problemi con driver ati su slack 12.2
h8er
Re: problemi con driver ati su slack 12.2
Messaggio da h8er »
spina ha scritto:
h8er ha scritto:...sh nomeinstallerati.run --buildpkg Slackware/All...
Con gli ultimi driver ti basta dare:
o addirittura
sh nomeinstallerati.run --buildandinstallpkg
per installare i pacchetti dopo la creazione.
Spina
buono a sapersi grazie spina!
Darkstar89
Nome Cognome: Francesco
Slackware: 13
Messaggio da Darkstar89 »
Grazie per l'aiuto;
Questo è /var/log/Xorg.0.log:
X.Org X Server 1.4.2
Release Date: 11 June 2008
Build Operating System: Slackware 12.1 Slackware Linux Project
Current Operating System: Linux Akenza 2.6.27.7-smp #2 SMP Thu Nov 20 22:32:43 CST 2008 i686
Build Date: 30 June 2008  11:35:29PM
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Feb 15 13:35:50 2009
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "Monitor0"
(**) |   |-->Device "Card0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(==) Including the default font path /usr/share/fonts/TTF,/usr/share/fonts/OTF,/usr/share/fonts/Type1,/usr/share/fonts/misc,/usr/share/fonts/75dpi/:unscaled.
(**) FontPath set to:
(**) RgbPath set to "/usr/share/X11/rgb"
(**) ModulePath set to "/usr/lib/xorg/modules"
(II) Loader magic: 0x81d0280
(II) Module ABI versions:
	X.Org ANSI C Emulation: 0.3
	X.Org Video Driver: 2.0
	X.Org XInput driver : 2.0
	X.Org Server Extension : 0.3
	X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
	compiled for 1.4.2, module version = 1.0.0
	ABI class: X.Org Video Driver, version 2.0
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,3188 card 1043,80a3 rev 01 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,b188 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:0f:0: chip 1106,3149 card 1043,80ed rev 80 class 01,04,00 hdr 80
(II) PCI: 00:0f:1: chip 1106,0571 card 1043,80ed rev 06 class 01,01,8a hdr 00
(II) PCI: 00:10:0: chip 1106,3038 card 1043,80ed rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:1: chip 1106,3038 card 1043,80ed rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:2: chip 1106,3038 card 1043,80ed rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:3: chip 1106,3038 card 1043,80ed rev 81 class 0c,03,00 hdr 80
(II) PCI: 00:10:4: chip 1106,3104 card 1043,80ed rev 86 class 0c,03,20 hdr 80
(II) PCI: 00:11:0: chip 1106,3227 card 1043,80ed rev 00 class 06,01,00 hdr 80
(II) PCI: 00:11:5: chip 1106,3059 card 1043,810d rev 60 class 04,01,00 hdr 00
(II) PCI: 00:11:6: chip 1106,3068 card 0000,0000 rev 80 class 07,80,00 hdr 00
(II) PCI: 00:12:0: chip 1106,3065 card 1043,80ed rev 78 class 02,00,00 hdr 00
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:00:0: chip 1002,5960 card 1043,004c rev 01 class 03,00,00 hdr 80
(II) PCI: 01:00:1: chip 1002,5940 card 1043,004d rev 01 class 03,80,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
	[0] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
	[0] -1	0	0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000a (VGA_EN is set)
(II) Bus 1 I/O range:
	[0] -1	0	0x0000e000 - 0x0000efff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
	[0] -1	0	0xfbd00000 - 0xfbffffff (0x300000) MX[B]
(II) Bus 1 prefetchable memory range:
	[0] -1	0	0xe8000000 - 0xfaffffff (0x13000000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:17:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) ATI Technologies Inc RV280 [Radeon 9200 PRO] rev 1, Mem @ 0xe8000000/27, 0xfbe00000/16, I/O @ 0xe000/8, BIOS @ 0xfbd00000/17
