errore compilazione geomview
brancalessio
Messaggio da brancalessio »
Ciao a tutti!
Volevo installare un programma che si chiama Geomview (http://www.geomview.org/). Sono su Slackware 10.1.
L'errore che ottengo è
gcc -DHAVE_CONFIG_H -I. -I. -I../../../.. -I/usr/local/Geomview -I../../../../include -g -O2 -c glob.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../.. -I/usr/local/Geomview -I../../../../include -g -O2 -c mallocp.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../.. -I/usr/local/Geomview -I../../../../include -g -O2 -c porting.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../.. -I/usr/local/Geomview -I../../../../include -g -O2 -c ppopen.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../.. -I/usr/local/Geomview -I../../../../include -g -O2 -c vvec.c
c++ -DHAVE_CONFIG_H -I. -I. -I../../../.. -I/usr/local/Geomview -I../../../../include -g -O2 -c glibglue.C
In file included from /usr/include/c++/3.3.4/backward/streambuf.h:31,
from glibglue.C:1:
/usr/include/c++/3.3.4/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header. Please consider using one of the 32 headers found in section 17.4.1.2 of the C++ standard. Examples include substituting the <X> header for the <X.h> header for C++ includes, or <sstream> instead of the deprecated header <strstream.h>. To disable this warning use -Wno-deprecated.
glibglue.C:2:23: strstream.h: No such file or directory
glibglue.C:3:25: stdiostream.h: No such file or directory
glibglue.C:11: error: syntax error before `*' token
glibglue.C:12: error: syntax error before `*' token
glibglue.C:15: error: syntax error before `*' token
glibglue.C: In function `stdio_mark* CC_stdio_setmark(stdio_mark*, FILE*)':
glibglue.C:24: error: 'struct stdio_mark' has no member named 'm'
glibglue.C:26: error: 'struct stdio_mark' has no member named 'instream'
glibglue.C:26: error: parse error before `(' token
glibglue.C:27: error: 'struct stdio_mark' has no member named 'm'
glibglue.C:27: error: parse error before `(' token
glibglue.C: In function `int CC_stdio_seekmark(stdio_mark*)':
glibglue.C:34: error: 'struct stdio_mark' has no member named 'instream'
glibglue.C:34: error: 'struct stdio_mark' has no member named 'm'
glibglue.C: In function `void CC_stdio_freemark(stdio_mark*)':
glibglue.C:40: error: 'struct stdio_mark' has no member named 'm'
glibglue.C:41: error: 'struct stdio_mark' has no member named 'instream'
make[5]: *** [glibglue.o] Error 1
make[5]: Leaving directory `/tmp/geomview-1.8.1/src/lib/oogl/util'
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory `/tmp/geomview-1.8.1/src/lib/oogl'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/tmp/geomview-1.8.1/src/lib'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/tmp/geomview-1.8.1/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/tmp/geomview-1.8.1'
make: *** [all-recursive-am] Error 2
e ho notato che, nonostante il ./configure vada avanti liscio (mi avverte solo che mi manca un pacchetto non strettamente necessario), il file config.log è pieno di errori... (scusate la lunghezza)
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
configure:593: checking host system type
configure:614: checking target system type
configure:632: checking build system type
configure:686: checking for a BSD compatible install
configure:739: checking whether build environment is sane
configure:796: checking whether make sets ${MAKE}
configure:842: checking for working aclocal
configure:855: checking for working autoconf
configure:868: checking for working automake
configure:881: checking for working autoheader
configure:894: checking for working makeinfo
configure:932: checking for gcc
configure:1045: checking whether the C compiler (gcc ) works
configure:1061: gcc -o conftest conftest.c 1>&5
configure:1087: checking whether the C compiler (gcc ) is a cross-compiler
configure:1092: checking whether we are using GNU C
configure:1101: gcc -E conftest.c
configure:1120: checking whether gcc accepts -g
configure:1156: checking for c++
configure:1188: checking whether the C++ compiler (c++ ) works
configure:1204: c++ -o conftest conftest.C 1>&5
configure:1227: checking whether the C++ compiler (c++ ) is a cross-compiler
configure:1237: checking whether we are using GNU C++
configure:1246: c++ -E conftest.C
configure:1265: checking whether c++ accepts -g
