Ciao!!!
Configurazione iniziale
HackerGates
- absinthe
- Slackware: 12.1 - defunct
- Kernel: 2.6.32-5-amd64
- Desktop: gnome
cd /etc/X11
risetta l'xorg.conf di default:
rm xorg.conf
cp xorg.conf-vesa xorg.conf
avvia il server X
copia il file di log in una partizione accessibile ad un altro os, apri il file di log con un editor e postalo qua.
M
- alessiodf
- Kernel: 2.6.26.4
- Desktop: Kde 4.1
First specify a mouse protocol type. Choose one from the following list:
1. Auto [Auto detect]
2. SysMouse [SysMouse]
3. MouseSystems [Mouse Systems (3-button protocol)]
4. PS/2 [PS/2 Mouse]
5. Microsoft [Microsoft compatible (2-button protocol)]
6. Busmouse [Bus Mouse]
7. IMPS/2 [IntelliMouse PS/2]
8. ExplorerPS/2 [Explorer PS/2]
9. GlidePointPS/2 [GlidePoint PS/2]
10. MouseManPlusPS/2 [MouseManPlus PS/2]
11. NetMousePS/2 [NetMouse PS/2]
12. NetScrollPS/2 [NetScroll PS/2]
13. ThinkingMousePS/2 [ThinkingMouse PS/2]
14. AceCad [AceCad]
Please answer the following question with either 'y' or 'n'.
Do you want to enable Emulate3Buttons? Codice: Seleziona tutto
Now give the full device name that the mouse is connected to, for example
/dev/tty00. Just pressing enter will use the default, /dev/mouse.
Mouse device: Codice: Seleziona tutto
1 Generic 101-key PC
2 Generic 102-key (Intl) PC
3 Generic 104-key PC
4 Generic 105-key (Intl) PC
5 Dell 101-key PC
6 Everex STEPnote
7 Keytronic FlexPro
8 Microsoft Natural
9 Northgate OmniKey 101
10 Winbook Model XP5
11 Japanese 106-key
12 PC-98xx Series
13 A4Tech KB-21
14 A4Tech KBS-8
15 Brazilian ABNT2
16 Acer AirKey V
Enter a number to choose the keyboard.
1 U.S. English
2 Arabic
3 Albania
4 Armenia
5 Azerbaijan
6 Belarus
7 Belgium
8 Bangladesh
9 India
10 Bosnia and Herzegovina
11 Brazil
12 Bulgaria
13 Myanmar
14 Canada
15 Croatia
16 Czechia
17 Denmark
18 Netherlands
Enter a number to choose the country.
Poi ancora invio...
Do you want to select additional XKB options (group switcher,
group indicator, etc.)? ndopo ancora invio...
hsync in kHz; monitor type with characteristic modes
1 31.5; Standard VGA, 640x480 @ 60 Hz
2 31.5 - 35.1; Super VGA, 800x600 @ 56 Hz
3 31.5, 35.5; 8514 Compatible, 1024x768 @ 87 Hz interlaced (no 800x600)
4 31.5, 35.15, 35.5; Super VGA, 1024x768 @ 87 Hz interlaced, 800x600 @ 56 Hz
5 31.5 - 37.9; Extended Super VGA, 800x600 @ 60 Hz, 640x480 @ 72 Hz
6 31.5 - 48.5; Non-Interlaced SVGA, 1024x768 @ 60 Hz, 800x600 @ 72 Hz
7 31.5 - 57.0; High Frequency SVGA, 1024x768 @ 70 Hz
8 31.5 - 64.3; Monitor that can do 1280x1024 @ 60 Hz
9 31.5 - 79.0; Monitor that can do 1280x1024 @ 74 Hz
10 31.5 - 82.0; Monitor that can do 1280x1024 @ 76 Hz
11 Enter your own horizontal sync range
2 50-90
3 50-100
4 40-150
5 Enter your own vertical sync range
The strings are free-form, spaces are allowed.
Enter an identifier for your monitor definition: Codice: Seleziona tutto
Now we must configure video card specific settings. At this point you can
choose to make a selection out of a database of video card definitions.
Because there can be variation in Ramdacs and clock generators even
between cards of the same model, it is not sensible to blindly copy
the settings (e.g. a Device section). For this reason, after you make a
selection, you will still be asked about the components of the card, with
the settings from the chosen database entry presented as a strong hint.
The database entries include information about the chipset, what driver to
run, the Ramdac and ClockChip, and comments that will be included in the
Device section. However, a lot of definitions only hint about what driver
to run (based on the chipset the card uses) and are untested.
If you can't find your card in the database, there's nothing to worry about.
You should only choose a database entry that is exactly the same model as
your card; choosing one that looks similar is just a bad idea (e.g. a
GemStone Snail 64 may be as different from a GemStone Snail 64+ in terms of
hardware as can be).
Do you want to look at the card database? yespoi prova a dargli una di queste...
0 * Generic VESA compatible
1 * Generic VGA compatible
2 * Unsupported VGA compatible poi ancora invio
How much video memory do you have on your video card:
1 256K
2 512K
3 1024K
4 2048K
5 4096K
6 8192K
7 16384K
8 32768K
9 65536K
10 131072K
11 262144K
12 OtherCodice: Seleziona tutto
Enter an identifier for your video card definition: Codice: Seleziona tutto
"1280x1024" "1024x768" "800x600" "640x480" for 8-bit
"1280x1024" "1024x768" "800x600" "640x480" for 16-bit
"1280x1024" "1024x768" "800x600" "640x480" for 24-bit
Modes that cannot be supported due to monitor or clock constraints will
be automatically skipped by the server.
1 Change the modes for 8-bit (256 colors)
2 Change the modes for 16-bit (32K/64K colors)
3 Change the modes for 24-bit (24-bit color)
4 The modes are OK, continue.
Enter your choice: Codice: Seleziona tutto
Please specify which color depth you want to use by default:
1 1 bit (monochrome)
2 4 bits (16 colors)
3 8 bits (256 colors)
4 16 bits (65536 colors)
5 24 bits (16 million colors)
I am going to write the xorg.conf file now. Make sure you don't accidently
overwrite a previously configured one.
Do you want it written to the current directory as 'xorg.conf'? PS: che scheda video hai? che monitor?? che scheda madre hai? se non lo sai, dai il comando "lspci"
ciaoZ!
HackerGates