(--) PCI: (1:0:1) ATI Technologies Inc RV280 [Radeon 9200 PRO] (Secondary) rev 1, Mem @ 0xf0000000/27, 0xfbf00000/16
(II) Addressable bus resource ranges are
	[1] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
	[0] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
	[1] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
	[2] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
	[3] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
	[4] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[5] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe4000000 from 0xe7ffffff to 0xe3ffffff
(II) Active PCI resource ranges:
	[0] -1	0	0xfba00000 - 0xfba000ff (0x100) MX[B]
	[1] -1	0	0xfbb00000 - 0xfbb000ff (0x100) MX[B]
	[2] -1	0	0xe4000000 - 0xe3ffffff (0x0) MX[B]O
	[3] -1	0	0xfbf00000 - 0xfbf0ffff (0x10000) MX[B](B)
	[4] -1	0	0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
	[5] -1	0	0xfbd00000 - 0xfbd1ffff (0x20000) MX[B](B)
	[6] -1	0	0xfbe00000 - 0xfbe0ffff (0x10000) MX[B](B)
	[7] -1	0	0xe8000000 - 0xefffffff (0x8000000) MX[B](B)
	[8] -1	0	0x0000a000 - 0x0000a0ff (0x100) IX[B]
	[9] -1	0	0x0000a400 - 0x0000a4ff (0x100) IX[B]
	[10] -1	0	0x0000b800 - 0x0000b81f (0x20) IX[B]
	[11] -1	0	0x0000b400 - 0x0000b41f (0x20) IX[B]
	[12] -1	0	0x0000b000 - 0x0000b01f (0x20) IX[B]
	[13] -1	0	0x0000a800 - 0x0000a81f (0x20) IX[B]
	[14] -1	0	0x0000fc00 - 0x0000fc0f (0x10) IX[B]
	[15] -1	0	0x0000c000 - 0x0000c0ff (0x100) IX[B]
	[16] -1	0	0x0000c400 - 0x0000c40f (0x10) IX[B]
	[17] -1	0	0x0000c800 - 0x0000c803 (0x4) IX[B]
	[18] -1	0	0x0000d000 - 0x0000d007 (0x8) IX[B]
	[19] -1	0	0x0000d400 - 0x0000d403 (0x4) IX[B]
	[20] -1	0	0x0000d800 - 0x0000d807 (0x8) IX[B]
	[21] -1	0	0x0000e000 - 0x0000e0ff (0x100) IX[B](B)
(II) Inactive PCI resource ranges:
	[0] -1	0	0x00001000 - 0x000010ff (0x100) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) Inactive PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
	[4] -1	0	0xfba00000 - 0xfba000ff (0x100) MX[B]
	[5] -1	0	0xfbb00000 - 0xfbb000ff (0x100) MX[B]
	[6] -1	0	0xe4000000 - 0xe3ffffff (0x0) MX[B]O
	[7] -1	0	0xfbf00000 - 0xfbf0ffff (0x10000) MX[B](B)
	[8] -1	0	0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
	[9] -1	0	0xfbd00000 - 0xfbd1ffff (0x20000) MX[B](B)
	[10] -1	0	0xfbe00000 - 0xfbe0ffff (0x10000) MX[B](B)
	[11] -1	0	0xe8000000 - 0xefffffff (0x8000000) MX[B](B)
	[12] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[13] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[14] -1	0	0x0000a000 - 0x0000a0ff (0x100) IX[B]
	[15] -1	0	0x0000a400 - 0x0000a4ff (0x100) IX[B]
	[16] -1	0	0x0000b800 - 0x0000b81f (0x20) IX[B]
	[17] -1	0	0x0000b400 - 0x0000b41f (0x20) IX[B]
	[18] -1	0	0x0000b000 - 0x0000b01f (0x20) IX[B]
	[19] -1	0	0x0000a800 - 0x0000a81f (0x20) IX[B]
	[20] -1	0	0x0000fc00 - 0x0000fc0f (0x10) IX[B]
	[21] -1	0	0x0000c000 - 0x0000c0ff (0x100) IX[B]
	[22] -1	0	0x0000c400 - 0x0000c40f (0x10) IX[B]
	[23] -1	0	0x0000c800 - 0x0000c803 (0x4) IX[B]
	[24] -1	0	0x0000d000 - 0x0000d007 (0x8) IX[B]
	[25] -1	0	0x0000d400 - 0x0000d403 (0x4) IX[B]
	[26] -1	0	0x0000d800 - 0x0000d807 (0x8) IX[B]
	[27] -1	0	0x0000e000 - 0x0000e0ff (0x100) IX[B](B)
	[28] -1	0	0x00001000 - 0x000010ff (0x100) IX[B]
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "freetype" will be loaded. This was enabled by default and also specified in the config file.
(II) "type1" will be loaded. This was enabled by default and also specified in the config file.
