inkscape su 12.2
Re: inkscape su 12.2
inkscape-0.46-i686-4sl (ancora da inserire nel repository)
$ ldd /usr/bin/inkscape
        linux-gate.so.1 =>  (0xffffe000)
        libgtkmm-2.4.so.1 => /usr/X11R6/lib/libgtkmm-2.4.so.1 (0xb7c1f000)
        libgdkmm-2.4.so.1 => /usr/X11R6/lib/libgdkmm-2.4.so.1 (0xb7bda000)
        libatkmm-1.6.so.1 => /usr/X11R6/lib/libatkmm-1.6.so.1 (0xb7b97000)
        libpangomm-1.4.so.1 => /usr/X11R6/lib/libpangomm-1.4.so.1 (0xb7b6d000)
        libcairomm-1.0.so.1 => /usr/X11R6/lib/libcairomm-1.0.so.1 (0xb7b54000)
        libglibmm-2.4.so.1 => /usr/X11R6/lib/libglibmm-2.4.so.1 (0xb7aff000)
        libxslt.so.1 => /usr/X11R6/lib/libxslt.so.1 (0xb7acb000)
        libz.so.1 => /usr/X11R6/lib/libz.so.1 (0xb7ab7000)
        libxml2.so.2 => /usr/X11R6/lib/libxml2.so.2 (0xb799c000)
        libsigc-2.0.so.0 => /usr/X11R6/lib/libsigc-2.0.so.0 (0xb7996000)
        libgtkspell.so.0 => /usr/X11R6/lib/libgtkspell.so.0 (0xb798f000)
        libgtk-x11-2.0.so.0 => /usr/X11R6/lib/libgtk-x11-2.0.so.0 (0xb7629000)
        libgdk-x11-2.0.so.0 => /usr/X11R6/lib/libgdk-x11-2.0.so.0 (0xb75a7000)
        libatk-1.0.so.0 => /usr/X11R6/lib/libatk-1.0.so.0 (0xb758e000)
        libgdk_pixbuf-2.0.so.0 => /usr/X11R6/lib/libgdk_pixbuf-2.0.so.0 (0xb7577000)
        libpangocairo-1.0.so.0 => /usr/X11R6/lib/libpangocairo-1.0.so.0 (0xb756e000)
        libpango-1.0.so.0 => /usr/X11R6/lib/libpango-1.0.so.0 (0xb7531000)
        libcairo.so.2 => /usr/X11R6/lib/libcairo.so.2 (0xb74d1000)
        libgobject-2.0.so.0 => /usr/X11R6/lib/libgobject-2.0.so.0 (0xb7497000)
        libgmodule-2.0.so.0 => /usr/X11R6/lib/libgmodule-2.0.so.0 (0xb7494000)
        libdl.so.2 => /lib/libdl.so.2 (0xb7490000)
        libgthread-2.0.so.0 => /usr/X11R6/lib/libgthread-2.0.so.0 (0xb748b000)
        librt.so.1 => /lib/librt.so.1 (0xb7482000)
        libglib-2.0.so.0 => /usr/X11R6/lib/libglib-2.0.so.0 (0xb73b6000)
        libpng12.so.0 => /usr/X11R6/lib/libpng12.so.0 (0xb737b000)
        libpng.so.3 => /usr/X11R6/lib/libpng.so.3 (0xb7340000)
        libpopt.so.0 => /usr/X11R6/lib/libpopt.so.0 (0xb7339000)
        libXft.so.2 => /usr/X11R6/lib/libXft.so.2 (0xb7326000)
        libXrender.so.1 => /usr/X11R6/lib/libXrender.so.1 (0xb731e000)
        libfontconfig.so.1 => /usr/X11R6/lib/libfontconfig.so.1 (0xb72f5000)
        libfreetype.so.6 => /usr/X11R6/lib/libfreetype.so.6 (0xb7285000)
        libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0xb719e000)
        libpangoft2-1.0.so.0 => /usr/X11R6/lib/libpangoft2-1.0.so.0 (0xb7177000)
