccle/amdcccle_pt_BR.qm
usr/share/ati/amdcccle/amdcccle_ru_RU.qm
usr/share/ati/amdcccle/amdcccle_sv_SE.qm
usr/share/ati/amdcccle/amdcccle_th.qm
usr/share/ati/amdcccle/amdcccle_tr_TR.qm
usr/share/ati/amdcccle/amdcccle_zh_CN.qm
usr/share/ati/amdcccle/amdcccle_zh_TW.qm
usr/src/
usr/src/ati/
usr/src/ati/fglrx_panel_sources.tgz
usr/src/ati/fglrx_sample_source.tgz
usr/opt/
usr/opt/kde3/
usr/opt/kde3/share/
usr/opt/kde3/share/applnk/
usr/opt/kde3/share/applnk/amdcccle_kde3.desktop
tar-1.13: fglrx-8.35.5-i686-1.x690.tar is the archive; not dumped
Gzipping fglrx-8.35.5-i686-1.x690.tar...
Renaming fglrx-8.35.5-i686-1.x690.tar.gz to fglrx-8.35.5-i686-1.x690.tgz...
Removing temporary directory: fglrx-install.wbzFCX
spero queste info ti possano essere utili:
Driver ATI: 8.35.5
Versione X: 6.9.0
Kernel: bareacpi.i 2.4.33.3 precompilato
Scheda video: ATI Mobility Radeon 9700 - 128 MB VRAM
Architettura: i686 Pentium IV - 32 bit
i due pacchetti sono stati comunque creati correttamente.
Ciao e grazie
ekxius ha scritto:...non ho ben capito se è andato tutto bene o no. scusami per la lunghezza:
Sisi, è andato tutto mooolto bene. L'importante è che crei i pacchetti. Se li crea vuol dire che è andato tutto a posto. Se hai notato c'è un avviso iniziale, questo perchè non ci sono patch da applicare per il tuo kernel inquanto sembra che i driver funzionino senza bisogno di patch. comunque, il modulo del kernel è stato creato bene.
Grazie mille ekxius!!! E grazie anche per le info sull'architettura e tutto il resto.
Spina
#edit: Ora che ho rivisto meglio l'output ho notato che non ha trovato il tipo di server X. Devo modificare ancora....ti mancano i programmi specifici per il tuo server X nel pacchetto fglrx-8.35.5-i686-1.x690.tar.gz. comunque grazie al tuo feedback posso risolvere il problema in due secondi, grazie ;).
ekxius
Slackware: 12.0
Kernel: 2.6.23.12
Desktop: KDE 3.5.9
Spina
ma grazie a te che ti sbatti.
io spero col tuo aiuto di far andare sti maledetti driver perchè con quelli del kernel ho problemi. con X 6.9 mi parte la ventola della GPU al massimo mentre con X 6.8 non mi succedeva.
mi chiarisci le differenze tra i due pacchetti creati? e poi una volta installati se bisogna fare delle operazioni particolari?
grazie e buon lavoro
ciao 8)
ekxius ha scritto:....mi chiarisci le differenze tra i due pacchetti creati? e poi una volta installati se bisogna fare delle operazioni particolari?
In ordine. I pacchetti sono due per un motivo molto semplice. Il primo pacchetto riguarda la compilazione del modulo per il kernel, mentre il secondo è strettamente privato al server X. I due pacchetti possono anche essere generati separatamente invocando l'installer ATI con i seguenti parametri:
--custom-package/Slack_Module
per generare solo il pacchetto per il modulo del kernel e
--custom-package/Slack_X
per generare il pacchetto per il server X.
Questo vuol dire che, se ad esempio uno si modifica il kernel, non ha bisogno di rigenerare il pacchetto per il server X, basta che si ricrei quello per il kernel. E questo ragionamento vale anche per il server X, se uno cambia server non ha bisogna di rigenerare il pacchetto per il modulo del kernel, basta che faccia quello di X.
Quando installi il pacchetto per il modulo del server non bisogna fare niente di particolare, le dipendenze vengono automaticamente create dallo script associato al pacchetto, che si limita a lanciare
depmod
Quando installi invece il pacchetto per X, dovresti configurare anche il server X in modo che usi il driver appena installato. Nello script di post-installazione, in accordo con @lennynero ho messo semplicemente un avviso di cosa bisogna fare senza modificare nulla. L'idea di modificare file esterni al pacchetto non ci è piaciuta. comunque la cosa da fare è relativamente facile, basta usare lo script della ATI
aticonfig
che viene installato con il pacchetto stesso.
Ma veniamo a noi. Ti ho detto che stamani mi sono accorto che non ti andava bene la creazione del pacchetto per X. I problemi erano i seguenti:
Il primo deriva dal fatto che il mio utente root ha un PATH "diverso" da quello standard della slackware, sicché a me funzionava mentre a te no.
