eccomi!
ecco il
dmesg
root@darkstar:/dev# dmesg
Linux version 2.4.31 (root@tree) (gcc version 3.3.5) #6 Sun Jun 5 19:04:47 PDT 2005
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000000fff0000 (usable)
BIOS-e820: 000000000fff0000 - 000000000fff3000 (ACPI NVS)
BIOS-e820: 000000000fff3000 - 0000000010000000 (ACPI data)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
255MB LOWMEM available.
On node 0 totalpages: 65520
zone(0): 4096 pages.
zone(1): 61424 pages.
zone(2): 0 pages.
Kernel command line: BOOT_IMAGE=Linux ro root=342
Initializing CPU#0
Detected 1403.212 MHz processor.
Console: colour dummy device 80x25
Calibrating delay loop... 2798.38 BogoMIPS
Memory: 256020k/262080k available (1832k kernel code, 5672k reserved, 607k data, 120k init, 0k highmem)
Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
Inode cache hash table entries: 16384 (order: 5, 131072 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 16384 (order: 4, 65536 bytes)
Page-cache hash table entries: 65536 (order: 6, 262144 bytes)
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 256K (64 bytes/line)
CPU: After generic, caps: 0383f9ff c1cbf9ff 00000000 00000000
CPU: Common caps: 0383f9ff c1cbf9ff 00000000 00000000
CPU: AMD Athlon(tm) XP 1600+ stepping 02
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
mtrr: v1.40 (20010327) Richard Gooch (rgooch@atnf.csiro.au)
mtrr: detected mtrr type: Intel
PCI: PCI BIOS revision 2.10 entry at 0xfb470, last bus=1
PCI: Using configuration type 1
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
PCI: Via IRQ fixup
PCI: Using IRQ router VIA [1106/3074] at 00:11.0
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
VFS: Disk quotas vdquot_6.5.1
Journalled Block Device driver loaded
vesafb: framebuffer at 0xd8000000, mapped to 0xd080d000, size 3072k
vesafb: mode is 1024x768x16, linelength=2048, pages=0
vesafb: protected mode interface info at c000:0a15
vesafb: scrolling: redraw
vesafb: directcolor: size=0:5:6:5, shift=0:11:5:0
Console: switching to colour frame buffer device 128x48
fb0: VESA VGA frame buffer device
pty: 512 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with HUB-6 MANY_PORTS MULTIPORT SHARE_IRQ SERIAL_PCI enabled
ttyS00 at 0x03f8 (irq = 4) is a 16550A
ttyS01 at 0x02f8 (irq = 3) is a 16550A
Real Time Clock Driver v1.10f
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
RAMDISK driver initialized: 16 RAM disks of 7777K size 1024 blocksize
loop: loaded (max 8 devices)
Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 00:11.1
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8233 (rev 00) IDE UDMA100 controller on pci00:11.1
ide0: BM-DMA at 0xdc00-0xdc07, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xdc08-0xdc0f, BIOS settings: hdc:DMA, hdd:DMA
hda: QUANTUM FIREBALLP AS40.0, ATA DISK drive
hdb: WDC WD1600JB-00GVA0, ATA DISK drive
blk: queue c03af460, I/O limit 4095Mb (mask 0xffffffff)
blk: queue c03af59c, I/O limit 4095Mb (mask 0xffffffff)
hdc: _NEC DVD_RW ND-3540A, ATAPI CD/DVD-ROM drive
hdd: Pioneer DVD-ROM ATAPIModel DVD-116 0122, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
ide1 at 0x170-0x177,0x376 on irq 15
hda: attached ide-disk driver.
hda: host protected area => 1
hda: 78177792 sectors (40027 MB) w/1902KiB Cache, CHS=4866/255/63, UDMA(100)
hdb: attached ide-disk driver.
hdb: host protected area => 1
hdb: 312581808 sectors (160042 MB) w/8192KiB Cache, CHS=19457/255/63, UDMA(100)
hdc: attached ide-cdrom driver.
hdc: ATAPI 48X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.12
hdd: attached ide-cdrom driver.
