Slackware, Debian & Lilo
414N
Kernel: 5.15.19
Re: Slackware, Debian & Lilo
Messaggio da 414N »
Di niente.
Vista la risposta anche sull'altro forum, potresti postare il contenuto di /deb5/boot, per favore?
fortea
Kernel: 2.6.29.6
Desktop: fluxbox
Messaggio da fortea »
Vistop che sul forum di debian ho avuto poca attenzione continuo a chiedere aiuto a voi! :D
 $ ls /deb5/boot/ -l
    total 9532
    -rw-r--r-- 1 root root 1226453 2010-08-31 13:23 System.map-2.6.26-2-amd64
    -rw-r--r-- 1 root root     137 2011-01-08 14:44 boot_message.txt
    -rw-r--r-- 1 root root   85694 2010-08-31 13:23 config-2.6.26-2-amd64
    -rw-r--r-- 1 root root 6657959 2011-01-01 14:40 initrd.img-2.6.26-2-amd64
    -rw-r--r-- 1 root root 1756688 2010-08-31 13:22 vmlinuz-2.6.26-2-amd64
    $ ls /deb5/ -l
    total 120
    drwxr-xr-x  2 root root  4096 2011-01-01 14:39 bin
    drwxr-xr-x  2 root root  4096 2011-01-19 19:46 boot
    lrwxrwxrwx  1 root root    11 2011-01-01 14:38 cdrom -> media/cdrom
    drwxr-xr-x  4 root root  4096 2011-01-01 14:39 dev
    drwxr-xr-x 44 root root  4096 2011-01-14 18:20 etc
    drwxr-xr-x  3 root root  4096 2011-01-01 14:45 home
    lrwxrwxrwx  1 root root    30 2011-01-01 14:40 initrd.img -> boot/initrd.img-2.6.26-2-amd64
    drwxr-xr-x 11 root root  4096 2011-01-01 14:44 lib
    lrwxrwxrwx  1 root root     4 2011-01-01 14:38 lib64 -> /lib
    drwxr-xr-x  2 root root 49152 2011-01-01 14:38 lost+found
    drwxr-xr-x  4 root root  4096 2011-01-01 14:38 media
    drwxr-xr-x  2 root root  4096 2010-08-30 03:33 mnt
    drwxr-xr-x  2 root root  4096 2011-01-01 14:39 opt
    drwxr-xr-x  2 root root  4096 2010-08-30 03:33 proc
    drwxr-xr-x  4 root root  4096 2011-01-01 14:43 root
    drwxr-xr-x  2 root root  4096 2011-01-14 18:26 sbin
    drwxr-xr-x  2 root root  4096 2008-09-16 09:22 selinux
    drwxr-xr-x  2 root root  4096 2011-01-01 14:39 srv
    drwxr-xr-x  2 root root  4096 2008-08-12 16:20 sys
    drwxrwxrwt  2 root root  4096 2011-01-16 20:00 tmp
    drwxr-xr-x 10 root root  4096 2011-01-01 14:39 usr
    drwxr-xr-x 13 root root  4096 2011-01-01 14:39 var
    lrwxrwxrwx  1 root root    27 2011-01-01 14:40 vmlinuz -> boot/vmlinuz-2.6.26-2-amd64
Dovrebbe essere corretto... Ho rimosso il file si initramfs; prima avevo creato un link chiamato initrd.img che puntava al file initramfs in /deb5/boot, ma non ho ridato il comando 'lilo -v'. Comunque nulla da fare. non funziona ancora...