(II) "record" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
	compiled for 7.1.0, module version = 1.0.0
	ABI class: X.Org Server Extension, version 0.3
(II) LoadModule: "xtrap"
(II) Loading /usr/lib/xorg/modules/extensions//libxtrap.so
(II) Module xtrap: vendor="X.Org Foundation"
(II) Loading extension DEC-XTRAP
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension XC-MISC
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "fgl.renamed.libdri"
(WW) Warning, couldn't open module fgl.renamed.libdri
(II) UnloadModule: "fgl.renamed.libdri"
(EE) Failed to load module "fgl.renamed.libdri" (module does not exist, 0)
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
	compiled for 1.4.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts//libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
	compiled for 1.4.2, module version = 2.1.0
	Module class: X.Org Font Renderer
	ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: "type1"
(II) Loading /usr/lib/xorg/modules/fonts//libtype1.so
(II) Module type1: vendor="X.Org Foundation"
	compiled for 1.4.2, module version = 1.0.2
(II) Loading font Type1
(II) LoadModule: "radeon"
(II) Loading /usr/lib/xorg/modules/drivers//radeon_drv.so
(II) Module radeon: vendor="X.Org Foundation"
	compiled for 1.4.2, module version = 4.3.0
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
	compiled for 1.4.0.90, module version = 1.3.0
	Module class: X.Org XInput Driver
	ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
	compiled for 1.4.2, module version = 1.3.1
(II) RADEON: Driver for ATI Radeon chipsets:
	ATI Radeon Mobility X600 (M24) 3150 (PCIE),
	ATI Radeon Mobility X300 (M24) 3152 (PCIE),
	ATI FireGL M24 GL 3154 (PCIE), ATI Radeon X600 (RV380) 3E50 (PCIE),
	ATI FireGL V3200 (RV380) 3E54 (PCIE), ATI Radeon IGP320 (A3) 4136,
	ATI Radeon IGP330/340/350 (A4) 4137, ATI Radeon 9500 AD (AGP),
	ATI Radeon 9500 AE (AGP), ATI Radeon 9600TX AF (AGP),
	ATI FireGL Z1 AG (AGP), ATI Radeon 9800SE AH (AGP),
	ATI Radeon 9800 AI (AGP), ATI Radeon 9800 AJ (AGP),
	ATI FireGL X2 AK (AGP), ATI Radeon 9600 AP (AGP),
	ATI Radeon 9600SE AQ (AGP), ATI Radeon 9600XT AR (AGP),
	ATI Radeon 9600 AS (AGP), ATI FireGL T2 AT (AGP), ATI Radeon 9650,
	ATI FireGL RV360 AV (AGP), ATI Radeon 7000 IGP (A4+) 4237,
	ATI Radeon 8500 AIW BB (AGP), ATI Radeon 8500 AIW BC (AGP),
	ATI Radeon IGP320M (U1) 4336, ATI Radeon IGP330M/340M/350M (U2) 4337,
	ATI Radeon Mobility 7000 IGP 4437, ATI Radeon 9000/PRO If (AGP/PCI),
	ATI Radeon 9000 Ig (AGP/PCI), ATI Radeon X800 (R420) JH (AGP),
	ATI Radeon X800PRO (R420) JI (AGP),
	ATI Radeon X800SE (R420) JJ (AGP), ATI Radeon X800 (R420) JK (AGP),
	ATI Radeon X800 (R420) JL (AGP), ATI FireGL X3 (R420) JM (AGP),
	ATI Radeon Mobility 9800 (M18) JN (AGP),
	ATI Radeon X800 SE (R420) (AGP), ATI Radeon X800XT (R420) JP (AGP),
	ATI Radeon X850 XT (R480) (AGP), ATI Radeon X850 SE (R480) (AGP),
	ATI Radeon X850 PRO (R480) (AGP), ATI Radeon X850 XT PE (R480) (AGP),
	ATI Radeon Mobility M7 LW (AGP),
	ATI Mobility FireGL 7800 M7 LX (AGP),
	ATI Radeon Mobility M6 LY (AGP), ATI Radeon Mobility M6 LZ (AGP),
	ATI FireGL Mobility 9000 (M9) Ld (AGP),
	ATI Radeon Mobility 9000 (M9) Lf (AGP),
	ATI Radeon Mobility 9000 (M9) Lg (AGP), ATI Radeon 9700 Pro ND (AGP),
	ATI Radeon 9700/9500Pro NE (AGP), ATI Radeon 9600TX NF (AGP),
	ATI FireGL X1 NG (AGP), ATI Radeon 9800PRO NH (AGP),
	ATI Radeon 9800 NI (AGP), ATI FireGL X2 NK (AGP),
	ATI Radeon 9800XT NJ (AGP),
	ATI Radeon Mobility 9600/9700 (M10/M11) NP (AGP),
	ATI Radeon Mobility 9600 (M10) NQ (AGP),
	ATI Radeon Mobility 9600 (M11) NR (AGP),
	ATI Radeon Mobility 9600 (M10) NS (AGP),
	ATI FireGL Mobility T2 (M10) NT (AGP),
	ATI FireGL Mobility T2e (M11) NV (AGP), ATI Radeon QD (AGP),
	ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
	ATI FireGL 8700/8800 QH (AGP), ATI Radeon 8500 QL (AGP),
