KDE 3.5.5
Meskalamdug
- pino.giaquinto
- pino.giaquinto
Ho la slack 11.0 e quella libreria NON fa parte del pacchetto x11-devel-6.9.0-i486-11.tgz
Seguendo le indicazioni che ho trovato in un forum (brasiliano!) ho risolto così:
che mi ha creato un file libGL.la il cui contenuto è:
Ho ricompilato ed ora ho un altro problema:
Ho scoperto che c'è una directory /usr/X11R6/lib/.libs quindi provo con
Sta compilando... vi faccio sapere
root@celeron:~# grep libGL /var/log/packages/x11-devel-6.9.0-i486-11
usr/X11R6/lib/libGL.a
usr/X11R6/lib/libGLU.a
usr/X11R6/lib/libGLw.aCodice: Seleziona tutto
cd /usr/X11R6/lib
libtool --mode=link gcc -g -O -o libGL.la -rpath /usr/X11R6/lib -lm
ln -s /usr/X11R6/lib/libGL.la /usr/lib/libGL.laCodice: Seleziona tutto
# libGL.la - a libtool library file
# Generated by ltmain.sh - GNU libtool 1.5.22 (1.1220.2.365 2005/12/18 22:14:06)
# Please DO NOT delete this file!
# It is necessary for linking the library.
# The name that we can dlopen(3).
dlname='libGL.so.0'
# Names of this library.
library_names='libGL.so.0.0.0 libGL.so.0 libGL.so'
# The name of the static archive.
old_library='libGL.a'
# Libraries that this one depends upon.
dependency_libs=' -lm'
# Version information for libGL.
current=0
age=0
revision=0
# Is this an already installed library?
installed=no
# Should we warn about portability when linking against -modules?
shouldnotlink=no
# Files to dlopen/dlpreopen
dlopen=''
dlpreopen=''
# Directory that this library needs to be installed in:
libdir='/usr/X11R6/lib'Codice: Seleziona tutto
i486-slackware-linux-g++: /usr/lib/.libs/libGL.so: No such file or directory
make[4]: *** [atlantikdesigner] Error 1
make[4]: Leaving directory `/tmp/kdeaddons-3.5.5/atlantikdesigner/designer'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/tmp/kdeaddons-3.5.5/atlantikdesigner/designer'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/tmp/kdeaddons-3.5.5/atlantikdesigner'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/tmp/kdeaddons-3.5.5'
make: *** [all] Error 2Codice: Seleziona tutto
ln -s /usr/X11R6/lib/.libs /usr/lib/.libs- pino.giaquinto
kdeaddons è OK
Gzipping kdeaddons-3.5.5-i486-1pg.tar...
Renaming kdeaddons-3.5.5-i486-1pg.tar.gz to kdeaddons-3.5.5-i486-1pg.tgz...
Moving kdeaddons-3.5.5-i486-1pg.tgz to .....
Package creation complete.Avevo letto malepino.giaquinto ha scritto:Ho la slack 11.0 e quella libreria NON fa parte del pacchetto x11-devel-6.9.0-i486-11.tgzCodice: Seleziona tutto
root@celeron:~# grep libGL /var/log/packages/x11-devel-6.9.0-i486-11 usr/X11R6/lib/libGL.a usr/X11R6/lib/libGLU.a usr/X11R6/lib/libGLw.a
libGL.a
invece che libGL.la