hdd: ATAPI 40X DVD-ROM drive, 256kB Cache, UDMA(66)
Partition check:
hda: hda1
hdb: hdb1 hdb2 hdb3 hdb4
SCSI subsystem driver Revision: 1.00
kmod: failed to exec /sbin/modprobe -s -k scsi_hostadapter, errno = 2
md: linear personality registered as nr 1
md: raid0 personality registered as nr 2
md: raid1 personality registered as nr 3
md: raid5 personality registered as nr 4
raid5: measuring checksumming speed
8regs : 2011.200 MB/sec
32regs : 1347.200 MB/sec
pIII_sse : 3810.400 MB/sec
pII_mmx : 3283.600 MB/sec
p5_mmx : 4195.200 MB/sec
raid5: using function: pIII_sse (3810.400 MB/sec)
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
LVM version 1.0.8(17/11/2003)
Initializing Cryptographic API
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 2048 buckets, 16Kbytes
TCP: Hash tables configured (established 16384 bind 32768)
Linux IP multicast router 0.06 plus PIM-SM
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
FAT: bogus logical sector size 0
UMSDOS: msdos_read_super failed, mount aborted.
reiserfs: found format "3.6" with standard journal
reiserfs: checking transaction log (device ide0(3,66)) ...
for (ide0(3,66))
ide0(3,66):Using r5 hash to sort names
VFS: Mounted root (reiserfs filesystem) readonly.
Freeing unused kernel memory: 120k freed
Adding Swap: 562260k swap-space (priority -1)
apm: BIOS version 1.2 Flags 0x07 (Driver version 1.16)
Linux agpgart interface v0.99 (c) Jeff Hartmann
agpgart: Maximum main memory to use for agp memory: 203M
agpgart: Detected Via Apollo Pro KT266 chipset
agpgart: AGP aperture is 128M @ 0xd0000000
8139too Fast Ethernet driver 0.9.26
PCI: Found IRQ 10 for device 00:0a.0
PCI: Sharing IRQ 10 with 00:09.1
eth0: RealTek RTL8139 at 0xd0c46000, 00:30:84:3b:f7:1b, IRQ 10
eth0: Identified 8139 chip type 'RTL-8139C'
scsi0 : SCSI host adapter emulation for IDE ATAPI devices
reiserfs: checking transaction log (device ide0(3,67)) ...
for (ide0(3,67))
ide0(3,67):Using r5 hash to sort names
NTFS driver v1.1.22 [Flags: R/O MODULE]
NTFS: unkown option 'nls'
Linux Kernel Card Services 3.1.22
options: [pci] [cardbus] [pm]
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Intel ISA PCIC probe: not found.
Databook TCIC-2 PCMCIA probe: not found.
ds: no socket drivers loaded!
eth0: link down
PCI: Found IRQ 11 for device 00:0d.0
PCI: Sharing IRQ 11 with 00:09.2
PCI: Sharing IRQ 11 with 00:11.2
PCI: Sharing IRQ 11 with 00:11.3
PCI: Sharing IRQ 11 with 00:11.4
NVRM: loading NVIDIA Linux x86 NVIDIA Kernel Module 1.0-7174 Tue Mar 22 06:44:39 PST 2005
spurious 8259A interrupt: IRQ7.
NTFS: Warning! NTFS volume version is Win2k+: Mounting read-only
tty_io.c: process 457 (mc) used obsolete /dev/cua - update software to use /dev/ttyS15
tty_io.c: process 457 (mc) used obsolete /dev/cua - update software to use /dev/ttyS30
Cyclades driver 2.3.2.8 2000/07/06 18:14:16
built Jun 5 2005 18:46:40
Sony CDU-535: probing base address 340
Did not find a Sony CDU-535 drive
ftape v3.04d 25/11/97
(c) 1993-1996 Bas Laarhoven (bas@vimec.nl)
(c) 1995-1996 Kai Harrekilde-Petersen (khp@dolphinics.no)
(c) 1996-1997 Claus-Justus Heine (claus@momo.math.rwth-aachen.de)
QIC-117 driver for QIC-40/80/3010/3020 floppy tape drives
Compiled for Linux version 2.4.31
[000] ftape-init.c (ftape_init) - installing QIC-117 floppy tape hardware drive ... .