	ATI Radeon 9100 QM (AGP), ATI Radeon 7500 QW (AGP/PCI),
	ATI Radeon 7500 QX (AGP/PCI), ATI Radeon VE/7000 QY (AGP/PCI),
	ATI Radeon VE/7000 QZ (AGP/PCI), ATI ES1000 515E (PCI),
	ATI Radeon Mobility X300 (M22) 5460 (PCIE),
	ATI Radeon Mobility X600 SE (M24C) 5462 (PCIE),
	ATI FireGL M22 GL 5464 (PCIE), ATI Radeon X800 (R423) UH (PCIE),
	ATI Radeon X800PRO (R423) UI (PCIE),
	ATI Radeon X800LE (R423) UJ (PCIE),
	ATI Radeon X800SE (R423) UK (PCIE),
	ATI Radeon X800 XTP (R430) (PCIE), ATI Radeon X800 XL (R430) (PCIE),
	ATI Radeon X800 SE (R430) (PCIE), ATI Radeon X800 (R430) (PCIE),
	ATI FireGL V7100 (R423) (PCIE), ATI FireGL V5100 (R423) UQ (PCIE),
	ATI FireGL unknown (R423) UR (PCIE),
	ATI FireGL unknown (R423) UT (PCIE),
	ATI Mobility FireGL V5000 (M26) (PCIE),
	ATI Mobility Radeon X700 XL (M26) (PCIE),
	ATI Mobility Radeon X700 (M26) (PCIE),
	ATI Radeon X550XTX 5657 (PCIE), ATI Radeon 9100 IGP (A5) 5834,
	ATI Radeon Mobility 9100 IGP (U3) 5835,
	ATI Radeon XPRESS 200 5954 (PCIE),
	ATI Radeon XPRESS 200M 5955 (PCIE), ATI Radeon 9250 5960 (AGP),
	ATI Radeon 9200 5961 (AGP), ATI Radeon 9200 5962 (AGP),
	ATI Radeon 9200SE 5964 (AGP), ATI FireMV 2200 (PCI),
	ATI ES1000 5969 (PCI), ATI Radeon XPRESS 200 5974 (PCIE),
	ATI Radeon XPRESS 200M 5975 (PCIE),
	ATI Radeon XPRESS 200 5A41 (PCIE),
	ATI Radeon XPRESS 200M 5A42 (PCIE),
	ATI Radeon XPRESS 200 5A61 (PCIE),
	ATI Radeon XPRESS 200M 5A62 (PCIE),
	ATI Radeon X300 (RV370) 5B60 (PCIE),
	ATI Radeon X600 (RV370) 5B62 (PCIE),
	ATI Radeon X550 (RV370) 5B63 (PCIE),
	ATI FireGL V3100 (RV370) 5B64 (PCIE),
	ATI FireMV 2200 PCIE (RV370) 5B65 (PCIE),
	ATI Radeon Mobility 9200 (M9+) 5C61 (AGP),
	ATI Radeon Mobility 9200 (M9+) 5C63 (AGP),
	ATI Mobility Radeon X800 XT (M28) (PCIE),
	ATI Mobility FireGL V5100 (M28) (PCIE),
	ATI Mobility Radeon X800 (M28) (PCIE), ATI Radeon X850 5D4C (PCIE),
	ATI Radeon X850 XT PE (R480) (PCIE),
	ATI Radeon X850 SE (R480) (PCIE), ATI Radeon X850 PRO (R480) (PCIE),
	ATI unknown Radeon / FireGL (R480) 5D50 (PCIE),
	ATI Radeon X850 XT (R480) (PCIE),
	ATI Radeon X800XT (R423) 5D57 (PCIE),
	ATI FireGL V5000 (RV410) (PCIE), ATI Radeon X700 XT (RV410) (PCIE),
	ATI Radeon X700 PRO (RV410) (PCIE),
	ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X700 (RV410) (PCIE),
	ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X1800,
	ATI Mobility Radeon X1800 XT, ATI Mobility Radeon X1800,
	ATI Mobility FireGL V7200, ATI FireGL V7200, ATI FireGL V5300,
	ATI Mobility FireGL V7100, ATI Radeon X1800, ATI Radeon X1800,
	ATI Radeon X1800, ATI Radeon X1800, ATI Radeon X1800,
	ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
	ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
	ATI Mobility Radeon X1400, ATI Radeon X1300/X1550,
	ATI Radeon X1550 64-bit, ATI Mobility Radeon X1300,
	ATI Mobility Radeon X1300, ATI Mobility Radeon X1300,
	ATI Mobility Radeon X1300, ATI Radeon X1300, ATI Radeon X1300,
	ATI RV505, ATI RV505, ATI FireGL V3300, ATI FireGL V3350,
	ATI Radeon X1300, ATI Radeon X1550 64-bit, ATI Radeon X1300/X1550,
	ATI Radeon X1600, ATI Radeon X1300/X1550, ATI Mobility Radeon X1450,
	ATI Radeon X1300/X1550, ATI Mobility Radeon X2300,
	ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
	ATI Mobility Radeon X1350, ATI Mobility Radeon X1450,
	ATI Radeon X1300, ATI Radeon X1550, ATI Mobility Radeon X1350,
	ATI FireMV 2250, ATI Radeon X1550 64-bit, ATI Radeon X1600,
	ATI Radeon X1650, ATI Radeon X1600, ATI Radeon X1600,
	ATI Mobility FireGL V5200, ATI Mobility Radeon X1600,
	ATI Radeon X1650, ATI Radeon X1650, ATI Radeon X1600,
	ATI Radeon X1300 XT/X1600 Pro, ATI FireGL V3400,
	ATI Mobility FireGL V5250, ATI Mobility Radeon X1700,
	ATI Mobility Radeon X1700 XT, ATI FireGL V5200,
	ATI Mobility Radeon X1700, ATI Radeon X2300HD,
	ATI Mobility Radeon HD 2300, ATI Mobility Radeon HD 2300,
	ATI Radeon X1950, ATI Radeon X1900, ATI Radeon X1950,
