Ultimi aggiornamenti X11 ramo stable [RISOLTO]
salbutamolo
Messaggio da salbutamolo »
Ciao a tutti,
il problema si risolve rimuovendo e reinstallando il pacchetto "font-config". Dal changelog della stable:
Stable ChangeLog for Intel
Fri Apr 20 13:47:39 CDT 2007
patches/packages/x11-6.9.0-i486-14_slack11.0.tgz:
Removed old versions of fc-cache and fc-list.
Somehow a couple of old fontconfig binaries snuck into this package, and
prevent fc-cache from working properly at boot (or any other time).
If you've already installed these upgrades, reinstalling the fontconfig
package will fix the issue. If you do that, there's no need to reinstall
this new x11 package -- it's been fixed so that there's no longer a problem
with the package install order (and because those fc-* binaries didn't
belong there). Sorry for any inconvenience...
Thanks to Petri Kaukasoina for pointing this out.
(* Fix *)
Have a nice day
