Ho configurato scheda di rete e connessione, credo in modo corretto. Su Windows 2000 funziona tutto, su Slackware purtroppo no. I DNS in /etc/resolv.conf sono a posto, oltretutto non mi funziona neppure un ping all'indirizzo 216.239.59.147 (ho visto alcuni post precedenti). Il modem ADSL è ethernet. Potete aiutarmi?
Ciao e grazie
Paco
Vi mostro qualcosa che forse può esservi di aiuto:
root@slacky:~# pppoe-start
. Connected!
root@slacky:~# pppoe-status
pppoe-status: Link is up and running on interface ppp0
ppp0 Link encap:Point-to-Point Protocol
inet addr:82.52.30.145 P-t-P:192.168.100.1 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1492 Metric:1
RX packets:7 errors:0 dropped:0 overruns:0 frame:0
TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:202 (202.0 b) TX bytes:37 (37.0 b)
root@slacky:~# ifconfig
eth0 Link encap:Ethernet HWaddr 00:0E:A6:27:B3:EF
inet addr:192.168.1.2 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST NOTRAILERS RUNNING MULTICAST MTU:1500 Metric:1
RX packets:340 errors:0 dropped:0 overruns:0 frame:0
TX packets:292 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:48523 (47.3 Kb) TX bytes:42798 (41.7 Kb)
Interrupt:5
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:16 errors:0 dropped:0 overruns:0 frame:0
TX packets:16 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1344 (1.3 Kb) TX bytes:1344 (1.3 Kb)
RX packets:11 errors:0 dropped:0 overruns:0 frame:0
RX bytes:374 (374.0 b) TX bytes:37 (37.0 b)
root@slacky:~# ping 216.239.59.147
PING 216.239.59.147 (216.239.59.147) 56(84) bytes of data.
From 192.168.1.1 icmp_seq=1 Destination Net Unreachable
From 192.168.1.1 icmp_seq=2 Destination Net Unreachable
From 192.168.1.1 icmp_seq=3 Destination Net Unreachable
From 192.168.1.1 icmp_seq=4 Destination Net Unreachable
From 192.168.1.1 icmp_seq=5 Destination Net Unreachable
From 192.168.1.1 icmp_seq=6 Destination Net Unreachable
--- 216.239.59.147 ping statistics ---
problema connessione ADSL
non ti routa i pacchetti...cambia il default gateway.Se provi a fare un ping da ppp0 con la configurazione che hai adesso sicuramente va
ping 216.239.59.147 -I ppp0
