Soundserver crash
Litie
Soundserver crash
Messaggio da Litie »
L'applicazione Noatun mi va in crash ogni volta che tento di aprire un file musicale...mi appare un finestra di errore e diventa instabile tutto il sistema!
Ecco la Backtrace
(no debugging symbols found)
Using host libthread_db library "/lib/libthread_db.so.1".
[Thread debugging using libthread_db enabled]
[New Thread 16384 (LWP 5753)]
[New Thread 32769 (LWP 5754)]
[New Thread 950274 (LWP 5827)]
[KCrash handler]
#15 0x40b3c914 in aKode::CrossFader::done () from /opt/kde/lib/libakode.so.1
#16 0x40b3b71e in aKode::CrossFader::readFrame ()
#17 0x40b40a04 in aKode::StreamToFrameDecoder::readFrame ()
#18 0x40af1d5e in akodePlayObject_impl::readFrame ()
from /opt/kde/lib/libarts_akode.so
#19 0x40af23cf in akodePlayObject_impl::calculateBlock ()
#20 0x40123506 in Arts::StdScheduleNode::gslProcess ()
from /opt/kde/lib/libartsflow.so.1
#21 0x401976b9 in _gsl_init_engine_utils () from /opt/kde/lib/libartsflow.so.1
#22 0x40197a2c in _gsl_init_engine_utils () from /opt/kde/lib/libartsflow.so.1
#23 0x40194d43 in gsl_engine_dispatch () from /opt/kde/lib/libartsflow.so.1
#24 0x40129eb6 in GslMainLoop::run () from /opt/kde/lib/libartsflow.so.1
#25 0x401258c0 in Arts::StdScheduleNode::requireFlow ()
#26 0x4012234e in Arts::Synth_PLAY_impl::needMore ()
#27 0x4012b2ab in Arts::AudioSubSystem::handleIO ()
#28 0x401505fa in Arts::AudioIOALSA::notifyIO ()
#29 0x4041c31e in Arts::StdIOManager::processOneEvent ()
from /opt/kde/lib/libmcop.so.1
#30 0x4041c791 in Arts::StdIOManager::run () from /opt/kde/lib/libmcop.so.1
#31 0x40419a67 in Arts::Dispatcher::run () from /opt/kde/lib/libmcop.so.1
#32 0x08062c22 in Arts::SoundServer_skel::~SoundServer_skel ()
#33 0x407b644b in __libc_start_main () from /lib/libc.so.6
#34 0x08053d91 in ?? ()
chi ha risolto questo problema???
Cosa devo fare???
forza pavia
touchstyle
Slackware: 12.1
Kernel: 2.6.27
Messaggio da touchstyle »
Problema analogo con Digikam : http://www.slacky.it/forum/viewtopic.ph ... ht=digikam.
Fai un upgrade/downgrade della libreria che crasha.
Ciao,
Touch.
ChriD
Messaggio da ChriD »
touchstyle ha scritto:Problema analogo con Digikam : http://www.slacky.it/forum/viewtopic.ph ... ht=digikam.
Ciao,
Touch.
ma libexif che gestisce????
mi daresti un supportino per sapere come installarla e dove prenderla???
Litie
/*RISOLTO*/
In effetti è la Libreria libakode.so.1 che fa i capricci ;-) !!!! si trova quì
/opt/kde/lib/libakode.so.1.0.0
Ho disinstallato il pacchetto kdemultimedia-3.4.2-i486-1.tgz con il comando
removepkg kdemultimedia-3.4.2-i486-1.tgz
quindi, sempre da root :
installpkg kdemultimedia-3.4.2-i486-1.tgz
...adesso funzione tutto alla grande!!GrAzIe...
PS:Io sto utilizzando Slack 10.2 con KDE 3.4
il Pacchetto kdemultimedia-3.4.2-i486-1.tgz l'ho trovato sul DVD d'installazione sotto la dir /kde ; come alternativa si può scaricare dalla rete al link :
http://www.slackware.it/pb/search.php?v ... akode.so.1
