Problema con il wireless atheros [RISOLTO PROBLEMA ROUTER]
Ahh, anche l'output di:
- route -n
Spina
sonzo
Messaggio da sonzo »
Ciao, dmesg mi da questo output:
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
eth0: no IPv6 routers present
ath0: no IPv6 routers present
hda-intel: Invalid position buffer, using LPIB read method instead.
psmouse.c: TouchPad at isa0060/serio4/input0 lost synchronization, throwing 1 bytes away.
avevo provato a togliere la chiave all'AP.. ma non cambia niente :(
Ora sto collegato con eth0:
# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
0.0.0.0 192.168.0.1 0.0.0.0 UG 1 0 0 eth0
avevo provato anche a mettere route add default gw 192.168.0.1 ath0... ma niente di niente :(
root@localhost:/usr/src/linux# iwconfig
lo        no wireless extensions.
wifi0     no wireless extensions.
ath0      IEEE 802.11g  ESSID:""  Nickname:"localhost"
          Mode:Managed  Frequency:2.417 GHz  Access Point: Not-Associated
          Bit Rate:0 kb/s   Tx-Power:9 dBm   Sensitivity=0/3
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality=0/94  Signal level=-95 dBm  Noise level=-95 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
eth0      no wireless extensions.
sit0      no wireless extensions.
root@localhost:/usr/src/linux# ifconfig
ath0      Link encap:Ethernet  HWaddr 00:16:CF:A1:62:B1
          inet6 addr: fe80::216:cfff:fea1:62b1/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 b)  TX bytes:0 (0.0 b)
eth0      Link encap:Ethernet  HWaddr 00:16:D4:65:9D:F5
          inet addr:192.168.0.6  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::216:d4ff:fe65:9df5/64 Scope:Link
          RX packets:9632 errors:0 dropped:0 overruns:0 frame:0
          TX packets:10002 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:5978035 (5.7 MiB)  TX bytes:1652118 (1.5 MiB)
          Interrupt:21 Base address:0xa000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
wifi0     Link encap:UNSPEC  HWaddr 00-16-CF-A1-62-B1-00-00-00-00-00-00-00-00-00-00
          RX packets:18196 errors:0 dropped:0 overruns:0 frame:70344
          TX packets:32171 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:199
          RX bytes:1440302 (1.3 MiB)  TX bytes:1479866 (1.4 MiB)
          Interrupt:18 Memory:f8b00000-f8b10000
Ultima modifica di sonzo il ven 26 gen 2007, 0:35, modificato 1 volta in totale.
Si ma si servono i dati che ti ho chiesto.
Fai la prova di disabilitare la chiave nell'AP e poi postami quello che ti avevo chiesto. Per una diagnosi, servono i sintomi ;)
Spina
sonzo
ora penso di averti risposto.. dicevo comunque che iwconfig e ifconfig sembrano corretti. Ho anche impostato l'ip di ath0 e in route... ma niente di che!
Ho provato anche a togliere la key nell'AP, ma risultato 0!
Nota che non hai un ip nell'interfaccia ath0.
Ma dovevi buttare giù tutte le interfacce. ifconfig deve dare solo i risultati dell'interfaccia ath0 non quella di tutte le altre ;).
Addirittura hai un interfaccia promiscua :).
Dai, prova come ti ho detto è posta tutti gli output.
Spina
Ultima modifica di targzeta il ven 26 gen 2007, 1:13, modificato 1 volta in totale.
P.S. ahhh, nell'ordine che te li ho chiesti :)
Pippi.S. non ti dimenticare di postare anche l'output di dmesg dopo che hai caricato il modulo della scheda wifi
sonzo
Allora ho tirato giù tutte le intefacce ho tolto i moduli e li ho rimessi ed ecco cosa mi dice dmesg:
(i moduli caricati sono:
modprobe ath_pci
modprobe wlan_scan_sta
#dmesg (è solo una parte, la parte finale)
ACPI: PCI interrupt for device 0000:06:02.0 disabled
ath_pci: driver unloaded
ath_pci: 0.9.4.5 (0.9.2.1)
ACPI: PCI Interrupt 0000:06:02.0[A] -> GSI 22 (level, low) -> IRQ 18
wifi0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
wifi0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
wifi0: H/W encryption support: WEP AES AES_CCM TKIP
wifi0: mac 7.8 phy 4.5 radio 5.6
wifi0: Use hw queue 1 for WME_AC_BE traffic
wifi0: Use hw queue 0 for WME_AC_BK traffic
wifi0: Use hw queue 2 for WME_AC_VI traffic
wifi0: Use hw queue 3 for WME_AC_VO traffic
wifi0: Use hw queue 8 for CAB traffic
wifi0: Use hw queue 9 for beacons
wifi0: Atheros 5212: mem=0xc0200000, irq=18
Questo è iwconfig
# iwconfig
          Mode:Managed  Frequency:2.467 GHz  Access Point: Not-Associated
          Encryption key:off
# ifconfig
          inet addr:192.168.0.7  Bcast:192.168.0.255  Mask:255.255.255.0
          RX packets:907 errors:0 dropped:0 overruns:0 frame:2277
          TX packets:1445 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:71930 (70.2 KiB)  TX bytes:66470 (64.9 KiB)
          Interrupt:18 Memory:f8b20000-f8b30000
Ed ecco route -n
# route -n
192.168.0.0     0.0.0.0         255.255.255.0   U     0      0        0 ath0
0.0.0.0         192.168.0.1     0.0.0.0         UG    0      0        0 ath0
per concludere vi pasto anche la scansione delle reti!! (che trova.. )
#wlanconfig ath0 list scan
SSID            BSSID              CHAN RATE  S:N   INT CAPS
house      00:0c:f6:27:6e:08   11   54M 61:0   100 E
# iwlist ath0 scan
ath0      Scan completed :
          Cell 01 - Address: 00:0C:F6:27:6E:08
                    ESSID:"house"
                    Mode:Master
                    Frequency:2.462 GHz (Channel 11)
                    Quality=61/94  Signal level=-34 dBm  Noise level=-95 dBm
                    Encryption key:off
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
                              9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s; 36 Mb/s
                              48 Mb/s; 54 Mb/s
                    Extra:bcn_int=100
Per concludere ho provato a collegarmi all'AP senza passwd..
