gDesklets: sempre loro
nowhere
Messaggio da nowhere »
scusate l'ennesimo post sull'argomento...ma son 3 giorni che provo a farle andare e niente.
Premetto che mi sono spazzolato tutti i 3d del forum a riguardo usando search: gdesklets, ma non ho trovato la soluzione.
In sintesi: la connessione al demone va in timeout avviando gdesklets
Vi posto l'errore riportato nel file di log:
=== Error in the core! Please report this bug!
[EXC]exceptions.IOError:
[EXC][Errno 4] Interrupted system call
in /usr/lib/gdesklets/gdesklets-daemon: line 127 ?
in /usr/lib/gdesklets/gdesklets-daemon: line 114 _gdesklets_main
in /tmp/package-gdesklets/usr/lib/gdesklets/utils/ErrorFormatter.py: line 119 _new_imp
in /tmp/package-gdesklets/usr/lib/gdesklets/main/Starter.py: line 6 ?
in /tmp/package-gdesklets/usr/lib/gdesklets/factory/DisplayFactory.py: line 1 ?
in /tmp/package-gdesklets/usr/lib/gdesklets/factory/ControlFactory.py: line 46 ?
in /tmp/package-gdesklets/usr/lib/gdesklets/factory/ControlFactory.py: line 24 __init__
in /tmp/package-gdesklets/usr/lib/gdesklets/plugin/ControlRegistry.py: line 28 __init__
in /tmp/package-gdesklets/usr/lib/gdesklets/plugin/ControlRegistry.py: line 105
__search_for_controls
in /tmp/package-gdesklets/usr/lib/gdesklets/utils/MetaDataRegistry.py: line 57
scan_repositories
in /tmp/package-gdesklets/usr/lib/gdesklets/plugin/ControlRegistry.py: line 72
__register_control
in /usr/lib/python2.4/commands.py: line 54 getstatusoutput
[---]/usr/lib/python2.4/commands.py
[---] 49 #
[---] 50 def getstatusoutput(cmd):
[---] 51 """Return (status, output) of executing cmd in a shell."""
[---] 52 import os
[---] 53 pipe = os.popen('{ ' + cmd + '; } 2>&1', 'r')
[ERR]> 54 text = pipe.read()
[---] 55 sts = pipe.close()
[---] 56 if sts is None: sts = 0
[---] 57 if text[-1:] == '\n': text = text[:-1]
[---] 58 return sts, text
[---] 59
[---] 60
P.S. ho verificato tutte le dipendenze (anche gdesklets check da ok), in particolare avevo dei problemi con il pacchetto cairo 0.50 prelevato da questo repository (libcairo.so.1 non andava bene, ci voleva libcairo.so.2...). Questo riportato comunque è l'ultimo errore che non riesco proprio a risolvere. Ultima cosa gdesklets shell mi avvia la shell grafica e quella del Tip of the day...ma entrambe senza testo, poco dopo devo killare il processo.
C'è qualcuno che è riuscito a farle andare ste cavolo di gdesklets?!?
Thks
