scopro subito che dopo aver fatto:
swaret --update
swaret --upgrade
k3b non funziona più:
k3b: error while loading shared libraries: libdvdread.so.3: cannot open shared object file: No such file or directory
vlc non funziona più:
VLC media player 0.9.0-svn Grishenko
[00000300] main playlist error: Reloading playlist not implemented.
[00000310] main dialogs provider error: no dialogs provider module matched "any"
[00000307] skins2 interface error: no suitable dialogs provider found (hint: compile the wxWidgets plugin, and make sure it is loaded properly)
[00000307] skins2 interface: skin: VLC 0.8.5 Default Skin author: aLtgLasS
Suppongo entrambi i problemi siano risolvibili ma bastano per decidermi a non usare più swaret
p.s. questo è il mio swaret.conf:
# swaret.conf, Version: 1.6.3
### /etc/swaret.conf - SWARET EXAMPLE CONFIGURATION FILE ###
# Define a valid Slackware Linux Version.
# (Used for Dependency Support and other Features)
# NOTE: If you want to use Slackware Linux Current,
# set VERSION to 'current' (VERSION=current).
VERSION=12.0
# Define the language for status and error messages
LANGUAGE=ITALIANO
# Define Slackware (8.1 or Higher or Current) Linux Mirrors.
# (Used for Official Slackware Linux Packages)
# (Slackware Linux Mirrors available at http://www.slackware.com)
# Syntax: ROOT=PROTOCOL:URL
# NOTE: swaret will use the order of the specified ROOT URL's.
#ROOT=file:/mnt/cdrom
#ROOT=file:/mnt/dvdrom
#ROOT=file:/mnt/usbmemstick
ROOT=ftp://ftp.nluug.nl/pub/os/Linux/distr/slackware/slackware-$VERSION
ROOT=http://sunsite.cnlab-switch.ch/ftp/mirror/slackware/slackware-$VERSION
ROOT=ftp://ftp.slackware.no/pub/linux/slackware/slackware-$VERSION
ROOT=http://www.slackware.no/slackware/slackware-$VERSION
ROOT=ftp://ftp.slackware.at/slackware-$VERSION
ROOT=http://www.slackware.at/data/slackware-$VERSION
ROOT=ftp://ftp.planetmirror.com/pub/slackware/slackware-$VERSION
ROOT=http://ftp.planetmirror.com/pub/slackware/slackware-$VERSION
#ROOT=rsync://rsync.slackware.no/slackware/slackware-$VERSION
#ROOT=rsync://rsync.slackware.at/slackware/slackware-$VERSION
#ROOT=file:/pub/slackware
#ROOT=file:/mnt/nfsshare/slackware
#ROOT=file:/mnt/sambashare/slackware
# Define Repository URL's with Slackware Linux Packages.
# (Used for Repository Slackware Linux Packages)
# (Repository URL's available at http://swaret.sourceforge.net and
# at http://www.linuxpackages.net/mirrors.php)
# NOTE 1: To use a Local Repository or Remote Repository,
# be sure it contains the following Files:
# - CHECKSUMS.md5 (For MD5 Sum, REQUIRED)
# - FILELIST.TXT (For Package Name + Size, REQUIRED)
# - PACKAGES.TXT (For Package Description, NOT REQUIRED)
# - MANIFEST.bz2 (For Dependency Support, NOT REQUIRED)
# NOTE 2: To create your own Repository, use 'swaret-tools'.
# You can get 'swaret-tools' at http://swaret.sourceforge.net!
# Syntax: REPOS_ROOT=REPOSITORYNAME%PROTOCOL:URL
# NOTE 1: The REPOSITORY NAME can only be ONE Keyword!
# NOTE 2: swaret will use the order of the specified REPOS_ROOT URL's.
#REPOS_ROOT=LinuxPackagesDOTNET%http://www2.linuxpackages.net/packages/Slackware-10.0
#REPOS_ROOT=My_Slackware_Packages_On_CD-ROM%file:/mnt/cdrom
#REPOS_ROOT=My_Slackware_Packages_On_DVD-ROM%file:/mnt/dvdrom
#REPOS_ROOT=My_Slackware_Packages_On_USB_Memory_Stick%file:/mnt/usbmemstick
#REPOS_ROOT=SomeRemoteRepository%ftp://ftp.someremoterepository.net/slackware/slackware-10.0
#REPOS_ROOT=SomeRemoteRepository%http://www.someremoterepository.net/slackware/slackware-10.0
#REPOS_ROOT=SomeRemoteRepository%rsync://rsync.someremoterepository.net/slackware/slackware-10.0
