scheda wireless broadcom non riconosciuta
Procopio
Kernel: 4.4.14
Desktop: Awesome
Re: scheda wireless broadcom non riconosciuta
Messaggio da Procopio »
[    7.813654] ACPI: Sleep Button [SBTN]
[    7.814432] ACPI: Deprecated procfs I/F for AC is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
[    7.814612] ACPI: AC Adapter [AC] (on-line)
[    7.838486] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[    7.939822] Monitor-Mwait will be used to enter C-1 state
[    7.939877] Monitor-Mwait will be used to enter C-2 state
[    7.939899] Monitor-Mwait will be used to enter C-3 state
[    7.939904] Marking TSC unstable due to TSC halts in idle
[    7.940029] ACPI: acpi_idle registered with cpuidle
[    7.941049] Switching to clocksource hpet
[    7.975762] Linux agpgart interface v0.103
[    8.047456] firewire_ohci 0000:02:01.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[    8.068215] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    8.068402] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    8.068585] sd 8:0:0:0: Attached scsi generic sg2 type 0
[    8.101077] firewire_ohci: Added fw-ohci device 0000:02:01.1, OHCI v1.10, 4 IR + 4 IT contexts, quirks 0x11
[    8.129279] input: PS/2 Mouse as /devices/platform/i8042/serio1/input/input5
[    8.145260] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input6
[    8.151927] thermal LNXTHERM:00: registered as thermal_zone0
[    8.152025] ACPI: Thermal Zone [THM] (57 C)
[    8.159565] ACPI: Deprecated procfs I/F for battery is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
[    8.159696] ACPI: Battery Slot [BAT0] (battery present)
[    8.159948] wmi: Mapper loaded
[    8.192645] tg3.c:v3.121 (November 2, 2011)
[    8.192907] tg3 0000:09:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    8.193017] tg3 0000:09:00.0: setting latency timer to 64
[    8.201796] tg3 0000:09:00.0: eth0: Tigon3 [partno(BCM95761e) rev 5761100] (PCI Express) MAC address 00:23:ae:1f:ec:51
[    8.201928] tg3 0000:09:00.0: eth0: attached PHY is 5761 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[    8.202084] tg3 0000:09:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[    8.202208] tg3 0000:09:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[    8.327053] i801_smbus 0000:00:1f.3: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    8.358551] yenta_cardbus 0000:02:01.0: CardBus bridge found [1028:0263]
[    8.395263] input: Dell WMI hotkeys as /devices/virtual/input/input7
[    8.480849] yenta_cardbus 0000:02:01.0: ISA IRQ mask 0x0cb8, PCI irq 19
[    8.480939] yenta_cardbus 0000:02:01.0: Socket status: 30000006
[    8.481032] pci_bus 0000:02: Raising subordinate bus# of parent bus (#02) from #03 to #06
[    8.481154] yenta_cardbus 0000:02:01.0: pcmcia: parent PCI bridge window: [io  0x2000-0x2fff]
[    8.481271] yenta_cardbus 0000:02:01.0: pcmcia: parent PCI bridge window: [mem 0xf6800000-0xf68fffff]
[    8.481389] pcmcia_socket pcmcia_socket0: cs: memory probe 0xf6800000-0xf68fffff: excluding 0xf68f0000-0xf68fffff
[    8.481646] yenta_cardbus 0000:02:01.0: pcmcia: parent PCI bridge window: [mem 0x80000000-0x83ffffff pref]
[    8.481764] pcmcia_socket pcmcia_socket0: cs: memory probe 0x80000000-0x83ffffff: excluding 0x80000000-0x83ffffff
[    8.602939] firewire_core: created device fw0: GUID 364fc00026b5a490, S400
[    8.626325] snd_hda_intel 0000:00:1b.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[    8.626516] snd_hda_intel 0000:00:1b.0: irq 44 for MSI/MSI-X
[    8.626548] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[    8.843224] pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0fffff: excluding 0xc0000-0xcffff 0xe0000-0xfffff
[    8.843572] pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff: excluding 0x60000000-0x60ffffff
[    8.843869] pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff: clean.
[    8.916700] HDMI status: Codec=2 Pin=3 Presence_Detect=0 ELD_Valid=0
[    8.916988] input: HDA Intel HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[    8.917251] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[    8.917459] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[    8.917664] input: HDA Intel Line-out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[    8.917867] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[    8.918410] agpgart-intel 0000:00:00.0: Intel GM45 Chipset
[    8.918619] agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[    8.919674] agpgart-intel 0000:00:00.0: detected 32768K stolen memory
[    8.920032] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[    8.987841] [drm] Initialized drm 1.1.0 20060810
[    9.251175] i915 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    9.251267] i915 0000:00:02.0: setting latency timer to 64
[    9.296280] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[    9.296399] [drm] MTRR allocation failed.  Graphics performance may suffer.
