E17 from svn is ready!
Blallo
Nome Cognome: Savino Liguori
Slackware: 14.2 / 12.2
Kernel: 4.4.14-smp
Desktop: DWM
Re: Problema eet 64bit
Messaggio da Blallo »
lampo di genio! ho avuto la geniale idea di leggermi un pò approfonditamente il ./configure e ho risolto così
	ECORE_EVAS_LIBS="$SLKLDFLAGS -lecore_evas -lecore_x -lecore_input -lecore_txt -levas -lecore -leina" \
	ECORE_XCB_LIBS="$SLKLDFLAGS -lxcb -lecore_x -lecore_input -lecore_txt -levas -lecore -leina" \
	ECORE_X_LIBS="$SLKLDFLAGS -lecore_x -lecore_input -lecore_txt -levas -lecore -leina" \
	ECORE_LIBS="$SLKLDFLAGS -lecore_txt -lecore_file -lecore_con -lgnutls -lcurl -lecore -leina" \
	EDJE_LIBS="$SLKLDFLAGS -ledje -lecore_imf_evas -llua -lm -lembryo -lecore_job -leet -lecore_imf -levas -lecore -leina" \
	EFREET_LIBS="$SLKLDFLAGS -lefreet -lefreet_mime -lecore_file -lecore_con -lgnutls -lcurl -lecore -leina" \
	EMOTION_LIBS="$SLKLDFLAGS -lemotion -levas -leina" \
	EVAS_LIBS="$SLKLDFLAGS -levas -leina" \
	EPSILON_LIBS="$SLKLDFLAGS -lepsilon" \
jimmy_page_89 ha scritto: A proposito conraid lo SLKLDFLAGS="-L/usr/lib64" lo devo modificare (per i 32 bit) come SLKLDFLAGS="-L/usr/lib" ?
no, lo lasci vuoto
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
Re: E17 form svn is ready!
lo script è pronto! per chi volesse testare sui 32 bit mi fa un favore (fa tutto da solo, lo lanciate e fate quello che volete)
#!/bin/sh
#e17 Slackware Builder
#This simple script download lastest trunk from e17's SVN, package and install it ;)
#You can select if you want a basiliar or a full-of-all installation
#Compatible with Slackware 12.2 and (i hope) later
#Copyright jimmy_page_89 ( email jimmy_page_89 AT hotmail DOT it )
#Thanks to Conraid for SVN help :D
echo "##e17 Slackware Builder##"
echo "##Author: jimmy_page_89##"
TMP=${TMP:-/tmp/e17}
TAG=1jim
CWD=`pwd`
OUTPUT=$CWD/e17-slackware-pkgs-1jim
ARCH=`uname -m`
JOBS="-j3"
if [ "$ARCH" = "i486" ]; then
	SLKCFLAGS="-O2 -march=i486 -mtune=i686"
	LIBDIRSUFFIX=""
	SLKLDFLAGS=""
elif [ "$ARCH" = "i686" ]; then
	SLKCFLAGS="-O2 -march=i686 -mtune=i686"
	LIBDIRSUFFIX=""
	SLKLDFLAGS=""
	SLKCFLAGS="-O2 -fPIC"
	LIBDIRSUFFIX="64"
fi
echo "checking dependencies..."
if [ ! -d $OUTPUT ];then
	mkdir -p $OUTPUT
fi
mkdir -p $TMP
cd $OUTPUT
for j in lua libast libmpd;
do
if [ ! -e /var/log/packages/$j-* ];then
	echo "Please install $j, exiting..."
	exit 1
fi
done
echo "Start Downloading..."
cd $TMP
svn co http://svn.enlightenment.org/svn/e || exit 1
wget http://www.slackbuilds.org/slackbuilds/12.2/desktop/enlightenment/xinitrc.enlightenment17 || exit 1
cd e/trunk
VERSION=r$(LANG=en_US svn info | awk '/Revision:/{print $2}')
for i in BINDINGS BROKEN devs DOCS E16 packaging PROTO SCRIPTS THEMES web;
do
	rm -rf $i || exit 1
done
mkdir -p $OUTPUT || exit 1
for i in imlib2 eina eet imlib2_loaders imlib2_tools evas ecore efreet embryo edje e_dbus e exml esmart eterm ethumb emotion;
do
if [ ! -e $OUTPUT/$i-$VERSION-$ARCH-$TAG.tgz ];then
	echo "Building $i..."
	cd $i
	if [ "$i" = "eterm" ];then
	    cd Eterm
	fi
	chown -R root:root .
