BusID "PCI:5:0.0"Codice: Seleziona tutto
BusID "PCI:5:0:0"Moderatore: Staff
BusID "PCI:5:0:0"
BusID "PCI:5:0:0"Codice: Seleziona tutto
BusID "PCI:5:0.0"
X.Org X Server 1.7.7
Release Date: 2010-05-04
Build Operating System: Slackware 13.1 Slackware Linux Project
Current Operating System: Linux yari 2.6.35.10-smp #1 SMP Fri Feb 11 00:23:00 CET 2011 i686
Kernel command line: BOOT_IMAGE=Linux-2.6.35.10 ro root=804 vt.default_utf8=0
Build Date: 05 May 2010 01:54:53AM
Current version of pixman: 0.16.6
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Feb 11 20:20:46 2011
(==) ServerLayout "Layout0"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Device0"
(**) |-->Input Device "Keyboard0"
(**) |-->Input Device "Mouse0"
(WW) The directory "/usr/share/fonts/local" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/share/fonts/CID" does not exist.
(**) FontPath set to:
/usr/lib/X11/fonts/misc/:unscaled,
/usr/lib/X11/fonts/100dpi/:unscaled,
/usr/lib/X11/fonts/75dpi/:unscaled,
/usr/lib/X11/fonts/misc/,
/usr/lib/X11/fonts/Type1/,
/usr/lib/X11/fonts/Speedo/,
/usr/lib/X11/fonts/100dpi/,
/usr/lib/X11/fonts/75dpi/,
/usr/lib/X11/fonts/cyrillic/,
/usr/lib/X11/fonts/TTF/,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF,
/usr/share/fonts/Type1,
/usr/share/fonts/misc,
/usr/share/fonts/75dpi,
/usr/share/fonts/100dpi,
/usr/share/fonts/cyrillic
(==) ModulePath set to "/usr/lib/xorg/modules"
(WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
(WW) Disabling Keyboard0
(WW) Disabling Mouse0
(II) Loader magic: 0x81e4c80
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(--) using VT number 7
(--) PCI:*(0:0:2:0) 8086:a001:1043:8446 rev 2, Mem @ 0xf5d00000/524288, 0xb0000000/268435456, 0xf5c00000/1048576, I/O @ 0x0000cc00/8
(--) PCI: (0:0:2:1) 8086:a002:1043:8446 rev 2, Mem @ 0xf5d80000/524288
(--) PCI: (0:5:0:0) 10de:0a76:1043:8446 rev 162, Mem @ 0xfa000000/16777216, 0xd0000000/268435456, 0xce000000/33554432, I/O @ 0x0000ec00/128, BIOS @ 0x????????/524288
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
compiled for 1.7.7, module version = 1.0.0
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module 260.19.36 Tue Jan 18 17:28:21 PST 2011
(II) Loading extension GLX
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
(II) NVIDIA dlloader X Driver 260.19.36 Tue Jan 18 17:12:14 PST 2011
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 00@00:02:0
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "wfb"
(II) LoadModule: "wfb"
(II) Loading /usr/lib/xorg/modules/libwfb.so
(II) Module wfb: vendor="X.Org Foundation"
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Module "ramdac" already built-in
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) Feb 11 20:20:48 NVIDIA(0): Enabling RENDER acceleration
(II) Feb 11 20:20:48 NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
(II) Feb 11 20:20:48 NVIDIA(0): enabled.
(WW) Feb 11 20:20:49 NVIDIA(GPU-0): Unable to read EDID for display device CRT-0
(II) Feb 11 20:20:49 NVIDIA(0): NVIDIA GPU ION (GT218) at PCI:5:0:0 (GPU-0)
(--) Feb 11 20:20:49 NVIDIA(0): Memory: 524288 kBytes
(--) Feb 11 20:20:49 NVIDIA(0): VideoBIOS: 70.18.55.00.0c
(II) Feb 11 20:20:49 NVIDIA(0): Detected PCI Express Link width: 1X
(--) Feb 11 20:20:49 NVIDIA(0): Interlaced video modes are supported on this GPU
(--) Feb 11 20:20:49 NVIDIA(0): Connected display device(s) on ION at PCI:5:0:0
(--) Feb 11 20:20:49 NVIDIA(0): CRT-0
(--) Feb 11 20:20:49 NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
(II) Feb 11 20:20:49 NVIDIA(0): Assigned Display Device: CRT-0
(==) Feb 11 20:20:49 NVIDIA(0):
(==) Feb 11 20:20:49 NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
(==) Feb 11 20:20:49 NVIDIA(0): will be used as the requested mode.