[001] ftape-init.c (ftape_init) - ftape_init @ 0xd22c6060.
[002] ftape-buffer.c (add_one_buffer) - buffer nr #1 @ c15508c0, dma area @ c0f28000.
[003] ftape-buffer.c (add_one_buffer) - buffer nr #2 @ c15506c0, dma area @ c0f20000.
[004] ftape-buffer.c (add_one_buffer) - buffer nr #3 @ c1550640, dma area @ c0f18000.
[005] ftape-calibr.c (time_inb) - inb() duration: 1414 nsec.
[006] ftape-calibr.c (ftape_calibrate) - TC for `ftape_udelay()' = 89 nsec (at 40959 counts).
[007] ftape-calibr.c (ftape_calibrate) - TC for `fdc_wait()' = 3053 nsec (at 2559 counts).
zftape for ftape v3.04d 25/11/97
(c) 1996, 1997 Claus-Justus Heine (claus@momo.math.rwth-aachen.de)
vfs interface for ftape floppy tape driver.
Support for QIC-113 compatible volume table, dynamic memory allocation
and builtin compression (lzrw3 algorithm).
[008] zftape-init.c (zft_init) - zft_init @ 0xd22ebba0.
[009] zftape-init.c (zft_init) - installing zftape VFS interface for ftape driver ....
[010] fdc-io.c (fdc_config) - fdc base: 0x3f0, irq: 6, dma: 2.
[011] fdc-io.c (fdc_probe) - Type 82077AA FDC found.
[012] ftape-ctl.c (ftape_activate_drive) - no tape drive found !.
[013] ftape-ctl.c (ftape_enable) - ftape_activate_drive(&ftape_status.fti_drive_type) failed: -19.
[014] zftape-ctl.c (_zft_open) - ftape_enable failed: -19.
[015] zftape-init.c (zft_open) - _ftape_open failed.
paride: version 1.06 installed (parport)
pcd: pcd version 1.07, major 46, nice 0
pcd0: Autoprobe failed
pcd: No CD-ROM drive found
pt: pt version 1.04, major 96
pt0: Autoprobe failed
pt: No ATAPI tape drive detected
CSLIP: code copyright 1989 Regents of the University of California
PPP generic driver version 2.4.2
parport0: PC-style at 0x378 [PCSPP,TRISTATE]
lp0: using parport0 (polling).
e arriva lo
xorg.conf
# File generated by xf86config.
# Copyright (c) 1999 by The XFree86 Project, Inc.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE XFREE86 PROJECT BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
# WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
# OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
# Except as contained in this notice, the name of the XFree86 Project shall
# not be used in advertising or otherwise to promote the sale, use or other
# dealings in this Software without prior written authorization from the
# XFree86 Project.
# Refer to the XF86Config(4/5) man page for details about the format of
# this file.
# NOTE: This is a NEW IMPROVED version of XF86Config-fbdev that uses the vesa
# driver instead of the fbdev driver. Thanks to Kenneth Fanyo who pointed
# this out to me. :)
# This XF86Config file is designed for use with the VESA framebuffer.
# This generic interface should work with nearly all video cards
# (although not every card will support every resolution).
# With the new driver, it should no longer be required to have frame buffer
# support in the kernel, or to run it on the console.
# Enjoy! :)
# -- volkerdi@slackware.com
# Module section -- this section is used to specify
# which dynamically loadable modules to load.
Section "Module"
# This loads the DBE extension module.
Load "dbe" # Double buffer extension
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
SubSection "extmod"
Option "omit xfree86-dga" # don't initialise the DGA extension
EndSubSection
# This loads the font modules
Load "type1"
Load "freetype"
#Load "speedo"
# This loads the GLX module
Load "glx"
Load "dri"
# Richiesto dai drivers NVIDIA ma non trovato
# Load "GLcore"
EndSection
# Files section. This allows default font and rgb paths to be set
Section "Files"
# The location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
RgbPath "/usr/X11R6/lib/X11/rgb"
