dove li trovo gli headers per questo kernel???
comunque mi sembrava strano in effetti che si trattava di un pacchetto mancante
mkdir /tmp/kernel-headers/Codice: Seleziona tutto
make headers_install INSTALL_HDR_PATH=/tmp/kernel-headers/Codice: Seleziona tutto
g@darkenergy:~$ grep limits.h /var/log/packages/kernel-headers-2.6.21.5-i386-2
usr/include/linux/limits.h
usr/include/asm-i386/mach-default/irq_vectors_limits.h
usr/include/asm-i386/mach-generic/irq_vectors_limits.h
usr/include/asm-i386/mach-summit/irq_vectors_limits.h
Infine un'ultima cosa il pacchetto creato si chiama così: gwenview-1.4.1-i686-1_darkstar.tgz.............non si può eliminare il nick "darkstar" e lasciare solo con il finale -i686-1.tgz?root@darkstar:/usr/src/linux-2.6.22.5# make headers_install INSTALL_HDR_PATH=/tmp/kernel-headers/
CHK include/linux/version.h
HOSTCC scripts/basic/fixdep
In file included from /usr/include/bits/posix1_lim.h:153,
from /usr/include/limits.h:145,
from /usr/lib/gcc/i486-slackware-linux/4.1.2/include/limits.h:122,
from /usr/lib/gcc/i486-slackware-linux/4.1.2/include/syslimits.h:7,
from /usr/lib/gcc/i486-slackware-linux/4.1.2/include/limits.h:11,
from scripts/basic/fixdep.c:115:
/usr/include/bits/local_lim.h:36:26: error: linux/limits.h: No such file or directory
In file included from /usr/include/sys/socket.h:35,
from /usr/include/netinet/in.h:24,
from /usr/include/arpa/inet.h:23,
from scripts/basic/fixdep.c:117:
/usr/include/bits/socket.h:310:24: error: asm/socket.h: No such file or directory
scripts/basic/fixdep.c: In function 'use_config':
scripts/basic/fixdep.c:206: error: 'PATH_MAX' undeclared (first use in this function)
scripts/basic/fixdep.c:206: error: (Each undeclared identifier is reported only once
scripts/basic/fixdep.c:206: error: for each function it appears in.)
scripts/basic/fixdep.c:206: warning: unused variable 's'
scripts/basic/fixdep.c: In function 'parse_dep_file':
scripts/basic/fixdep.c:306: error: 'PATH_MAX' undeclared (first use in this function)
scripts/basic/fixdep.c:306: warning: unused variable 's'
make[1]: *** [scripts/basic/fixdep] Error 1
make: *** [scripts_basic] Error 2
Posta:slucky ha scritto:...
durante la fase di installazione, non mi è uscito sul terminale i messaggi di info del pacchetto, e sebbene io abbia fatto lo slack-desc,
eh già, per installare gli headers, bisogna avere gli headers installatislucky ha scritto:...root@darkstar:/usr/src/linux-2.6.22.5# make headers_install
Si, basta modificare:slucky ha scritto: ...non si può eliminare il nick "darkstar" e lasciare solo con il finale -i686-1.tgz?
conBUILD=${BUILD:-1_`uname -n`}
SpinaBUILD=${BUILD:-1}
