Scheda wireless Atheros
Black bart
Nome Cognome: Omar
Re: Scheda wireless Atheros
Messaggio da Black bart »
Eccolo:
bash-4.3# dmesg | grep ath
[    4.024684] md: multipath personality registered for level -4
[    7.483191] ath10k_pci 0000:01:00.0: enabling device (0000 -> 0002)
[    7.486949] ath10k_pci 0000:01:00.0: pci irq msi-x interrupts 8 irq_mode 0 reset_mode 0
[    7.737763] ath10k_pci 0000:01:00.0: Direct firmware load for ath10k/cal-pci-0000:01:00.0.bin failed with error -2
[    8.051621] ath10k_pci 0000:01:00.0: board id is not exist in otp, ignore it
[   10.481072] ath10k_pci 0000:01:00.0: firmware crashed! (uuid 5f53557f-ab7d-4df3-bc21-42f83c5ebd31)
[   10.482299] ath10k_pci 0000:01:00.0: qca9377 hw1.1 (0x05020001, 0x003821ff sub 1028:1810) fw WLAN.TF.1.0-00002-QCATFSWPZ-5 fwapi 5 bdapi 2 htt-ver 0.0 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1 features ignore-otp
[   10.484872] ath10k_pci 0000:01:00.0: debug 0 debugfs 1 tracing 0 dfs 0 testmode 0
[   10.488483] ath10k_pci 0000:01:00.0: firmware register dump:
[   10.489749] ath10k_pci 0000:01:00.0: [00]: 0x05020001 0x00000000 0x00A0F774 0x00000000
[   10.491019] ath10k_pci 0000:01:00.0: [04]: 0x00A0F774 0x00060130 0x00000010 0xFFFFE000
[   10.492217] ath10k_pci 0000:01:00.0: [08]: 0x0042136C 0x00420660 0x00400000 0x00400000
[   10.493361] ath10k_pci 0000:01:00.0: [12]: 0x00000000 0x00000000 0x00952CD0 0x00952CE6
[   10.494520] ath10k_pci 0000:01:00.0: [16]: 0x00000002 0x01010101 0x00000003 0x0000000A
[   10.495627] ath10k_pci 0000:01:00.0: [20]: 0x00000328 0x00429880 0x009A37AC 0x00000032
[   10.496764] ath10k_pci 0000:01:00.0: [24]: 0x800A0D0A 0x0040EA88 0x00420170 0x004173B0
[   10.497915] ath10k_pci 0000:01:00.0: [28]: 0x00401F64 0x00401F68 0x00000000 0x00417550
[   10.499067] ath10k_pci 0000:01:00.0: [32]: 0x00401FC0 0x905A5628 0x004049B4 0x00000003
[   10.500208] ath10k_pci 0000:01:00.0: [36]: 0x800A0907 0x00000001 0x0000085B 0x339011B2
[   10.501242] ath10k_pci 0000:01:00.0: [40]: 0x0000FFFE 0x0000000A 0x009BFE28 0x009BE0DC
[   10.502248] ath10k_pci 0000:01:00.0: [44]: 0x800A0D0A 0x0040EA88 0x00420170 0x004173B0
[   10.503203] ath10k_pci 0000:01:00.0: [48]: 0x00400000 0x00400000 0x00000001 0xFFFFFFFF
[   10.504186] ath10k_pci 0000:01:00.0: [52]: 0x800A0614 0x0040EAA8 0x0041FA10 0x00420170
[   10.505195] ath10k_pci 0000:01:00.0: [56]: 0x00400000 0x00421370 0x00419980 0x004212E8
[   11.470429] ath10k_pci 0000:01:00.0: failed to receive control response completion, polling..
[   12.472501] ath10k_pci 0000:01:00.0: ctl_resp never came in (-110)
[   12.474358] ath10k_pci 0000:01:00.0: failed to connect to HTC: -110
[   12.477043] ath10k_pci 0000:01:00.0: could not init core (-110)
[   12.478907] ath10k_pci 0000:01:00.0: could not probe fw (-110)
[   12.485521] ath10k_pci 0000:01:00.0: cannot restart a device that hasn't been started
Ok.
