[RISOLTO] connessione internet
nicolix
Nome Cognome: nicolò
Slackware: 13
Kernel: 4.4.14
Re: connessione internet
Messaggio da nicolix »
ecco posto quello che mi è venuto fuori...
root@nicolix:/home/nicolix# ifconfig -a
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
collisions:0 txqueuelen:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
root@nicolix:/home/nicolix# lspci -k
lspci: invalid option -- k
Usage: lspci [<switches>]
-v Be verbose
-n Show numeric ID's
-nn Show both textual and numeric ID's (names & numbers)
-b Bus-centric view (PCI addresses and IRQ's instead of those seen by the CP
U)
-x Show hex-dump of the standard portion of config space
-xxx Show hex-dump of the whole config space (dangerous; root only)
-xxxx Show hex-dump of the 4096-byte extended config space (root only)
-s [[[[<domain>]:]<bus>]:][<slot>][.[<func>]] Show only devices in selected slots
-d [<vendor>]:[<device>] Show only selected devices
-t Show bus tree
-m Produce machine-readable output
-i <file> Use specified ID database instead of /usr/share/pci.ids.gz
-D Always show domain numbers
-M Enable `bus mapping' mode (dangerous; root only)
-P <dir> Use specified directory instead of /proc/bus/pci
-H <mode> Use direct hardware access (<mode> = 1 or 2)
-F <file> Read configuration data from given file
-G Enable PCI access debugging
root@nicolix:/home/nicolix# lsmod
Module Size Used by
snd_seq_dummy 6788 0
snd_seq_oss 32896 0
snd_seq_midi_event 10112 1 snd_seq_oss
snd_seq 50640 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi_event
snd_seq_device 10508 3 snd_seq_dummy,snd_seq_oss,snd_seq
snd_pcm_oss 42784 0
snd_mixer_oss 18048 1 snd_pcm_oss
ipv6 254496 14
pcmcia 34988 0
pcmcia_core 36500 1 pcmcia
capability 7304 0
commoncap 9344 1 capability
lp 13736 0
parport_pc 27812 1
parport 34760 2 lp,parport_pc
pcspkr 6528 0
psmouse 39048 0
serio_raw 9220 0
intel_agp 25116 1
agpgart 31432 1 intel_agp
snd_hda_intel 20248 0
snd_hda_codec 209152 1 snd_hda_intel
snd_pcm 72068 3 snd_pcm_oss,snd_hda_intel,snd_hda_codec
snd_timer 22532 2 snd_seq,snd_pcm
snd 47204 9 snd_seq_oss,snd_seq,snd_seq_device,snd_pcm_oss,snd_mixer_ oss,snd_hda_intel,snd_hda_codec,snd_pcm,snd_timer
iTCO_wdt 12964 0
iTCO_vendor_support 7172 1 iTCO_wdt
soundcore 9824 1 snd
snd_page_alloc 11528 2 snd_hda_intel,snd_pcm
sg 30364 0
i2c_i801 11408 0
ata_generic 9220 0
shpchp 33172 0
evdev 11904 1
grazie mille
ALT
allora è diverso il discorso, se su ubuntu fai pppoeconf, anche su Slackware devi configurare pppoe
Togli quel dhcp da rc.inet1.conf e dopo lancia
# pppoe-setup
nicolix
Slackware: 13
Kernel: 4.4.14
conraid ha scritto:ALT
# pppoe-setup
ok grazie quando mi dice di inserire dei ip o codici cosa inserisco??
nicolix
Slackware: 13
Kernel: 4.4.14
comunque uso netconfig per togliere il dchp???grazie
# pppoe-setup
Quelli che inserisci in ubuntu :-)
Non dovrebbe farti inserire un IP
Per togliere il dhcp puoi anche usare un normale editor di testi
nicolix
Slackware: 13
Kernel: 4.4.14
ok esiste gedit in slackware??devo essere root per modificare i text system???
nicolix
Slackware: 13
Kernel: 4.4.14
ho disattivato dchp e poi ho fatto così
Looks good! Now, please enter some information:
pppoe-setup
USER NAME
>>> Enter your PPPoE user name (default nicolix): nicolix
INTERFACE
>>> Enter the Ethernet interface connected to the DSL modem
For Solaris, this is likely to be something like /dev/hme0.
