System Linux barkode 2.6.21.5-smp #2 SMP Tue Jun 19 14:58:11 CDT 2007 i686
Build Date Jun 29 2007 00:17:15
Configure Command './configure' '--prefix=/usr' '--with-apxs2=/usr/sbin/apxs' '--prefix=/usr' '--sysconfdir=/etc' '--disable-safe-mode' '--enable-apc' '--enable-apc-mmap' '--enable-memory-limit' '--enable-suhosin' '--disable-magic-quotes' '--enable-zend-multibyte' '--enable-mbregex' '--enable-tokenizer=shared' '--with-config-file-scan-dir=/etc/php' '--with-config-file-path=/etc/httpd' '--with-mod_charset' '--with-layout=PHP' '--enable-sigchild' '--enable-xml' '--with-libxml-dir=/usr' '--enable-simplexml' '--enable-spl' '--enable-filter' '--disable-debug' '--with-openssl=shared' '--with-pcre-regex=/usr' '--with-zlib=shared,/usr' '--enable-bcmath=shared' '--with-bz2=shared,/usr' '--enable-calendar=shared' '--enable-ctype=shared' '--with-curl=shared' '--with-curlwrappers' '--enable-dba=shared' '--with-gdbm=/usr' '--with-db4=/usr' '--enable-dbase=shared' '--enable-exif=shared' '--enable-ftp=shared' '--with-gd=shared' '--with-jpeg-dir=/usr' '--with-png-dir=/usr' '--with-zlib-dir=/usr' '--with-xpm-dir=/usr' '--with-freetype-dir=/usr' '--with-t1lib=/usr' '--enable-gd-native-ttf' '--enable-gd-jis-conv' '--with-gettext=shared,/usr' '--with-gmp=shared,/usr' '--with-iconv=shared' '--with-imap-ssl=/usr' '--with-imap=/usr/local/lib/c-client' '--with-ldap=shared' '--enable-mbstring=shared' '--with-hash' '--with-mhash=shared,/usr' '--with-mysql=shared,/usr' '--with-mysqli=shared,/usr/bin/mysql_config' '--enable-pdo=shared' '--with-pdo-mysql=shared,/usr' '--with-pdo-sqlite=shared' '--with-pspell=shared,/usr' '--with-mm=/usr' '--enable-shmop=shared' '--with-snmp=shared,/usr' '--enable-soap=shared' '--enable-sockets' '--with-sqlite=shared' '--enable-sqlite-utf8' '--with-regex=php' '--enable-sysvmsg' '--enable-sysvsem' '--enable-sysvshm' '--enable-wddx=shared' '--with-xsl=shared,/usr' '--enable-zip=shared' '--with-tsrm-pthreads' '--enable-shared=yes' '--enable-static=no' '--with-gnu-ld' '--with-pic' '--build=i486-slackware-linux'
Server API Apache 2.0 Handler
Virtual Directory Support disabled
Configuration File (php.ini) Path /etc/httpd
Loaded Configuration File /etc/httpd/php.ini
Scan this dir for additional .ini files /etc/php
PHP API 20041225
PHP Extension 20060613
Zend Extension 220060519
Debug Build no
Thread Safety disabled
Zend Memory Manager enabled
IPv6 Support enabled
Registered PHP Streams php, file, data, compress.bzip2, tftp, ftp, telnet, dict, ldap, http, https, ftps, zip, compress.zlib
Registered Stream Socket Transports tcp, udp, unix, udg, ssl, sslv3, sslv2, tls
Registered Stream Filters string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, bzip2.*, convert.iconv.*, zlib.*
e così via... ora va tutto ok. Ninobi non so come ringraziarti
