bash-4.1# cpufreq-info
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
driver: powernow-k8
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 8.0 us.
hardware limits: 800 MHz - 3.00 GHz
available frequency steps: 3.00 GHz, 2.30 GHz, 1.60 GHz, 800 MHz
available cpufreq governors: userspace, conservative, performance
current policy: frequency should be within 800 MHz and 3.00 GHz.
The governor "performance" may decide which speed to use
within this range.
current CPU frequency is 3.00 GHz (asserted by call to hardware).
cpufreq stats: 3.00 GHz:9.95%, 2.30 GHz:4.25%, 1.60 GHz:18.93%, 800 MHz:66.87% (25999)
analyzing CPU 1:
driver: powernow-k8
CPUs which run at the same hardware frequency: 1
CPUs which need to have their frequency coordinated by software: 1
within this range.
cpufreq stats: 3.00 GHz:9.27%, 2.30 GHz:0.72%, 1.60 GHz:7.42%, 800 MHz:82.59% (14963)
analyzing CPU 2:
driver: powernow-k8
CPUs which run at the same hardware frequency: 2
CPUs which need to have their frequency coordinated by software: 2
within this range.
cpufreq stats: 3.00 GHz:9.19%, 2.30 GHz:0.29%, 1.60 GHz:3.85%, 800 MHz:86.68% (9694)
analyzing CPU 3:
driver: powernow-k8
CPUs which run at the same hardware frequency: 3
CPUs which need to have their frequency coordinated by software: 3
within this range.
cpufreq stats: 3.00 GHz:9.17%, 2.30 GHz:0.21%, 1.60 GHz:2.58%, 800 MHz:88.04% (6764)
analyzing CPU 4:
driver: powernow-k8
CPUs which run at the same hardware frequency: 4
CPUs which need to have their frequency coordinated by software: 4
within this range.
cpufreq stats: 3.00 GHz:9.13%, 2.30 GHz:0.12%, 1.60 GHz:1.29%, 800 MHz:89.46% (3554)
analyzing CPU 5:
driver: powernow-k8
CPUs which run at the same hardware frequency: 5
CPUs which need to have their frequency coordinated by software: 5
within this range.
cpufreq stats: 3.00 GHz:9.25%, 2.30 GHz:0.32%, 1.60 GHz:1.81%, 800 MHz:88.62% (3770)
era presa proprio da questo comando la stringa di prima
