qwt slackware 13.1 x86_64 [risolto]
so_slack
- Nome Cognome: noog
- Kernel: x86_64
Re: qwt slackware 13.1 x86_64
sorry it's the same
- 414N
- Kernel: 5.15.19
Pretty strange...
I took the time to adjust the SlackBuild for qwt (by the way, I updated the one I posted before) and tried to build qgis.
I just modified the CMakeLists.txt to make it search for qwt before the other shared libs, so that I didn't need the other required libs to only test this.
Cmake found the qwt in /usr/lib64 on the first try, without the need to add a sed line.
After this, I suggest you to remove the qwt package previously created, create a new one with the updated SlackBuild and retry with qgis.
If this still doesn't work, maybe there's something strange in you environment settings...
so_slack
- Kernel: x86_64
it's ok thank you so much !!!
- 414N
- Kernel: 5.15.19
No problem.
Please add a [RISOLTO] tag to the title of the thread, editing your first post.
This way, others can easily find this solution too.