	find . \
 	\( -perm 777 -o -perm 775 -o -perm 711 -o -perm 555 -o -perm 511 \) \
 	-exec chmod 755 {} \; -o \
 	\( -perm 666 -o -perm 664 -o -perm 600 -o -perm 444 -o -perm 440 -o -perm 400 \) \
 	-exec chmod 644 {} \;
	PKG=$TMP/package-$i
	mkdir -p $PKG || exit 1
	LDFLAGS="$SLKLDFLAGS" \
	CFLAGS="$SLKCFLAGS" \
	CXXFLAGS="$SLKCFLAGS" \
	./autogen.sh \
	--prefix=/usr \
	--libdir=/usr/lib${LIBDIRSUFFIX} \
	--sysconfdir=/etc \
  	--localstatedir=/var \
  	--mandir=/usr/man \
  	--disable-static || exit 1
	make $JOBS|| exit 1
	make install DESTDIR=$PKG || exit 1
	( cd $PKG
  	find . | xargs file | grep "executable" | grep ELF | cut -f 1 -d : | \
    	  xargs strip --strip-unneeded 2> /dev/null || true
  	find . | xargs file | grep "shared object" | grep ELF | cut -f 1 -d : | \
	mkdir -p $PKG/usr/doc/$i || exit 1
	cp -a AUTHORS COPYING INSTALL NEWS README $PKG/usr/doc/$i
	if [ "$i" = "e" ];then
		mkdir -p $PKG/etc/X11/xinit
		cp $TMP/xinitrc.enlightenment17 $PKG/etc/X11/xinit/
	fi
	mkdir -p $PKG/install
	echo "       |-----handy-ruler------------------------------------------------------|" >> $PKG/install/slack-desc
	echo "$i" >> $PKG/install/slack-desc
	echo "$i: $i svn build - $VERSIO - $VERSION" >> $PKG/install/slack-desc
	echo "" >> $PKG/install/slack-desc
	echo "if [ -x /usr/bin/update-mime-database ]; then
  /usr/bin/update-mime-database /usr/share/mime &> /dev/null
fi" >> $PKG/install/doinst.sh
	echo "" >> $PKG/install/doinst.sh
	echo "if [ -x /usr/bin/update-desktop-database ]; then
  /usr/bin/update-desktop-database 1> /dev/null 2> /dev/null
	echo "if [ -x /usr/bin/gtk-update-icon-cache ]; then
  /usr/bin/gtk-update-icon-cache  -f -q /usr/share/icons/hicolor 1> /dev/null 2> /dev/null
	cd $PKG
	makepkg -l y -c n $OUTPUT/$i-$VERSION-$ARCH-$TAG.tgz || exit 1
	upgradepkg --install-new $OUTPUT/$i-$VERSION-$ARCH-$TAG.tgz
	rm -rf $TMP/package-$i || exit 1
	cd $TMP/e/trunk
fi
done
cd $TMP/e/trunk/OLD
for i in etk etk_extra engrave enhance edata ecore_li edb emphasis epsilon evolve exhibit e_utils epeg;
do
	cd $i
	find . \
	PKG=$TMP/package-$i
	if [ "$i" = "evfs" ];then
	  mv debian/changelog debian/changelog.in
	fi
	./autogen.sh \
	--prefix=/usr \
	--sysconfdir=/etc \
  	--mandir=/usr/man \
	make $JOBS || exit 1
	( cd $PKG
	cd $PKG
	cd $TMP/e/trunk/OLD
fi
done
cd $TMP/e/trunk
i=ewl;
	cd $i
	find . \
	PKG=$TMP/package-$i
	#make clean
	CFLAGS=" $SLKCFLAGS" \
	./autogen.sh \
	--prefix=/usr \
	--sysconfdir=/etc \
  	--mandir=/usr/man \
	--libexecdir=/usr/lib${LIBDIRSUFFIX} \
	make $JOBS|| exit 1
	( cd $PKG
	cd $PKG
	cd $TMP/e/trunk
fi
for i in estickies exquisite expedite emotion emprint;
do
	cd $i
	    cd Eterm
	fi
	find . \
	PKG=$TMP/package-$i
	./autogen.sh \
	--prefix=/usr \
	--sysconfdir=/etc \
  	--mandir=/usr/man \
	make $JOBS|| exit 1
	( cd $PKG
	cd $PKG
	cd $TMP/e/trunk
fi
done
cd TMP/st
for i in elementary elementary-alarm elementary-presenter elementary-sms waker;
do
	cd $i
	find . \
	PKG=$TMP/package-$i
	./autogen.sh \
	--prefix=/usr \
	--sysconfdir=/etc \
  	--mandir=/usr/man \
	make $JOBS|| exit 1
	( cd $PKG
	cd $PKG
	cd $TMP/e/trunk/TMP/st
fi
done
cd $TMP/e/trunk
i=exalt
	cd $i
	find . \
	PKG=$TMP/package-$i
	./autogen.sh \
	--prefix=/usr \
	--sysconfdir=/etc \
  	--mandir=/usr/man \
	make $JOBS|| exit 1
	( cd $PKG
	cd $PKG
	cd $TMP/e/trunk
fi
cd E-MODULES-EXTRA
for i in alarm bling calendar configmenu cpu deskshow diskio drawer efm-nav efm-path emu exalt-client execwatch flame forecasts iiirk language mail mem moon \
mpdule net news notification penguins photo places rain screenshot skel slideshow snow taskbar tclock tiling uptime weather winselector wlan;
do
	cd $i
	find . \
	PKG=$TMP/package-$i
	./autogen.sh \
	--prefix=/usr \
	--sysconfdir=/etc \
  	--mandir=/usr/man \
	( cd $PKG
	cd $PKG
	cd $TMP/e/trunk/E-MODULES-EXTRA
fi
done
echo "Installation Complete!"