configure:1321: checking how to run the C preprocessor
configure:1342: gcc -E conftest.c >/dev/null 2>conftest.out
configure:1406: checking for flex
configure:1439: checking for flex
configure:1473: checking for yywrap in -lfl
configure:1492: gcc -o conftest -g -O2 conftest.c -lfl 1>&5
configure:1515: checking lex output file root
configure:1536: checking whether yytext is a pointer
configure:1555: gcc -o conftest -g -O2 conftest.c -lfl 1>&5
configure:1581: checking for bison
configure:1614: checking for ranlib
configure:1653: checking for a BSD compatible install
configure:1718: checking for dvipdf
configure:1789: checking for X
configure:2103: checking for dnet_ntoa in -ldnet
configure:2122: gcc -o conftest -g -O2 conftest.c -ldnet 1>&5
/usr/lib/gcc-lib/i486-slackware-linux/3.3.4/../../../../i486-slackware-linux/bin/ld: cannot find -ldnet
collect2: ld returned 1 exit status
configure: failed program was:
#line 2111 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char dnet_ntoa();
int main() {
dnet_ntoa()
; return 0; }
configure:2144: checking for dnet_ntoa in -ldnet_stub
configure:2163: gcc -o conftest -g -O2 conftest.c -ldnet_stub 1>&5
/usr/lib/gcc-lib/i486-slackware-linux/3.3.4/../../../../i486-slackware-linux/bin/ld: cannot find -ldnet_stub
#line 2152 "configure"
char dnet_ntoa();
int main() {
dnet_ntoa()
; return 0; }
configure:2192: checking for gethostbyname
configure:2220: gcc -o conftest -g -O2 conftest.c 1>&5
configure:2290: checking for connect
configure:2318: gcc -o conftest -g -O2 conftest.c 1>&5
configure:2382: checking for remove
configure:2410: gcc -o conftest -g -O2 conftest.c 1>&5
configure:2474: checking for shmat
configure:2502: gcc -o conftest -g -O2 conftest.c 1>&5
configure:2575: checking for IceConnectionNumber in -lICE
configure:2594: gcc -o conftest -g -O2 -L/usr/X11R6/lib conftest.c -lICE 1>&5
configure:2632: checking for Xmu
configure:2649: checking for XmuLookupStandardColormap with
configure:2662: gcc -o conftest -g -O2 conftest.c -lXmu -L/usr/X11R6/lib -lSM -lICE -lXt -lXext -lX11 1>&5
configure:2699: checking for motif
configure:2717: checking for Xm/Xm.h with
configure:2724: gcc -E conftest.c >/dev/null 2>conftest.out
configure:2720:21: Xm/Xm.h: No such file or directory
#line 2719 "configure"
#include <Xm/Xm.h>
#include <Xm/Xm.h>
configure:2717: checking for Xm/Xm.h with -I/usr/X11R6/include
configure:2724: gcc -E -I/usr/X11R6/include conftest.c >/dev/null 2>conftest.out
configure:2787: checking for XmCreateForm with
configure:2800: gcc -o conftest -g -O2 conftest.c -lXm -L/usr/X11R6/lib -lSM -lICE -lXt -lXext -lX11 1>&5
configure:2835: checking for opengl
configure:2852: checking for GL/gl.h with
configure:2859: gcc -E conftest.c >/dev/null 2>conftest.out
configure:2916: checking for glBegin with
configure:2929: gcc -o conftest -g -O2 conftest.c -lGL -L/usr/X11R6/lib -lSM -lICE -lXt -lXext -lX11 -lm 1>&5
configure:2970: checking for gluBeginPolygon with
configure:2983: gcc -o conftest -g -O2 conftest.c -lGLU -lGL -L/usr/X11R6/lib -lSM -lICE -lXt -lXext -lX11 -lm 1>&5
configure:3033: checking for xforms
configure:3064: checking for forms.h with
configure:3071: gcc -E conftest.c >/dev/null 2>conftest.out
configure:3067:21: forms.h: No such file or directory
#line 3066 "configure"
#include <forms.h>
#include <forms.h>
configure:3064: checking for forms.h with -I/usr/X11R6/include
configure:3071: gcc -E -I/usr/X11R6/include conftest.c >/dev/null 2>conftest.out
#include <forms.h>
configure:3064: checking for forms.h with -I/usr/X11R6/include/X11
configure:3071: gcc -E -I/usr/X11R6/include/X11 conftest.c >/dev/null 2>conftest.out
#include <forms.h>
configure:3064: checking for forms.h with -I/usr/local/include
configure:3071: gcc -E -I/usr/local/include conftest.c >/dev/null 2>conftest.out
#include <forms.h>
configure:3112: checking for fl_initialize with
configure:3125: gcc -o conftest -g -O2 conftest.c -lforms -L/usr/X11R6/lib -lSM -lICE -lXt -lXext -lX11 -lm 1>&5
/usr/lib/gcc-lib/i486-slackware-linux/3.3.4/../../../../i486-slackware-linux/bin/ld: cannot find -lforms
#line 3114 "configure"
char fl_initialize();
int main() {
fl_initialize()
; return 0; }
int main() {
fl_initialize()
; return 0; }
configure:3112: checking for fl_initialize with -L/usr/X11R6/lib