[    9.296802] i915 0000:00:02.0: irq 45 for MSI/MSI-X
[    9.296808] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[    9.296892] [drm] Driver supports precise vblank timestamp query.
[    9.297029] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    9.834433] fbcon: inteldrmfb (fb0) is primary device
[   10.200632] Console: switching to colour frame buffer device 160x50
[   10.203995] fb0: inteldrmfb frame buffer device
[   10.203996] drm: registered panic notifier
[   10.225016] acpi device:37: registered as cooling_device2
[   10.225610] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/LNXVIDEO:00/input/input13
[   10.225740] ACPI: Video Device [VID] (multi-head: yes  rom: no  post: no)
[   10.225801] [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[   10.226020] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[   10.419834] fuse init (API version 7.17)
[   11.495509] EXT4-fs (sda1): re-mounted. Opts: (null)
[   11.589067] EXT4-fs (sda1): re-mounted. Opts: (null)
[   12.082864] ppdev: user-space parallel port driver
[   12.098937] lp: driver loaded but no devices found
[   18.380501] tg3 0000:09:00.0: irq 46 for MSI/MSI-X
[   20.069649] tg3 0000:09:00.0: eth0: Link is up at 100 Mbps, full duplex
[   20.069649] tg3 0000:09:00.0: eth0: Flow control is on for TX and on for RX
[   29.942524] NET: Registered protocol family 10
[   40.258055] eth0: no IPv6 routers present
[  128.289988] ata1.00: configured for UDMA/133
[  128.289996] ata1: EH complete
[  128.962191] EXT4-fs (sda1): re-mounted. Opts: commit=0
[11686.842139] nepomukservices[2633]: segfault at 0 ip           (null) sp 00007fffd2cf9e68 error 14 in nepomukservicestub[400000+7000]
[11784.766812] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[12139.024174] usb 6-1: new low-speed USB device number 2 using uhci_hcd
[12139.184334] usb 6-1: New USB device found, idVendor=093a, idProduct=2500
[12139.184343] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[12139.184351] usb 6-1: Product: USB OPTICAL MOUSE
[12139.184357] usb 6-1: Manufacturer: PIXART
[12139.256157] input: PIXART USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/input/input14
[12139.256361] generic-usb 0003:093A:2500.0001: input,hidraw0: USB HID v1.10 Mouse [PIXART USB OPTICAL MOUSE] on usb-0000:00:1d.0-1/input0
[12139.256391] usbcore: registered new interface driver usbhid
[12139.256395] usbhid: USB HID core driver
bash-4.2#
l'ho dovuto addirittura dividere in due messaggi perchè non ci stava!!!!
Procopio
Kernel: 4.4.14
Desktop: Awesome
tutto uguale, a parte il tipo nella foto che non sono io :lol: ...scherzi a parte: dalle immagini il pc è identico, ma se vado nelle specifiche tecniche non c'è traccia ad esempio della broadcom wired che risulta dall'lspci...si riesce anche a intravedere lo switch per abilitare le schede wireless (dico "le schede" perchè da bios tiene insieme la scheda di rete senza fili e il bluethoot nell'unicasezione wireless)
comunque il fatto di avere un dmesg da più di 7000 caratteri non vi sembra strano? #-o
il pc nativamente aveva vista (e lì il wifi funzionava), poi il proprietario ha installato xp (e lì ha smesso già di funzionare), in questi giorni sto provando a farlo resuscitare con slacky...
Eh i caratteri non li ho contati e il tipo non lo conosco manco io :D però noto un segfault, anche se non riguarda la questione della scheda wirless:
Quanto alle secifiche del PC si legge:
Connectivity
Wired:
10/100/1000 Gigabit1
e sembra compatibile col tuo lspci. C'è una scheda wired da 1Gbit (della Broadcom nello specifico) e che da quanto capisco funziona bene: o sbaglio?
Manca la wireless, che dovrebbe essere una di queste:
Dell Wireless 1397 (802.11g), Dell Wireless 1510 (802.11 a/g/n 2x2), Intel® WiFi Link 5100 [802.11a/g/n (1x2)]; Intel WiFi Link 5300 [802.11a/g/n (3x3)]
Quindi 2 schede di rete: e ne manca una. Come mai? Non è che il tuo amico ha aperto il pc?