REPOS_ROOT=Slacky%http://slacky.uglyplace.org/repository/slackware-12.0/
# Define Libraries (8.1 or Higher or Current) List Mirrors.
# (Used for Dependency Support)
# NOTE 1: You need to specify a Libraries List Mirror which
# contains a 'libraries-VERSION' File.
# NOTE 2: To create the Libraries List, use 'swaret-tools'.
# You can also clear all DEP_ROOT Variable(s) which will
# allow swaret to create the Libraries List for you
# during Dependency Check using the defined ROOT Variable(s) above.
# Syntax: DEP_ROOT=PROTOCOL:URL
# NOTE: swaret will use the order of the specified DEP_ROOT URL's.
DEP_ROOT=http://swaret.sourceforge.net
#DEP_ROOT=file:/mnt/cdrom
#DEP_ROOT=file:/mnt/dvdrom
#DEP_ROOT=file:/mnt/usbmemstick
#DEP_ROOT=file:/pub/swaret
#DEP_ROOT=file:/mnt/nfsshare/swaret
#DEP_ROOT=file:/mnt/sambashare/swaret
# General Settings
# Do you want swaret to use Random Slackware Linux Mirrors?
# -> 1 for yes, 0 for no.
RANDOMR=0
# Do you want swaret to back-up your packages when upgradeing?
# -> If set to 1, old packages are backed up in $CACH_DIR/rollback.
# Normally this is /var/swaret/rollback. ROLLBACKMAX is the number
# of "upgrades" that will be backed up before old backups will be
# removed. Turning on rollback means upgrading packages takes
# longer, but it is more safe.
# -> If set to 0, swaret will not back up packages.
ROLLBACK=0
ROLLBACKMAX=3
# Do you want swaret to parse all the Package Descriptions?
# -> If set to 1, swaret will also match Packages whose Description
# is matching the Keyword(s) you specify after --ACTION.
# NOTE: swaret will parse all the Package Descriptions for this,
# and might slow down swaret when using an older System.
# -> If set to 0, swaret will not use Package Descriptions
# to match one or more Packages.
USEPKGDESC=0
# If you don't want swaret to Upgrade, Install, Re-Install, Download,...
# some Packages, add the KEYWORDS to the EXCLUDE Variable.
# To disable Exclude Method: swaret --exclude -off
# To enable Exclude Method: swaret --exclude -on
# NOTE: You can add ANY EXTENDED REGEXP (Regular Expression) to the EXCLUDE Variable(s)
# Basic Exclude
EXCLUDE=kernel alsa lilo
EXCLUDE=swaret
EXCLUDE=aaa_
EXCLUDE=MANIFEST.bz2$
EXCLUDE=.*dl$ .*PACKAGER$ .*MYBUILD$
# Advanced Exclude
# Syntax: KEYWORD[DONT_EXCLUDE_ME_KEYWORD1,DONT_EXCLUDE_ME_KEYWORD2,...]
# Example: kde-i18n[nl,en_GB] koffice-i18n[nl,en_GB]
#EXCLUDE=kde-i18n[nl,en_GB] koffice-i18n[nl,en_GB]
# Do you want to enable Dependency Check?
# -> If set to 1, swaret will start the Dependency Check after
# every Upgrade, Install and Re-Install Procedure.
# -> If set to 0, swaret will not start the Dependency Check
# after any Procedure.
DEPENDENCY=1
# Do you want swaret to Search for missing Libraries (and Fix)
# which could be found on your System, but not tracked by ldconfig?
DSEARCHLIB=1
# Set to 1, if you want swaret to use the 'slocate' program
# to Search for missing Libraries.
# (be sure to issue the 'updatedb' Command regularly!)
# If DSEARCHM is set to 0, swaret will use
# the 'find' program to locate missing Libraries.
DSEARCHM=0
# Start MD5 Check after Fetching Packages, Patches and Sources?
MD5CHECK=1
# Start GPG Signature Check after Fetching Packages, Patches and Sources?
# NOTE: Check out F.A.Q. (--faq gpg) how to Import a Public GPG Key which
# will be used by the GPG Signature Check.
GPGCHECK=0
# Show Description for Packages during
# Upgrade, Install, Re-Install,... Procedures?
# -> If set to 0, you will not see a Description.
# -> If set to 1, you will see a Description.
DESC=0
# Cache Directory for (Repository) Packages and Sources.
CACHE_DIR=/var/swaret
# Enable Logging?
LOG=1
# swaret Log File
LOG_FILE=/var/log/swaret
# Show Warnings?
WARNINGS=1
# Show Information?
INFORMATION=1
# Network Settings
# Network Interface
# Use this if you have a Network Interface.
NIC=eth0
# Local Interface
# Use this if you do not have a Network Interface.
# For Example (CD-ROM):
# You got a Slackware Linux CD-ROM,
# mount the CD-ROM to /mnt/cdrom and
# set ROOT to 'file:/mnt/cdrom' in /etc/swaret.conf.
# Also, set NIC to 'lo' (Local Loop Device).
# NIC=lo
# Progress
# If set to 0, swaret will use the '%' Download Interface.
# If set to 1, swaret will use the 'size' Download Interface.
# If set to 2, swaret will use the 'wget/rsync' Download Interface.
PROGRESS=0
# Timeout for wget and/or rsync.
# -> Number of seconds for Timeout
TIMEOUT=35
# Retries for wget and/or rsync.
# -> Number of Retries
RETRIES=5
# Behind a Firewall? Using FTP Mirrors?
PASSIVE_FTP=1
# If you want HTTP or FTP Proxy Support,
# uncomment and Setup the following Variable:
# WGET_PROXY=http://IP or HOST:PORT
# If you want RSYNC Proxy Support,
# RSYNC_PROXY=IP or HOST:PORT
