Si. Unico ricevitore.
Ecco il link della mia tastiera
http://www.logitech.com/index.cfm/produ ... ENTID=9530
allego il risultato di lsusb e dmesg
root@RhaptorX:~# lsusb
Bus 005 Device 001: ID 0000:0000
Bus 004 Device 001: ID 0000:0000
Bus 003 Device 001: ID 0000:0000
Bus 003 Device 002: ID 1131:1001 Integrated System Solution Corp. KY-BT100 Bluetooth Adapter
Bus 002 Device 001: ID 0000:0000
Bus 002 Device 002: ID 046d:c505 Logitech, Inc. Cordless Mouse+Keyboard Receiver
Bus 002 Device 003: ID 03eb:3301 Atmel Corp. 4-port Hub
Bus 002 Device 004: ID 03f0:4f11 Hewlett-Packard
Bus 002 Device 005: ID 0d7d:1400 Phison Electronics Corp.
Bus 001 Device 001: ID 0000:0000
root@RhaptorX:~# dmesg
hash table entries: 65536 (order: 7, 524288 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 65536 (order: 6, 262144 bytes)
Page-cache hash table entries: 262144 (order: 8, 1048576 bytes)
CPU: Trace cache: 12K uops, L1 D cache: 16K
CPU: L2 cache: 1024K
CPU: After generic, caps: bfebfbff 00000000 00000000 00000000
CPU: Common caps: bfebfbff 00000000 00000000 00000000
CPU: Intel(R) Pentium(R) 4 CPU 3.00GHz stepping 01
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
mtrr: v1.40 (20010327) Richard Gooch (
rgooch@atnf.csiro.au)
mtrr: detected mtrr type: Intel
PCI: Using configuration type 1
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
PCI: Via IRQ fixup
PCI: Using IRQ router default [1106/3227] at 00:11.0
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
VFS: Disk quotas vdquot_6.5.1
Journalled Block Device driver loaded
vesafb: framebuffer at 0xe0000000, mapped to 0xf880d000, size 3072k
vesafb: mode is 1024x768x16, linelength=2048, pages=84
vesafb: protected mode interface info at c000:56f7
vesafb: scrolling: redraw
vesafb: directcolor: size=0:5:6:5, shift=0:11:5:0
Console: switching to colour frame buffer device 128x48
fb0: VESA VGA frame buffer device
pty: 512 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with HUB-6 MANY_PORTS MULTIPORT SHARE_IRQ SERIAL_PCI enabled
ttyS00 at 0x03f8 (irq = 4) is a 16550A
Redundant entry in serial pci_table. Please send the output of
lspci -vv, this message (134d,7896,150d,0001)
and the manufacturer and name of serial board or modem board
to
serial-pci-info@lists.sourceforge.net.
register_serial(): autoconfig failed
Real Time Clock Driver v1.10f
Floppy drive(s): fd0 is 1.44M
keyboard: Timeout - AT keyboard not present?(ed)
keyboard: Timeout - AT keyboard not present?(f4)
FDC 0 is a post-1991 82077
RAMDISK driver initialized: 16 RAM disks of 7777K size 1024 blocksize
loop: loaded (max 8 devices)
Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 00:0f.1
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci00:0f.1
ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:DMA, hdd:DMA
hda: Maxtor 6Y080L0, ATA DISK drive
hdb: Maxtor 6Y080L0, ATA DISK drive
blk: queue c03af460, I/O limit 4095Mb (mask 0xffffffff)
blk: queue c03af59c, I/O limit 4095Mb (mask 0xffffffff)
hdc: _NEC DVD_RW ND-3520A, ATAPI CD/DVD-ROM drive
hdd: HL-DT-STDVD-ROM GDR8163B, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
ide1 at 0x170-0x177,0x376 on irq 15
hda: attached ide-disk driver.
hda: host protected area => 1
hda: 160086528 sectors (81964 MB) w/2048KiB Cache, CHS=9964/255/63, UDMA(133)
hdb: attached ide-disk driver.
hdb: host protected area => 1
hdb: 160086528 sectors (81964 MB) w/2048KiB Cache, CHS=9964/255/63, UDMA(133)
hdc: attached ide-cdrom driver.
hdc: ATAPI 48X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.12
hdd: attached ide-cdrom driver.
hdd: ATAPI 52X DVD-ROM drive, 256kB Cache, UDMA(33)
Partition check:
hda: hda1 hda2 hda3
hdb: hdb1 hdb2
SCSI subsystem driver Revision: 1.00
kmod: failed to exec /sbin/modprobe -s -k scsi_hostadapter, errno = 2
md: linear personality registered as nr 1
md: raid0 personality registered as nr 2
md: raid1 personality registered as nr 3
md: raid5 personality registered as nr 4
raid5: measuring checksumming speed
8regs : 3196.000 MB/sec
32regs : 2150.800 MB/sec
pIII_sse : 5091.600 MB/sec
pII_mmx : 3171.200 MB/sec
p5_mmx : 3168.000 MB/sec
raid5: using function: pIII_sse (5091.600 MB/sec)
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
LVM version 1.0.8(17/11/2003)
Initializing Cryptographic API
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 8192 buckets, 64Kbytes
TCP: Hash tables configured (established 262144 bind 65536)
Linux IP multicast router 0.06 plus PIM-SM
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 120k freed
apm: BIOS not found.
