Aiutoo,devo capire se si sia bruciata la lan
Gnomenetor
Messaggio da Gnomenetor »
ragazzi ieri sera ero tutto tranquillo sulla mia scla sul fisso,ad un tratto un tuono si spegne tutto,riaccendo tutto ok,ma quando vado x dare adsl-start nn si connette,e ho pensato alla lan,infatti la scheda di rete nn lampeggia,quindi ceredo nn ci sia scambio di pakketti,vi posto un po' di roba,tutte a me :cry:
bash-3.00# ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:13:8F:48:32:81
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interrupt:11 Base address:0xd400
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
collisions:0 txqueuelen:0
bash-3.00#
Se do il ping alla lan risponde guardate..
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=0.057 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=0.024 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=0.023 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=0.024 ms
64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=0.022 ms
64 bytes from 192.168.1.1: icmp_seq=6 ttl=64 time=0.023 ms
64 bytes from 192.168.1.1: icmp_seq=7 ttl=64 time=0.023 ms
64 bytes from 192.168.1.1: icmp_seq=8 ttl=64 time=0.023 ms
64 bytes from 192.168.1.1: icmp_seq=9 ttl=64 time=0.023 ms
64 bytes from 192.168.1.1: icmp_seq=10 ttl=64 time=0.035 ms
64 bytes from 192.168.1.1: icmp_seq=11 ttl=64 time=0.025 ms
64 bytes from 192.168.1.1: icmp_seq=12 ttl=64 time=0.023 ms
64 bytes from 192.168.1.1: icmp_seq=13 ttl=64 time=0.024 ms
64 bytes from 192.168.1.1: icmp_seq=14 ttl=64 time=0.023 ms
64 bytes from 192.168.1.1: icmp_seq=15 ttl=64 time=0.024 ms
64 bytes from 192.168.1.1: icmp_seq=16 ttl=64 time=0.023 ms
64 bytes from 192.168.1.1: icmp_seq=17 ttl=64 time=0.023 ms
64 bytes from 192.168.1.1: icmp_seq=18 ttl=64 time=0.024 ms
64 bytes from 192.168.1.1: icmp_seq=19 ttl=64 time=0.024 ms
Paoletta
Slackware: 14.2 - 64 bit
Desktop: fluxbox
Messaggio da Paoletta »
dal tuo output non si vede nulla di anomalo...posta un output di route -n
P.S. gradirei che tu scrivessi "pacchetti" e non "pakketti", i post non sono sms
Gnomenetor
Scusami paoletta,forse e perche' scrivo troppo veloce....Comunque
bash-3.00# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
0.0.0.0 192.168.1.2 0.0.0.0 UG 1 0 0 eth0
bash-3.00#
krisis
Distribuzione: debian
Messaggio da krisis »
Gnomenetor ha scritto:Scusami paoletta,forse e perche' scrivo troppo veloce....Comunque
ahahahahah bella scusa
bash-3.00# route -n
bash-3.00#
Non ci vedo nulla di strano
Anche perchè tu hai pingato la tua scheda di rete , prova a pingare il gw.
Gnomenetor
ecco,krisis,questo e il bello...
PING 192.168.1.2 (192.168.1.2) 56(84) bytes of data.
From 192.168.1.1 icmp_seq=1 Destination Host Unreachable
From 192.168.1.1 icmp_seq=2 Destination Host Unreachable
From 192.168.1.1 icmp_seq=3 Destination Host Unreachable
From 192.168.1.1 icmp_seq=4 Destination Host Unreachable
From 192.168.1.1 icmp_seq=5 Destination Host Unreachable
From 192.168.1.1 icmp_seq=6 Destination Host Unreachable
From 192.168.1.1 icmp_seq=7 Destination Host Unreachable
From 192.168.1.1 icmp_seq=8 Destination Host Unreachable
From 192.168.1.1 icmp_seq=9 Destination Host Unreachable
MAT
Nome Cognome: Matteo Magni
Kernel: 2.6.20
Desktop: Fluxbox
Distribuzione: Gentoo
Messaggio da MAT »
Si sarà bruciato il tuo router, ma la scheda di rete sembra a posto.
krisis
Hai provato a cambiare il cavo?