	ATI Radeon X1900, ATI Radeon X1900, ATI Radeon X1900,
	ATI AMD Stream Processor, ATI Radeon X1900, ATI Radeon X1950,
	ATI RV560, ATI RV560, ATI Mobility Radeon X1900, ATI RV560,
	ATI Radeon X1950 GT, ATI RV570, ATI RV570, ATI ATI FireGL V7400,
	ATI RV560, ATI Radeon X1650, ATI Radeon X1650, ATI RV560,
	ATI Radeon 9100 PRO IGP 7834, ATI Radeon Mobility 9200 IGP 7835,
	ATI Radeon X1200, ATI Radeon X1200, ATI Radeon X1200,
	ATI Radeon X1200, ATI Radeon X1200, ATI RS740, ATI RS740M, ATI RS740,
	ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 XT,
	ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro, ATI Radeon HD 2900 GT,
	ATI FireGL V8650, ATI FireGL V8600, ATI FireGL V7600, ATI RV610,
	ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
	ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI RV610,
	ATI ATI Radeon HD 2350, ATI Mobility Radeon HD 2400 XT,
	ATI Mobility Radeon HD 2400, ATI RADEON E2400, ATI RV610, ATI RV670,
	ATI Radeon HD3870, ATI Radeon HD3850, ATI RV670,
	ATI Radeon HD3870 X2, ATI FireGL V7700, ATI RV630,
	ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
	ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
	ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
	ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
	ATI FireGL V3600, ATI Radeon HD 2600 LE, ATI Radeon HD 3470,
	ATI Radeon HD 3450, ATI Radeon HD 3430, ATI Mobility Radeon HD 3430,
	ATI Mobility Radeon HD 3400 Series, ATI FireMV 2450, ATI FireMV 2260,
	ATI FireMV 2260, ATI ATI Radeon HD 3600 Series,
	ATI ATI Radeon HD 3650 AGP, ATI ATI Radeon HD 3600 PRO,
	ATI ATI Radeon HD 3600 XT, ATI ATI Radeon HD 3600 PRO,
	ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
	ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
(II) Primary Device is: PCI 01:00:0
(WW) RADEON: No matching Device section for instance (BusID PCI:1:0:0) found
(WW) RADEON: No matching Device section for instance (BusID PCI:1:0:1) found
(EE) No devices detected.
Fatal server error:
no screens found
Io installavo i pacchetti in un'altro modo (sicuramente sbagliato), così "./atidriverxxxx --install"
La scheda video è agp quindi riproverò ad installare i driver 8.x... così:
sh atidriver-8xxx.run --buildpkg
e installpkg,
La mia domanda è visto che ho installato i driver a mio modo, come faccio a disinstallarli?
h8er
Messaggio da h8er »
ciao bella domanda, prova vedere nell'help del comando forse hanno messo un opzione --uninstall o --remove, dal log sembra che tu non abbia una section "Device" corretta nel tuo xorg.conf e oltretutto ti carica il modulo radeon invece di fglrx prova a fare così metti una section device simile alla mia
Section "Device"
        Identifier  "ATI Technologies Inc Radeon R350 [Radeon 9800 Pro]"
        Driver      "fglrx"
        Option      "VideoOverlay" "on"
        Option      "OpenGLOverlay" "off"
        Option      "UseInternalAGPGART" "yes"
        Option      "MaxGARTSize" "128"
        Option      "AccelMethod" "EXA"
        Option      "XAANoOffscreenPixmaps" "true"
        Option      "AGPMode" "8"
        Option      "AGPFastWrite" "true"
        Option      "UseFastTLS" "1"
        BusID       "PCI:2:0:0"
EndSection
edita l'Identifier come vuoi tu non so metti "Ati Radeon", edita BusID nel modo corretto per far questo dai da root il comando lspci questo è il mio output per quanto riguarda la scheda video
02:00.0 VGA compatible controller: ATI Technologies Inc Radeon R350 [Radeon 9800 Pro]
02:00.1 Display controller: ATI Technologies Inc Radeon R350 [Radeon 9800 Pro] (Secondary)
a noi interessa il controller vga primario per cui io ho messo BusID "PCI:2:0:0" se a te da una roba diversa cambialo di conseguenza... fatto questo devi avere una section "Screen" e una section "Monitor" nello xorg configurati nel modo corretto, queste sono le mie:
Section "Screen"