rm -rf $TMP
raffaele181188
Nome Cognome: Raffaele
Kernel: 2.6.29.6
Desktop: KDE 4.3
Distribuzione: Ubuntu
Re: E17 from svn is ready!
Messaggio da raffaele181188 »
Siccome mi devo regolare.. Tra download e compilazione quanto credi che impieghi questo script?
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
credo che tre quarti d'ora siano più che sufficienti (a meno che non hai un processore recente, gli ho impostato make -j3)
EDIT DECENTE, non recente :p
raffaele181188
Kernel: 2.6.29.6
Desktop: KDE 4.3
OK, allora ci sentiamo tra tre quarti d'ora :D
Mi aggiunge già lui il file xsession per scegliere la sessione E17 da KDM?
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
Ovvio
in più scarica tutto quello che serve dall'inizio, quindi puoi anche staccare internet appena inizia a compilare se hai una tariffa al minuto (o destinarlo ad altri usi) :D
raffaele181188
Kernel: 2.6.29.6
Desktop: KDE 4.3
Ok allora vado.. Come al solito bisogna lanciarlo da root #-o incrocio le dita, tanto è una macchina virtuale, mi fido di te :D
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
sei in x86 o x86_64?
raffaele181188
Kernel: 2.6.29.6
Desktop: KDE 4.3
x86 ma non ho ancora iniziato perchè sto creando il pacchetto di libmpd, che è richiesto come dipendenza e non c'è ancora per 13.0. Un attimo che risolvo tutto :D già che ci sono lo metto pure sull'FTP
raffaele181188
Kernel: 2.6.29.6
Desktop: KDE 4.3
«Jimmy, abbiamo un problema» (cit.)
Scusa, ma non ho resistito :D Sono appena tornato a casa, avevo voglia di provare questo E17 ma... sorpresa!!! Purtroppo non sono in grado di esprimermi con certezza, ma mi pare che ci sia qualcosa che non va nella versione SVN
No protocol specified
*** ECORE ERROR: Ecore Magic Check Failed!!!
*** IN FUNCTION: ecore_evas_window_get()
  Input handle pointer is NULL!
*** NAUGHTY PROGRAMMER!!!
*** SPANK SPANK SPANK!!!
*** Now go fix your code. Tut tut tut!
make[3]: *** [etk_test.eet] Segmentation fault
make[3]: Leaving directory `/tmp/e17/e/trunk/OLD/evolve/data/interfaces/etk_test'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/tmp/e17/e/trunk/OLD/evolve/data/interfaces'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/tmp/e17/e/trunk/OLD/evolve/data'
make: *** [all-recursive] Error 1
Se non altro mi sono fatto quattro risate :D Davvero non convenzionali questi tipi di Enlightement eheh :thumbright: Sono sicuro che sarà carino.. Ora cerco un po' con Google, ma l'ora è tarda e poi dubito di poter risolvere io.. :-k
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
prova a riscaricare domani, sul pomeriggio..probabilmente stanno modificando il codice..