Come puoi vedere tu stesso, c'è un errore durante il caricamento del firmware, cui segue un bel crash:
Prova innanzitutto a fare questo tentativo:
- "uccidi" qualsiasi demone/programma che potrebbe impegnare la scheda wireless - es: wicd, NetworkManager, script di slackware riguardante il wifi.
- rimuovi il driver del kernel:
sudo modprobe -v -r ath10k_pci
e ricaricalo in questo modo:
sudo modprobe -v ath10k_core skip_otp=1
sudo modprobe -v ath10k_pci
Controlla con 'iwconfig' se salta fuori la scheda wireless e nuovamente l'output di 'dmesg', incollando qui i risultati.
Se nulla cambia, proveremo a esaminare la questione 'aggiornamento firmware'.
Black bart
Nome Cognome: Omar
Dopo fatto tutto,iwconfig mi da
bash-4.3# iwconfig
lo        no wireless extensions.
eth0      no wireless extensions.
Strano perchè current funziona alla grande...
Ok, allora prova ad aggiornare il pacchetto kernel-firmware prendendolo dalla current 64-bit:
wget 'http://slackware.osuosl.org/slackware64-current/slackware64/a/kernel-firmware-20190221_9ee52be-noarch-1.txz'
(**** Se sei su 32-bit, sostituisci l'url con 'http://slackware.osuosl.org/slackware-c ... arch-1.txz' ***)
Edit Il risultato non cambia, dato che è un pacchetto -noarch.
Installalo con:
sudo upgradepkg --install-new --reinstall ./kernel-firmware-20190221_9ee52be-noarch-1.txz
Riavvia e verifica se c'è qualche cambiamento.
Altrimenti, ammesso che gli aggiornamenti di kernel e config del botlloader siano stato fatti correttamente, devi compilarti un kernel più recente, magari il 4.19 usato nella current.
Kernel: 7.2.10
comunque, Black bart, ti consiglierei di leggere bene quello che ti viene scritto e di provare a seguire le indicazioni che ti vengono gentilmente offerte alla lettera: se rik70 ti dice di eseguire dei comandi e di postare l'output fallo per favore per tutti i comandi che ti vengono elencati, non scegliere di tua iniziativa cosa postare e cosa no, senno' per chi ti vuole aiutare diventa un compito improbo capire cosa ti stia succedendo.
Black bart
Nome Cognome: Omar
ponce ha scritto:comunque, Black bart, ti consiglierei di leggere bene quello che ti viene scritto e di provare a seguire le indicazioni che ti vengono gentilmente offerte alla lettera: se rik70 ti dice di eseguire dei comandi e di postare l'output fallo per favore per tutti i comandi che ti vengono elencati, non scegliere di tua iniziativa cosa postare e cosa no, senno' per chi ti vuole aiutare diventa un compito improbo capire cosa ti stia succedendo.
Mi sembra di averlo fatto...
Scaricato ed installato come consigliato kernel-firmware ma non cambia nulla,ho sempre gli stessi output postati in precedenza.
Credo sia necessario compilare un nuovo kernel,anche perchè il portatile è piuttosto nuovo,magari i driver con quello della 14.2 non sono supportati...ma è una mia idea...
Kernel: 7.2.10
rik70 ha scritto:Da terminale, dai questo comando e incolla qui l'output:
sudo dmesg | grep ath
Se non restituisce nulla, prova con:
e incolla il risultato.
rik70 ha scritto:- "uccidi" qualsiasi demone/programma che potrebbe impegnare la scheda wireless - es: wicd, NetworkManager, script di slackware riguardante il wifi.
se leggi bene non avevi messo tutto quello che ti era stato chiesto... magari prova a rifare questi passaggi ora che hai aggiornato il firmware, giusto per vere se nell'output che ti da modprobe e di dmesg cambiasse qualcosa (incolla tutti gli output qui)...
