Bug report per Openshot e kdenlive
gohanz
Re: Bug report per Openshot e kdenlive
Messaggio da gohanz »
Potrebbe essere un problema di errate dipendenze. Prova a lanciare sia ffmpeg che melt da riga di comando. Vedi se ti danno qualche indicazione.
nyquist
Nome Cognome: Cristiano Urban
Slackware: 15.0 multilib
Kernel: 5.15.161
Messaggio da nyquist »
Allora, lanciando ffmpeg da linea di comando ottengo:
cristiano@darkstar:~$ ffmpeg
ffmpeg version 0.8.6, Copyright (c) 2000-2011 the FFmpeg developers
  built on Nov  5 2011 07:55:56 with gcc 4.5.2
  configuration: --prefix=/usr --shlibdir=/usr/lib --libdir=/usr/lib --build-suffix= --mandir=/usr/man --disable-static --enable-shared --enable-x11grab --enable-vaapi --enable-vdpau --enable-gpl --enable-version3 --enable-nonfree --enable-postproc --enable-swscale --enable-avfilter --enable-pthreads --enable-bzlib --enable-libcelt --enable-frei0r --enable-libaacplus --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libdc1394 --enable-libdirac --enable-libfaac --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libvpx --enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-memalign-hack --enable-libxavs --enable-libxvid --enable-zlib --disable-debug --enable-vdpau --arch=i686 --disable-ssse3 --disable-amd3dnowext --disable-mmx2
  libavutil    51.  9. 1 / 51.  9. 1
  libavcodec   53.  7. 0 / 53.  7. 0
  libavformat  53.  4. 0 / 53.  4. 0
  libavdevice  53.  1. 1 / 53.  1. 1
  libavfilter   2. 23. 0 /  2. 23. 0
  libswscale    2.  0. 0 /  2.  0. 0
  libpostproc  51.  2. 0 / 51.  2. 0
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Use -h to get full help or, even better, run 'man ffmpeg'
Lanciando melt, invece:
cristiano@darkstar:~$ melt
Usage: melt [options] [producer [name=value]* ]+
Options:
  -attach filter[:arg] [name=value]*       Attach a filter to the output
  -attach-cut filter[:arg] [name=value]*   Attach a filter to a cut
  -attach-track filter[:arg] [name=value]* Attach a filter to a track
  -attach-clip filter[:arg] [name=value]*  Attach a filter to a producer
  -audio-track | -hide-video               Add an audio-only track
  -blank frames                            Add blank silence to a track
  -consumer id[:arg] [name=value]*         Set the consumer (sink)
  -debug                                   Set the logging level to debug
  -filter filter[:arg] [name=value]*       Add a filter to the current track
  -group [name=value]*                     Apply properties repeatedly
  -help                                    Show this message
  -jack                                    Enable JACK transport synchronization
  -join clips                              Join multiple clips into one cut
  -mix length                              Add a mix between the last two cuts
  -mixer transition                        Add a transition to the mix
  -null-track | -hide-track                Add a hidden track
  -profile name                            Set the processing settings
  -progress                                Display progress along with position
  -remove                                  Remove the most recent cut
  -repeat times                            Repeat the last cut
  -query                                   List all of the registered services
  -query "consumers" | "consumer"=id       List consumers or show info about one
  -query "filters" | "filter"=id           List filters or show info about one
  -query "producers" | "producer"=id       List producers or show info about one
  -query "transitions" | "transition"=id   List transitions, show info about one
  -query "profiles" | "profile"=id         List profiles, show info about one
  -query "presets" | "preset"=id           List presets, show info about one
  -query "formats"                         List audio/video formats
  -query "audio_codecs"                    List audio codecs
  -query "video_codecs"                    List video codecs
  -serialise [filename]                    Write the commands to a text file
  -silent                                  Do not display position/transport
  -split relative-frame                    Split the last cut into two cuts
  -swap                                    Rearrange the last two cuts
  -track                                   Add a track
  -transition id[:arg] [name=value]*       Add a transition
  -verbose                                 Set the logging level to verbose
  -version                                 Show the version and copyright
  -video-track | -hide-audio               Add a video-only track
For more help: <http://www.mltframework.org/>
