[RISOLTO][CONSIGLIO]Disco Esterno Per Backup
Re: [CONSIGLIO] Disco Esterno Per Backup
ilmich ha scritto: ↑
sab 2 apr 2022, 21:22
a meno che nn sia impazzito il portatile e invece dei 5v ne ha erogati 12.
Esatto, ma a rigor di logica sarebbe dovuta saltare prima la schedina usb.
prova a collegarlo ad una sorgente 'affidabile' tipo un case USB alimentato o un PC che non sia il tuo portatile
Eh, come ho detto sopra l'ho tolto dal case e installato nel Desktop ma la situazione è identica.
Questi gli errori:
 ata5.00: exception Emask 0x0 SAct 0x6000 SErr 0x0 action 0x0
 ata5.00: irq_stat 0x40000001
 ata5.00: failed command: READ FPDMA QUEUED
 ata5.00: cmd 60/00:68:e8:a4:02/01:00:00:00:00/40 tag 13 ncq dma 131072 in
a5:02/00:01:00:00:00/40 Emask 0x409 (media error) <F>
 ata5.00: status: { DRDY ERR }
 ata5.00: error: { UNC }
 ata5.00: cmd 60/00:70:e8:a5:02/01:00:00:00:00/40 tag 14 ncq dma 131072 in
a5:02/00:00:00:00:00/40 Emask 0x9 (media error)
 ata5.00: configured for UDMA/100
 sd 4:0:0:0: [sdb] tag#13 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=4s
 sd 4:0:0:0: [sdb] tag#13 Sense Key : Medium Error [current]
 sd 4:0:0:0: [sdb] tag#13 Add. Sense: Unrecovered read error - auto reallocate failed
 sd 4:0:0:0: [sdb] tag#13 CDB: Read(10) 28 00 00 02 a4 e8 00 01 00 00
 I/O error, dev sdb, sector 173328 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
 sd 4:0:0:0: [sdb] tag#14 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=4s
 sd 4:0:0:0: [sdb] tag#14 Sense Key : Medium Error [current]
 sd 4:0:0:0: [sdb] tag#14 Add. Sense: Unrecovered read error - auto reallocate failed
 sd 4:0:0:0: [sdb] tag#14 CDB: Read(10) 28 00 00 02 a5 e8 00 01 00 00
 I/O error, dev sdb, sector 173544 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
 ata5: EH complete
 ata5.00: exception Emask 0x0 SAct 0x800 SErr 0x0 action 0x0
 ata5.00: irq_stat 0x40000008
 ata5.00: cmd 60/08:58:58:a5:02/00:00:00:00:00/40 tag 11 ncq dma 4096 in
a5:02/00:00:00:00:00/40 Emask 0x409 (media error) <F>
 sd 4:0:0:0: [sdb] tag#11 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=3s
 sd 4:0:0:0: [sdb] tag#11 Sense Key : Medium Error [current]
 sd 4:0:0:0: [sdb] tag#11 Add. Sense: Unrecovered read error - auto reallocate failed
 sd 4:0:0:0: [sdb] tag#11 CDB: Read(10) 28 00 00 02 a5 58 00 00 08 00
 I/O error, dev sdb, sector 173400 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
 Buffer I/O error on dev sdb, logical block 21675, async page read
 ata5: EH complete
 ata5.00: exception Emask 0x0 SAct 0x1000 SErr 0x0 action 0x0
 ata5.00: cmd 60/08:60:58:a5:02/00:00:00:00:00/40 tag 12 ncq dma 4096 in
 sd 4:0:0:0: [sdb] tag#12 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=3s
 sd 4:0:0:0: [sdb] tag#12 Sense Key : Medium Error [current]
 sd 4:0:0:0: [sdb] tag#12 Add. Sense: Unrecovered read error - auto reallocate failed
 sd 4:0:0:0: [sdb] tag#12 CDB: Read(10) 28 00 00 02 a5 58 00 00 08 00
 ata5: EH complete
 ata5.00: exception Emask 0x0 SAct 0x10000000 SErr 0x0 action 0x0
 ata5.00: cmd 60/08:e0:58:a5:02/00:00:00:00:00/40 tag 28 ncq dma 4096 in
 sd 4:0:0:0: [sdb] tag#28 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=3s
 sd 4:0:0:0: [sdb] tag#28 Sense Key : Medium Error [current]
 sd 4:0:0:0: [sdb] tag#28 Add. Sense: Unrecovered read error - auto reallocate failed
 sd 4:0:0:0: [sdb] tag#28 CDB: Read(10) 28 00 00 02 a5 58 00 00 08 00
 ata5: EH complete
 ata5.00: exception Emask 0x0 SAct 0x100000 SErr 0x0 action 0x0
 ata5.00: cmd 60/08:a0:58:a5:02/00:00:00:00:00/40 tag 20 ncq dma 4096 in
 sd 4:0:0:0: [sdb] tag#20 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=3s
 sd 4:0:0:0: [sdb] tag#20 Sense Key : Medium Error [current]
 sd 4:0:0:0: [sdb] tag#20 Add. Sense: Unrecovered read error - auto reallocate failed
 sd 4:0:0:0: [sdb] tag#20 CDB: Read(10) 28 00 00 02 a5 58 00 00 08 00
 ata5: EH complete
 ata5.00: exception Emask 0x0 SAct 0x8000 SErr 0x0 action 0x0
 ata5.00: cmd 60/08:78:58:a5:02/00:00:00:00:00/40 tag 15 ncq dma 4096 in
 sd 4:0:0:0: [sdb] tag#15 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=3s
 sd 4:0:0:0: [sdb] tag#15 Sense Key : Medium Error [current]
 sd 4:0:0:0: [sdb] tag#15 Add. Sense: Unrecovered read error - auto reallocate failed
 sd 4:0:0:0: [sdb] tag#15 CDB: Read(10) 28 00 00 02 a5 58 00 00 08 00
guarda prova a cambiare cavo/usare solo quello sul tuo desktop(magari con live USB)
googlando l'errore leggo spesso di problemi di alimentazione/cavetteria
comunque fosse fisicamente guasto penso sia questione di sfiga e non di usura... alias ti potrebbe accadere anche con hdd appena preso
sab 2 apr 2022, 22:46
Sì, gli indizi portano a quello. Nel caso però il problema è nell'elettronica, non nei cavi o nell'interfaccia usb originale.
Non lo butto, perché se me ne capita uno simile proverò a sostituire l'elettronica.
Ok, arrivato il Crucial e copiato i dati.
Dato che l'uso al momento sarà esclusivamente come disco esterno, col TRIM come mi regolo?
Diamo a 'manovella' `fstrim` ogni tot tempo quando inizierò a cancellare dati, o lo abilito permanentemente nelle opzioni del filesystem(ext4)?
Scusate se incasino la discussione con troppe cose.
rik70 ha scritto: ↑
dom 3 apr 2022, 17:33
Mi rispondo da solo:
qui è spiegato bene e funziona.
Si va di fstrim periodicamente e fine della storia.
