...si ci avevo già pensato e difatti confermo che era il plguin ...ora mi chiede qualche altra libreria, che sto provvedendo ad installare.
(<unknown>:8824): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgstsouphttpsrc.so': libsoup-2.4.so.1: cannot open shared object file: No such file or directory
(<unknown>:8824): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgstshout2.so': libshout.so.3: cannot open shared object file: No such file or directory
POST EDIT; E confermo anche l'errore di Gohanz, occorre il pacchetto gst-plugins-bad.
Non solo, ma ora mi chiede anche altre librerie da installare;
micha@darkstar:~$ minitube
(<unknown>:13566): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgstmms.so': libmms.so.0: cannot open shared object file: No such file or directory
(<unknown>:13566): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgsttrm.so': libmusicbrainz.so.4: cannot open shared object file: No such file or directory
(<unknown>:13566): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgstofa.so': libofa.so.0: cannot open shared object file: No such file or directory
(<unknown>:13566): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgstwildmidi.so': libWildMidi.so.0: cannot open shared object file: No such file or directory
(<unknown>:13566): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgstfaad.so': libfaad.so.0: cannot open shared object file: No such file or directory
(<unknown>:13566): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgstmythtvsrc.so': libgmyth.so.0: cannot open shared object file: No such file or directory
Ma adesso devo andare a pranzare. A dopo.
Bye
Ultima modifica di michele.p il mer 5 ago 2009, 13:10, modificato 1 volta in totale.
Ringrazio Corrado per la ricompilazione del pacchetto, ma neanche con quello nuovo riesco a visualizzare qualcosa.
Le dipendenze sono soddisfatte, comunque, lanciando minitube da riga di comando, ottengo questo output:
alutri@mody:~$ minitube
(<unknown>:31815): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgstmpeg2dec.so': libmpeg2.so.0: cannot open shared object file: No such file or directory
(<unknown>:31815): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgstwildmidi.so': libWildMidi.so.0: cannot open shared object file: No such file or directory
(<unknown>:31815): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgst1394.so': libiec61883.so.0: cannot open shared object file: No such file or directory
(<unknown>:31815): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgstsid.so': libsidplay.so.1: cannot open shared object file: No such file or directory
Gstreamer, ovviamente, è installato.
Burroughs.
gohanz ha scritto:Ti mancano le dipendenze di gst-plugins-bad. Controlla ed installa.
Sì, ho installato le dipendenze mancanti (e qualche altra ancora, in verità).
Adesso minitube parte senza segnalarmi errori ma non è in grado di riprodurre alcun contenuto multimediale.
Questo è l'output che mi restituisce quando cerco di riprodurre un video musicale:
<unknown>:5175): GStreamer-WARNING **: Failed to load plugin '/usr/lib/gstreamer-0.10/libgstfaad.so': libfaad.so.0: cannot open shared object file: No such file or directory
Phonon error: "A required codec is missing. You need to install the following codec(s) to play this content: MPEG-4 AAC, H.264" 2
Source changed: QUrl( "http://www.youtube.com/get_video?video_id=5J5GVVz0gjA&t=vjVQa1PpcFNft4JUFnm8b7kfYUkYAL8_ceIz-ddNUPQ=&eurl=&el=embedded&ps=default&fmt=18" )
loading
Burroughs.
