Kde 4.2..si inizia
Meskalamdug
Re: Kde 4.2..si inizia
Messaggio da Meskalamdug »
Provato,da adesso omploader
sperando che konqueror non rompa
con il limite di rete..
Kernel: 7.0.12
mi spiace mesk, ma col tempo mi sono ritrovato a odiare rapidshare in modi che nemmeno conoscevo :doubt:
Meskalamdug
[ 81%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/oscaraccount.o
[ 81%] Building CXX object kopete/protocols/wlm/CMakeFiles/kopete_wlm.dir/wlmprotocol.o
In file included from /tmp/kdenetwork-4.1.87/kopete/protocols/wlm/wlmprotocol.cpp:18:
/tmp/kdenetwork-4.1.87/kopete/libkopete/kopeteaccount.h:378: warning: 'virtual bool Kopete::Account::isBlocked(const QString&)' was hidden
/tmp/kdenetwork-4.1.87/kopete/protocols/wlm/wlmaccount.h:109: warning: by 'bool WlmAccount::isBlocked(const QString&) const'
In file included from /tmp/kdenetwork-4.1.87/kopete/protocols/wlm/wlmprotocol.cpp:19:
/tmp/kdenetwork-4.1.87/kopete/libkopete/kopetecontact.h:236: warning: 'virtual QList<KAction*>* Kopete::Contact::customContextMenuActions(Kopete::ChatSession*)' was hidden
/tmp/kdenetwork-4.1.87/kopete/protocols/wlm/wlmcontact.h:70: warning: by 'virtual QList<KAction*>* WlmContact::customContextMenuActions()'
[ 81%] Building CXX object kopete/protocols/wlm/CMakeFiles/kopete_wlm.dir/wlmcontact.o
In file included from /tmp/kdenetwork-4.1.87/kopete/protocols/wlm/wlmcontact.cpp:17:
In file included from /tmp/kdenetwork-4.1.87/kopete/protocols/wlm/wlmcontact.cpp:35:
[ 81%] Building CXX object kopete/protocols/wlm/CMakeFiles/kopete_wlm.dir/wlmaccount.o
[ 81%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/oscarcontact.o
In file included from /tmp/kdenetwork-4.1.87/kopete/protocols/wlm/wlmaccount.cpp:17:
In file included from /tmp/kdenetwork-4.1.87/kopete/protocols/wlm/wlmaccount.cpp:50:
/tmp/kdenetwork-4.1.87/kopete/protocols/wlm/wlmaccount.cpp: In member function 'void WlmAccount::slotChangePublicName()':
/tmp/kdenetwork-4.1.87/kopete/protocols/wlm/wlmaccount.cpp:253: error: no matching function for call to 'MSN::NotificationServerConnection::setFriendlyName(char*, bool)'
/usr/include/msn/notificationserver.h:266: note: candidates are: void MSN::NotificationServerConnection::setFriendlyName(std::string)
make[2]: *** [kopete/protocols/wlm/CMakeFiles/kopete_wlm.dir/wlmaccount.o] Error 1
make[1]: *** [kopete/protocols/wlm/CMakeFiles/kopete_wlm.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 81%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/oscarmyselfcontact.o
[ 81%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/oscarencodingselectiondialog.o
[ 81%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/oscarlistnonservercontacts.o
[ 81%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/oscarversionupdater.o
[ 81%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/oscarprivacyengine.o
[ 81%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/aimcontactbase.o
[ 81%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/icqcontactbase.o
[ 81%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/oscarpresence.o
[ 81%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/oscarpresencesdataclasses.o
[ 81%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/oscarstatusmanager.o
[ 81%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/nscainfoevent.o
[ 82%] Building CXX object kopete/protocols/oscar/CMakeFiles/kopete_oscar.dir/kopete_oscar_automoc.o
Linking CXX shared library ../../../lib/libkopete_oscar.so
[ 82%] Built target kopete_oscar
Kernel: 7.0.12
non so se risolve, ma ho aggiornato libmsn alla 4.0-beta2 del 22 di dicembre.
Meskalamdug
Avevo già provato,non compila ne la 1.87
ne kdenetwork da svn
intanto eccovi una lista
provvisoria
http://rapidshare.de/files/41261647/goo ... g.tgz.html
http://omploader.org/vMTMzaw/libmsn-4.0b2-i486-1mg.tgz
http://omploader.org/vMTMzZw/kdeaccessi ... 86-2mg.tgz
http://omploader.org/vMTMzbA/kdeadmin-4 ... 86-2mg.tgz
http://omploader.org/vMTMzbQ/kdeartwork ... 86-2mg.tgz
http://omploader.org/vMTMyYg/kdebase-4. ... 86-2mg.tgz
http://omploader.org/vMTMydA/kdebase-wo ... 86-2mg.tgz
http://omploader.org/vMTMzNw/kdebase-ru ... 86-2mg.tgz
http://omploader.org/vMTMzbw/kdegames-4 ... 86-2mg.tgz
http://omploader.org/vMTMzcA/kdegraphic ... 86-2mg.tgz
http://omploader.org/vMTMzcQ/kdemultime ... 86-2mg.tgz
http://rapidshare.de/files/41261570/kde ... g.tgz.html
http://omploader.org/vMTM0NA/kdepim-4.1.87-i486-2mg.tgz
http://rapidshare.de/files/41261632/kde ... g.tgz.html
http://omploader.org/vMTMzdQ/kdesdk-4.1.87-i486-1mg.tgz
http://omploader.org/vMTMzdg/kdetoys-4. ... 86-2mg.tgz
http://omploader.org/vMTMzdw/kdeutils-4 ... 86-2mg.tgz
http://omploader.org/vMTMzeA/kdewebdev- ... 86-2mg.tgz
p.s=ponce sto facendo alcune dipendenze di kdeedu
+ OCaml: OCaml is needed by Kalzium for the Equation Solver <http://caml.inria.fr/>
+ LibFacile: libfacile is needed by Kalzium for the Equation Solver. <http://www.recherche.enac.fr/log/facile/>
+ OpenBabel2, 2.2 or higher: OpenBabel is needed by Kalzium for the 3D-molecule viewer <http://openbabel.sourceforge.net/>
+ libcfitsio0, 3.09 or higher: A library for reading and writing data files in FITS (Flexible Image Transport System) data format <http://indi.sf.net>
Gives KStars support for FITS images.