krisis
azz MAT , abbiamo postato nello stesso secondo :lol:
Gnomenetor
hehehe,ragazzi,sono connesso con lo stesso cavo con lo stesso modem sul portatile... X questo diko,ho provato una live di debian velocemente,ho dato pppoeconf xvedere il dhcp che fa',nulla di fatto,non trova alcun modem....
krisis
ipotizzo un jack bruciato , prova con una nuova scheda di rete
[shutdown]
Messaggio da [shutdown] »
comunque una scheda di rete costa tra i 9 e gli 11 euro non mi sembra una danno cosi consistente
ciao
MAT
Kernel: 2.6.20
Desktop: Fluxbox
Messaggio da MAT »
[shutdown] ha scritto:comunque una scheda di rete costa tra i 9 e gli 11 euro non mi sembra una danno cosi consistente
ciao
Già! Se è la scheda ti è andata di lusso! A me una volta un fulmine ha fatto saltare il router da 130 euro! :evil:
Però sono riuscito a farmelo cambiare in garanzia :lol:
Gnomenetor
uhm ok,ho la lan nuova,ma una volta che la monto su PCI la riconoscera'?? e una realtek...
MAT
Kernel: 2.6.20
Desktop: Fluxbox
Messaggio da MAT »
Gnomenetor ha scritto:uhm ok,ho la lan nuova,ma una volta che la monto su PCI la riconoscera'?? e una realtek...
Che ne dici di provare? :lol:
Gnomenetor
uhm..Messa la nuova lan,ho subito dato lspci x vedere,e la riconosce comu device sconosciuto,ho cercato di dargli un ip in questo caso 192.168.1.2 ma nel ping nn la trova,tant e vero che nemmeno si avvende la lucetta della lan.. Dove sbaglio??
bash-3.00# lspci
00:00.0 Host bridge: VIA Technologies, Inc.: Unknown device 0258
00:00.1 Host bridge: VIA Technologies, Inc.: Unknown device 1258
00:00.2 Host bridge: VIA Technologies, Inc.: Unknown device 2258
00:00.3 Host bridge: VIA Technologies, Inc.: Unknown device 3258
00:00.4 Host bridge: VIA Technologies, Inc.: Unknown device 4258
00:00.7 Host bridge: VIA Technologies, Inc.: Unknown device 7258
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237 PCI Bridge
00:09.0 Ethernet controller: I-O Data Device, Inc.: Unknown device 8139
00:0f.0 RAID bus controller: VIA Technologies, Inc.: Unknown device 3149 (rev 80)
00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C/VT8235 PIPC Bus Master IDE (rev 06)
00:10.0 USB Controller: VIA Technologies, Inc. VT6202 [USB 2.0 controller] (rev 81)
00:10.1 USB Controller: VIA Technologies, Inc. VT6202 [USB 2.0 controller] (rev 81)
00:10.2 USB Controller: VIA Technologies, Inc. VT6202 [USB 2.0 controller] (rev 81)
00:10.3 USB Controller: VIA Technologies, Inc. VT6202 [USB 2.0 controller] (rev 81)
00:10.4 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 86)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8237 ISA bridge [K8T800 South]
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 60)
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 78)
01:00.0 VGA compatible controller: Matrox Graphics, Inc. MGA G400 AGP (rev 82)
bash-3.00#
eccola,dovrebbe essere lei..
Anche se qui compare la lan che nn va
TX packets:426 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:17862 (17.4 Kb)
RX packets:5176 errors:0 dropped:0 overruns:0 frame:0
TX packets:5176 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:446116 (435.6 Kb) TX bytes:446116 (435.6 Kb)
bash-3.00#
Mi risponde in questo modo
bash-3.00$ ping 192.168.1.2
From 192.168.1.1 icmp_seq=10 Destination Host Unreachable
From 192.168.1.1 icmp_seq=11 Destination Host Unreachable
From 192.168.1.1 icmp_seq=12 Destination Host Unreachable
From 192.168.1.1 icmp_seq=13 Destination Host Unreachable
From 192.168.1.1 icmp_seq=14 Destination Host Unreachable
From 192.168.1.1 icmp_seq=15 Destination Host Unreachable
in fine
bash-3.00# route -n
bash-3.00#
Credo di avervi dato tutte le info possibili,sbaglio qualcosa o devo ricompilare???