(II) Feb 11 20:20:49 NVIDIA(0): Validated modes:
(II) Feb 11 20:20:49 NVIDIA(0): "nvidia-auto-select"
(II) Feb 11 20:20:49 NVIDIA(0): Virtual screen size determined to be 640 x 480
(WW) Feb 11 20:20:49 NVIDIA(0): Unable to get display device CRT-0's EDID; cannot compute DPI
(WW) Feb 11 20:20:49 NVIDIA(0): from CRT-0's EDID.
(==) Feb 11 20:20:49 NVIDIA(0): DPI set to (75, 75); computed from built-in default
(==) Feb 11 20:20:49 NVIDIA(0): Enabling 32-bit ARGB GLX visuals.
(--) Depth 24 pixmap format is 32 bpp
(II) Feb 11 20:20:49 NVIDIA: Using 768.00 MB of virtual memory for indirect memory access.
(II) Feb 11 20:20:49 NVIDIA(0): Initialized GPU GART.
(II) Feb 11 20:20:49 NVIDIA(0): ACPI display change hotkey events enabled: the X server is new
(II) Feb 11 20:20:49 NVIDIA(0): enough to receive ACPI hotkey events.
(WW) Feb 11 20:20:49 NVIDIA(0): ACPI: Error: Unable to find the brightness file path under
(WW) Feb 11 20:20:49 NVIDIA(0): /proc/acpi/video. The NVIDIA X driver will not be able to
(WW) Feb 11 20:20:49 NVIDIA(0): respond to ACPI brightness change hotkey events.
(II) Feb 11 20:20:49 NVIDIA(0): Setting mode "nvidia-auto-select"
(II) Feb 11 20:20:49 NVIDIA(0): Built-in logo is bigger than the screen.
(II) Loading extension NV-GLX
(II) Feb 11 20:20:49 NVIDIA(0): Initialized OpenGL Acceleration
(==) NVIDIA(0): Disabling shared memory pixmaps
(II) Feb 11 20:20:49 NVIDIA(0): Initialized X Rendering Acceleration
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(**) NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(II) Loading extension XINERAMA
(==) RandR enabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing extension GLX
(II) config/hal: Adding input device SynPS/2 Synaptics TouchPad
(II) LoadModule: "synaptics"
(II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
(II) Module synaptics: vendor="X.Org Foundation"
compiled for 1.7.5, module version = 1.2.2
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 7.0
(II) Synaptics touchpad driver version 1.2.2
(**) Option "Device" "/dev/input/event6"
(II) SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5624
(II) SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4754
(II) SynPS/2 Synaptics TouchPad: pressure range 0 - 255
(II) SynPS/2 Synaptics TouchPad: finger width range 0 - 0
(II) SynPS/2 Synaptics TouchPad: buttons: left right
(**) Option "TapButton1" "1"
(--) SynPS/2 Synaptics TouchPad: touchpad found
(**) SynPS/2 Synaptics TouchPad: always reports core events
(II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD)
(**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
(**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 0
(II) config/hal: Adding input device AT Translated Set 2 keyboard
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.7.6, module version = 2.3.3
(**) AT Translated Set 2 keyboard: always reports core events
(**) AT Translated Set 2 keyboard: Device: "/dev/input/event0"
(II) AT Translated Set 2 keyboard: Found keys
(II) AT Translated Set 2 keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "evdev"
(**) Option "xkb_layout" "us"
(**) Option "xkb_options" "terminate:ctrl_alt_bksp"
(II) config/hal: Adding input device Eee PC WMI hotkeys
(**) Eee PC WMI hotkeys: always reports core events
(**) Eee PC WMI hotkeys: Device: "/dev/input/event7"
(II) Eee PC WMI hotkeys: Found keys
(II) Eee PC WMI hotkeys: Configuring as keyboard
(II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD)
(II) config/hal: Adding input device USB2.0 UVC 1.3M WebCam
(**) USB2.0 UVC 1.3M WebCam: always reports core events
(**) USB2.0 UVC 1.3M WebCam: Device: "/dev/input/event5"
(II) USB2.0 UVC 1.3M WebCam: Found keys
(II) USB2.0 UVC 1.3M WebCam: Configuring as keyboard
(II) XINPUT: Adding extended input device "USB2.0 UVC 1.3M WebCam" (type: KEYBOARD)
(II) config/hal: Adding input device Sleep Button
(**) Sleep Button: always reports core events
(**) Sleep Button: Device: "/dev/input/event2"
(II) Sleep Button: Found keys
(II) Sleep Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD)
(II) config/hal: Adding input device Power Button
(**) Power Button: always reports core events
(**) Power Button: Device: "/dev/input/event3"
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
(II) config/hal: Adding input device Video Bus
(**) Video Bus: always reports core events
(**) Video Bus: Device: "/dev/input/event8"
(II) Video Bus: Found keys
(II) Video Bus: Configuring as keyboard
(II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD)
(**) Video Bus: Device: "/dev/input/event9"
(**) Power Button: Device: "/dev/input/event4"