+ libindi, 0.6 or higher: A framework for controlling astronomical devices such as telescopes, CCDs, filter wheels..etc. <http://indi.sf.net>
Gives KStars support for controlling astronomical devices.
+ Qalculate, 0.9.5 or higher: A multi-purpose desktop calculator <http://qalculate.sourceforge.net/>
Ocalm la ho già fatta,vuoi sobbarcarti qualche dipendenza?
Meskalamdug
Meskalamdug
Ho fatto tutte le dipendenze
Meskalamdug
Nuove dipendenze
http://omploader.org/vMTM0Yw/ocaml-3.11.0-i686-1mg.tgz
http://www.mytux.org/content/viewslackp ... php?id=315
http://www.mytux.org/content/viewslackp ... php?id=314
http://www.mytux.org/content/viewslackp ... php?id=316
http://www.mytux.org/content/viewslackp ... php?id=317
http://www.mytux.org/content/viewslackp ... php?id=318
http://www.mytux.org/content/viewslackp ... php?id=319
Pacchetti 4.1.87(mancano i bindings e network che non compila)
http://omploader.org/vMTM0eA/kdeedu-4.1.87-i486-1mg.tgz
http://omploader.org/vMTM0dQ/kdesdk-4.1.87-i486-1mg.tgz
http://omploader.org/vMTM1Mg/konq-plugi ... 86-1mg.tgz
extragear
http://omploader.org/vMTM1NQ/guidance-p ... 86-2mg.tgz
http://omploader.org/vMTM1NA/kaudiocrea ... 86-2mg.tgz
http://omploader.org/vMTM1Mw/ktorrent-r ... 86-2mg.tgz
Kernel: 7.0.12
c'e' qualche problema col protocollo http (anche il plasmoide del tempo non riesce a scaricare i dati) probabilmente legato a kio_http (kdelibs?)
per il resto mi funzionano gli effetti desktop senza attivare il compositing in xorg.conf :shock:
driver nvidia 177.82
per kdenetwork dai un'occhiata agli slackbuild leggermente aggiornati che avevo postato, ci sono due patch che lo dovrebbero far compilare.
Meskalamdug
Ponce,ti va di farli te network e bindings?
A me danno entrambi errore
Kernel: 7.0.12
ho un problemuccio: mi si e' sputtanato il file col disco della macchina virtuale e sto ripartendo da zero (fortuna che avevo fatto il .tar.gz degli slackbuild) :cry:
non so quando saro' operativo :?:
Kernel: 7.0.12
buone notizie :D
- ricompilato kdelibs, va anche l'http;
- compilato kdenetwork;
- aggiornando soprano e phonon compila anche kdebindings.
preparo gli ultimi pacchetti (devo ricompilare anche kdebase-workspace dopo i bindings) e poi uppo al solito posto :)
Kernel: 7.0.12
http://www2.arch.unipi.it/slackware-12.2/kde_4.1.87/
questo e' il .tar della directory.
kmplayer in extragear richiede mplayer (non incluso).
Kernel: 7.0.12
scusate per l'OT, ma vi e' piaciuto omploader (con i link diretti)? :D
un servizio gratuito comodo cosi' non l'avevo ancora visto (e' una scoperta recente anche per me) :)
Bakkio2
Nome Cognome: Carlo B.
Slackware: 13.37 64
Kernel: 2.6.33.4-smp
Desktop: kde-4.4.3
Messaggio da Bakkio2 »
ponce ha scritto:http://www2.arch.unipi.it/slackware-12.2/kde_4.1.87/
Io ho fatto come descritto nel readme del tar, ma due problemi...
il primo ovvio è che non c'è più amarok 2, e rapidshare ha tolto il file che avevi messo a dicembre...
ma questo problema mi sembra ovvio, visto che non c'è il tgz nel tuo pacchetto...
il secondo è più fastidioso.
Quando avvio kde con l'utente root, visualizzo il desktop nero, e quindi non visualizzo ne il desktop, ne tantomeno la barra di start.
Se però digito CTRL + F11, visualizzo bene il cubo.
Mentre creando un nuovo utente, non ho questi problemi.
Forse dovrei cancellare la directory /root/.kde .
Non ho provato, in compenso ho creato un utente normale, e per questo che non mi lamento, ma vi facccio partecipe del problema.