# Multiple FontPath entries are allowed (which are concatenated together),
# as well as specifying multiple comma-separated entries in one FontPath
# command (or a combination of both methods)
# If you don't have a floating point coprocessor and emacs, Mosaic or other
# programs take long to start up, try moving the Type1 and Speedo directory
# to the end of this list (or comment them out).
FontPath "/usr/X11R6/lib/X11/fonts/local/"
FontPath "/usr/X11R6/lib/X11/fonts/misc/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
FontPath "/usr/X11R6/lib/X11/fonts/CID/"
FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic/"
# ModulePath can be used to set a search path for the X server modules.
# The default path is shown here.
# ModulePath "/usr/X11R6/lib/modules"
EndSection
# Server flags section.
Section "ServerFlags"
# Uncomment this to cause a core dump at the spot where a signal is
# received. This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
# Option "NoTrapSignals"
# Uncomment this to disable the <Crtl><Alt><Fn> VT switch sequence
# (where n is 1 through 12). This allows clients to receive these key
# events.
# Option "DontVTSwitch"
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
# Option "DontZap"
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
# sequences. This allows clients to receive these key events.
# Option "DontZoom"
# Uncomment this to disable tuning with the xvidtune client. With
# it the client can still run and fetch card and monitor attributes,
# but it will not be allowed to change them. If it tries it will
# receive a protocol error.
# Option "DisableVidModeExtension"
# Uncomment this to enable the use of a non-local xvidtune client.
# Option "AllowNonLocalXvidtune"
# Uncomment this to disable dynamically modifying the input device
# (mouse and keyboard) settings.
# Option "DisableModInDev"
# Uncomment this to enable the use of a non-local client to
# change the keyboard or mouse settings (currently only xset).
# Option "AllowNonLocalModInDev"
# Set the basic blanking screen saver timeout.
# Option "blank time" "10" # 10 minutes
# Set the DPMS timeouts. These are set here because they are global
# rather than screen-specific. These settings alone don't enable DPMS.
# It is enabled per-screen (or per-monitor), and even then only when
# the driver supports it.
# Option "standby time" "20"
# Option "suspend time" "30"
# Option "off time" "60"
# On some platform the server needs to estimate the sizes of PCI
# memory and pio ranges. This is done by assuming that PCI ranges
# don't overlap. Some broken BIOSes tend to set ranges of inactive
# devices wrong. Here one can adjust how aggressive the assumptions
# should be. Default is 0.
# Option "EstimateSizesAggresively" "0"
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
Identifier "Keyboard1"
Driver "kbd"
# For most OSs the protocol can be omitted (it defaults to "Standard").
# When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
# uncomment the following line.
# Option "Protocol" "Xqueue"
# Set the keyboard auto repeat parameters. Not all platforms implement
# this.
# Option "AutoRepeat" "500 5"
# Specifiy which keyboard LEDs can be user-controlled (eg, with xset(1)).
# Option "Xleds" "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
# Option "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a European
# keyboard, you will probably want to use one of:
# Option "XkbModel" "pc102"
# Option "XkbModel" "pc105"
# If you have a Microsoft Natural keyboard, you can use:
# Option "XkbModel" "microsoft"
# If you have a US "windows" keyboard you will want:
# Option "XkbModel" "pc104"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# Option "XkbLayout" "de"
# or:
# Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# Option "XkbOptions" "ctrl:swapcaps"
# These are the default XKB settings for X.Org
# Option "XkbRules" "xorg"
# Option "XkbModel" "pc101"
# Option "XkbLayout" "us"
# Option "XkbVariant" ""
# Option "XkbOptions" ""
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
Identifier "Mouse1"
Driver "mouse"
# On platforms where PnP mouse detection is supported the following
# protocol setting can be used when using a newer PnP mouse:
# Option "Protocol" "Auto"
# The available mouse protocols types that you can set below are:
# Auto BusMouse GlidePoint GlidePointPS/2 IntelliMouse IMPS/2
# Logitech Microsoft MMHitTab MMSeries Mouseman MouseManPlusPS/2
# MouseSystems NetMousePS/2 NetScrollPS/2 OSMouse PS/2 SysMouse
# ThinkingMouse ThinkingMousePS/2 Xqueue
Option "Protocol" "PS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate 3Buttons" "no"