        libssl.so.0 => /usr/X11R6/lib/libssl.so.0 (0xb7135000)
        libcrypto.so.0 => /usr/X11R6/lib/libcrypto.so.0 (0xb6ff8000)
        libgc.so.1 => /usr/X11R6/lib/libgc.so.1 (0xb6fb7000)
        liblcms.so.1 => /usr/X11R6/lib/liblcms.so.1 (0xb6f80000)
        libpoppler.so.3 => /usr/X11R6/lib/libpoppler.so.3 (0xb6dde000)
        libpoppler-glib.so.3 => /usr/X11R6/lib/libpoppler-glib.so.3 (0xb6db7000)
        libstdc++.so.6 => /usr/X11R6/lib/libstdc++.so.6 (0xb6cd1000)
        libm.so.6 => /lib/libm.so.6 (0xb6cab000)
        libgcc_s.so.1 => /usr/X11R6/lib/libgcc_s.so.1 (0xb6ca0000)
        libpthread.so.0 => /lib/libpthread.so.0 (0xb6c89000)
        libc.so.6 => /lib/libc.so.6 (0xb6b3d000)
        libenchant.so.1 => /usr/X11R6/lib/libenchant.so.1 (0xb6b33000)
        libXcomposite.so.1 => /usr/X11R6/lib/libXcomposite.so.1 (0xb6b30000)
        libXdamage.so.1 => /usr/X11R6/lib/libXdamage.so.1 (0xb6b2d000)
        libXfixes.so.3 => /usr/X11R6/lib/libXfixes.so.3 (0xb6b28000)
        libXext.so.6 => /usr/X11R6/lib/libXext.so.6 (0xb6b1a000)
        libXinerama.so.1 => /usr/X11R6/lib/libXinerama.so.1 (0xb6b16000)
        libXi.so.6 => /usr/X11R6/lib/libXi.so.6 (0xb6b0e000)
        libXrandr.so.2 => /usr/X11R6/lib/libXrandr.so.2 (0xb6b08000)
        libXcursor.so.1 => /usr/X11R6/lib/libXcursor.so.1 (0xb6aff000)
        libpixman-1.so.0 => /usr/X11R6/lib/libpixman-1.so.0 (0xb6aca000)
        /lib/ld-linux.so.2 (0xb7f64000)
        libexpat.so.1 => /usr/X11R6/lib/libexpat.so.1 (0xb6aa9000)
        libxcb-xlib.so.0 => /usr/X11R6/lib/libxcb-xlib.so.0 (0xb6aa7000)
        libxcb.so.1 => /usr/X11R6/lib/libxcb.so.1 (0xb6a90000)
        libjpeg.so.62 => /usr/X11R6/lib/libjpeg.so.62 (0xb6a70000)
        libXau.so.6 => /usr/X11R6/lib/libXau.so.6 (0xb6a6c000)
        libXdmcp.so.6 => /usr/X11R6/lib/libXdmcp.so.6 (0xb6a67000)
gnome-vfs non ce l'ho nemmeno installato
Ho messo adesso la stable e provato quel che dici, va in segfault
la svn idem
(inkscape:8999): GLib-WARNING **: g_main_loop_run(): called recursively from within a source's check() or prepare() member, iteration not possible.
se trovi come risolvere fammelo sapere
JohnnyMnemonic
Kernel: 3.5.5-thanatos
Messaggio da JohnnyMnemonic »
sya54M ha scritto:nel menu:
Testo >> Testo e carattere...
e poi chiudi la finestra appena aperta
Fatto, niente crash
Fatto, niente crash
L'unica cosa che penso è che tu hai la 3sl che ho compilato sulla 12.2 ma con le dipendenze della 12.1, che sia qualcuna di queste?