Ripeto da qualche parte la seconda scheda deve saltare fuori, driver o non driver.
Procopio
Kernel: 4.4.14
Desktop: Awesome
rik70 ha scritto:C'è una scheda wired da 1Gbit (della Broadcom nello specifico) e che da quanto capisco funziona bene: o sbaglio?
dici giusto!
rik70 ha scritto:Quindi 2 schede di rete: e ne manca una. Come mai? Non è che il tuo amico ha aperto il pc?
eh no, son sicuro, è una ragazza che lo usava solo per salvare le foto ed andare su internet...l'unica cosa che è stata fatta è che è stato messo xp al posto di vista...poi quando mi ha contattato il pa non si accendeva nemmeno più con xp...
l'unica cosa a livello hardware è una porta sotto al pc, a fianco della batteria come vedete da quest immagine http://i.techrepublic.com.com/gallery/2 ... 20-364.jpg
Uhm... quindi il PC era piantato?
Butta un occhio e vedi se anche nell'esemplare che hai sotto mano c'è installata una scheda wireless, come mostrato qui:
http://support.dell.com/support/edocs/s ... #wp1180289
...sperando che il link funzioni.
Procopio
Kernel: 4.4.14
Desktop: Awesome
guardato...e la scheda wireless è fisicamente presente.....
Ok...
hai notato qualche scritta nella scheda che possa farci capire che modello è?
Hai per caso notato segni di surriscaldamento o cose simili?
Procopio ha scritto:...poi il proprietario ha installato xp (e lì ha smesso già di funzionare), in questi giorni sto provando a farlo resuscitare con slacky...
Ma siamo sicuri che la scheda wireless funzionI? Se con XP non funzionava allora la cosa mi puzza.
Procopio
Kernel: 4.4.14
Desktop: Awesome
rik70 ha scritto: hai notato qualche scritta nella scheda che possa farci capire che modello è?
ho fatto una cavolata e spanato una vite, tra l'altro con un solo giro di cacciavite...mah... io vorrei sapere se ste viti le fanno con il burro.. :doubt: [-X adesso devo toglierla poi lo riapro e lego il modello che non ho letto prima perchè la scheda è protetta da un secondo coperchietto che non avevo tolto....appena lo apro scrivo qui le info!
spina ha scritto:Ma siamo sicuri che la scheda wireless funzionI? Se con XP non funzionava allora la cosa mi puzza.
su vista funzionava....dovrei provare ad installare vista.....
Se le informazioni qui riportate sono corrette, dovrebbe trattarsi di una Intel:
http://www.intel.com/Assets/PDF/general ... p_list.pdf
... e la scheda è supportata sin dal kernel 2.6.27.
Vedi un pò se riaprendo il latop ottieni informazione diverse.
Diversamente, io propenderei per un problema hardware.
Anche perché ieri ho provato a rimuovere il modulo della scheda audio, ho rifatto il boot e posso confermare che lspci vede la scheda audio anche senza il driver.
Procopio
Kernel: 4.4.14
Desktop: Awesome
allora, la situzaione è alquanto strana, vi allego la foto che ho fatto. Pare che ci sia una sola scheda, la "BROADCOM BCM92046MPCIE FLASH".
In rierimento alla foto, questa scheda poggia su un etichetta nera, come quella che vedete a sinistra, ma con scritta WPAN...ho googlato e qualcuno chiama questa scheda wireless, ma io ho paura che sia semplicemente bluethoot e che quindi non ci sia la wlan...è strano però perchè anche la scheda eternet non si vede...che mi dite?? la proprietaria continua a giurarmi che con vista funzionava....ma magari in un posto dove si collegava via bluethoot al wireless.... #-o #-o non so più che pensare...
Eh... c'hai poco a cui pensare e l'hai già pensata giusta:
non c'è alcuna scheda wireless ^_^
La scheda ethernet molto probabilmente è integrata nella mobo: per questo non la vedi.
Procopio
Kernel: 4.4.14
Desktop: Awesome
eh appunto rik...e non c'è neanche alcuna speranza che la scheda a fianco abbia anche la ricezione wlan? certo che però è strano che un pc così nuovo sia senza scheda wireless...
Non so, io non ne capisco molto - anzi nulla - di reti Wpan e Bluethoot. In effetti un po' strana la faccenda, ma nulla di strano che il produttore prevedesse l'acquisto della scheda wlan a parte.
Piuttosto: non è che il PC è stato portato in assistenza o prestato a qualcuno?