Black bart ha scritto:Credo sia necessario compilare un nuovo kernel,anche perchè il portatile è piuttosto nuovo,magari i driver con quello della 14.2 non sono supportati...ma è una mia idea...
scusa, per capire: non avevi detto che con il kernel di default della 14.2 il wifi ti funzionava e che ha smesso di andare dopo gli aggiornamenti?
Black bart ha scritto:Ho installato la 14.2 e constatato che all'avvio,senza aggiornare nulla e quindi con il kernel 4.4.14 funziona tutto egregiamente,le reti le vede e ci si può connettere...il guaio inizia dopo l'aggiornamento al 4.4.172,una volta riavviato le reti non ci sono più,da quello che ho capito è che il wi-fi non viene attivato.
Black bart
Nome Cognome: Omar
Questi gli output in sequenza,quello che non capisco è perchè col kernel più "vecchi" 4.4.14 funzionava bene...
bash-4.3# modprobe -v -r ath10k_pci
rmmod ath10k_pci
rmmod ath10k_core
rmmod mac80211
rmmod ath
rmmod cfg80211
bash-4.3# modprobe -v ath10k_core skip_otp=1
insmod /lib/modules/4.4.172/kernel/net/wireless/cfg80211.ko
insmod /lib/modules/4.4.172/kernel/net/mac80211/mac80211.ko
insmod /lib/modules/4.4.172/kernel/drivers/net/wireless/ath/ath.ko
insmod /lib/modules/4.4.172/kernel/drivers/net/wireless/ath/ath10k/ath10k_core.ko skip_otp=1
bash-4.3# modprobe -v ath10k_pci
insmod /lib/modules/4.4.172/kernel/drivers/net/wireless/ath/ath10k/ath10k_pci.ko
Kernel: 7.2.10
...e quello di "dmesg | grep ath"?
Black bart
Nome Cognome: Omar
Giusto...comunque è vero,col vecchio kernel andava ottimamente...
[    4.019683] md: multipath personality registered for level -4
[    7.776970] ath10k_pci 0000:01:00.0: enabling device (0000 -> 0002)
[    7.779488] ath10k_pci 0000:01:00.0: pci irq msi-x interrupts 8 irq_mode 0 reset_mode 0
[    8.016725] ath10k_pci 0000:01:00.0: Direct firmware load for ath10k/cal-pci-0000:01:00.0.bin failed with error -2
[    8.218066] ath10k_pci 0000:01:00.0: board id is not exist in otp, ignore it
[   10.688507] ath10k_pci 0000:01:00.0: firmware crashed! (uuid 3f2bc599-f321-483e-b51a-567259a4a950)
[   10.689269] ath10k_pci 0000:01:00.0: qca9377 hw1.1 (0x05020001, 0x003821ff sub 1028:1810) fw WLAN.TF.1.0-00002-QCATFSWPZ-5 fwapi 5 bdapi 2 htt-ver 0.0 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1 features ignore-otp
[   10.690847] ath10k_pci 0000:01:00.0: debug 0 debugfs 1 tracing 0 dfs 0 testmode 0
[   10.693964] ath10k_pci 0000:01:00.0: firmware register dump:
[   10.694725] ath10k_pci 0000:01:00.0: [00]: 0x05020001 0x00000000 0x00A0F774 0x00000000
[   10.695520] ath10k_pci 0000:01:00.0: [04]: 0x00A0F774 0x00060130 0x00000010 0xFFFFE000
[   10.696270] ath10k_pci 0000:01:00.0: [08]: 0x0042136C 0x00420660 0x00400000 0x00400000
[   10.697043] ath10k_pci 0000:01:00.0: [12]: 0x00000000 0x00000000 0x00952CD0 0x00952CE6
[   10.697757] ath10k_pci 0000:01:00.0: [16]: 0x00000002 0x01010101 0x00000003 0x0000000A
[   10.698457] ath10k_pci 0000:01:00.0: [20]: 0x00000328 0x00429880 0x009A37AC 0x00000032
[   10.699158] ath10k_pci 0000:01:00.0: [24]: 0x800A0D0A 0x0040EA88 0x00420170 0x004173B0
[   10.699816] ath10k_pci 0000:01:00.0: [28]: 0x00401F64 0x00401F68 0x00000000 0x00417550
[   10.700502] ath10k_pci 0000:01:00.0: [32]: 0x00401FC0 0x905A5628 0x004049B4 0x00000003
[   10.701160] ath10k_pci 0000:01:00.0: [36]: 0x800A0907 0x00000001 0x0000085B 0x339011B2
[   10.701821] ath10k_pci 0000:01:00.0: [40]: 0x0000FFFE 0x0000000A 0x009BFE28 0x009BE0DC
[   10.702517] ath10k_pci 0000:01:00.0: [44]: 0x800A0D0A 0x0040EA88 0x00420170 0x004173B0
[   10.703183] ath10k_pci 0000:01:00.0: [48]: 0x00400000 0x00400000 0x00000001 0xFFFFFFFF
[   10.703886] ath10k_pci 0000:01:00.0: [52]: 0x800A0614 0x0040EAA8 0x0041FA10 0x00420170
[   10.704541] ath10k_pci 0000:01:00.0: [56]: 0x00400000 0x00421370 0x00419980 0x004212E8
[   11.677933] ath10k_pci 0000:01:00.0: failed to receive control response completion, polling..
