intendi rimettere LC_ALL=it_IT@euro cioè il valore precedente di LC_ALL ?Certamente prima fai l' export ... e poi rimetti tutto a posto
Allarme: removepkg lento !!! .. quasi [Risolto]
- mauro
- Kernel: uno degli ultimi...
- Desktop: dwm
Non credo che sia necessario rimettere le cose a posto, dovrebbe gia' essere tutto ok.
mauro@slackino:~$ cat exp_demo.sh
#!/bin/sh
export LC_ALL=C
echo $LC_ALL
mauro@slackino:~$ export LC_ALL=it_IT@euro
mauro@slackino:~$ echo $LC_ALL
it_IT@euro
mauro@slackino:~$ ./exp_demo.sh
C
it_IT@euro
mauro@slackino:~$
- submax82
- Desktop: xfce
- Distribuzione: SalixOS
ragazzi dal changelog di Pat!!!
quindi strarisolto!
cosiglio a tutti slack11 o slack 12 l'aggiornameto ftp://ftp.slackware.com/pub/slackware/s ... arch-1.tgz
estratto Use LC_ALL=C locale, which is much faster with "sort". Thanks to Tsomi.a/pkgtools-12.1.0-noarch-1.tgz: Upgraded to pkgtools-12.1.0-noarch-1.
Fixed the following issues with removepkg:
Fix problem removing packages with a large number of fields. Thanks to
Niki Kovacs for noticing this, and to Piter Punk for the patch.
Don't try to remove any package that starts with '-'. This is not a proper
package name (usually a typo), and results in the package database being
broken as the "package" beginning with '-' is passed along as an option to
a command later in the script. Thanks to Jef Oliver.
Patched cat_except() to allow the last Slackware package on a partition to
be removed (using ROOT=, of course). Thanks to Selkfoster for the patch,
and to everyone else who proposed solutions before. This issue really
wasn't given the highest priority before, but as long as I was here...
Fixed pkgtool to handle much larger numbers of installed packages.
Thanks to Gabriele Inghirami for the patch.
quindi strarisolto!
- Luci0
- Slackware: 12.2 14.0
- Desktop: KDE 3.5.10 Xfce
Peccato che non ci sia una menzione a Slacky per le patch sull' LC_ALL
Invece la patch di Albatros (Gabriele Inghirami) l' ha menzionata ... e adottata
Comunque indirettamente ...
Thanks to Selkfoster for the patch, and to everyone else who proposed solutions before. This issue really wasn't given the highest priority before, but as long as I was here...
Su una 12 posso aggiornare in tutta tranquillità ?submax82 ha scritto: cosiglio a tutti slack11 o slack 12 l'aggiornameto ftp://ftp.slackware.com/pub/slackware/s ... arch-1.tgz
Inoltre puoi farmi una sintesi su qual era il problema ? :)
- submax82
- Desktop: xfce
certo che puoi aggiornare anche su una 11 puoi farlo senza problemi... mi pare di averlo scritto...Dani ha scritto:Su una 12 posso aggiornare in tutta tranquillità ?submax82 ha scritto: cosiglio a tutti slack11 o slack 12 l'aggiornameto ftp://ftp.slackware.com/pub/slackware/s ... arch-1.tgz
il problema è che per sfruttare il sort alla massima velocità, usato nel codice di removepkg, bisognava impostare la variabile LC_ALL=C, questo nelle versioni precedenti non veniva fatto
puoi ci sono altri fix importanti
- Luci0
Inoltre se installano tanti pacchetti es. Gnome Slacky, venivano fuori dei problemi in fase disinstallazione e removepkg smetteva di funzionare, questo bug lo trovi però su un altro 3D...
viewtopic.php?t=19967&start=0&postdays= ... =removepkg
... rimane ancora aperto il lavoro fatto da mauro con il multi_removepkg sarebbe bene farlo presente a Pat ... perché quando l' altra volta quando submax lo ha contattato era troppo impegnato nel rilascio della 12.0.
... e forse si accorge anche che esiste Slacky.eu ... a proposito ricordate di metterci un link se scrivete a Pat