Il secondo invece (il mv) deriva dal fatto che mi sono fidato della rilevazione dell'architettura fatta da uno script della ATI. In effetti rileva la tua architettura come una i686 solo che poi all'interno dell'installer ha solo due directory, una x86 e l'altra x86_64. A me funziona, avendo un architettura x86_64, mentre a te non funziona perchè cerca nella directory i686 invece di x86.
Entrambi i bug sono stati sistemati nel nuovo pacchetto:
http://www.cli.di.unipi.it/~tomasi/ati- ... arch-1.tgz
Mi faresti la cortesia di provarlo e di postare l'output?
Spina
Ultima modifica di targzeta il mar 5 giu 2007, 2:33, modificato 1 volta in totale.
ekxius
Slackware: 12.0
Kernel: 2.6.23.12
Desktop: KDE 3.5.9
Created directory fglrx-install.DFvutx
        spina80@freemail.it
initializing...
cleaning...
done.
You must change your working directory to /tmp/fglrx-install.DFvutx/common/lib/modules/fglrx
Creating tar file fglrx-module-8.35.5-x86-1.tar...
install/
install/doinst.sh
install/slack-desc
lib/
lib/modules/
tar-1.13: fglrx-module-8.35.5-x86-1.tar is the archive; not dumped
Gzipping fglrx-module-8.35.5-x86-1.tar...
Renaming fglrx-module-8.35.5-x86-1.tar.gz to fglrx-module-8.35.5-x86-1.tgz...
usr/X11R6/lib/libGL.so.1 -> libGL.so.1.2
usr/X11R6/lib/libfglrx_dm.so.1 -> libfglrx_dm.so.1.0
usr/X11R6/lib/libfglrx_gamma.so.1 -> libfglrx_gamma.so.1.0
usr/X11R6/lib/libfglrx_pp.so.1 -> libfglrx_pp.so.1.0
usr/X11R6/lib/libfglrx_tvout.so.1 -> libfglrx_tvout.so.1.0
Making symbolic link creation script:
( cd usr/X11R6/lib ; rm -rf libGL.so.1 )
( cd usr/X11R6/lib ; ln -sf libGL.so.1.2 libGL.so.1 )
( cd usr/X11R6/lib ; rm -rf libfglrx_dm.so.1 )
( cd usr/X11R6/lib ; ln -sf libfglrx_dm.so.1.0 libfglrx_dm.so.1 )
( cd usr/X11R6/lib ; rm -rf libfglrx_gamma.so.1 )
( cd usr/X11R6/lib ; ln -sf libfglrx_gamma.so.1.0 libfglrx_gamma.so.1 )
( cd usr/X11R6/lib ; rm -rf libfglrx_pp.so.1 )
( cd usr/X11R6/lib ; ln -sf libfglrx_pp.so.1.0 libfglrx_pp.so.1 )
( cd usr/X11R6/lib ; rm -rf libfglrx_tvout.so.1 )
( cd usr/X11R6/lib ; ln -sf libfglrx_tvout.so.1.0 libfglrx_tvout.so.1 )
Unless your existing installation script already contains the code
to create these links, you should append these lines to your existing
install script. Now's your chance. :^)
Would you like to add this stuff to the existing install script and
remove the symbolic links ([y]es, [n]o)? y
Removing symbolic links:
`./usr/X11R6/lib/libGL.so.1' rimosso
`./usr/X11R6/lib/libfglrx_dm.so.1' rimosso
`./usr/X11R6/lib/libfglrx_gamma.so.1' rimosso
`./usr/X11R6/lib/libfglrx_pp.so.1' rimosso
`./usr/X11R6/lib/libfglrx_tvout.so.1' rimosso
Updating your ./install/doinst.sh...
Creating tar file fglrx-8.35.5-x86-1.x690.tar...
install/
install/doinst.sh
install/slack-desc
usr/
usr/X11R6/
usr/X11R6/lib/
usr/X11R6/lib/libfglrx_tvout.a
usr/X11R6/lib/libfglrx_tvout.so.1.0
usr/X11R6/lib/libfglrx_gamma.a
usr/X11R6/lib/libfglrx_gamma.so.1.0
usr/X11R6/lib/libfglrx_pp.a
usr/X11R6/lib/libfglrx_pp.so.1.0
usr/X11R6/lib/libfglrx_dm.a
usr/X11R6/lib/libfglrx_dm.so.1.0
usr/X11R6/lib/libGL.so.1.2
usr/X11R6/lib/modules/dri/
usr/X11R6/lib/modules/dri/fglrx_dri.so
usr/X11R6/bin/
usr/X11R6/bin/fglrx_xgamma
usr/X11R6/bin/aticonfig
usr/X11R6/bin/fglrxinfo
usr/X11R6/bin/fgl_glxgears
usr/X11R6/bin/amdcccle
usr/X11R6/include/
usr/sbin/
usr/sbin/atieventsd
usr/include/
usr/include/GL/
usr/share/
usr/share/doc/
usr/share/man/
usr/share/man/man8/
usr/share/gnome/
usr/share/icons/
usr/share/ati/
usr/src/
usr/src/ati/
usr/opt/
usr/opt/kde3/
usr/opt/kde3/share/
tar-1.13: fglrx-8.35.5-x86-1.x690.tar is the archive; not dumped
Gzipping fglrx-8.35.5-x86-1.x690.tar...