[   12.679890] ath10k_pci 0000:01:00.0: ctl_resp never came in (-110)
[   12.682201] ath10k_pci 0000:01:00.0: failed to connect to HTC: -110
[   12.685413] ath10k_pci 0000:01:00.0: could not init core (-110)
[   12.687774] ath10k_pci 0000:01:00.0: could not probe fw (-110)
[   12.694872] ath10k_pci 0000:01:00.0: cannot restart a device that hasn't been started
[ 1769.300572] ath10k_pci 0000:01:00.0: pci irq msi-x interrupts 8 irq_mode 0 reset_mode 0
[ 1769.536172] ath10k_pci 0000:01:00.0: Direct firmware load for ath10k/cal-pci-0000:01:00.0.bin failed with error -2
[ 1769.615457] ath10k_pci 0000:01:00.0: board id is not exist in otp, ignore it
[ 1771.850397] ath10k_pci 0000:01:00.0: firmware crashed! (uuid 33bb585b-5792-4bec-9c50-bbd53d45d50f)
[ 1771.850407] ath10k_pci 0000:01:00.0: qca9377 hw1.1 (0x05020001, 0x003821ff sub 1028:1810) fw WLAN.TF.1.0-00002-QCATFSWPZ-5 fwapi 5 bdapi 2 htt-ver 0.0 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1 features ignore-otp
[ 1771.850410] ath10k_pci 0000:01:00.0: debug 0 debugfs 1 tracing 0 dfs 0 testmode 0
[ 1771.852726] ath10k_pci 0000:01:00.0: firmware register dump:
[ 1771.852730] ath10k_pci 0000:01:00.0: [00]: 0x05020001 0x00000000 0x00A0F774 0x00000000
[ 1771.852733] ath10k_pci 0000:01:00.0: [04]: 0x00A0F774 0x00060130 0x00000010 0xFFFFE000
[ 1771.852735] ath10k_pci 0000:01:00.0: [08]: 0x0042136C 0x00420660 0x00400000 0x00400000
[ 1771.852738] ath10k_pci 0000:01:00.0: [12]: 0x00000000 0x00000000 0x00952CD0 0x00952CE6
[ 1771.852740] ath10k_pci 0000:01:00.0: [16]: 0x00000002 0x01010101 0x00000003 0x0000000A
[ 1771.852742] ath10k_pci 0000:01:00.0: [20]: 0x00000328 0x00429880 0x009A37AC 0x00000032
[ 1771.852745] ath10k_pci 0000:01:00.0: [24]: 0x800A0D0A 0x0040EA88 0x00420170 0x004173B0
[ 1771.852747] ath10k_pci 0000:01:00.0: [28]: 0x00401F64 0x00401F68 0x00000000 0x00417550
[ 1771.852749] ath10k_pci 0000:01:00.0: [32]: 0x00401FC0 0x905A5628 0x004049B4 0x00000003
[ 1771.852752] ath10k_pci 0000:01:00.0: [36]: 0x800A0907 0x00000001 0x0000085B 0x339011B2
[ 1771.852754] ath10k_pci 0000:01:00.0: [40]: 0x0000FFFE 0x0000000A 0x009BFE28 0x009BE0DC
[ 1771.852756] ath10k_pci 0000:01:00.0: [44]: 0x800A0D0A 0x0040EA88 0x00420170 0x004173B0
[ 1771.852758] ath10k_pci 0000:01:00.0: [48]: 0x00400000 0x00400000 0x00000001 0xFFFFFFFF
[ 1771.852761] ath10k_pci 0000:01:00.0: [52]: 0x800A0614 0x0040EAA8 0x0041FA10 0x00420170
[ 1771.852763] ath10k_pci 0000:01:00.0: [56]: 0x00400000 0x00421370 0x00419980 0x004212E8
[ 1772.839740] ath10k_pci 0000:01:00.0: failed to receive control response completion, polling..