Linux agpgart interface v0.99 (c) Jeff Hartmann
agpgart: Maximum main memory to use for agp memory: 816M
agpgart: Unsupported Via chipset (device id: 0258), you might want to try agp_try_unsupported=1.
agpgart: no supported devices found.
scsi0 : SCSI host adapter emulation for IDE ATAPI devices
NTFS driver v1.1.22 [Flags: R/O MODULE]
via-rhine.c:v1.10-LK1.1.19 July-12-2003 Written by Donald Becker
http://www.scyld.com/network/via-rhine.html
eth0: VIA VT6102 Rhine-II at 0xd000, 00:0b:6a:9e:ce:bc, IRQ 11.
eth0: MII PHY found at address 1, status 0x7849 advertising 05e1 Link 0000.
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
ehci_hcd 00:10.4: VIA Technologies, Inc. USB 2.0
ehci_hcd 00:10.4: irq 5, pci mem f8b41800
usb.c: new USB bus registered, assigned bus number 1
ehci_hcd 00:10.4: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
hub.c: USB hub found
hub.c: 8 ports detected
uhci.c: USB Universal Host Controller Interface driver v1.1
uhci.c: USB UHCI at I/O 0xc000, IRQ 11
usb.c: new USB bus registered, assigned bus number 2
hub.c: 2 ports detected
uhci.c: USB UHCI at I/O 0xc400, IRQ 11
usb.c: new USB bus registered, assigned bus number 3
uhci.c: USB UHCI at I/O 0xc800, IRQ 10
usb.c: new USB bus registered, assigned bus number 4
uhci.c: USB UHCI at I/O 0xcc00, IRQ 10
usb.c: new USB bus registered, assigned bus number 5
gameport0: Emu10k1 Gameport at 0xb800 size 8 speed 1104 kHz
pcnet32.c:v1.30h 06.24.2004
tsbogend@alpha.franken.de
pcnet32: PCnet/FAST 79C971 at 0xb000, warning: CSR address invalid,
using instead PROM address of 00 60 b0 ec 83 56
tx_start_pt(0x0c00):~220 bytes, BCR18(9861):BurstWrEn BurstRdEn NoUFlow
SRAMSIZE=0x7f00, SRAM_BND=0x3f00, assigned IRQ 10.
eth1: registered as PCnet/FAST 79C971
pcnet32: 1 cards_found.
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: shpc_init : shpc_cap_offset == 0
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
pciehp: PCI Express Hot Plug Controller Driver version: 0.5
hub.c: new USB device 00:10.1-1, assigned address 2
usb.c: USB device 2 (vend/prod 0x1131/0x1001) is not claimed by any active driver.
hub.c: new USB device 00:10.0-1, assigned address 2
usb.c: USB device 2 (vend/prod 0x46d/0xc505) is not claimed by any active driver.
hub.c: new USB device 00:10.0-2, assigned address 3
hub.c: 4 ports detected
hub.c: new USB device 00:10.0-2.2, assigned address 4
usb.c: USB device 4 (vend/prod 0x3f0/0x4f11) is not claimed by any active driver.
BlueZ Core ver 2.4 Copyright (C) 2000,2001 Qualcomm Inc
Written 2000,2001 by Maxim Krasnyansky <
maxk@qualcomm.com>
usb.c: registered new driver usbmouse
BlueZ HCI USB driver ver 2.7 Copyright (C) 2000,2001 Qualcomm Inc
maxk@qualcomm.com>
usb.c: registered new driver hci_usb
input0: Logitech USB Receiver on usb2:2.1
usbmouse.c: v1.6:USB HID Boot Protocol mouse driver
usb.c: registered new driver hiddev
input: USB HID v1.10 Keyboard [Logitech USB Receiver] on usb2:2.0
hid-core.c: v1.8.1 Andreas Gal, Vojtech Pavlik <
vojtech@suse.cz>
hid-core.c: USB HID support drivers
mice: PS/2 mouse device common for all mice
usb.c: registered new driver usblp
printer.c: usblp0: USB Bidirectional printer dev 4 if 1 alt 0 proto 2 vid 0x03F0 pid 0x4F11
printer.c: v0.13: USB Printer Device Class driver
usb.c: registered new driver usbkbd
usbkbd.c: :USB HID Boot Protocol keyboard driver
hub.c: new USB device 00:10.0-2.4, assigned address 5
usb.c: USB device 5 (vend/prod 0xd7d/0x1400) is not claimed by any active driver.
Initializing USB Mass Storage driver...
usb.c: registered new driver usb-storage
scsi1 : SCSI emulation for USB Mass Storage devices
Vendor: Model: Memorex TD 2B Rev: PMAP
Type: Direct-Access ANSI SCSI revision: 02
Attached scsi removable disk sda at scsi1, channel 0, id 0, lun 0
SCSI device sda: 2031616 512-byte hdwr sectors (1040 MB)
sda: Write Protect is off
sda: sda1
WARNING: USB Mass Storage data integrity not assured
USB Mass Storage device found at 5
USB Mass Storage support registered.
Installing knfsd (copyright (C) 1996
okir@monad.swb.de).
parport0: PC-style at 0x378 (0x778) [PCSPP,TRISTATE,EPP]
parport0: irq 7 detected
lp0: using parport0 (polling).
keyboard: Timeout - AT keyboard not present?(f3)
Potete aiutarmi ?
Cia e grazie ancora
