è un bug conosciuto (googola un po')
io ho fatto un rollback alla 0.9.3 infatti
Problemi con VLC 0.9.3
- Trotto@81
- Nome Cognome: Andrea
- Kernel: default
- Desktop: KDE 4.14.14
Re: Problemi con VLC 0.9.3
Attendiamo ansiosi il fix allora.
slacky82
- Kernel: 2.6.25.4
- Desktop: kde 3.5.10
- Distribuzione: slackware
io invece ho questo problema che non riesco a risolvere!!!
[00000001] main libvlc debug: VLC media player - version 0.9.4 Grishenko - (c) 1996-2008 the VideoLAN team
[00000001] main libvlc debug: libvlc was configured with ./configure '--prefix=/usr' '--libdir=/usr/lib' '--sysconfdir=/etc' '--mandir=/usr/man' '--localstatedir=/var' '--without-contrib' '--disable-rpath' '--disable-debug' '--disable-testsuite' '--disable-static' '--enable-shared' '--enable-release' '--enable-optimize-memory=no' '--enable-qt4' '--disable-arts' '--enable-esd' '--disable-gnomevfs' '--enable-pvr' '--disable-dv' '--enable-dvbpsi' '--enable-dvdnav' '--with-dvdnav-config-path=/mnt/hd/tmp-vlc/vlcdeps/usr/bin' '--enable-libcdio' '--enable-cddax' '--enable-vcdx' '--enable-libcddb' '--enable-svg' '--enable-svgalib' '--enable-telx' '--disable-zvbi' '--disable-snapshot' '--disable-musicbrainz' '--enable-libass' '--enable-v4l' '--enable-caca' '--enable-aa' '--enable-galaktos' '--enable-daap' '--enable-upnp' '--enable-flac' '--enable-shout' '--enable-schroedinger' '--enable-live555' '--with-live555-tree=/mnt/hd/tmp-vlc/live' '--enable-real' '--enable-realrtsp' '--enable-speex' '--with-speex-tree=/mnt/hd/tmp-vlc/speex-1.2rc1' '--enable-x264' '--with-x264-tree=/mnt/hd/tmp-vlc/x264-snapshot-20080928-2245' '--enable-a52' '--with-a52-tree=/mnt/hd/tmp-vlc/a52dec-0.7.4' '--enable-dca' '--with-dca-tree=/mnt/hd/tmp-vlc/libdca-0.0.5' '--enable-faad' '--with-faad-tree=/mnt/hd/tmp-vlc/faad2' '--enable-twolame' '--with-twolame-tree=/mnt/hd/tmp-vlc/twolame-0.3.12' '--enable-ogg' '--enable-vorbis' '--enable-theora' '--enable-avcodec' '--enable-avformat' '--enable-swscale' '--enable-mozilla' '--enable-loader' '--program-prefix=' '--program-suffix=' '--build=i486-slackware-linux' 'AVCODEC_LIBS=-lavcodec -lbz2 -lz -ldl -ltheora -lvorbisenc -lavutil -lvorbis -lm -logg' 'AVCODEC_CFLAGS=' 'build_alias=i486-slackware-linux' 'CFLAGS=-O2 -march=i486 -mtune=i686 -I/mnt/hd/tmp-vlc/vlcdeps/usr/include' 'LDFLAGS= -L/mnt/hd/tmp-vlc/vlcdeps/usr/lib' 'CPPFLAGS=-I/mnt/hd/tmp-vlc/vlcdeps/usr/include' 'CXXFLAGS=-O2 -march=i486 -mtune=i686 -I/mnt/hd/tmp-vlc/vlcdeps/usr/include' 'PKG_CONFIG_PATH=/mnt/hd/tmp-vlc/vlcdeps/usr/lib/pkgconfig'
[00000001] main libvlc debug: translation test: code is "C"
[00000001] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00000746] main generic error: no dialogs provider module matched "any"
[00000745] skins2 interface error: no suitable dialogs provider found (hint: compile the qt4 plugin, and make sure it is loaded properly)
[00000745] skins2 interface: skin: VLC 0.8.5 Default Skin author: aLtgLasS
- Trotto@81
- Kernel: default
Dove hai preso il package?