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
script aggiornato con ordine delle dipendenze aggiustato
#!/bin/sh
TAG=1jim
CWD=`pwd`
ARCH=`uname -m`
JOBS="-j3"
	LIBDIRSUFFIX=""
	SLKLDFLAGS=""
	LIBDIRSUFFIX=""
	SLKLDFLAGS=""
	LIBDIRSUFFIX="64"
fi
	mkdir -p $OUTPUT
fi
mkdir -p $TMP
cd $OUTPUT
do
	exit 1
fi
done
cd $TMP
#svn co http://svn.enlightenment.org/svn/e || exit 1
#wget http://www.slackbuilds.org/slackbuilds/12.2/desktop/enlightenment/xinitrc.enlightenment17 || exit 1
cd e/trunk
do
	rm -rf $i || exit 1
done
for i in imlib2 eina eet imlib2_loaders imlib2_tools evas ecore efreet embryo edje e_dbus e exml esmart eterm ethumb exquisite expedite emotion emprint;
do
	cd $i
	    cd Eterm
	fi
	find . \
	PKG=$TMP/package-$i
	if [ "$i" = "ecore" ];then
	ECORE="--enable-ecore-evas-software-buffer --enable-ecore-evas-software-x11 --enable-ecore-evas-xrender-x11  --enable-ecore-evas-opengl-x11 --enable-ecore-evas-software-16-x11 --enable-ecore-evas-xrender-xcb --enable-ecore-evas-software-gdi --enable-ecore-evas-software-ddraw --enable-ecore-evas-direct3d--enable-ecore-evas-opengl-glew --enable-ecore-evas-software-16-ddraw--enable-ecore-evas-quartz --enable-ecore-evas-software-sdl --enable-ecore-evas-directfb --enable-ecore-evas-fb --enable-ecore-evas-software-16-wince"
	else
	ECORE=""
	fi
	./autogen.sh \
	--prefix=/usr \
	$ECORE \
	--sysconfdir=/etc \
  	--mandir=/usr/man \
	make $JOBS|| exit 1
	( cd $PKG
	fi
	cd $PKG
	cd $TMP/e/trunk
fi
done
# evfs  etk-perl enotes examine entropy flipbook
cd $TMP/e/trunk/OLD
do
	cd $i
	find . \
	PKG=$TMP/package-$i
	fi
	./autogen.sh \
	--prefix=/usr \
	--sysconfdir=/etc \
  	--mandir=/usr/man \
	( cd $PKG
	cd $PKG
	cd $TMP/e/trunk/OLD
fi
done
cd ..
i=ewl;
	cd $i
	find . \
	PKG=$TMP/package-$i
	#make clean
	./autogen.sh \
	--prefix=/usr \
	--sysconfdir=/etc \
  	--mandir=/usr/man \
	make $JOBS|| exit 1
	( cd $PKG
	cd $PKG
	cd $TMP/e/trunk
fi
#elementary-contacts
cd TMP/st
do
	cd $i
	find . \
	PKG=$TMP/package-$i
	./autogen.sh \
	--prefix=/usr \
	--sysconfdir=/etc \
  	--mandir=/usr/man \
	make $JOBS|| exit 1
	( cd $PKG
	cd $PKG
fi
done
cd $TMP/e/trunk
i=exalt
	cd $i
	find . \
	PKG=$TMP/package-$i
	./autogen.sh \
	--prefix=/usr \
	--sysconfdir=/etc \
  	--mandir=/usr/man \
	make $JOBS|| exit 1
	( cd $PKG
	cd $PKG
	cd $TMP/e/trunk
fi
cd E-MODULES-EXTRA
do
	cd $i
	find . \
	PKG=$TMP/package-$i
	./autogen.sh \
	--prefix=/usr \
	--sysconfdir=/etc \
  	--mandir=/usr/man \
	( cd $PKG
	cd $PKG
fi
done
i=estickies
	cd $i
	find . \
	PKG=$TMP/package-$i
	#make clean
	./autogen.sh \
	--prefix=/usr \
	--sysconfdir=/etc \
  	--mandir=/usr/man \
	make $JOBS|| exit 1
	( cd $PKG
	cd $PKG
	cd $TMP/e/trunk
fi
#rm -rf $TMP
raffaele181188
Kernel: 2.6.29.6
Desktop: KDE 4.3
Ho appena lanciato lo script, ti faccio sapere se quel problema è sparito. Intanto occhio che qui ti sei dimenticato di decommentare
Anche perchè mi pare che non fai un check sull'esistenza dei sorgenti, quindi lo script esce in malo modo se non li trova ;)
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
ops pardon...è che io per correggere lo script ho dovuto commentarli altrimenti mi scaricava ogni volta il trunk...al massimo ora provvedo per mettere un controllo...comunque lo stai testando?
Io sto scrivendo da enlightenment, ha ancora molti difetti operativi, ma è stabile e leggerissimo...se lo usi usalo con thunar, perchè il file manager interno è grezzo