For Linux, it will be ethn, where 'n' is a number.
(default eth0): 0
Do you want the link to come up on demand, or stay up continuously?
If you want it to come up on demand, enter the idle time in seconds
after which the link should be dropped. If you want the link to
stay up permanently, enter 'no' (two letters, lower-case.)
NOTE: Demand-activated links do not interact well with dynamic IP
addresses. You may have some problems with demand-activated links.
>>> Enter the demand value (default no): (premuto invio)
DNS
Please enter the IP address of your ISP's primary DNS server.
If your ISP claims that 'the server will provide DNS addresses',(premuto invio)
enter 'server' (all lower-case) here.
If you just press enter, I will assume you know what you are
doing and not modify your DNS setup.
>>> Enter the DNS information here:(premuto invio)
PASSWORD
>>> Please enter your PPPoE password:
>>> Please re-enter your PPPoE password:
FIREWALLING
Please choose the firewall rules to use. Note that these rules are
very basic. You are strongly encouraged to use a more sophisticated
firewall setup; however, these will provide basic security. If you
are running any servers on your machine, you must choose 'NONE' and
set up firewalling yourself. Otherwise, the firewall rules will deny
access to all standard servers like Web, e-mail, ftp, etc. If you
are using SSH, the rules will block outgoing SSH connections which
allocate a privileged source port.
The firewall choices are:
0 - NONE: This script will not set any firewall rules. You are responsible
for ensuring the security of your machine. You are STRONGLY
recommended to use some kind of firewall rules.
1 - STANDALONE: Appropriate for a basic stand-alone web-surfing workstation
2 - MASQUERADE: Appropriate for a machine acting as an Internet gateway
for a LAN
>>> Choose a type of firewall (0-2): 0
** Summary of what you entered **
Ethernet Interface: 0
User name: nicolix
Activate-on-demand: No
DNS: Do not adjust
Firewalling: NONE
>>> Accept these settings and adjust configuration files (y/n)? y
Adjusting /etc/ppp/pppoe.conf
Adjusting /etc/ppp/pap-secrets and /etc/ppp/chap-secrets
(But first backing it up to /etc/ppp/pap-secrets-bak)
(But first backing it up to /etc/ppp/chap-secrets-bak)
Congratulations, it should be all set up!
Type 'pppoe-start' to bring up your PPPoE link and 'pppoe-stop' to bring
it down. Type 'pppoe-status' to see the link status.
root@nicolix:/home/nicolix# pppoe-start
................TIMED OUT
/usr/sbin/pppoe-start: line 193: 3713 Terminated $CONNECT "$@" >/dev/null 2>&1
ecco ho provato ma niente non va in internet neancora :((((((((((((((((((((((8
nicolix
Slackware: 13
Kernel: 4.4.14
non riesco a capire perchè ragazzi stesso problema me lo da con un'altro semplice modem, alice gate normale....cosa devo fare???cosa potrebbe essere il problema??grazie ciao
danix
Nome Cognome: Danilo M.
Slackware: 64 current
Kernel: 6.12.13 x86_64
Desktop: i3
Messaggio da danix »
scusami, ero totalmente fuso ieri, non ricordavo che serve pppoe per navigare con quel catorcio di modem, le risposte a pppoe-setup sono:
USER = l'user della tua connessione, io con telecom metto aliceadsl
INTERFACE = puoi scrivere eth0 se è quella la tua scheda di rete, oppure premi invio, in caso sia eth1 o altro devi scriverla per intero
DNS = devi scrivere server per farti dare i dns dal modem
PASSWORD = devi mettere la password della connessione, io con telecom metto sempre aliceadsl (uguale per tutti)
FIREWALLING = puoi mettere 1 se il tuo pc non deve fare da gateway per altri pc nella lan
poi devi accettare le impostazioni con y (come hai fatto)
e poi devi lanciare pppoe-start per avviare la connessione (da root) e pppoe-stop per fermarla...
