cambiamento disposizione dischi e kernel panic
ti posto il mio lilo.conf :
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
boot = /dev/hdc1
message = /boot/boot_message.txt
prompt
timeout = 1200
# Override dangerous defaults that rewrite the partition table:
change-rules
reset
vga = 773
# Normal VGA console
# vga = normal
# vga=791
# VESA framebuffer console @ 1024x768x32k
# vga=790
# vga=773
# VESA framebuffer console @ 800x600x64k
# vga=788
# VESA framebuffer console @ 800x600x32k
# vga=787
# VESA framebuffer console @ 800x600x256
# vga=771
# VESA framebuffer console @ 640x480x64k
# vga=785
# VESA framebuffer console @ 640x480x32k
# vga=784
# VESA framebuffer console @ 640x480x256
# vga=769
# End LILO global section
# Windows bootable partition config begins
#image = /dev/hda/boot.ini
#other = /dev/hda1
# label = Windows
# table = /dev/hda
# Windows bootable partition config ends
image = /boot/vmlinuz
root = /dev/hdd1
label = Linux
read-only
#Linux smp kernel
image = /boot/vmlinuz-smp
root = /dev/hdd1
label = Linux-smp
read-only
boot = /dev/hdc1
prompt
timeout = 1200
change-rules
reset
vga = 773
# vga = normal
# vga=791
# vga=790
# vga=773
# vga=788
# vga=787
# vga=771
# vga=785
# vga=784
# vga=769
#other = /dev/hda1
# label = Windows
# table = /dev/hda
root = /dev/hdd1
label = Linux
read-only
#Linux smp kernel
root = /dev/hdd1
label = Linux-smp
read-only
non non si trova piu in hda ma in hdc1 tanto che ho modificato cosi lilo.conf
ma image = /dev/hdc1/boot.ini è giusta ?perche su lilo del portatile questa stringa è completamente assente .
#image = /dev/hdc1/boot.ini
other = /dev/hdc1
label = Windows
table = /dev/hdc
#Windows bootable partition config ends
root = /dev/hdd1
label = Linux
read-only
#Linux smp kernel
root = /dev/hdd1
label = Linux-smp
read-only
other = /dev/hdc1
label = Windows
table = /dev/hdc
root = /dev/hdd1
label = Linux
read-only
#Linux smp kernel
root = /dev/hdd1
label = Linux-smp
read-only
Puoi fare un ultimo tentativo con
other = /dev/hdc1
map-drive = 0x80
to = 0x81
map-drive = 0x81
to = 0x80
label="Windows"
table = /dev/hdc
devi modificare 0x82 con 0x81
SE POI IL PROBLEMA è il bootloader di windows lo puoi provare a ricostiure dalla console di ripristino e dando bootcfg/rebuild
Altrimenti ti tocca reinstallare
other = /dev/hdc1
map-drive = 0x80
to = 0x81
map-drive = 0x81
to = 0x80
label="Windows"
table = /dev/hdc