# The mouse device. The device is normally set to /dev/mouse,
# which is usually a symbolic link to the real device.
Option "Device" "/dev/mouse"
# Option "Device" "/dev/psaux"
# Option "Device" "/dev/ttyS0"
# Option "Device" "/dev/ttyS1"
# When using XQUEUE, comment out the above two lines, and uncomment
# the following line.
# Baudrate and SampleRate are only for some Logitech mice. In
# almost every case these lines should be omitted.
# Option "BaudRate" "9600"
# Option "SampleRate" "150"
# Emulate3Buttons is an option for 2-button Microsoft mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
# Option "Emulate3Buttons"
# Option "Emulate3Timeout" "50"
# ChordMiddle is an option for some 3-button Logitech mice
# Option "ChordMiddle"
EndSection
# Some examples of extended input devices
# Section "InputDevice"
# Identifier "spaceball"
# Driver "magellan"
# Option "Device" "/dev/cua0"
# EndSection
# Identifier "spaceball2"
# Driver "spaceorb"
# EndSection
# Identifier "touchscreen0"
# Driver "microtouch"
# Option "MinX" "1412"
# Option "MaxX" "15184"
# Option "MinY" "15372"
# Option "MaxY" "1230"
# Option "ScreenNumber" "0"
# Option "ReportingMode" "Scaled"
# Option "ButtonNumber" "1"
# Option "SendCoreEvents"
# EndSection
# Identifier "touchscreen1"
# Driver "elo2300"
# Option "MinX" "231"
# Option "MaxX" "3868"
# Option "MinY" "3858"
# Option "MaxY" "272"
# Option "ButtonThreshold" "17"
# EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
Identifier "My Monitor"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY. REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
HorizSync 30 - 70.0
# HorizSync 30-64 # multisync
# HorizSync 31.5, 35.2 # multiple fixed sync frequencies
# HorizSync 15-25, 30-50 # multiple ranges of sync frequencies
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
VertRefresh 50-160
EndSection
# Graphics device section
# Any number of graphics device sections may be present
Section "Device"
Identifier "VESA Framebuffer"
Driver "nvidia"
#VideoRam 4096
# Insert Clocks lines here if appropriate
EndSection
# Screen sections
# Any number of screen sections may be present. Each describes
# the configuration of a single screen. A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
Section "Screen"
Identifier "Screen 1"
Device "VESA Framebuffer"
Monitor "My Monitor"
# If your card can handle it, a higher default color depth (like 24 or 32)
# is highly recommended.
# DefaultDepth 8
# DefaultDepth 16
DefaultDepth 24
# DefaultDepth 32
# "1024x768" is also a conservative usable default resolution. If you
# have a better monitor, feel free to try resolutions such as
# "1152x864", "1280x1024", "1600x1200", and "1800x1400" (or whatever your
# card/monitor can produce)
Subsection "Display"
Depth 8
Modes "1024x768" "800x600" "640x480"
EndSubsection
Depth 16
EndSubsection
Depth 24
EndSubsection
Depth 32
EndSubsection
EndSection
# ServerLayout sections.
# Any number of ServerLayout sections may be present. Each describes
# the way multiple screens are organised. A specific ServerLayout
# section may be specified from the X server command line with the
# "-layout" option. In the absence of this, the first section is used.
# When now ServerLayout section is present, the first Screen section
# is used alone.
Section "ServerLayout"
# The Identifier line must be present
Identifier "Simple Layout"
# Each Screen line specifies a Screen section name, and optionally
# the relative position of other screens. The four names after
# primary screen name are the screens to the top, bottom, left and right
# of the primary screen. In this example, screen 2 is located to the
# right of screen 1.
Screen "Screen 1"
# Each InputDevice line specifies an InputDevice section name and
# optionally some options to specify the way the device is to be
# used. Those options include "CorePointer", "CoreKeyboard" and
# "SendCoreEvents".
InputDevice "Mouse1" "CorePointer"
InputDevice "Keyboard1" "CoreKeyboard"
EndSection
Section "DRI"
mode 0666
EndSection