# If your card can handle it, a higher default color depth (like 24 or 32)
# is highly recommended.
#   DefaultDepth 8
#   DefaultDepth 16
#   DefaultDepth 32
# "1024x768" is also a conservative usable default resolution.  If you
# have a better monitor, feel free to try resolutions such as
# "1152x864", "1280x1024", "1600x1200", and "1800x1400" (or whatever your
# card/monitor can produce)
        Identifier "Screen 1"
        Device     "ATI Technologies Inc Radeon R350 [Radeon 9800 Pro]"
        Monitor    "My Monitor"
        DefaultDepth     24
        SubSection "Display"
               Depth     8
               Modes    "1280x1024" "1024x768" "800x600" "640x480"
        EndSubSection
               Depth     16
        EndSubSection
                Depth     24
        EndSubSection
EndSection
nota che Device deve essere uguale all'Identifier che hai settato sopra nella section "Device" ! i modes devi settarli tu nel modo giusto in base alle risoluzioni supportate dalla scheda video e dal tuo monitor, io inizierei lasciando le canoniche "1280x1024" "1024x768" "800x600" "640x480" per tutte le depth
Section "Monitor"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY.  REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
#    HorizSync  30-64         # multisync
#    HorizSync  31.5, 35.2    # multiple fixed sync frequencies
#    HorizSync  15-25, 30-50  # multiple ranges of sync frequencies
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
        Identifier   "My Monitor"
#        DisplaySize  504        315
       HorizSync    30.0 - 81.0
       VertRefresh  56.0 - 75.0
#        Modeline "1900x1200_60.00"  191.96  1904 2032 2240 2576  1200 1201 1204 1242  -HSync +Vsync
        Option      "DPMS"
EndSection
nella sezione monitor setti le frequenze del monitor in base al tuo monitor , io uso una modeline in realtà (al momento tu lascia commentato sia DisplaySize sia Modeline) ovviamente l'identifier "My Monitor" deve essere identico al Monitor "My Monitor" della section "Screen", infine c'è la section ServerLayout
Section "ServerLayout"
# The Identifier line must be present
# Each Screen line specifies a Screen section name, and optionally
# the relative position of other screens.  The four names after
# primary screen name are the screens to the top, bottom, left and right
# of the primary screen.  In this example, screen 2 is located to the
# right of screen 1.
# Each InputDevice line specifies an InputDevice section name and
# optionally some options to specify the way the device is to be
# used.  Those options include "CorePointer", "CoreKeyboard" and
# "SendCoreEvents".
#       InputDevice    "MX1000" "SendCoreEvents"
#       InputDevice    "MX1000" "CorePointer"
        Identifier     "Simple Layout"
        Screen      0  "Screen 1" 0 0
        InputDevice    "Keyboard1" "CoreKeyboard"
        Option      "AIGLX" "false"
EndSection
qua potresti dover aggiungere delle cose per quanto riguarda le InputDevice, l'importante è che "Screen 1" sia uguale all'Identifier della section "Screen", io c'ho un mouse usb che richiede una sezione InputDevice a parte ma forse a te non serve fai sta roba poi guarda cosa ti dice il log di Xorg, ovviamente credo avrai capito è fondamentale che i vari Identifier siano corretti all'interno dello xorg.conf (anche per le altre sezioni tipo InputDevice ecc ecc) ovviamente tutto sto discorso è inutile se non riesce a caricarti il modulo fglrx con un banale modprobe, se proprio non riesci ad installare sti benedetti catalyst edita il campo Driver nella section "Device" e al posto di fglrx prova a mettere "radeon"
ciao
Ultima modifica di h8er il dom 15 feb 2009, 16:16, modificato 1 volta in totale.
Darkstar89
Slackware: 13
Ciao, nel mio xorg.conf c'è la section device.. ora lo scrivo tutto..