Renaming fglrx-8.35.5-x86-1.x690.tar.gz to fglrx-8.35.5-x86-1.x690.tgz...
Removing temporary directory: fglrx-install.DFvutx
submax82
Distribuzione: SalixOS
Messaggio da submax82 »
@spina
pignoleria...
lo chiamerei fglrx-x690-8.35.5-x86-1.tgz
questo perchè segue ti più lo schema dell'altro pacchetto
poi dì a Loris se lo mette su slacky...
ekxius
Slackware: 12.0
Kernel: 2.6.23.12
Desktop: KDE 3.5.9
ho riprovato e mi pare che sia andato tutto bene questa volta.
anche se non ho capito quei warning all'inizio :D
comunque appena mi dai l'ok installo e cerco di configurare i driver e ti faccio sapere.
ekxius 8)
submax82 ha scritto:@spina
pignoleria...
Certo segue di più lo schema, il problema è che il suffisso x690 non è statico, il suo si chiama così perchè usa il server Xorg 6.9 ed ha una architettura a 32 bit.
Ora, il package installer della slackware, se non sbaglio, vuole un formato, come nome di pacchetto come il seguente:
nome-versione-architettura-release.tgz
se non trova esattamente questi campi non stampa le info sul pacchetto (il file slack-desc).
Nel caso del modulo, il "nome" è proprio "fglrx-module", e questo viene scritto nel file delle informazioni (lo slack-desc). Se vogliamo una cosa dinamica, allora anche lo slack-desc del pacchetto per X dovrebbe cambiare dinamicamente. Tutto si può fare, ma all'inizio mi sono sbrigato.
In questi giorni vedrò di fare anche questo ;).
Grazie per il suggerimento,
Spina
ekxius ha scritto:ho riprovato e mi pare che sia andato tutto bene questa volta.
ekxius 8)
Ok, sembra che hai tutto ciò che serve, installa i pacchetti e, per qualsiasi problema scrivi pure.
Il warning all'inizio, come tutti warning, uno di solito li ignora :). Il punto è che, dato che nn ho la patch per quel kernel, se qualcosa non va, uno mi scrive.
Spina
LaZyBoY
Messaggio da LaZyBoY »
boh, io ho appena provato: non funzia :(
cioè crea i 2 pacchetti correttamente (almeno credo), e li installo.
aticonfig mi dice command not found.. vabbeh modifico xorg.conf a mano e metto fglrx al posto di vesa. riavvio X e mi dice che nn può caricare il modulo fglrx.
(WW) Warning, couldn't open module fglrx
(II) UnloadModule: "fglrx"
(EE) Failed to load module "fglrx" (module does not exist, 0)
da /var/log/Xorg.0.log
Inoltre non c'è nemmeno il nuovo catalyst control center nei pacchetti creati.. è normale tutto ciò? Se hai bisogno di qualche output :D
LaZyBoY ha scritto:boh, io ho appena provato: non funzia :(
Si si, mandami l'output della creazione, o con un messaggio privato, o all'indirizzo spina80@freemail.it
Se non trova aticonfig vuol dire che qualche cosa non è andato correttamente, stesso vale per il modulo fglrx.
Grazie mille anche a te LaZyBoY.
Spina
LaZyBoY
hai posta :D
LaZyBoY ha scritto:hai posta :D
Anche tu :).
Ti ho scritto il motivo per cui non andava. Ma sei sicuro di aver usato l'ultimo tool? l'1.0.4? sembra che hai gli stessi problemi che aveva ekxius.
Confermami la versione, intanto, come ti ho scritto, vedo di rinominare il pacchetto secondo quanto detto con submax82.
Spina
Io ho fatto ciò che si è detto con submax82. Aggiornato alla versione 1.0.5 che trovate ovviamente all'indirizzo:
ho messo dei link alle versioni precedenti in modo che tutte puntano allo stesso file. Così quando scaricate, qualunque versione scarichiate, scaricate sempre l'ultima.
Ah, ho provato anche il Catalyst Control Center. Oh, a me funziona tutto bene. Voi datemi feedback, voglio che chiunque sia costretto ad usare i driver proprietari ATI sotto la Slackware e altre porting simili (Slamd64 etc..), lo possa fare nel modo più semplice possibile.
Spina
Ultima modifica di targzeta il mar 5 giu 2007, 2:34, modificato 1 volta in totale.
ekxius
Slackware: 12.0
Kernel: 2.6.23.12
Desktop: KDE 3.5.9
spina ho installato i pacchetti e ho lanciato il comando
aticonfig --initial
solo che se do startx non si avvia X. ho guardato l'xorg e ci sono sicuramente errori perchè il comando ha fatto casino ( mi ha messo 2 screen, 2 driver ecc )
quindi potresti dirmi bene la procedura per configurare i driver? scusa ma non so proprio cosa fare.
ciao ;)
