PC nuovo, nuovo problema.
sunreal
Slackware: 14.1
Re: PC nuovo, nuovo problema.
Messaggio da sunreal »
Effettuati tutti i controlli di rito sono pronto per installare lilo sulla pennetta, in prtica dovrebbe bastare mettere in /etc il "giusto" lilo.conf e poi da konsole lanciare lilo -v, OK?
Questo il lilo.conf:
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
boot = /dev/sdd
#compact # faster, but won't work on all systems.
# Boot BMP Image.
# Bitmap in BMP format: 640x480x8
bitmap = /boot/slack.bmp
# Menu colors (foreground, background, shadow, highlighted
# foreground, highlighted background, highlighted shadow):
bmp-colors = 255,0,255,0,255,0
# Location of the option table: location x, location y, number of
# columns, lines per column (max 15), "spill" (this is how many
# entries must be in the first column before the next begins to
# be used. We don't specify it here, as there's just one column.
bmp-table = 60,6,1,16
# Timer location x, timer location y, foreground color,
# background color, shadow color.
bmp-timer = 65,27,0,255
# Standard menu.
# Or, you can comment out the bitmap menu above and
# use a boot message with the standard menu:
#message = /boot/boot_message.txt
# Append any additional kernel parameters:
append=" vt.default_utf8=0"
prompt
timeout = 50
vga = 773
# Normal VGA console
# vga = normal
# vga=791
# VESA framebuffer console @ 1024x768x32k
# vga=790
# vga=773
# VESA framebuffer console @ 800x600x64k
# vga=788
# VESA framebuffer console @ 800x600x32k
# vga=787
# VESA framebuffer console @ 800x600x256
# vga=771
# VESA framebuffer console @ 640x480x64k
# vga=785
# VESA framebuffer console @ 640x480x32k
# vga=784
# VESA framebuffer console @ 640x480x256
# vga=769
# ramdisk = 0 # paranoia setting
# End LILO global section
image = /boot/vmlinuz
root = /dev/sda5
label = SL13164
read-only # Partitions should be mounted read-only for checking
OK? OK?
Sembra corretto, ma perchè hai così paura :lol:
sunreal
Slackware: 14.1
Perchè in pratica da sempre ho installato lilo da liloconfig scegliendo l'opzione esperto e poi installa su floppy, quindi per me è una novità affidarmi completamente alla konsole, e poi, come dicevo all'inizio del post vorrei lasciare immacolato il MBR, comunque grazie per le risposte e il sostegno morale. Ciao.
