K3b: unable determinate DVD media type
bbg5ne
Messaggio da bbg5ne »
dvd-dati...comunque come si fa in entrambi i casi???
bbg5ne
quessto è il debugging output:
System
K3b Version: 0.12.17
KDE Version: 3.5.1
QT Version:  3.3.6
Kernel:      2.6.15.6
Devices
HL-DT-ST DVDRAM GSA-4120B A102 (/dev/hdd, ) at  [CD-R; CD-RW; CD-ROM; DVD-ROM; DVD-RAM; DVD-R; DVD-RW; DVD+R; DVD+RW; DVD+R DL] [DVD-ROM; DVD-R Sequential; DVD-RAM; DVD-RW Restricted Overwrite; DVD-RW Sequential; DVD+RW; DVD+R; DVD+R Double Layer; CD-ROM; CD-R; CD-RW] [SAO; TAO; RAW; SAO/R96P; SAO/R96R; RAW/R16; RAW/R96P; RAW/R96R; Restricted Overwrite]
HL-DT-ST DVD-ROM GDR8160B 0009 (/dev/hdc, ) at /mnt/cdrom [CD-ROM; DVD-ROM] [DVD-ROM; CD-ROM] [None]
nessuno ha qualche idea????
:roll:
bbg5ne
questi sono i risultati cercando di creare una copia da dvd a iso:
root@mkLinux:~/Desktop# growisofs -Z /dev/hdc -R -J nome_iso.iso
:-( /dev/hdc: media is not recognized as recordable DVD: 8
root@mkLinux:~/Desktop# cdrecord dev=/dev/hdc -v nome_iso.iso
cdrecord: No write mode specified.
cdrecord: Asuming -tao mode.
cdrecord: Future versions of cdrecord may have different drive dependent defaults.
cdrecord: Continuing in 5 seconds...
Cdrecord-Clone 2.01 (i686-pc-linux-gnu) Copyright (C) 1995-2004 Jörg Schilling
cdrecord: Warning: Running on Linux-2.6.15.6
cdrecord: There are unsettled issues with Linux-2.5 and newer.
cdrecord: If you have unexpected problems, please try Linux-2.4 or Solaris.
TOC Type: 1 = CD-ROM
scsidev: '/dev/hdc'
devname: '/dev/hdc'
scsibus: -2 target: -2 lun: -2
Warning: Open by 'devname' is unintentional and not supported.
Linux sg driver version: 3.5.27
Using libscg version 'schily-0.8'.
SCSI buffer size: 64512
atapi: 1
Device type    : Removable CD-ROM
Version        : 0
Response Format: 2
Capabilities   :
Vendor_info    : 'HL-DT-ST'
Identifikation : 'DVD-ROM GDR8160B'
Revision       : '0009'
Device seems to be: Generic mmc2 DVD-ROM.
Current: 0x0008
Profile: 0x0010
Profile: 0x0008 (current)
cdrecord: Sorry, no CD/DVD-Recorder or unsupported CD/DVD-Recorder found on this target.
bbg5ne
qualcuno mi sa dire se è giusto che i permessi sia di lettore che masterizzatore siano 660? :roll:
bbg5ne
ho notato deentro le opzioni che mancano 2 programmi esterni uno è tcprobe e l'altro è eMovix!
qualcuno sa se puo essere causato da queste mancanze il mio problema?
goldy
Slackware: Current
Kernel: 2.6.26.5
Desktop: KDE 3.5.10
Messaggio da goldy »
tcprobe e eMovix non c'entrano
anche perchè non riesci neanche a masterizzare con cdrecord.
qui
http://www.debianizzati.org/component/o ... itstart,6/
c'è un tipo che ha un problema similie al tuo e ha risolto
Altre idee non ne ho
bbg5ne
sigh non mi sembra proprio lo stesso!!! :(
comunque
comunque ho fatto dpkg-reconfigure cdrecord
ho spuntato l'opzione che abilita il gruppo cdrom
ho impostato k3b con gruppo cdrom
quale è la traduzione in slack???
la cosa bnrutta è che fallisce la creazione dell'immagine che poi deve masterizzare, cosa che non succede con i cd...
come inizia a leggere per creare l'immagine mi da l'errore...:(
Ultima modifica di bbg5ne il mer 27 set 2006, 21:10, modificato 1 volta in totale.
goldy
Slackware: Current
Kernel: 2.6.26.5
Desktop: KDE 3.5.10
Veramente io avevo focalizzato l'errore
che è lo stesso che hai anche tu
e anche tu hai degli errori in lettura , da quello che ho letto dai tuoi post,
e quindi , la strada probabilmente da percorrere per risolvere il problema
potrebbe essere questa.
Nel thread che ti ho linkato ci sono diverse soluzioni
il gruppo cdrom da affibiare al masterizzatore, e metterci dentro l'utente,
i moduli ide-cd da caricare, eventualmente ide-scsi,
non lo so dovresti fare delle prove.
bbg5ne
goldy ha scritto:Veramente io avevo focalizzato l'errore
ops forse hai ragione!!!
come si fa a fare entrambe le cose?
tango13
Messaggio da tango13 »
bbg5ne, hai poi risolto questo problema?
Te lo chiedo perché anche io sembro afflitto dallo stesso mistero... :?
I CD vanno regolarmente, sia in lettura che in scrittura.
I DVD vanno bene in lettura ma non riesco a scriverli.
Sto impazzendo da un paio di giorni appresso a questo problema ma non riesco ancora a trovare il bandolo della matassa.
Ho provato vari supporti ma sempre con lo stesso risultato.
Ho provato varie ricompilazioni del kernel aggiungendo o togliendo qualcosa ma nisba!
Ho addirittura provato a sostituire il masterizzatore prendendone in prestito uno da un vecchio computer, ma anche quello ha dato lo stesso problema!
Tra l'altro, sublime rottura di @#£$%#?^, ogni volta che provo, tentando qualche modifica (e il tentativo regolarmente fallisce), il masterizzatore viene messo offline, e l'unico modo per rimetterlo online è fare un reboot... :evil: :evil: :evil: :evil:
Bah... Vediamo un po' se riusciamo a uscire da questa situazione...
Ciauz
bbg5ne
si è stato risolto...ma quasi mi vergogno a raccontarvi come... :oops:
in pratica...quelli che andavo a masterizzare non erano dvd, ma cd... :oops:
aho ero convinto che fossero dvd!!! :oops:
il tuo problema mi sembra diverso...se provi a masterizzare un immagine iso riesci a farlo??? :roll:
tango13
bbg5ne ha scritto:si è stato risolto...ma quasi mi vergogno a raccontarvi come... :oops:
Non ti preoccupare... succede!
Soprattutto quando ci si va a impelagare in rogne del genere alla fine non si riesce neanche più a vedere le cose sotto al naso...
Però no, nel mio caso non ho confuso i cd con i dvd :)
Magari lo avessi fatto! :D
bbg5ne ha scritto:se provi a masterizzare un immagine iso riesci a farlo??? :roll:
No, non riesco a fare niente con i dvd in scrittura. :(
Mi viene il dubbio che o c'è qualcosa che non va con i dvd+rw-tools oppure che sia k3b che sta incasinando i device.
Magari ora provo a fare qualche test con xcdroast e da riga di comando.
bbg5ne
ma hai aggiornato cdrtools o dvdrtools?
tango13
Sì, ma ancora niente... :( :( :? :?
bbg5ne
io ho avuto dei problemi simili subito dopo aver aggioornato questi 2 pacchetti, prova afare il downgare alla versione della current!
:roll:
