Dunque:
[ 287.605] (II) config/udev: Adding drm device (/dev/dri/card1)
[ 287.605] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 288.106] (EE) systemd-logind: failed to take device /dev/dri/card1: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
[ 294.913] (EE) /dev/dri/card1: failed to set DRM interface version 1.4: Permission denied
[ 294.913] (EE)
[ 294.913] (EE) Backtrace:
Nota il riferimento systemd-logind e a problemi di permessi, poi segue il crash.
Il dmesg invece apparentemente non da errori: la scheda sembra che venga correttamente attivata:
[ 286.799573] bbswitch: enabling discrete graphics
[ 287.401250] MXM: GUID detected in BIOS
[ 287.401327] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131218/nsarguments-95)
[ 287.401387] ACPI Warning: \_SB_.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20131218/nsarguments-95)
[ 287.401479] pci 0000:02:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
[ 287.401481] VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.PEG0.PEGP handle
[ 287.401779] [drm] hdmi device not found 2 0 1
[ 287.401825] nouveau [ DEVICE][0000:02:00.0] BOOT0 : 0x0e7360a2
[ 287.401828] nouveau [ DEVICE][0000:02:00.0] Chipset: GK107 (NVE7)
[ 287.401829] nouveau [ DEVICE][0000:02:00.0] Family : NVE0
[ 287.401866] nouveau [ VBIOS][0000:02:00.0] checking PRAMIN for image...
[ 287.449983] nouveau [ VBIOS][0000:02:00.0] ... signature not found
[ 287.449985] nouveau [ VBIOS][0000:02:00.0] checking PROM for image...
[ 287.450075] nouveau [ VBIOS][0000:02:00.0] ... signature not found
[ 287.450077] nouveau [ VBIOS][0000:02:00.0] checking ACPI for image...
[ 294.540558] nouveau [ VBIOS][0000:02:00.0] ... appears to be valid
[ 294.540562] nouveau [ VBIOS][0000:02:00.0] using image from ACPI
[ 294.540680] nouveau [ VBIOS][0000:02:00.0] BIT signature found
[ 294.540683] nouveau [ VBIOS][0000:02:00.0] version 80.07.b3.00.0c
[ 294.540915] nouveau [ DEVINIT][0000:02:00.0] adaptor not initialised
[ 294.540924] nouveau [ VBIOS][0000:02:00.0] running init tables
[ 294.678397] nouveau 0000:02:00.0: irq 54 for MSI/MSI-X
[ 294.678404] nouveau [ PMC][0000:02:00.0] MSI interrupts enabled
[ 294.678479] nouveau [ PFB][0000:02:00.0] RAM type: GDDR5
[ 294.678480] nouveau [ PFB][0000:02:00.0] RAM size: 2048 MiB
[ 294.678481] nouveau [ PFB][0000:02:00.0] ZCOMP: 0 tags
[ 294.680487] nouveau [ VOLT][0000:02:00.0] GPU voltage: 600000uv
[ 294.706955] nouveau [ PTHERM][0000:02:00.0] FAN control: none / external
[ 294.706959] nouveau [ PTHERM][0000:02:00.0] fan management: automatic
[ 294.706962] nouveau [ PTHERM][0000:02:00.0] internal sensor: yes
[ 294.706991] nouveau [ CLK][0000:02:00.0] 07: core 405 MHz memory 810 MHz
[ 294.707018] nouveau [ CLK][0000:02:00.0] 0a: core 405-705 MHz memory 1600 MHz
[ 294.707052] nouveau [ CLK][0000:02:00.0] 0f: core 405-705 MHz memory 2800 MHz
[ 294.707197] nouveau [ CLK][0000:02:00.0] --: core 405 MHz memory 810 MHz
[ 294.741616] vga_switcheroo: enabled
[ 294.741816] [TTM] Zone kernel: Available graphics memory: 8169714 kiB
[ 294.741818] [TTM] Zone dma32: Available graphics memory: 2097152 kiB
[ 294.741819] [TTM] Initializing pool allocator
[ 294.741823] [TTM] Initializing DMA pool allocator
[ 294.741830] nouveau [ DRM] VRAM: 2048 MiB
[ 294.741831] nouveau [ DRM] GART: 1048576 MiB
[ 294.741833] nouveau E[ DRM] Pointer to TMDS table invalid
[ 294.741835] nouveau [ DRM] DCB version 4.0
[ 294.741837] nouveau E[ DRM] Pointer to flat panel table invalid
[ 294.741856] nouveau [ DRM] ACPI backlight interface available, not registering our own
[ 294.753612] nouveau [ DRM] MM: using COPY for buffer copies
[ 294.753619] [drm] Initialized nouveau 1.1.1 20120801 for 0000:02:00.0 on minor 1
Quindi: perché Xorg da quell'errore? Mi sta venendo un grosso dubbio: ma non è che col tuo hardware dobbiamo usare l'altro approccio e non bumblebee?
Riassumendo:
il tuo user appartiene al gruppo bumblebee? Si? Sulla tty1 tu fai il login solo con questo utente e non con altri - tipo root: giusto?
Bene prova questo allora: aggiungi i moduli "i915 bbswitch" all'initramfs, rigenera l'initrrd, riavvia e prova a vedere che succede. Se non va, rimuovi i moduli, rigenera ancora l'initramfs e valutiamo il da farsi.
Nel frattemo reincolla il tuo ~/.xinitrc