[ 1773.839692] ath10k_pci 0000:01:00.0: ctl_resp never came in (-110)
[ 1773.839702] ath10k_pci 0000:01:00.0: failed to connect to HTC: -110
[ 1773.840808] ath10k_pci 0000:01:00.0: could not init core (-110)
[ 1773.840898] ath10k_pci 0000:01:00.0: could not probe fw (-110)
[ 1773.845691] ath10k_pci 0000:01:00.0: cannot restart a device that hasn't been started
Kernel: 7.2.10
non voglio "rubare il cliente" a rik70 :), ma qui trovi una guida per compilarti un kernel da solo
https://docs.slackware.com/howtos:slack ... elbuilding
puoi prendere il file di configurazione da usare come .config da current
ftp://ftp.slackware.com/pub/slackware/s ... .19.28.x64
se non hai da compilarti dei moduli del kernel tuoi (non potresti farlo perche' le versioni di gcc usate per compilare il kernel e i moduli sarebbero diverse) puoi anche usare direttamente i pacchetti kernel-* di current.
Che strano.... che sia un bug del kernel 4.4.172? Ma su kernel.org non vedo nulla di significativo nei log.
Ad ogni modo, se non vuoi compilare un nuovo kernel te la puoi tentare con i backport:
- installa: "kernel-source-4.4.172-noarch-1'';
- scarica ed estrai:
wget 'https://cdn.kernel.org/pub/linux/kernel/projects/backports/stable/v4.19.23/backports-4.19.23-1.tar.xz'
tar xvf backports-4.19.23-1.tar.xz
- entra in:
cd backports-4.19.23-1/
configura e compila i driver:
make defconfig-ath10k
make modules
- installali in questo modo[da root]:
mkdir /lib/modules/4.4.172/kernel/upgrade/
for i in $(find . -type f -name *.ko); do install $i -vm 0644 /lib/modules/4.4.172/kernel/upgrade/; done
- e infine:
sudo depmod -a 4.4.172
Riavvii e vedi se cambia qualcosa.
Se non va, incolla sempre
dmesg | grep ath
Occhio che questa procedura è rischiosa:
il sistema potrebbe non partire.
Nel caso, per recuperarlo devi essere in grado di:
- avviare il sistema da una live - va bene anche il cd/usb d'installazione di slackware;
- montare la root e rimuovere la directory '/lib/modules/4.4.172/kernel/upgrade'.
Ricordati di aggiungere 'kernel-firmware' in /etc/slackpkg/blacklist
EDIT
Avevo sbagliato qualcosa nei comandi. Spiacente, ricontrolla prima di procedere.
Black bart
Nome Cognome: Omar
Ho fatto tutto con calma ma in effetti il sistema al riavvio non è più partito...
Ti ringrazio della pazienza e dei consigli...
In ogni caso non avevo nulla da salvare perchè il lavoro lo tengo sul portatile HP dove la 14.2 funziona alla perfezione.
Su questo dell ho optato per la current,essendo un portatile personale non ci sono problemi...
Grazie a tutti...