Thanks for the help
414N
Kernel: 5.15.19
Messaggio da 414N »
Quando dai lilo -v cosa sputa fuori?
matzu
Nome Cognome: Franco
Slackware: 64-13.37 13.1
Kernel: generic
Messaggio da matzu »
Se non ho letto male, avevi modificato il puntamento a vmlinuz[...] in lilo.conf, cambiando da "link nella root di debian" a "kernel vero e proprio" in /boot/ di debian, ovvero /deb5/boot/ di slackware. Ma non hai fatto la stessa cosa con l'initrd. Perciò con quel link che hai postato, il bootloader va a cercarti un initrd nella /boot/ di slackware, che non c'è. Se è così, in lilo.conf punta direttamente all'initrd, anziché usare il link.
fortea
Kernel: 2.6.29.6
Desktop: fluxbox
matzu ha scritto:Se non ho letto male, avevi modificato il puntamento a vmlinuz[...] in lilo.conf, cambiando da "link nella root di debian" a "kernel vero e proprio" in /boot/ di debian, ovvero /deb5/boot/ di slackware. Ma non hai fatto la stessa cosa con l'initrd. Perciò con quel link che hai postato, il bootloader va a cercarti un initrd nella /boot/ di slackware, che non c'è. Se è così, in lilo.conf punta direttamente all'initrd, anziché usare il link.
Questo è il mio lilo.conf nella sezione di debian. Non capisco cosa intendi... il link punta al file in /deb5/boot/ non in /boot di slackware.
image = /deb5/vmlinuz
root = /dev/sda2
initrd=/deb5/initrd.img
label = Deb5
read-only
che il problema siano gli spazi attorno all'uguale alla riga 3 del codice postato?
414N ha scritto:Quando dai lilo -v cosa sputa fuori?
l'ho già scritto nei messaggi precedenti, prova a cercarlo.
matzu
Kernel: generic
fortea ha scritto:
matzu ha scritto:Se non ho letto male...
Scusa, avevo letto male, infatti; e cioè questo:
initrd.img -> /boot/initrd.img-2.6.26-2-amd64
al posto di questo:
414N
Kernel: 5.15.19
Messaggio da 414N »
fortea ha scritto:l'ho già scritto nei messaggi precedenti, prova a cercarlo.
Sì, ma quello che hai riportato in precedenza non prevedeva la initrd, che hai aggiunto ultimamente alla parte riguardante Debian.
fortea
Kernel: 2.6.29.6
Desktop: fluxbox
Hai ragione, scusate, non avevo capito. L'output di lilo è il seguente:
Reading boot sector from /dev/sda
Using MENU secondary loader
Calling map_insert_data
Mapping message file /boot/boot_message.txt
Calling map_insert_file
Boot image: /boot/vmlinuz -> vmlinuz-huge-2.6.29.6
Added S13.0 *
Boot image: /deb5/vmlinuz -> boot/vmlinuz-2.6.26-2-amd64
Mapping RAM disk /deb5/initrd.img -> boot/initrd.img-2.6.26-2-amd64
Added Deb5
Writing boot sector.
/boot/boot.0800 exists - no boot sector backup copy made.
matzu
Kernel: generic
fortea ha scritto:Comunque penso che siamo sulla strada giusta perchè lanciando Debian uno degli errori dati è "RAMDISK: Couldn´t find valid RAM disk image starting at 0"
All'installazione di Debian, dopo la scelta del kernel ti pone una scelta tra due initrd, uno "huge" diciamo, e uno "cucito addosso" al tuo sistema, avvertendoti che quest'ultimo ha qualche probabilità, sia pur minima, di non funzionare. Quale hai installato?
Se hai installato quello leggero potresti provare a installare l'altro. Prova ad avviare debian dal cd in modalità rescue. Dopo aver scelto quale root la partizione su cui hai installato il sistema debian da riparare, ti propone diverse opzioni, tra cui una shell. Da lì potresti eseguire un mkinitramfs. Prendila con le pinze, perché non conosco questo comando e la sto buttando lì. Dando un'occhiata al man, non è esattamente lo stesso di mkinitrd in slackware (per esempio mi pare non ci sia un'opzione con cui passargli i moduli, e queste istruzioni forse se le prende da certi suoi files di configurazione). Altrimenti vedi se ci sono altri comandi per ripristinare un initrd corretto.
