problemi con Quickcam Pro 4000
Non riesco a far funzionare la mia Quickcam Pro 4000 Logitech.
Utilizzo il kernel 2.6 con udev.
Come moduli credo di essere a posto, questo l'output di lsmod:
Module Size Used by
snd_pcm_oss 46240 0
snd_mixer_oss 15872 1 snd_pcm_oss
ipv6 225600 10
ohci_hcd 18436 0
audio 42624 0
via_agp 7552 1
shpchp 91364 0
snd_usb_audio 70080 1
snd_usb_lib 13312 1 snd_usb_audio
snd_hwdep 6944 1 snd_usb_audio
pwc 46716 0
videodev 7168 1 pwc
uhci_hcd 29584 0
ehci_hcd 29704 0
i2c_viapro 6928 0
i2c_core 16656 1 i2c_viapro
snd_via82xx 22592 2
gameport 11144 1 snd_via82xx
snd_ac97_codec 75388 1 snd_via82xx
snd_pcm 75016 4 snd_pcm_oss,snd_usb_audio,snd_via82xx,snd_ac97_codec
snd_timer 19716 1 snd_pcm
snd_page_alloc 7556 2 snd_via82xx,snd_pcm
snd_mpu401_uart 5888 1 snd_via82xx
snd_rawmidi 19232 2 snd_usb_lib,snd_mpu401_uart
snd_seq_device 6924 1 snd_rawmidi
snd 45572 18 snd_pcm_oss,snd_mixer_oss,snd_usb_audio,snd_usb_lib,snd_hwdep,snd_via82xx,snd_ac97_codec,snd_pcm,snd_timer,snd_mpu401_uart,snd_rawmidi,snd_seq_device
soundcore 6880 2 audio,snd
8139too 22016 0
mii 4608 1 8139too
ohci1394 30388 0
ieee1394 85304 1 ohci1394
nvidia 3703688 0
nls_iso8859_1 3968 1
nls_cp437 5632 1
evdev 7296 0
agpgart 28616 2 via_agp,nvidia
psmouse 29956 0
Lanciando camstream trovo la mia webcam ma si apre solo una finestra grigia
Questi i messaggi di camstream:
CCamWindow::CCamWindow()
CWebCamViewer::CWebCamViewer(0x80e9438, 320x240)
CVideoDevice::Init()
Using mmap(), VMBuf.size = 921600
Trying to find video options for Logitech QuickCam Pro 4000:/dev/video0
searching Logitech QuickCam Pro 4000
CSnapshotSettingsDlg::CSnapshotSettingsDlg(...)
QFont::setRawName(): Invalid XLFD: "null"
CVideoSettingsDlg::SizeChanged(320x240)
CVideoSettingsDlg::FramerateChanged(10)
Philips webcam detected, enabling extensions
CCamPanel::SetSize(320x240)
CCamPanel::SetImageSize(320x240)
CCamPanel::SetVisibleSize(320x240)
CVideoDevice::SetSize(320, 240)
CVideoDevice::MSync() ioctl: Invalid argument
RecalcTotalViewSize: resize viewport(320x240)
EnableRGB: +
CVideoDevice::SetPalette picked palette 15 [yuv420p]
CVideoDevice::CreateImagesRGB()
allocating space for RGB
CVideoDevice::StartCapture() go!
CVideoDevice::MCapture() ioctl: Device or resource busy
Mi sapete dare qualche dritta?
Module Size Used by
snd_pcm_oss 46240 0
ipv6 225600 10
ohci_hcd 18436 0
audio 42624 0
via_agp 7552 1
shpchp 91364 0
pwc 46716 0
videodev 7168 1 pwc
uhci_hcd 29584 0
ehci_hcd 29704 0
i2c_viapro 6928 0
snd_via82xx 22592 2
8139too 22016 0
mii 4608 1 8139too
ohci1394 30388 0
nvidia 3703688 0
nls_cp437 5632 1
evdev 7296 0
psmouse 29956 0
EnableRGB: +
prova a fare
per vedere che programma sta usando la webcam
lsof /dev/nome_dispositivo_webcamGrazie ragazzi.
Il busy l'avevo visto, comunque provando con il comando suggeritomi da Firetux ottengo questo:
perez@nighthawk:~$ lsof /dev/video0
perez@nighthawk:~$
Il device l'ho preso dall'output di dmesg:
usb 4-1: new full speed USB device using uhci_hcd and address 2
Linux video capture interface: v1.00
pwc Philips webcam module version 9.0.2-unofficial loaded.
pwc Supports Philips PCA645/646, PCVC675/680/690, PCVC720[40]/730/740/750 & PCVC 830/840.
pwc Also supports the Askey VC010, various Logitech Quickcams, Samsung MPC-C10 a nd MPC-C30,
pwc the Creative WebCam 5 & Pro Ex, SOTEC Afina Eye and Visionite VCS-UC300 and VCS-UM100.
pwc Logitech QuickCam 4000 Pro USB webcam detected.
pwc Registered as /dev/video0.
usbcore: registered new driver Philips webcam
usbcore: registered new driver snd-usb-audio
usbcore: registered new driver audio
drivers/usb/class/audio.c: v1.0.0:USB Audio Class driver
Devo dire anche che ho dovuto installare udev della slack 10.1, perché con la versione 064 della 10.2 dopo la rimozione la webcam non veniva più ricaricata alla reinserzione (niente su dmeg e lsusb si bloccava).
Comunque non funzionava neanche prima.
Avete altri suggerimenti?
perez@nighthawk:~$
ok, significa che il dispositivo non è utilizzato da nessun processo.
Cercando in google ho trovato che la tua webcam funziona installando "pwc"
http://www.seismo.ethz.ch/linux/webcam.html
