Webcam come funziona?
Ok, ecco quanto mi restituisce la console:
oot@darkstar:/home/mario# tar -xvzpf spca5xx-20060501.tar.gz
spca5xx-20060501/
spca5xx-20060501/README-KERNEL-UPTO-2.6.16
spca5xx-20060501/Makefile
spca5xx-20060501/LICENSE
spca5xx-20060501/RGB-YUV%2fmodule-setting
spca5xx-20060501/drivers/
spca5xx-20060501/drivers/usb/
spca5xx-20060501/drivers/usb/spca500.dat
spca5xx-20060501/drivers/usb/spca501.dat
spca5xx-20060501/drivers/usb/spca505.dat
spca5xx-20060501/drivers/usb/spca508.dat
spca5xx-20060501/drivers/usb/spcagamma.h
spca5xx-20060501/drivers/usb/cx11646.h
spca5xx-20060501/drivers/usb/sn9cxxx.h
spca5xx-20060501/drivers/usb/pac207.h
spca5xx-20060501/drivers/usb/cxlib.h
spca5xx-20060501/drivers/usb/zc3xx.h
spca5xx-20060501/drivers/usb/cs2102.h
spca5xx-20060501/drivers/usb/jpeg_qtables.h
spca5xx-20060501/drivers/usb/pas106b.h
spca5xx-20060501/drivers/usb/spca506.h
spca5xx-20060501/drivers/usb/spca561.h
spca5xx-20060501/drivers/usb/mr97311.h
spca5xx-20060501/drivers/usb/sonix.h
spca5xx-20060501/drivers/usb/spca5xx.c
spca5xx-20060501/drivers/usb/spca5xx.h
spca5xx-20060501/drivers/usb/spcausb.h
spca5xx-20060501/drivers/usb/icm105a.h
spca5xx-20060501/drivers/usb/hv7131b.h
spca5xx-20060501/drivers/usb/hv7131c.h
spca5xx-20060501/drivers/usb/spca501_init.h
spca5xx-20060501/drivers/usb/pb0330.h
spca5xx-20060501/drivers/usb/ov7630c.h
spca5xx-20060501/drivers/usb/et61xx51.h
spca5xx-20060501/drivers/usb/sp5xxfw2.h
spca5xx-20060501/drivers/usb/jpeg_header.h
spca5xx-20060501/drivers/usb/spca508_init.h
spca5xx-20060501/drivers/usb/spcaCompat.h
spca5xx-20060501/drivers/usb/dummy_cam.h
spca5xx-20060501/drivers/usb/spcadecoder.c
spca5xx-20060501/drivers/usb/spcadecoder.h
spca5xx-20060501/drivers/usb/tas5130c.h
spca5xx-20060501/drivers/usb/sp5xxfw2.dat
spca5xx-20060501/drivers/usb/hdcs2020.h
spca5xx-20060501/drivers/usb/spca505_init.h
spca5xx-20060501/drivers/usb/spca500_init.h
spca5xx-20060501/drivers/usb/tv8532.h
spca5xx-20060501/CHANGELOG
tar: spca5xx-20060501/drivers: implausibly old time stamp 1970-01-01 01:00:00
spca5xx-20060501/README-SONIX
spca5xx-20060501/README-TV8532
spca5xx-20060501/INSTALL
spca5xx-20060501/cutlog.py
root@darkstar:/home/mario# cd spca5xx-20060501
root@darkstar:/home/mario/spca5xx-20060501# ./configure
bash: ./configure: No such file or directory
spca5xx-20060501/
gohanz, scusa se ti stresso ancora ma non va, ti posto quanto restituito dal make && make install:
root@darkstar:/home/mario/spca5xx-20060501# make
Compiling drivers/usb/spcadecoder.c
Compiling drivers/usb/spca5xx.c
drivers/usb/spca5xx.c: In function `spca50x_read_proc':
error: structure has no member named `seq'
drivers/usb/spca5xx.c: At top level:
drivers/usb/spca5xx.c:150: warning: `bright' defined but not used
drivers/usb/spca5xx.c:151: warning: `contrast' defined but not used
make: *** [drivers/usb/spca5xx.o] Error 1
root@darkstar:/home/mario/spca5xx-20060501# make install
Nella dir /boot avevo già il file config che è un collegamento al file config-ide-2.4.31, quindi l'ho copiato in /usr/src/linux-2.4.31 e riprovato l'installazione, ma mi restiuisce ancora lo stesso errore.
Adesso dovrei controllare se all'interno di /usr/src ci sono i sorgenti del Kernel e il link simbolico che linux punta ad essi, ma anche qua son bloccato perchè non so come si fa.
Spero che non debba ricompilare il kernel, perchè non ho mai provato e la cosa mi preoccupa non poco, visto che ci ho messo una vita a far funzionare la connessione tramite cellulare e francamente ho paura che ricompilando (ammesso che vada tutto a buon fine) non perda poi quelle configurazioni.
Se puoi ancora perdere un pò di tempo con me, ti sono davvero grato (anche se non ne avessi di tempo, comunque ti ringrazio).
Guarda visto che giri sul 2.4.31 installa direttamaente il precompilato e risolvi tutto.
http://juno.utc.edu/~gqv812/packages/sp ... 1jonny.tgz
Devo mettere su il kernel 2.4.31 e provare altrimenti non ti so rispondere! Io ho sempre usato il diriver con i kernel della serie 2.6. Vediamo se c'è qalche problema! Anche se leggendo il Readme il 2.4.31 è stato testato ed è funzionante, forse c'è qualche problema nei tuoi sorgenti dei Kernelhog61 ha scritto:Gohanz, porca paletta! Li avevo gia quei driver, avevo già provato a installarli con pkgtool ma senza nessun risultato...Pazzesco! Ma non è che per caso, dovrei ricompilare il kernel, oppure devo seguire poi altre procedure?
Possibile che per usare la cam devo aprire Win???