# iwconfig ath0 essid "_house"
root@localhost:/home/omnipresent# iwconfig
ath0      IEEE 802.11g  ESSID:"house"  Nickname:"localhost"
          Mode:Managed  Frequency:2.437 GHz  Access Point: Not-Associated
          Bit Rate:36 Mb/s   Tx-Power:9 dBm   Sensitivity=0/3
          Encryption key:off
          Link Quality=54/94  Signal level=-41 dBm  Noise level=-95 dBm
sembro collegato.. provo e.. bam collegato!!
Ca**o, ma ieri notte non girava una mazza.. ora riprovo a collegarmi con la WEP.. strano, ma non capisco come mai ieri non andava -.-'' :(
Probabilmente sbagliavo qualcosa.. ora provo con la WEP abilitata e vi faccio sapere.. ma intanto mi chiedo e se dovessi scollegarmi dall'AP come faccio? devo per forza buttar giù l'interfaccia??
sonzo
Ragazzi penso di aver notato qualcosa:
# iwconfig
          Mode:Managed  Frequency:2.462 GHz  Access Point: 00:0C:F6:27:6E:08
          Encryption key:6163-3366-6666-6630-3431   Security mode:restricted
          Link Quality=65/94  Signal level=-30 dBm  Noise level=-95 dBm
          Rx invalid nwid:20  Rx invalid crypt:0  Rx invalid frag:0
questo è quello che vedo quando sono collegato (senza chiave di rete), se invece provo a collegarmi con la chiave WEP (magari sbaglio a collegarmi) vedo che non ho piu' un AP non associato:
# iwconfig
          Mode:Managed  Frequency:2.427 GHz  Access Point: Not-Associated
          Link Quality=57/94  Signal level=-38 dBm  Noise level=-95 dBm
Probabilemente sbaglio a collegarmi, ecco cosa faccio:
iwconfig ath0 key s:ac0aaac044
iwpriv ath0 authmode 2
iwconfig ath0 essid "house"
Forse sbaglio qui.. non so, che mi dite?[/quote]
Prova a dare tutte le opzioni di iwconfig con un sola chiamata.
Ieri sera ti sei collegato bene con
iwconfig ath0 essid "house" ap 00:0C:F6:27:6E:08 key cc3cccf333
almeno da quello che hai postato.
Spina
sonzo
Ho provato ancora a collegarmi senza password e funziona benone, con la password invece no!! (si parla di WEP e non WPA.. sto solo facendo dei test!!)
quel che mi preoccupa è:
# iwconfig
Encryption key:off
Link Quality=61/94 Signal level=-34 dBm Noise level=-95 dBm
A quanto vedo sono collegato all'AP perchè vedo il suo MAC il problema è che con la WEP non vedo il MAC dell'AP, vedo una cosa tipo Non Associato..
ora mi sorge un'altro problema.. come faccio per scollegarmi dal wireless??
Si, buttare giù la ath0 è una soluzione ottimale, solo che se poi do un iwconfig lui mi vede collegato:
Encryption key:off
e quindi come ESSID vede ancora "house" invece dovrebbe vedere "" (ossia nulla!!) come posso fare?
Ma hai provato a collegarti con la WEP come ti ho detto io?
Per scollegarti fai
iwconfig essid "off"  channel 0 ap "off"
dovrebbe funzionare.
Spina
sonzo
ragazzi sinceramente non ho capito perchè prima non andava ora va.. tanto per postarvi quello che ho fatto:
1) impostato ip a ath0 e ho messo il default gw
iwconfig ath0 key chiave
ora va.. grazie mille a tutti.. grazie per avermi aiutato, ma dopo tanto e dopo tanti test ora gira benone!!
:D
Ora voglio proprio installare il WPA solo che praticamente sul sito ufficiale di wpa_supplicant non è raggiungibile, qualcuno ha un link o un pacchetto da installare??
sonzo
E' incredibile!!!! E' veramente incredibile!
Dopo un format totale per fare alcuni test, non riesco piu' ad accedere al wireless attraverso la WEP!
Senza key, accedo senza problemi, con la key WEP non riesco proprio più ad accedere :(
Incredibile!