Dalla modalità rescue puoi pure tentare la "reinstallazione" (ex novo nel tuo caso) di grub, di tra le opzioni che ti propone. Potresti farlo, almeno, per esaminare il menu.lst come ti suggeriva 414N, e utilizzare la configurazione che c'è in esso per inserirla in lilo. Solo che l'errore non sembra essere nel lilo.conf.
fortea
Kernel: 2.6.29.6
Desktop: fluxbox
Per quanto riguarda l'initramfs, ho già provato. Non funzionava, ma non conoscendolo nemmeno io non sono sicuro di averlo utilizzato crrettamente. Fra l'altro non capisco perchè Debian inserisca il comando per creare automaticamente gli initramfs e poi usa didefault gli initrd... :?:
matzu ha scritto: All'installazione di Debian, dopo la scelta del kernel ti pone una scelta tra due initrd, uno "huge" diciamo, e uno "cucito addosso" al tuo sistema, avvertendoti che quest'ultimo ha qualche probabilità, sia pur minima, di non funzionare. Quale hai installato?
Quale scelta del kernel? non mi pare di aver dovuto scegliere, penso che ce ne fosse uno solo.
matzu ha scritto: Dalla modalità rescue puoi pure tentare la "reinstallazione" (ex novo nel tuo caso) di grub, di tra le opzioni che ti propone. Potresti farlo, almeno, per esaminare il menu.lst come ti suggeriva 414N, e utilizzare la configurazione che c'è in esso per inserirla in lilo. Solo che l'errore non sembra essere nel lilo.conf.
Ci ho pensato anch'io. Ma per principio non accetto che non funzioni con lilo e con grub sì.
Ostico il problema, nè? :p
matzu
Kernel: generic
L'installer della debian 5 per i386 (32bit) propone:
linux-image-2.6-486
linux-image-2.6-686
linux-image-2.6.26-2-486
linux-image-2.6.26-2-686
(il default dipende dall'hardware)
Per l'initrd:
generic: include all available drivers
targeted: only include drivers needed for this system
(il default è il generic)
A proposito della scelta del initrd dice, tra l'altro:
With the smaller targeted initrd there is a very small chance that not all needed drivers are included.
Comunque non so se il discorso sia analogo per 64bit.
fortea
Kernel: 2.6.29.6
Desktop: fluxbox
ho riprovato a fare partire il cd di installazione per amd64. Nell'installaizone normale non c'è, e nemmeno in quella "expert". Magari però si possono recuperare col rescue mode?
ma altri problemi non possono esserci? possibile che debian dia l'initrd sbagliato? non sarà da qualche altra parte?
414N
Kernel: 5.15.19
Messaggio da 414N »
Può darsi che oltre al problema dell'initrd ci siano altri problemi. Per esempio, magari di default il kernel di Debian si aspetta certi parametri al boot...
Se grub fosse stato installato e configurato in automatico dal setup di Debian, almeno potremmo vedere di preciso con quali parametri e initrd il kernel verrebbe lanciato.
fortea
Kernel: 2.6.29.6
Desktop: fluxbox
deer
Nome Cognome: Maurizio Brunelli
Kernel: 2.6.33.4
Desktop: KDE4-FluxboxWM
Distribuzione: Debian-ArchBang
Messaggio da deer »
Se può essere utile, vi posto la parte relativa la boot Debian del mio Grub.cfg(grub versione 2)
menuentry 'Debian GNU/Linux, with Linux 2.6.32-5-686' --class debian --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
set root='(hd0,msdos1)'
search --no-floppy --fs-uuid --set 7c15c7f9-d5d8-42fb-b097-91507eb06577
echo 'Loading Linux 2.6.32-5-686 ...'
linux /boot/vmlinuz-2.6.32-5-686 root=UUID=7c15c7f9-d5d8-42fbb097-91507eb06577 ro quiet
echo 'Loading initial ramdisk ...'
initrd /boot/initrd.img-2.6.32-5-686-
L'initrd e il vmlinuz si trovano nella directory "boot".
Mai vista deb5 o simili.
