# bash -x slackpkg update
+ VERSION=2.81.1
+ PATH=/bin:/usr/bin:/sbin:/usr/sbin
++ cat /etc/slackware-version
++ cut -f2 '-d '
+ SLACKWARE_VERSION=14.1
+ CONF=/etc/slackpkg
++ sed -e 's/^[[:blank:]]*//' /etc/slackpkg/mirrors
++ grep -m1 -e '^\([a-z]\)'
+ SOURCE=http://slackware.mirrors.tds.net/pub/slackware/slackware64-14.1/
+ . /etc/slackpkg/slackpkg.conf
++ TEMP=/var/cache/packages
++ WORKDIR=/var/lib/slackpkg
++ WGETFLAGS=--passive-ftp
++ DELALL=on
++ CHECKMD5=on
++ CHECKGPG=on
++ CHECKSIZE=off
++ PRIORITY=(patches %PKGMAIN extra pasture testing)
++ POSTINST=on
++ ONLY_NEW_DOTNEW=off
++ ONOFF=on
++ DOWNLOAD_ALL=on
++ DIALOG=on
++ BATCH=off
++ DEFAULT_ANSWER=n
++ USE_INCLUDES=on
++ SPINNING=on
++ DIALOG_MAXARGS=139000
+ ERROR=
++ mktemp -p /tmp -d slackpkg.XXXXXX
+ TMPDIR=/tmp/slackpkg.ac3JAX
+ '[' 0 -ne 0 ']'
+ . /usr/libexec/slackpkg/core-functions.sh
++ trap cleanup 2 14 15
+ '[' 1 -eq 0 ']'
+ '[' -n update ']'
+ case $1 in
+ CMD=update
+ shift
+ '[' '' = gpg ']'
+ '[' -n '' ']'
+ system_setup
+ MEDIA=http
+ '[' http = cdrom ']'
+ '[' http = file ']'
+ '[' http = local ']'
+ LOCAL=0
+ '[' '' = curl ']'
+ DOWNLOADER='wget --passive-ftp -O'
+ '[' off = on ']'
+ '[' off = ON ']'
+ MORECMD=more
+ EDITCMD=vi
++ uname -m
+ ARCH=x86_64
+ case $ARCH in
+ ARCH='x86[_64]*'
+ SLACKKEY='Slackware Linux Project <security@slackware.com>'
+ PKGMAIN=slackware64
+ MAIN=slackware64
+ for i in 0 1 2 3 4
+ '[' patches = %PKGMAIN ']'
+ '[' %PKGMAIN = %PKGMAIN ']'
+ PRIORITY[$i]=slackware64
+ '[' extra = %PKGMAIN ']'
+ '[' pasture = %PKGMAIN ']'
+ '[' testing = %PKGMAIN ']'
+ TEMPLATEDIR=/etc/slackpkg/templates
+ '[' '!' -d /etc/slackpkg/templates ']'
++ grep '# v[0-9.]\+' /etc/slackpkg/slackpkg.conf
++ cut -f2 -dv
+ SLACKCFVERSION=2.8
+ CHECKSUMSFILE=/var/lib/slackpkg/CHECKSUMS.md5
++ md5sum /boot/vmlinuz
+ KERNELMD5='9da6ff54449ad71b335f20b9ee514af7 /boot/vmlinuz'
+ echo 'slackpkg 2.81.1 - Slackware Linux 14.1'
+ system_checkup
++ expr length 2.8
+ SLCKCFVL=3
++ echo 2.81.1
++ cut -c1-3
+ '[' 2.8 '!=' 2.8 ']'
+ '[' 'x86[_64]*' = none ']'
+ '[' /var/lib/slackpkg = '' ']'
++ ls '/var/lock/slackpkg.*'
+ touch /var/lock/slackpkg.16565
+ '[' /tmp/slackpkg.ac3JAX = FAILED ']'
+ '[' -f /var/lib/slackpkg/pkglist ']'
+ '[' http://slackware.mirrors.tds.net/pub/slackware/slackware64-14.1/ = '' ']'
++ echo http://slackware.mirrors.tds.net/pub/slackware/slackware64-14.1/
++ wc -w
++ tr -d ' '
+ COUNT=1
+ '[' 1 '!=' 1 ']'
+ grep '^ftp://ftp.slackware.com'
++ id -u
+ '[' 0 '!=' 0 ']'
+ which which
++ which md5sum
+ '[' /bin/md5sum ']'
+ '[' -f /var/lib/slackpkg/CHECKSUMS.md5 ']'
++ which awk
+ '[' /bin/awk ']'
+ which tput
++ which gpg
+ '[' /usr/bin/gpg ']'
++ gpg --list-keys '"Slackware' Linux Project '<security@slackware.com>"'
++ grep -c 'Slackware Linux Project <security@slackware.com>'
+ GPGFIRSTTIME=1
+ '[' 1 = 0 ']'
+ echo
+ for i in '/usr/libexec/slackpkg/functions.d/*.sh'
+ '[' -x /usr/libexec/slackpkg/functions.d/dialog-functions.sh ']'
+ . /usr/libexec/slackpkg/functions.d/dialog-functions.sh
++ export DIALOG_CANCEL=1
++ DIALOG_CANCEL=1
++ export DIALOG_ERROR=126
++ DIALOG_ERROR=126
++ export DIALOG_ESC=1
++ DIALOG_ESC=1
++ export DIALOG_EXTRA=3
++ DIALOG_EXTRA=3
++ export DIALOG_HELP=2
++ DIALOG_HELP=2
++ export DIALOG_ITEM_HELP=2
++ DIALOG_ITEM_HELP=2
++ export DIALOG_OK=0
++ DIALOG_OK=0
++ '[' on = on ']'
+ '[' -x /usr/libexec/slackpkg/functions.d/post-functions.sh ']'
+ . /usr/libexec/slackpkg/functions.d/post-functions.sh
+ case "$CMD" in
+ '[' '' = gpg ']'
+ '[' 1 = 0 ']'
+ echo 'Updating the package lists...'