facci sapere
danix
nicolix
Slackware: 13
Kernel: 4.4.14
provo e poi vi posto il risultato...grazie mille intanto per il supporto di tutti veramente siete gentilissimi :lol: :D :D
nicolix
Slackware: 13
Kernel: 4.4.14
danix ha scritto:scusami, ero totalmente fuso ieri, non ricordavo che serve pppoe per navigare con quel catorcio di modem, le risposte a pppoe-setup sono:
facci sapere
ciao ho fatto tutto questo procedimento...pero non ci crederai ancora niente non funzia.... ormai vado in disperazione :roll: :x :(
Purtroppo il tuo sistema non riconosce la eth, altrimenti con ifconfig -a dovrebbe mostrartela anche se non configurata
E non capisco come mai lspci -k non ti funzioni
Che versione di Slackeare usi?
Prova a postare
# lspci -n
così vediamo di che modulo hai bisogno
nicolix
Slackware: 13
Kernel: 4.4.14
la versione 12 pero se ce problemi posso passare alla 12.2....dici che se passo alla 12.2 si dovrebbero risolvere tutti i problemi???cambiando scheda enthernet posso aver risolto qualsiesi problema di connessione???(che marca mi consigli di schede di rete,nel senso qual'è la meglio supportata per linux?)....
ecco il risultato del comando:
root@nicolix:/home/nicolix# lspci -n
00:00.0 0600: 8086:2770 (rev 81)
00:01.0 0604: 8086:2771 (rev 81)
00:1b.0 0403: 8086:27d8 (rev 01)
00:1d.0 0c03: 8086:27c8 (rev 01)
00:1d.1 0c03: 8086:27c9 (rev 01)
00:1d.2 0c03: 8086:27ca (rev 01)
00:1d.3 0c03: 8086:27cb (rev 01)
00:1d.7 0c03: 8086:27cc (rev 01)
00:1e.0 0604: 8086:244e (rev e1)
00:1f.0 0601: 8086:27b8 (rev 01)
00:1f.1 0101: 8086:27df (rev 01)
00:1f.2 0101: 8086:27c0 (rev 01)
00:1f.3 0c05: 8086:27da (rev 01)
01:00.0 0300: 10de:0162 (rev a1)
02:01.0 0c00: 1106:3044 (rev 80)
02:08.0 0200: 8086:27dc (rev 01)
aspetto tue notizie
nicolix ha scritto:la versione 12 pero se ce problemi posso passare alla 12.2....dici che se passo alla 12.2 si dovrebbero risolvere tutti i problemi???cambiando scheda enthernet posso aver risolto qualsiesi problema di connessione???(che marca mi consigli di schede di rete,nel senso qual'è la meglio supportata per linux?)....
ethernet
comunque se ubuntu la vede la deve devere anche slackware, anche se nonricordo che kernel c'era nella 12.0 (12 sarebbe 12.0 vero?), e la scheda e100 che hai tu è supportata dal 2.6.25
nicolix ha scritto: aspetto tue notizie
non siamo un helpdesk però :-k
prova a fare
# modprobe e100
e se non ti da errore
# ifconfig -a
nicolix
Slackware: 13
Kernel: 4.4.14
ethernet
prova a fare
# modprobe e100
# ifconfig -a
si intendo la 12.0 comunque scusami so che non siete helpdesk è non volevo offenderti figuriamoci.....ti ringrazio moltissimo del tuo aiuto a prescindere se vada a buon fine questo esperimento...grazie adesso ti posto i risultati dei comandi sopra elencati:
root@nicolix:/home/nicolix# modprobe e100
eth0 Link encap:Ethernet HWaddr 00:13:D4:AF:16:A5
BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
Ultima modifica di nicolix il mar 10 mar 2009, 17:19, modificato 1 volta in totale.