	Identifier     "X.org Configured"
	Screen      0  "Screen0" 0 0
	InputDevice    "Mouse0" "CorePointer"
	InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
	RgbPath      "/usr/share/X11/rgb"
	ModulePath   "/usr/lib/xorg/modules"
	FontPath     "/usr/share/fonts/TTF"
	FontPath     "/usr/share/fonts/OTF"
	FontPath     "/usr/share/fonts/Type1"
	FontPath     "/usr/share/fonts/misc"
	FontPath     "/usr/share/fonts/75dpi/:unscaled"
EndSection
Section "Module"
	Load  "dri"
	Load  "xtrap"
	Load  "glx"
	Load  "extmod"
	Load  "dbe"
	Load  "FGL.renamed.libdri"
	Load  "record"
	Load  "GLcore"
	Load  "freetype"
	Load  "type1"
EndSection
Section "InputDevice"
	Identifier  "Keyboard0"
	Driver      "kbd"
	Option       "XkbModel"  "pc101"
	Option       "XkbLayout"  "it"
EndSection
	Identifier  "Mouse0"
	Driver      "mouse"
	Option	    "Protocol" "auto"
	Option	    "Device" "/dev/input/mice"
	Option	    "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
	#DisplaySize	  320   240	# mm
	Identifier   "Monitor0"
	VendorName   "AOC"
	ModelName    "7V"
 ### Comment all HorizSync and VertRefresh values to use DDC:
	HorizSync    30.0 - 70.0
	VertRefresh  50.0 - 160.0
	Option	    "DPMS"
EndSection
Section "Device"
        ### Available Driver options are:-
        ### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
        ### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
        ### [arg]: arg optional
        #Option     "NoAccel"            	# [<bool>]
        #Option     "SWcursor"           	# [<bool>]
        #Option     "Dac6Bit"            	# [<bool>]
        #Option     "Dac8Bit"            	# [<bool>]
        #Option     "BusType"            	# [<str>]
        #Option     "CPPIOMode"          	# [<bool>]
        #Option     "CPusecTimeout"      	# <i>
        #Option     "AGPMode"            	# <i>
        #Option     "AGPFastWrite"       	# [<bool>]
        #Option     "AGPSize"            	# <i>
        #Option     "GARTSize"           	# <i>
        #Option     "RingSize"           	# <i>
        #Option     "BufferSize"         	# <i>
        #Option     "EnableDepthMoves"   	# [<bool>]
        #Option     "EnablePageFlip"     	# [<bool>]
        #Option     "NoBackBuffer"       	# [<bool>]
        #Option     "DMAForXv"           	# [<bool>]
        #Option     "FBTexPercent"       	# <i>
        #Option     "DepthBits"          	# <i>
        #Option     "PCIAPERSize"        	# <i>
        #Option     "AccelDFS"           	# [<bool>]
        #Option     "DDCMode"            	# [<bool>]
        #Option     "IgnoreEDID"         	# [<bool>]
        #Option     "DisplayPriority"    	# [<str>]
        #Option     "PanelSize"          	# [<str>]
        #Option     "ForceMinDotClock"   	# <freq>
        #Option     "ColorTiling"        	# [<bool>]
        #Option     "VideoKey"           	# <i>
        #Option     "RageTheatreCrystal" 	# <i>
        #Option     "RageTheatreTunerPort" 	# <i>
        #Option     "RageTheatreCompositePort" 	# <i>
        #Option     "RageTheatreSVideoPort" 	# <i>
        #Option     "TunerType"          	# <i>
        #Option     "RageTheatreMicrocPath" 	# <str>
        #Option     "RageTheatreMicrocType" 	# <str>
        #Option     "ScalerWidth"        	# <i>
        #Option     "RenderAccel"        	# [<bool>]
        #Option     "SubPixelOrder"      	# [<str>]
        #Option     "ShowCache"          	# [<bool>]
        #Option     "DynamicClocks"      	# [<bool>]
        #Option     "VGAAccess"          	# [<bool>]
        #Option     "ReverseDDC"         	# [<bool>]
        #Option     "LVDSProbePLL"       	# [<bool>]
        #Option     "AccelMethod"        	# <str>
        #Option     "DRI"                	# [<bool>]
        #Option     "ConnectorTable"     	# <str>
        #Option     "DefaultConnectorTable" 	# [<bool>]
        #Option     "DefaultTMDSPLL"     	# [<bool>]
        #Option     "TVDACLoadDetect"    	# [<bool>]
        #Option     "ForceTVOut"         	# [<bool>]
        #Option     "TVStandard"         	# <str>
        #Option     "IgnoreLidStatus"    	# [<bool>]
        #Option     "DefaultTVDACAdj"    	# [<bool>]
        #Option     "Int10"              	# [<bool>]
	Identifier  "Card0"
	Driver      "radeon"
	VendorName  "ATI Technologies Inc"
	BoardName   "RV280 [Radeon 9200 PRO]"
	BusID       "PCI:01:00.0"
EndSection
Section "Screen"
	Identifier "Screen0"
	Device     "Card0"
	Monitor    "Monitor0"
	DefaultDepth 24
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Questo è l'output di "lspci |grep VGA"
01:00.0 VGA compatible controller: ATI Technologies Inc RV280 [Radeon 9200 PRO] (rev 01)
A voi non sembrerebbe tutto ok!, poi non capisco perche xorgsetup non mi riscrea un' xorg.conf funzionante..