+ updatefilelists
+ checkchangelog
+ '[' -e /var/lib/slackpkg/ChangeLog.txt ']'
+ echo -e '\tDownloading...'
Downloading...
+ getfile http://slackware.mirrors.tds.net/pub/slackware/slackware64-14.1/ChangeLog.txt /tmp/slackpkg.ac3JAX/ChangeLog.txt
+ '[' 0 = 1 ']'
+ echo -e '\t\t\tDownloading http://slackware.mirrors.tds.net/pub/slackware/slackware64-14.1/ChangeLog.txt...'
+ wget --passive-ftp -O /tmp/slackpkg.ac3JAX/ChangeLog.txt http://slackware.mirrors.tds.net/pub/slackware/slackware64-14.1/ChangeLog.txt
--2013-11-17 14:18:45-- http://slackware.mirrors.tds.net/pub/slackware/slackware64-14.1/ChangeLog.txt
Resolving slackware.mirrors.tds.net (slackware.mirrors.tds.net)... 204.246.0.134
Connecting to slackware.mirrors.tds.net (slackware.mirrors.tds.net)|204.246.0.134|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 217106 (212K) [text/plain]
Saving to: '/tmp/slackpkg.ac3JAX/ChangeLog.txt'
100%[===================================================================================================================>] 217,106 311KB/s in 0.7s
2013-11-17 14:18:48 (311 KB/s) - '/tmp/slackpkg.ac3JAX/ChangeLog.txt' saved [217106/217106]
+ grep -q '[a-z]' /tmp/slackpkg.ac3JAX/ChangeLog.txt
+ diff --brief /var/lib/slackpkg/ChangeLog.txt /tmp/slackpkg.ac3JAX/ChangeLog.txt
+ return 0
+ echo -e '\n\t\tNo changes in ChangeLog.txt between your last update and now.\n\t\tDo you really want to download all other files (y/N)? \c'
Do you really want to download all other files (y/N)? + answer
+ '[' off = on ']'
+ read ANSWER
n
+ '[' n '!=' Y ']'
+ '[' n '!=' y ']'
+ cleanup
+ '[' on = off ']'
+ tput cnorm
+ '[' -e /tmp/slackpkg.ac3JAX/error.log ']'
+ echo
+ '[' on = on ']'
+ exitInfatti:
$ man -d gcc
Reading config file /usr/lib64/man.conf
found man directory /usr/man
found man directory /usr/share/man
found man directory /usr/local/man
found man directory /usr/local/share/man
found man directory /usr/X11R6/man
found manpath map /bin --> /usr/share/man
found manpath map /sbin --> /usr/share/man
found manpath map /usr/bin --> /usr/share/man
found manpath map /usr/sbin --> /usr/share/man
found manpath map /usr/local/bin --> /usr/local/share/man
found manpath map /usr/local/sbin --> /usr/local/share/man
found manpath map /usr/X11R6/bin --> /usr/X11R6/man
found manpath map /usr/bin/X11 --> /usr/X11R6/man
found manpath map /usr/bin/mh --> /usr/share/man
using /usr/bin/less -is as pager
using /usr/bin/lynx as browser
using /usr/bin/lynx -dump to dump HTML pages as text
adding /usr/local/man to manpath
adding /usr/man to manpath
adding /usr/share/texmf/man to manpath
no cat page stored because of nonstandard line length
using default preprocessor sequence
found tbl(1) directive
man:
not executing command:
(cd "/usr/man" && (echo ".ll 14.1i"; echo ".nr LL 14.1i"; echo ".pl 1100i"; /bin/gunzip -c '/usr/man/man1/gcc.1.gz'; echo ".\\\""; echo ".pl \n(nlu+10") | /usr/bin/gtbl | /usr/bin/nroff -mandoc | /usr/bin/less -is)P.S: ZeroUno il tuo man.conf usa lynx come il mio?
