xfce 4.4.1 errore
- submax82
- Desktop: xfce
- Distribuzione: SalixOS
uffa
il paacchetto sembra ok... ma xfce non parte da utente e da root parte ma è "orfano" di xfwm4 oltre che dello sfondo... ufffffff
startxfce4 da root
startxfce4 da utente
startxfce4 da root
/usr/bin/startxfce4: Starting X server
X Window System Version 6.9.0
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 6.9
Build Operating System: Linux 2.4.33.3 i686 [ELF]
Current Operating System: Linux linuxbox 2.6.19.2 #1 Fri Jan 12 00:11:46 CET 2007 i686
Build Date: 16 September 2006
Before reporting problems, check http://wiki.X.Org
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Apr 17 14:30:58 2007
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols
> Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
Could not init font path element /usr/X11R6/lib/X11/fonts/CID/, removing from list!
Agent pid 2450
** Message: Menu Xfce: screen changed: 0
** Message: No valid plug window.
(xfce4-panel:2462): Gtk-CRITICAL **: gtk_socket_get_id: assertion `GTK_WIDGET_ANCHORED (socket)' failed
** (xfce4-panel:2462): CRITICAL **: An item was unexpectedly removed: "Menu Xfce".
** (xfce4-session:2458): WARNING **: xfsm-shutdown-helper.c:134: Failed to contact HAL: A security policy in place prevents this sender from sending this message to this recipient, see message bus configuration file (rejected message had interface "org.freedesktop.Hal.Device.SystemPowerManagement" member "ThisMethodMustNotExistInHal" error name "(unset)" destination "org.freedesktop.Hal")
** Message: xfsm-shutdown-helper.c:215: HAL not available or does not permit to shutdown/reboot the computer, trying sudo fallback instead.
Agent pid 2450 killed
The application 'xfce-mcs-manager' lost its connection to the display :0.0;
most likely the X server was shut down or you killed/destroyed
the application.
waiting for X server to shut down FreeFontPath: FPE "/usr/X11R6/lib/X11/fonts/misc/" refcount is 2, should be 1; fixing.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Apr 17 14:32:22 2007
Agent pid 2500
** (xfwm4:2515): WARNING **: The display does not support the XComposite extension.
** (xfwm4:2515): WARNING **: Compositing manager disabled.
Error: No running window found
/usr/lib/firefox-2.0.0.3/run-mozilla.sh: line 131: 2578 Illegal instruction "$prog" ${1+"$@"}
xscreensaver: 14:33:12: SIGHUP received: restarting...
xscreensaver: 14:33:12: initial effective uid/gid was submax/shadow (1000/43)
xscreensaver: 14:33:12: running as submax/users (1000/100)
(xfwm4:2515): libxfcegui4-WARNING **: ICE I/O Error
(xfwm4:2515): libxfcegui4-WARNING **: Disconnected from session manager.
The application 'xfwm4' lost its connection to the display :0.0;
the application.
Not initializing the Gtk-Qt theme engine
xinit: unexpected signal 1.
** Message: xfsm-shutdown-helper.c:215: HAL not available or does not permit to shutdown/reboot the computer, trying sudo fallback instead. Ma hai aggiunto il tuo user e root al gruppo mounters? Questo se usi pacchetti di Slacky!
- submax82
- Desktop: xfce
SI
ecco il file .xsession-error:
/usr/bin/startxfce4: X server already running on display :0
Agent pid 5877
*** glibc detected *** corrupted double-linked list: 0xb77be878 ***
(xfce4-panel:5889): Gtk-CRITICAL **: gtk_socket_get_id: assertion `GTK_WIDGET_ANCHORED (socket)' failed
** (xfce4-panel:5889): CRITICAL **: An item was unexpectedly removed: "Menu Xfce".
(Terminal:5899): Vte-WARNING **: Can not find appropiate font for character U+4e00.
(Terminal:5899): Vte-WARNING **: Can not find appropiate font for character U+4e8c.
(Terminal:5899): Vte-WARNING **: Can not find appropiate font for character U+4e09.
(Terminal:5899): Vte-WARNING **: Can not find appropiate font for character U+56db.