h8er
Messaggio da h8er »
prova a mettere BusID PCI:1:0:0 senza quegli zeri in più, comunque tu stai usando il driver "radeon" e non "fglrx"
ciao
Se stai cercando di usare i driver ATI proprietary, nella sezione "Device" devi metterci:
Driver      "fglrx"
e non
Driver      "radeon"
Spina
Darkstar89
Slackware: 13
Ho cambiato la parte Driver "radeon" con Driver "fglrx"
poi ho provato tutte le combinazioni, togliendo e mettendo gli zeri, nella parte BusID PCI:x1:x2:x3 ho anche messo il punto al posto dei 2 punti tra x2 e x3 come l'originale, sono riuscito a copiare il debug di ./ati-driver-installer-9-1-x86.x86_64.run --buildpkg Slackware/Only_Module..
è questo:
ATI Technologies Linux Driver Installer/Packager
ln: creating symbolic link x700: Operation not permitted
ln: creating symbolic link x700_64a: Operation not permitted
Generating package: Slackware/Only_Module
The name of the current directory should not contain any spaces
Removing temporary directory: fglrx-install.QDGemb
...Non riesco a reindirizzare l'output di startx per mostrarvi gli errori.. comunque non trova una libreria..
Come posso fare a reindirizzare l'output io ho fatto "startx >> slackeu"...
Darkstar89 ha scritto:...
Questo vuol dire che devi eseguire il comando in una directory il cui nome non contiene spazi, tipo la directory /tmp.
Spina
P.S. Dai al comando l'opzione '--buildpkg' e basta, creati tutti e due i pacchetti non solo quello del modulo
Darkstar89
Slackware: 13
Spina dice:
quindi ./ati-driver-installer-9-1-x86.x86_64.run --buildpkg
Grazie, ho già provato, se dò questo comando mi manda all'help...
E' strano, perchè se io do:
sh ati-driver-installer-9-1-x86.x86_64.run --buildpkg
ottengo:
Created directory fglrx-install.n0m6Qo
Verifying archive integrity... All good.
Uncompressing ATI Proprietary Linux Driver-8.573.....
Generating package: Slackware/All
che è quello che dovrebbe accadere, quindi c'è qualcosa non torna :)
Spina
Darkstar89
Slackware: 13
E lo dici a me strano!..Ieri l'ho tutto configurato, sono andato a letto alle 4, mi sa che io non ho provato a mettere sh all'inizio del comando però...Quale può essere il problema, ora ho guardato l'xorg.conf di ubuntu e come la maggior parte dei file di configurazione fa schifo.. Mentre invece ieri notte quando ho provato da solo a ripristinare x ho copiato l'xorg.conf da BackTrack che è più simile, ma non partiva neanche così.. Ho già riavviato più di 20 volte.. cosa posso fare [-o<
Ti ho mandato un MP
Spina
Darkstar89
Slackware: 13
Ho provato con l'xorg.conf dato da spina ma niente,
ho provato ad installare i driver in una directory con percorso senza spazi e i 9.1 mi danno un' output andato a buon fine...
mentre quelli 8.x (ne ho provato 2 tipi) mi danno un'errore in tutti e due i casi
Poi ho provato "modprobe fglrx" come suggerito da spina e mi restituisce:
FATAL: Module fglrx not found.
Cosa posso fare :cry: :)
Se il modprobe va male, allora vuol dire che non hai installato il modulo. Devi cercare di andare con ordine:
  • elimina qualsiasi cosa tu abbia installato dei driver ati (hai dei pacchetti? eliminali)
  • copia l'installer ATI (il 9.1) nella directory /tmp
  • vai nella directory /tmp e lancia:
    sh installer.run --buildpkg Slackware/All
  • se i pacchetti vengono generati (sono due), installali e poi lancia:
    startx
  • se i pacchetti non vengono generati, posta l'output del builder che vediamo perchè non vengono generati
Non provare 100 cose altrimenti rischi solo di incasinare il filesystem.
spina
Darkstar89
Slackware: 13
Lo so che sta andando male e sto incasinando tutto, ma l'output di ./atiXX non mi dà l'opzione remove e non so come rimuovere tutto, oltre a questo se faccio
"atiXXX --buildpkg" mi manda all'help
se invece lancio:
"atiXXX --buildpkg Slackware/Only_Module" mi genera solo un pacchetto e non due..
Questo è la parte da considerare dell'help:
  --install                                       Install the driver(default)
  --listpkg                                      List all the generatable packages
  --buildpkg package                      Build "package" if generatable ("package" as returned by --listpkg)
  --buildandinstallpkg package        Build and Install "package" as returned by --listpkg