configure:3125: gcc -o conftest -g -O2 conftest.c -L/usr/X11R6/lib -lforms -L/usr/X11R6/lib -lSM -lICE -lXt -lXext -lX11 -lm 1>&5
int main() {
fl_initialize()
; return 0; }
configure:3112: checking for fl_initialize with -L/usr/local/lib
configure:3125: gcc -o conftest -g -O2 conftest.c -L/usr/local/lib -lforms -L/usr/X11R6/lib -lSM -lICE -lXt -lXext -lX11 -lm 1>&5
int main() {
fl_initialize()
; return 0; }
configure:3316: c++ -o conftest -g -O2 conftest.C 1>&5
from configure:3305:
configure:3306:47: strstream.h: No such file or directory
configure:3307:49: stdiostream.h: No such file or directory
configure: In function `int main()':
configure:3312: error: parse error before `(' token
#line 3304 "configure"
#include <streambuf.h>
#include <strstream.h>
#include <stdiostream.h>
#include <iostream.h>
int main() {
char *mem = 0;
int len = 0;
new strstreambuf(mem, len);
; return 0; }
configure:3434: checking whether we need to link -lm to get math functions
configure:3443: gcc -o conftest -g -O2 conftest.c 1>&5
/tmp/ccIjxkuZ.o(.text+0x14): In function `main':
/tmp/geomview-1.8.1/configure:3439: undefined reference to `sin'
#line 3436 "configure"
#include <math.h>
int main() {
double s = sin(1.5);
; return 0; }
configure:3462: checking whether we need to link -lsocket to get socket()
configure:3471: gcc -o conftest -g -O2 conftest.c 1>&5
configure:3488: checking whether setpgrp takes no argument
configure:3516: gcc -o conftest -g -O2 conftest.c 1>&5
#line 3496 "configure"
#ifdef HAVE_UNISTD_H
#include <unistd.h>
#endif
* If this system has a BSD-style setpgrp, which takes arguments, exit
* successfully.
main()
if (setpgrp(1,1) == -1)
exit(0);
else
exit(1);
configure:3542: checking for fmemopen
configure:3570: gcc -o conftest -g -O2 conftest.c 1>&5
configure:3542: checking for __setfpucw
/tmp/ccuX0W4R.o(.text+0xa): In function `main':
/tmp/geomview-1.8.1/configure:3564: undefined reference to `__setfpucw'
#line 3547 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char __setfpucw(); below. */
#include <assert.h>
char __setfpucw();
int main() {
/* The GNU C library defines this for functions which it implements
to always fail with ENOSYS. Some functions are actually named
something starting with __ and the normal name is an alias. */
#if defined (__stub___setfpucw) || defined (__stub_____setfpucw)
choke me
#else
__setfpucw();
#endif
; return 0; }
configure:3598: checking for ANSI C header files
configure:3611: gcc -E conftest.c >/dev/null 2>conftest.out
configure:3678: gcc -o conftest -g -O2 conftest.c 1>&5
configure:3702: checking for size_t
configure:3735: checking whether byte ordering is bigendian
configure:3753: gcc -c -g -O2 conftest.c 1>&5
configure:3768: gcc -c -g -O2 conftest.c 1>&5
configure: In function `main':
configure:3763: error: `not' undeclared (first use in this function)
configure:3763: error: (Each undeclared identifier is reported only once
configure:3763: error: for each function it appears in.)
configure:3763: error: parse error before "big"
#line 3757 "configure"
#include <sys/types.h>
#include <sys/param.h>
int main() {
#if BYTE_ORDER != BIG_ENDIAN
not big endian
#endif
; return 0; }
configure:3829: checking for fpu_control.h
configure:3839: gcc -E conftest.c >/dev/null 2>conftest.out
configure:3829: checking for i386/fpu_control.h
configure:3835:30: i386/fpu_control.h: No such file or directory
#line 3834 "configure"
#include <i386/fpu_control.h>
configure:3829: checking for netinet/in.h
configure:3992: checking whether ln -s works
configure:4106: checking whether sources have a lib directory
Solo che di questi errori non riesco a capire molto... Potete aiutarmi?
brancalessio
Sigh... :cry: :cry: :cry: Non mi aiuta nessuno!
Però sembra che abbia trovato una soluzione ispirata dal pragmatismo e da un patto con il diavolo! :twisted:
La soluzione è semplice, basta installare con
rpm -ivh --nodeps file.rpm
gli rpm già costruiti e scaricabili dal sito. Avrei voluto non installare mai degli rpm (sono passato a Slackware anche grazie a rpm), ma... già questa estate l'avevo fatto per il compilatore della Intel...
Il programma parte. Purtroppo non sono capace di usarlo e non ho i dati che mi servirebbero per farlo andare, quindi non so dire se vada davvero. Comunque la gui parte...
Però se qualcuno scoprisse come fare a compilare geomview dai sorgenti, sarei contento se me lo dicesse.
Ciao!