(Terminal:5899): Vte-WARNING **: Can not find appropiate font for character U+4e94.
(Terminal:5899): Vte-WARNING **: Can not find appropiate font for character U+ac00.
(Terminal:5899): Vte-WARNING **: Can not find appropiate font for character U+ac01.
(Terminal:5899): Vte-WARNING **: Can not find appropiate font for character U+ac04.
(Terminal:5899): Vte-WARNING **: Can not find appropiate font for character U+ac08.
(Terminal:5899): Vte-WARNING **: Can not find appropiate font for character U+ac10.
(Terminal:5899): GLib-GObject-CRITICAL **: g_object_notify_queue_thaw: assertion `nqueue->freeze_count > 0' failed
- submax82
- Desktop: xfce
avevo provato a metterlo prima del configure nella compilazione... ma non và ancora...gohanz ha scritto:Prova a modificare il file /etc/profile.d/glibc.sh aggiungendo export MALLOC_CHECK_=0 e riavvia la shell! sembra che ci sia un problema di corruzione delle glibc
provo a fare come hai detto...
EDIT: infatti NON CAMBIA NULLA
- 6C33C
- Nome Cognome: Giorgio
- Slackware: 15.0 x86_64
- Kernel: 5.15.80
- Desktop: kde 5
Scusate se mi intrometto , premessa io non so nulla o quasi di script però
ho provato lo slackbuild preso dal sito http://rlworkman.net e sembra funzionare.
Ho installato prima tutte le dipendenze vte, dbus , dbus-glib, dbus-qt3, uri, gamin presi da slacky , se si installa anche hal e si configura come per kdebase group ,hal.conf ,udev.rules si riesce a compilare thunar-volman ed avere l'automount.
- submax82
- Desktop: xfce
lo sò già lo conoscevo ... solo che non mi piace come è fatto... il mio slackbuild ha dei vantaggi...6C33C ha scritto:Scusate se mi intrometto , premessa io non so nulla o quasi di script però
spiegami megliosi configura come per kdebase group ,hal.conf ,udev.rules
- 6C33C
- Kernel: 5.15.80
- Desktop: kde 5
Dunque ho fatto la prova 3 volte . Mi serviva xfce con l'automount per un vecchio athlon 1200 .
Sono partito da una installazione di slack 11 pulita ( ho configurato solo la rete e xorg.conf ). Dopidichè ho installato le dipendenze , poi ,
ho aggiunto il gruppo mounters ( addgroup mounters ) ,
modificato hal.conf al punto policy user="0" in policy group="104"
e modificato udev.rules nella riga #RUN+="socket:/org/freedesktop/hal/udev_event" tolgliendo #
avviato messagebus
/etc/rc.d/rc.messagebus start
avviato hal
/etc/rc.d/rc.hald start
riavviato udev
/etc/rc.d/rc.udev restart
ma forse queste cose tu le sapevi già
ho lanciato lo slackbuild , atteso circa 45 minuti installato il tgz
compilato thunar-volman e fatto il pachetto con checkinstall
installato tunar-volman . Finito.
A questo punto avviato x e inserito il pendrive compare l' icona sul destop.
Infine mi scuso per il poema .... ma ho notato che se lanciavo lo slackbuild loggato come root il paccetto generato era completo se invece lo facevo partire da da user (dopo aver dato in console "su e password " )
il tgz era orfano di qualche file vedi dimensioni finali .
Spero di essere stato chiaro ......
avviato messagebus
avviato hal
riavviato udev
Forse perchè devi dare
su -Submax secondo me bisogna ricompilare usando uno SlackBuild separato per ogni componente di XFCE!
Io ho provato con lo SlackBuild classico e poi ho provato ad abilitare l'automount! Usando thunar-volman!
Insomma alla fine sono dovuto rientrare in ogni directory di compilazione, perchè mancavano componenti come i moduli HAL per libexo e altre cose.
Vabbè alla fine Thunar con l'automount funziona, però come te c'è qualche cosa che non va!
Questo è thunar con l'automount abilitato sotto Gnome!
