matteo@matteo-laptop:~$ sudo lilo -C /media/d961d692-e1f3-4749-bffb-4c2adead28c5/etc/lilo.conf
[sudo] password for matteo:
Warning: LBA32 addressing assumed
Fatal: open /boot/slack.bmp: No such file or directory
matteo@matteo-laptop:~$ cat /media/d961d692-e1f3-4749-bffb-4c2adead28c5/etc/lilo.conf
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
boot = /dev/sda
#compact # faster, but won't work on all systems.
# Boot BMP Image.
# Bitmap in BMP format: 640x480x8
bitmap = /boot/slack.bmp
# Menu colors (foreground, background, shadow, highlighted
# foreground, highlighted background, highlighted shadow):
bmp-colors = 255,0,255,0,255,0
# Location of the option table: location x, location y, number of
# columns, lines per column (max 15), "spill" (this is how many
# entries must be in the first column before the next begins to
# be used. We don't specify it here, as there's just one column.
bmp-table = 60,6,1,16
# Timer location x, timer location y, foreground color,
# background color, shadow color.
bmp-timer = 65,27,0,255
# Standard menu.
# Or, you can comment out the bitmap menu above and
# use a boot message with the standard menu:
#message = /boot/boot_message.txt
# Append any additional kernel parameters:
append=" vt.default_utf8=0"
prompt
timeout = 50
# vga = 773
# Normal VGA console
# vga = normal
# vga=791
# VESA framebuffer console @ 1024x768x32k
# vga=790
# vga=773
# VESA framebuffer console @ 800x600x64k
# vga=788
# VESA framebuffer console @ 800x600x32k
# vga=787
# VESA framebuffer console @ 800x600x256
# vga=771
# VESA framebuffer console @ 640x480x64k
# vga=785
# VESA framebuffer console @ 640x480x32k
# vga=784
# VESA framebuffer console @ 640x480x256
# vga=769
# ramdisk = 0 # paranoia setting
# End LILO global section
image = /media/d961d692-e1f3-4749-bffb-4c2adead28c5/boot/vmlinuz
root = /dev/sda7
label = Slackware
read-only # Partitions should be mounted read-only for checking
image=image=/boot/vmlinuz-2.6.32-33-generic
label=ubuntu
root = /dev/sda8
initrd=/mnt/tmp/boot/initrd.img-2.6.32-33-generic
append="root=UUID=8b32897d-5bd1-440c-8264-daebf9d8e5a8 quiet"
# Windows bootable partition config begins
other = /dev/sda2
label = Vista
table = /dev/sda
# Windows bootable partition config ends
e c'è solo quello in /etc
matteo@matteo-laptop:~$ ls /media/d961d692-e1f3-4749-bffb-4c2adead28c5/etc/
a2ps.cfg dhcpcd.conf gxine joe modprobe.conf pcmcia sane.d termcap-Linux
a2ps-site.cfg dhcpd.conf hal kde modprobe.d pear.conf scim tin
acpi dialogrc hardwareclock ld.so.cache motd php screenrc udev
adjtime DIR_COLORS host.conf ld.so.conf mplayer pine.conf securetty updatedb.conf
alsa dnsmasq.conf HOSTNAME lftp.conf mtab pm sensors3.conf usb_modeswitch.conf
anthy-conf dnsmasq.conf.new hosts lilo.conf mtools.conf polkit-1 sensors3.conf.new usb_modeswitch.d
asciidoc dnsmasq.d hosts.allow lilo.conf~ mutt ppp sensors.d uucp
asound.conf enscript.cfg hosts.deny localtime my-huge.cnf printcap serial.conf vga
asound.state esd.conf hosts.equiv localtime-copied-from my-large.cnf profile services virtuoso.ini
at.deny etc.txt hp login.access my-medium.cnf profile.d services.new vsftpd.conf
autofs_ldap_auth.conf exports htdig login.access.new my-small.cnf proftpd.conf sgml vsftpd.conf.new
auto.master fb.modes httpd login.defs nail.rc protocols shadow warnquota.conf-sample
auto.misc file identd.conf login.defs.new named.conf quotagrpadmins-sample shadow- wgetrc
auto.net fonts im_palette.pal logrotate.conf netatalk quotatab-sample shadow.new wgetrc.new
auto.smb foomatic im_palette-small.pal logrotate.conf.new netgroup radiusclient shells wpa_supplicant.conf
bash_completion.d fstab im_palette-tiny.pal logrotate.d networks random-seed skel wpa_supplicant.conf.new
bluetooth ftpusers imrc lvm nntpserver rc0.d slackpkg X11
bootptab genpowerd.conf inetd.conf lynx.cfg nscd.conf rc1.d slackware-version xdg
ConsoleKit gettydefs init.d lynx.lss nsswitch.conf rc2.d slrn.rc xfce
cron.d gimp inittab mail nsswitch.conf-nis rc3.d slsh.rc xml
cron.daily gnupg inittab~ mc ntp rc4.d smartd.conf xpdfrc
cron.hourly gpm-root.conf inittab.new mdadm.conf ntp.conf rc5.d snmp yp.conf
cron.monthly gpm-syn.conf inputrc mediaprm obex-data-server rc6.d ssh ytalkrc
cron.weekly gpm-twiddler.conf iproute2 mercurial openldap rc.d ssl zprofile
csh.login group irssi.conf minicom.users openvpn resolv.conf stunnel
cups group- irssi.conf.new minirc.dfl organization resolv.conf~ sudoers
dbus-1 group.new isapnp.conf.sample misc pango rmt syslog.conf
default gshadow isapnp.gone.sample mke2fs.conf passwd rndc.key sysstat
dhclient.conf gtk issue mke2fs.conf.new passwd- rpc termcap
dhcpc gtk-2.0 issue.net mkinitrd.conf.sample passwd.new samba termcap-BSD
