ho già rigenerato due o tre volte, ma continua ad associarmi kernel a / a casaccio etichettandoli a casaccio. Per esempio ora sono da arch, nel menu di grub ho scelto il kernel normale e invece ho quello lts..
vrso ~ $ cat /boot/grub/grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_gpt
insmod ext2
set root='hd1,gpt8'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd1,gpt8 --hint-efi=hd1,gpt8 --hint-baremetal=ahci1,gpt8 73cd42f4-3a8d-44f5-91d3-f9507fa87104
else
search --no-floppy --fs-uuid --set=root 73cd42f4-3a8d-44f5-91d3-f9507fa87104
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=it_IT
insmod gettext
fi
terminal_input console
terminal_output gfxterm
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=menu
set timeout=5
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
set timeout=5
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Arch Linux' --class arch --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-73cd42f4-3a8d-44f5-91d3-f9507fa87104' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod fat
set root='hd1,gpt1'
search --no-floppy --fs-uuid --set=root --hint-bios=hd1,gpt1 --hint-efi=hd1,gpt1 --hint-baremetal=ahci1,gpt1 B4A7-CD38
else
search --no-floppy --fs-uuid --set=root B4A7-CD38
fi
echo 'Caricamento Linux linux-lts...'
linux /vmlinuz-linux-lts root=UUID=73cd42f4-3a8d-44f5-91d3-f9507fa87104 rw rcutree.rcu_idle_gp_delay=1 quiet
echo 'Caricamento ramdisk iniziale...'
initrd /initramfs-linux-lts.img
submenu 'Opzioni avanzate per Arch Linux' $menuentry_id_option 'gnulinux-advanced-73cd42f4-3a8d-44f5-91d3-f9507fa87104' {
menuentry 'Arch Linux, con Linux linux-lts' --class arch --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-lts-advanced-73cd42f4-3a8d-44f5-91d3-f9507fa87104' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Arch Linux, with Linux linux-lts (fallback initramfs)' --class arch --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-lts-fallback-73cd42f4-3a8d-44f5-91d3-f9507fa87104' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /initramfs-linux-lts-fallback.img
menuentry 'Arch Linux, con Linux linux' --class arch --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-advanced-73cd42f4-3a8d-44f5-91d3-f9507fa87104' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
echo 'Caricamento Linux linux...'
linux /vmlinuz-linux root=UUID=73cd42f4-3a8d-44f5-91d3-f9507fa87104 rw rcutree.rcu_idle_gp_delay=1 quiet
initrd /initramfs-linux.img
menuentry 'Arch Linux, with Linux linux (fallback initramfs)' --class arch --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-fallback-73cd42f4-3a8d-44f5-91d3-f9507fa87104' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
initrd /initramfs-linux-fallback.img
menuentry 'Arch Linux, con Linux huge-smp-3.10.17-smp' --class arch --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-huge-smp-3.10.17-smp-advanced-73cd42f4-3a8d-44f5-91d3-f9507fa87104' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
echo 'Caricamento Linux huge-smp-3.10.17-smp...'
linux /vmlinuz-huge-smp-3.10.17-smp root=/dev/sdb8 rw rcutree.rcu_idle_gp_delay=1 quiet
menuentry 'Arch Linux, con Linux huge-3.10.17' --class arch --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-huge-3.10.17-advanced-73cd42f4-3a8d-44f5-91d3-f9507fa87104' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
echo 'Caricamento Linux huge-3.10.17...'
linux /vmlinuz-huge-3.10.17 root=/dev/sdb8 rw rcutree.rcu_idle_gp_delay=1 quiet
menuentry 'Arch Linux, con Linux generic-smp-3.10.17-smp' --class arch --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-generic-smp-3.10.17-smp-advanced-73cd42f4-3a8d-44f5-91d3-f9507fa87104' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
echo 'Caricamento Linux generic-smp-3.10.17-smp...'
linux /vmlinuz-generic-smp-3.10.17-smp root=/dev/sdb8 rw rcutree.rcu_idle_gp_delay=1 quiet
menuentry 'Arch Linux, con Linux generic-3.10.17' --class arch --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-generic-3.10.17-advanced-73cd42f4-3a8d-44f5-91d3-f9507fa87104' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
echo 'Caricamento Linux generic-3.10.17...'
linux /vmlinuz-generic-3.10.17 root=/dev/sdb8 rw rcutree.rcu_idle_gp_delay=1 quiet
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows Boot Manager (su /dev/sdb1)' --class windows --class os $menuentry_id_option 'osprober-efi-B4A7-CD38' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
chainloader /EFI/Microsoft/Boot/bootmgfw.efi
menuentry 'Slackware Linux (Slackware 14.1) (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
submenu 'Opzioni avanzate per Slackware Linux (Slackware 14.1) (su /dev/sdb9)' $menuentry_id_option 'osprober-gnulinux-advanced-367ec3e7-861b-47c1-8920-236b645e0a41' {
menuentry 'Arch Linux (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-linux-lts--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Arch Linux, con Linux linux-lts (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-linux-lts--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Arch Linux, with Linux linux-lts (fallback initramfs) (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-linux-lts--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Arch Linux, con Linux linux (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-linux--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Arch Linux, with Linux linux (fallback initramfs) (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-linux--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Arch Linux, con Linux huge-smp-3.10.17-smp (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-huge-smp-3.10.17-smp--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Arch Linux, con Linux huge-3.10.17 (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-huge-3.10.17--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Arch Linux, con Linux generic-smp-3.10.17-smp (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-generic-smp-3.10.17-smp--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Arch Linux, con Linux generic-3.10.17 (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-generic-3.10.17--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Slackware Linux (Slackware 14.1) (su /dev/sdb9) (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-linux-lts--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Arch Linux (su /dev/sdb9) (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-huge-smp-3.10.17-smp--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
linux /vmlinuz-huge-smp-3.10.17-smp root=UUID=367ec3e7-861b-47c1-8920-236b645e0a41 rw rcutree.rcu_idle_gp_delay=1 quiet
menuentry 'Arch Linux, con Linux linux-lts (su /dev/sdb9) (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-linux-lts--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Arch Linux, with Linux linux-lts (fallback initramfs) (su /dev/sdb9) (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-linux-lts--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Arch Linux, con Linux linux (su /dev/sdb9) (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-linux--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
menuentry 'Arch Linux, with Linux linux (fallback initramfs) (su /dev/sdb9) (su /dev/sdb9)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz-linux--367ec3e7-861b-47c1-8920-236b645e0a41' {
insmod part_gpt
insmod fat
set root='hd1,gpt1'
else
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/60_memtest86+ ###
### END /etc/grub.d/60_memtest86+ ###