Purtroppo non ho più la 3sl per provare
Leggo in giro che si risolve abilitando gnome-vfs, ma così penso che ci voglia un nel po' di pacchetti gnomeschi
Prova a prendere la 4sl dal server ftp di slacky (quello usato dai pacchettizzatori) senza cancellare la 3sl e dimmi se ti va ugualmente
zxzxasas
Nome Cognome: Pasquale
Kernel: 2.6.35.7
Desktop: KDE 4.5.2
Messaggio da zxzxasas »
Scusate, ma le librerie
cairomm => 1.6.4
gc >= 7.1
glibmm >= 2.16.4
gtkmm >= 2.12.7
libsigc++ >= 2.2.3
a queste versioni tanto aggiornate, le trovo da qualche parte in tgz???
Perchè a me con le versioni che stanno attualmente su slacky dice questo:
root@pasquale:/# inkscape
inkscape: error while loading shared libraries: libgsl.so.0: cannot open shared object file: No such file or directory
Ultimo dettaglio che dimenticavo...sto usando il tgz di slackers!
zxzxasas ha scritto:Scusate, ma le librerie
cairomm => 1.6.4
gc >= 7.1
glibmm >= 2.16.4
gtkmm >= 2.12.7
libsigc++ >= 2.2.3
Qui su slacky
http://www.slacky.eu/aadm/pkgs/index.php?ver=6&cat=7
zxzxasas
Kernel: 2.6.35.7
Desktop: KDE 4.5.2
Ancora problema con quella libreria...
Il fatto è che in /usr/lib non esiste nessuna libgsl...
zxzxasas ha scritto:Ancora problema con quella libreria...
installa gsl
Tieni presente che i pacchetti su slackers non tengono conto delle dipendenze, sono segnate solamente nel README, ma spesso me ne sfuggono alcune, devi essere tu a capire cosa serve proprio in base a quegli errori che trovi. Ed i pacchetti sono a volte unstable, come inkscape.
JohnnyMnemonic
conraid ha scritto: Prova a prendere la 4sl dal server ftp di slacky (quello usato dai pacchettizzatori) senza cancellare la 3sl e dimmi se ti va ugualmente
Cosa intendi?
Cioè come faccio a provare la 4sl senza perdere la 3?
Sul computer in cui compilo i pacchetti non ho problemi :-k
ora guardo cosa c'è di diverso, a parte il numero di fonts e relativo tempo di avvio
JohnnyMnemonic
Aggiornato alla 4sl, nessun problema con lo strumento Testo
Ovviamente l'avvio è sempre lentissimo, ma poi funziona bene
sya54M
Nome Cognome: Andrea Peluso
Kernel: ultimo
Messaggio da sya54M »
conraid ha scritto:Leggo in giro che si risolve abilitando gnome-vfs, ma così penso che ci voglia un nel po' di pacchetti gnomeschi
infatti è quello che dicevo io
Però nel computer in cui compilo sto usando lo stesso pacchetto e non ho gnome-vfs
Di diverso c'è il numero di font, per il resto anche ldd da lo stesso risultato
sya54M
Kernel: ultimo
allora inkscape è posseduto da qualche demone?
mbrancalion
Nome Cognome: Marco Brancalion
Slackware: nessuna
Kernel: 2.6.38-11
Desktop: kde 4.6.2
Distribuzione: kubuntu 11.04
Messaggio da mbrancalion »
Io invece stanotte ho provato a compilare inkscape con questo slackbuild:
http://slackbuilds.org/repository/12.2/ ... /inkscape/
che vedo integrare una patch per poppler.
Pero' poi mi e' uscito un errore di compilazione di gtkmm (di cui ho il pacchetto di GSlacky 12.1 installato, e uso ora una slackware 12.2).
Credo dovro' aspettare il pacchetto apposito su slacky.eu ...... ;)
sya54M
Kernel: ultimo
mbrancalion ha scritto:Io invece stanotte ho provato a compilare inkscape con questo slackbuild:
prima leggi i precedenti post e vedi che il problema poppler era già nel primo post del topic e poi per quanto riguarda gtkmm devi aver installato le dipendenze
